Aeza.net - Ryzen Sweden 1 core, 4gb ram for 1 eur per month(recurring)
24
  • @IAmNix said: You get a /48 ipv6 subnet, but it's not configured by default in the debian 12 image.
    I see that it's set by default (Debian 12 image) in vps interface but it doesn't work.
    Thanked by (1)IAmNix
  • My "sweden" promo VPS I got some hour ago is located in Austria not Sweden. That's almost perfect for me.
    IPv6 is configured by default however it doesn't work. It doest not look like I can do anything on my side to make it work.
    I checked also from Hosthatch .AT vps:
    PING 77.221.136.xx (77.221.136.xx) 56(84) bytes of data.
    64 bytes from 77.221.136.xx: icmp_seq=1 ttl=61 time=0.446 ms
    64 bytes from 77.221.136.xx: icmp_seq=2 ttl=61 time=0.388 ms
    64 bytes from 77.221.136.xx: icmp_seq=3 ttl=61 time=0.355 ms
    64 bytes from 77.221.136.xx: icmp_seq=4 ttl=61 time=0.220 ms
    ICMP is anycasted, Use paping and TCP ping your SSH port.
    Thanked by (1)Mumbly
  • @zgato said: ICMP is anycasted
    Ah, I see. You're correct.
  • the most important question, is aeza recommendable and especially the sweden promo?
    It's pretty solid. I've been monitoring it for sometime now. No CPU steal or such stuff, looks pretty good.
    @zgato has been using it for longer.
    Thanked by (1)lapua
    Still using their old AMS-PROMO plan and was one of the first people to get the SWE-PROMO. Only 1 outage in Sweden and it was network related, nothing else. I think it also lasted only for a few minutes.
    It's been working flawlessly for me. It's also not expensive enough to not give it a try :)
    Thanked by (1)lapua
  • Got one.
    What can be done whit 10GB?
  • edited March 15
    @Fritz said:
    Got one.
    Network services. VPN, monitoring, reverse proxy, personal IPV4<->IPV6 proxy, https://atlas.ripe.net/ probe, https://headscale.net/ server, (Tor relay? allowed?)
    Edit: I guess Tor exit relays are allowed: https://relays.0x7c0.com/as/AS210644/
  • @Fritz said:
    Got one.
    lamp and nextcloud to host your selfie
  • Eh btw, paying with GPay (Google Pay is also recommended if you don't want to pay with your Credit Card directly).
    Google Pay will be the payment processor.
  • edited March 16
    If someone managed to set up IPv6 to work, let me know. I mean IPv6 is configured by default (Debian 12) and it seems everything already there, it just doesn't work for some reason.
    sudo sed -i 's/^precedence ::ffff/# precedence ::ffff/' /etc/gai.conf ?
  • I reinstalled Debian 12 (NEW Aeza Repo).
    Am i doing something wrong?
    root@aeza-se:~# curl -sL yabs.sh | bash -s -- -fig
    #                     v2024-03-05                    #
    Sat Mar 16 11:29:48 AM CET 2024
    Uptime     : 0 days, 0 hours, 5 minutes
    Processor  : AMD Ryzen 5 3600 6-Core Processor
    CPU cores  : 1 @ 3600.000 MHz
    VM-x/AMD-V : ❌ Disabled
    RAM        : 3.8 GiB
    Swap       : 512.0 MiB
    Disk       : 9.8 GiB
    Kernel     : 6.1.0-18-amd64
    ISP        : Aeza International LTD
    ASN        : AS210644 AEZA INTERNATIONAL LTD
    Host       : Aeza Group LLC
    Country    : Sweden
    YABS completed in 1 sec
  • @tototo said: I reinstalled Debian 12 (NEW Aeza Repo).
    Wrong in a what way?
    You picked -s -- -fig options.
    -f/-d Disables the fio (disk performance) test
    -i Disables the iperf (network performance) test
    -g Disables the Geekbench (system performance) test
    Thanked by (1)lapua
  • I got it yesterday. Everything except for non-working IPv6 seems fine so far.
