Aeza.net - Ryzen Sweden 1 core, 4gb ram for 1 eur per month(recurring)
So their promo plan is back in stock and I thought I will let you guys know, the value for this 1 eur is insane. The offer is recurring, and you can go even lower than 1 eur by paying annually. It also features Datapacket/CDN77 transit(or tunnel) and DDoS protection, 100Mbps "unlimited" bandwidth.
I have no idea how many they have in stock, but it must be a lot since they went live yesterday and still aren't sold out.
Very comfy plan for testing/dns/whatever.
https://aeza.net/virtual-servers
Promo plan rules:
YABS
# Yet-Another-Bench-Script #
# v2024-03-05 #
Uptime :
Processor : AMD Ryzen 5 3600 6-Core Processor
CPU cores : 1 @ 3593.248 MHz
AES-NI : ✔ Enabled
RAM : 3.8 GiB
Swap : 512.0 MiB
Disk : 9.8 GiB
Kernel : 6.1.0-18-amd64
VM Type : KVM
ISP : Aeza International LTD
ASN : AS210644 AEZA INTERNATIONAL LTD
Host : Aeza International LTD
Country : Sweden
fio Disk Speed Tests (Mixed R/W 50/50) (Partition /dev/vda2):
Read | 3.98 MB/s (996) | 63.77 MB/s (996)
Write | 4.01 MB/s (1.0k) | 64.18 MB/s (1.0k)
Total | 7.99 MB/s (1.9k) | 127.96 MB/s (1.9k)
Read | 498.99 MB/s (974) | 1.01 GB/s (991)
Write | 525.50 MB/s (1.0k) | 1.08 GB/s (1.0k)
Total | 1.02 GB/s (2.0k) | 2.09 GB/s (2.0k)
Clouvider | London, UK (10G) | 109 Mbits/sec | 18.7 Mbits/sec | 31.8 ms
Eranium | Amsterdam, NL (10G) | 110 Mbits/sec | 95.0 Mbits/sec | 29.8 ms
HOSTKEY | Helsinki, FI (10G) | 110 Mbits/sec | 18.1 Mbits/sec | 15.1 ms
Uztelecom | Tashkent, UZ (10G) | 106 Mbits/sec | 17.6 Mbits/sec | 83.8 ms
Leaseweb | Singapore, SG (10G) | 93.9 Mbits/sec | 26.9 Mbits/sec | 190 ms
Clouvider | Los Angeles, CA, US (10G) | 99.5 Mbits/sec | 6.50 Mbits/sec | 153 ms
Leaseweb | NYC, NY, US (10G) | 103 Mbits/sec | 25.4 Mbits/sec | 109 ms
Edgoo | Sao Paulo, BR (1G) | 95.8 Mbits/sec | 5.03 Mbits/sec | 193 ms
Clouvider | London, UK (10G) | 108 Mbits/sec | 86.0 Mbits/sec | 32.0 ms
Eranium | Amsterdam, NL (10G) | busy | 89.0 Mbits/sec | 37.4 ms
Uztelecom | Tashkent, UZ (10G) | 104 Mbits/sec | 39.9 Mbits/sec | 83.8 ms
Leaseweb | Singapore, SG (10G) | 85.8 Mbits/sec | 50.1 Mbits/sec | 188 ms
Clouvider | Los Angeles, CA, US (10G) | 97.7 Mbits/sec | 34.1 Mbits/sec | 153 ms
Leaseweb | NYC, NY, US (10G) | 103 Mbits/sec | 39.7 Mbits/sec | 108 ms
Edgoo | Sao Paulo, BR (1G) | 96.0 Mbits/sec | 40.1 Mbits/sec | 193 ms
Test | Value
Single Core | 1219
Multi Core | 1226
Full Test | https://browser.geekbench.com/v6/cpu/5234319
YABS completed in 27 min 15 sec
no paypal -- its always scary to add card info.
It's not. Get some Privacy.com/Revolut or any other FinTech with 'disposable / one time' cards and problem is gone.
Use crypto
You can get it locally and without KYC on https://agoradesk.com/
If you go with Monero, https://featherwallet.org/ (desktop), https://cakewallet.com/ (mobile)
Is this Russian company?
