I need the .htaccess file of vanilla forum, does anyone help?
Go the website Download the zip Extract Find the .htaccess file Copy
Enjoy!
The zip file doesn't has the .htaccess file! @AuroraZero
@imxmm said: The zip file doesn't has the .htaccess file!
Then install it on a throw away domain. Check to see if it creates one and grab it if it does.
@AuroraZero said: @imxmm said: The zip file doesn't has the .htaccess file! Then install it on a throw away domain. Check to see if it creates one and grab it if it does.
No! Nothing happened
@imxmm said: @AuroraZero said: @imxmm said: The zip file doesn't has the .htaccess file! Then install it on a throw away domain. Check to see if it creates one and grab it if it does. No! Nothing happened
@imxmm said:
Then it is a regular Apache .htacess file.
@AuroraZero said: @imxmm said: @AuroraZero said: @imxmm said: The zip file doesn't has the .htaccess file! Then install it on a throw away domain. Check to see if it creates one and grab it if it does. No! Nothing happened Then it is a regular Apache .htacess file.
I Just want the .htaccess file or the rewrite rules
Should work https://github.com/vanilla/vanilla/blob/v3.0.1/.htaccess.dist
@Hertonis said: Should work https://github.com/vanilla/vanilla/blob/v3.0.1/.htaccess.dist
Thanks!
Go the website
Download the zip
Extract
Copy
Enjoy!
Should work
Thanks!