    #                     v2024-03-05                    #
    Sat Mar 16 11:44:20 AM CET 2024
    Uptime     : 0 days, 0 hours, 32 minutes
    CPU cores  : 1 @ 3599.998 MHz
    RAM        : 3.8 GiB
    Swap       : 512.0 MiB
    Disk       : 9.8 GiB
    ISP        : INFOBOX
    ASN        : Unknown
    Host       : Infobox
    Country    : Russia
    fio Disk Speed Tests (Mixed R/W 50/50) (Partition /dev/vda2):
    Read       | 3.98 MB/s      (995) | 63.77 MB/s     (996)
    Write      | 4.00 MB/s     (1.0k) | 64.18 MB/s    (1.0k)
    Total      | 7.99 MB/s     (1.9k) | 127.96 MB/s   (1.9k)
    Read       | 498.02 MB/s    (972) | 1.00 GB/s      (985)
    Write      | 524.48 MB/s   (1.0k) | 1.07 GB/s     (1.0k)
    Total      | 1.02 GB/s     (1.9k) | 2.08 GB/s     (2.0k)
    Clouvider       | London, UK (10G)          | 109 Mbits/sec   | 95.6 Mbits/sec  | 35.2 ms
    Eranium         | Amsterdam, NL (10G)       | busy            | busy            | 28.9 ms
    HOSTKEY         | Helsinki, FI (10G)        | 68.4 Mbits/sec  | 94.8 Mbits/sec  | 14.8 ms
    Uztelecom       | Tashkent, UZ (10G)        | busy            | 92.6 Mbits/sec  | 86.4 ms
    Leaseweb        | Singapore, SG (10G)       | 84.5 Mbits/sec  | 78.5 Mbits/sec  | 191 ms
    Clouvider       | Los Angeles, CA, US (10G) | 98.5 Mbits/sec  | 28.7 Mbits/sec  | 161 ms
    Leaseweb        | NYC, NY, US (10G)         | 102 Mbits/sec   | 76.2 Mbits/sec  | 106 ms
    Edgoo           | Sao Paulo, BR (1G)        | 96.6 Mbits/sec  | 32.6 Mbits/sec  | 200 ms
    Single Core     | 1584
    Multi Core      | 1593
    YABS completed in 13 min 27 sec
    Oh, sorry. I wanted to say that IPv6 is enabled by default (but IPv4 is preferred).
  • Not here ... (I commented out precedence ::ffff/ as you suggested as well)
    #                     v2024-03-05                    #
    Sat Mar 16 12:04:52 PM CET 2024
    Uptime     : 0 days, 0 hours, 0 minutes
    RAM        : 3.8 GiB
    Swap       : 512.0 MiB
    Disk       : 9.8 GiB
    ISP        : INFOBOX
    ASN        : Unknown
    Host       : Infobox
    Country    : Russia
  • Statistics are not working, and is the ddos protection effective?
    Statistics on their custom control panel are broken from time to time, but they usually work.
    Do not try to protect game servers on SWE-PROMO plans, but as for my tests, it handles L4 attacks just fine, but expect some packet loss.
  • @Mumbly said:
    Maybe they run out of IPv6 blocks or something, my instances have IPv6 setup by default and it works just fine.
    You may want to try talking to their support via Telegram.
  • rootroot OG
    edited March 17
    So what was the catch? There has to some trick with such offers.
    How are you... online?
    my old AMS-PROMO has been alive for almost a year now, not sure about any catch there.
    Thanked by (1)sh97
  • rootroot OG
    edited March 17
    This offer seems to allow IRC (I can't see it mentioned in terms) and it also has some DDoS protection. Tagging @Not_Oles since he was thinking about IRC, while a proper IRC network needs multiple servers in different locations.
  • @zgato said: Maybe they run out of IPv6 blocks or something, my instances have IPv6 setup by default and it works just fine.
    Mine also works just fine.
    Thanked by (1)zgato
  • I'm not able to install tailscale on my VPS, because https://pkgs.tailscale.com return 451 Unavailable For Legal Reasons on seemingly all requests, making even apt update impossible.
    Is this type of thing common? Has anyone else gotten a 451?
  • edited March 18
    Subnet that was assigned to you likely has Russian geoip, tailscale doesn't let you install it on Russian IP's because much virtue signaling(war related).
    Fuck Internet neutrality, am I right?
    Thanked by (3)_MS_ IAmNix terrorgen
  • edited March 18
    Their new SWE blocks are all Russian/Armenia/Singapore GeoIP located.
    You can pay a fee of 2€ to have your IP changed, or wait for GeoIP changes. They usually let you pick the subnet. Keep in mind old subnets with correct GeoIP are almost full.
    If someone else wants to use Tailscale on a russian GeoIP server, here's a workaround using a random chinese apt mirror. It will still be secure since it uses the gpg key from tailscale.com.
    curl -fsSL https://pkgs.tailscale.com/stable/debian/bookworm.noarmor.gpg | tee /usr/share/keyrings/tailscale-archive-keyring.gpg >/dev/null
    echo "deb [signed-by=/usr/share/keyrings/tailscale-archive-keyring.gpg] https://mirrors.ysicing.net/tailscale/stable/debian bookworm main" | tee /etc/apt/sources.list.d/tailscale.list
    apt-get update
    apt-get install tailscale
    Thanked by (1)treesmokah
