I need 2TB of disk space, with 2TB of bandwidth, within the EU for 24 hours.
Hi there,
Currently on a quest of converting Virtualizor to Proxmox, have ironed out the process and all tested good but I need to transfer my 3 qcow2 files onto a temporary node for 6-24 hours whilst I reinstall it to Proxmox and then download again to restore.
I've looked pretty much everywhere, Vultr doesn't bill hourly for block storage, Hetzner only goes up to 1TB, I have a US server with 4TB of disk space but it only downloads at 20MB/s so it was going to take 29 hours.
Happy to pay someone some money for temporary access to a server/VM with such disk space in the EU. It'd be appreciated.
Thanks
I don't know the top up requirements but maybe look at the Scaleway "bare metal cloud servers"? Cheapest is €0.40/hour and has 3x1TB SSD with 500Mbps. €0.40/hour for 2x1TB NVMe and 1Gbps.
ExtraVM - KVM NVMe VPS in USA, EU, APAC -|- RackColo - Find Colo
Discord: mikea
I will check them out, thank you!
@tester4 It could get expensive if it takes a long time, but with the gigabit server it might go be well. From my experience Online has great speeds in Europe.
Discord: mikea
Yeah, testing it now, if my OVH node goes 500Mbps solid then it'll cost me 5 EUR or less which I guess is the cheapest I'm going to find.
You could use http://hostsolutions.ro/eng/hosting/kvm-storage with the 50% off code from LET.
https://duck.com (aff)
https://ecosia.org (aff) Plant trees from home.
Still looking? Is 2tb (disk) a hard limit or might it go over?
Thanks for the offer mate, but I've managed to get this done now luckily
