hi
i am using cloudns for years .. which is super , no complaints what so ever.
what are the other free providers options out there?
nice to know your selection?
Cloudflare?
Talistech.com — ICT Consultancy and NVMe web hosting solutions.
Afraid?
dedyn.io aka desec.io
Check our KVM VPS plans in 🇵🇱 Warsaw, Poland and 🇸🇪 Stockholm, Sweden
NO-IP, DuckDNS, Dynu and DynV6.
@skhron said: dedyn.io aka desec.io
+1
Solid service and great people.
ClouDns.net
@imxmm said: ClouDns.net
i am using it at moment and need to check alternatives.
dns.he.net
My recommendation 99.5% is: the one that your home router with software created 12 years ago and last time updated 10 years ago still supports...
Haven't bought a single service in VirMach Great Ryzen 2022 - 2023 Flash Sale. https://lowendspirit.com/uploads/editor/gi/ippw0lcmqowk.png
Asus routers used to have a service that worked fine. I'd probably to with CF tunnels though
an API is very important since i do not want to click on 100's of links to update several rules etc ...
but i will try those suggestions and those more to come.
@ehab said: an API is very important since i do not want to click on 100's of links to update several rules etc ... but i will try those suggestions and those more to come.
Just use cloudflare then
1984 servers dns ? I have not used them just found them googling . may be could work for you
https://1984.hosting Is frickin awesome. Been using them for 5+ years. Unlimited everything.
I recommend Hurricane Electric (he.net). On server set a crontab to update the DNS using a curl command and that's it.
Namecheap?
Never make the same mistake twice. There are so many new ones to make. It’s OK if you disagree with me. I can’t force you to be right.
Cloudflare?
Afraid?
+1
ClouDns.net
dns.he.net
Namecheap?