Filen.io - use this link to signup and we both get extra 10GB free.
https://filen.io/r/4d472d5cdb57f6663621a251065e0b51
Their "Global" division with a company in UK, but yeah, they are a Russian company.
Also I'm pretty sure DMCA is ignored on these vps too, Aeza is a known "bulletproof" provider, with several "shell" asn's.
Should work good like some low-budget reverse-proxy to ignore dmca.
It's stripe.com. You get redirected and make the payment there.
Also, there's not many free IP addresses on Sweden, so if anyone wants to get it, be fast.
Alt accounts are allowed too, contacted them on support and they said it's fine.
This provider will shutdown your VM randomly (maybe due to memory ballooning) and oversell to hell.
Don't ask why I know it. I tried it before.
I even made a keepalive system by heartbeat packet detection and interacting their panel api to boot it again when vm got shutdown. Usually during every 24 hours it can be shut down for average 2 times or more.
And then after several weeks. They baned my panel api. So I guess the shutdown may be very intended and manually operated by their staff to get more space for overselling.
By the way, I paid in year with crypto currency as no Paypal there. And if I remember right, they will add some fees finally when you checkout. So it wasn't that cheap as I looked.
So I learned a lesson.
Challenge accepted.
Wanted to try this, but 5% comission and minimum 5eur on stripe is kinda steep..
You get a cookie that is valid for 1 month.
If your server doesn't ping you just run:
Profit, for a more automated way, needs a selenium bot, that logs into your account, grabs the cookie and toggles a resume.
But can be done on any linux machine without display, just use a virtual screen.
€1.09 * 12 - 12% + 5% = €12.10 ?
@Neoon
Well done! It will help others who buy in year but can not really use it.
If I remember right they also have other panel which you can pass plain password to a HTTP GET request (no captcha thing) to get the cookie. But I remember password at that panel is not the same as your account in my.aeza.net. So then you need to trick forget password (not sure if something wrong there and it will try to redirect your request to 127.0.0.1 localhost or any else...) at that panel to reset your password there.
Is that the €1.63 8GB AMS-PROMO?
Here's the explanation (translated) for that shutdown, which doesn't happen in this 4GB SWE-PROMO plan.
So you buy a plan with 8G memory but when you use 8G memory (and my case should be around 5G I think) you marked as "RAM overspending".
This is ridiculous.
And this time at 4GB plan,
how you can make sure if memory are enough for the overselling and no need to mark people who use the 4GB memory resource what they legally get by paying you?
You Downloading RAM now ?
https://webhorizon.net
Just linked their explanation, guys, I'm not their Rep.
But they should've mentioned this limit in their AMS-PROMO plan description (while they were offering it), that you can use full 8GB continuously for X minutes or hours before the server is shutdown to free up RAM on the node.
You can see that they've learned from this shutdown issue, and they've started limiting their promo plans, and listing those limits in the plan description.
It's translated text. Blame Lingvanex. It should've been load instead of download.
aaand it's out of stock
told y'all
most likely not coming back to stock anytime soon as they seem to have used all of their just purchased SWE subnets.
same here, also I don't trust pulters
What captcha? It works fine, just wrote something that can login and grabs all cookies.
https://github.com/Ne00n/aeza
works fine.
Never had problems with Aeza.
Why is a security problem to add a card to Stripe? I don't see something dramatic there.
Amadex • Hosting Forums • root.hr
Back in stock 🤑
My VPS works just fine, 0 issues with it so far.
Back in stock again
Beware, you have to pay minimum €5. I chose 6 month billing cycle for a total of €6.25 / 6 months recurring.
You get a /48 ipv6 subnet, but it's not configured by default in the debian 12 image.
Will post YABS when it finishes.
Thanks!
Grabbed one...should be good for an upcoming project.
how is the ip reputation?
Mine is 100% clean, checked on ipvoid/hetrix/spamhaus/abuseipdb.
you're most likely assigned to 77.221.136.0/22 (or 77.221.140.0/22) and those are new IP blocks that they've just migrated.
