My "sweden" promo VPS I got some hour ago is located in Austria not Sweden. That's almost perfect for me.
IPv6 is configured by default however it doesn't work. It doest not look like I can do anything on my side to make it work.
I checked also from Hosthatch .AT vps:
PING 77.221.136.xx (77.221.136.xx) 56(84) bytes of data.
64 bytes from 77.221.136.xx: icmp_seq=1 ttl=61 time=0.446 ms
64 bytes from 77.221.136.xx: icmp_seq=2 ttl=61 time=0.388 ms
64 bytes from 77.221.136.xx: icmp_seq=3 ttl=61 time=0.355 ms
64 bytes from 77.221.136.xx: icmp_seq=4 ttl=61 time=0.220 ms
ICMP is anycasted, Use paping and TCP ping your SSH port.
@lapua said:
the most important question, is aeza recommendable and especially the sweden promo?
Still using their old AMS-PROMO plan and was one of the first people to get the SWE-PROMO. Only 1 outage in Sweden and it was network related, nothing else. I think it also lasted only for a few minutes.
It's been working flawlessly for me. It's also not expensive enough to not give it a try
If someone managed to set up IPv6 to work, let me know. I mean IPv6 is configured by default (Debian 12) and it seems everything already there, it just doesn't work for some reason.
sudo sed -i 's/^precedence ::ffff/# precedence ::ffff/' /etc/gai.conf ?
@alamdarzia said:
Statistics are not working, and is the ddos protection effective?
Statistics on their custom control panel are broken from time to time, but they usually work.
Do not try to protect game servers on SWE-PROMO plans, but as for my tests, it handles L4 attacks just fine, but expect some packet loss.
Maybe they run out of IPv6 blocks or something, my instances have IPv6 setup by default and it works just fine.
You may want to try talking to their support via Telegram.
This offer seems to allow IRC (I can't see it mentioned in terms) and it also has some DDoS protection. Tagging @Not_Oles since he was thinking about IRC, while a proper IRC network needs multiple servers in different locations.
I'm not able to install tailscale on my VPS, because https://pkgs.tailscale.com return 451 Unavailable For Legal Reasons on seemingly all requests, making even apt update impossible.
Is this type of thing common? Has anyone else gotten a 451?
Subnet that was assigned to you likely has Russian geoip, tailscale doesn't let you install it on Russian IP's because much virtue signaling(war related).
Fuck Internet neutrality, am I right?
Their new SWE blocks are all Russian/Armenia/Singapore GeoIP located.
You can pay a fee of 2€ to have your IP changed, or wait for GeoIP changes. They usually let you pick the subnet. Keep in mind old subnets with correct GeoIP are almost full.
If someone else wants to use Tailscale on a russian GeoIP server, here's a workaround using a random chinese apt mirror. It will still be secure since it uses the gpg key from tailscale.com.
I see that it's set by default (Debian 12 image) in vps interface but it doesn't work.
Ah, I see. You're correct.
It's pretty solid. I've been monitoring it for sometime now. No CPU steal or such stuff, looks pretty good.
@zgato has been using it for longer.
The Ultimate Speedtest Script | Get Instant Alerts on new LES/LET deals | Cheap VPS Deals
Got one.
What can be done whit 10GB?
https://microlxc.net/
Network services. VPN, monitoring, reverse proxy, personal IPV4<->IPV6 proxy, https://atlas.ripe.net/ probe, https://headscale.net/ server, (Tor relay? allowed?)
Edit: I guess Tor exit relays are allowed: https://relays.0x7c0.com/as/AS210644/
lamp and nextcloud to host your selfie
Amadex • Hosting Forums • Webshop • Virtmach • Wie ist meine IP-Adresse?
Eh btw, paying with GPay (Google Pay is also recommended if you don't want to pay with your Credit Card directly).
Google Pay will be the payment processor.
?@tototo no luck.
I reinstalled
Debian 12 (NEW Aeza Repo)
.Am i doing something wrong?
Wrong in a what way?
You picked
-s -- -fig
options.-f/-d Disables the fio (disk performance) test
-i Disables the iperf (network performance) test
-g Disables the Geekbench (system performance) test
I got it yesterday. Everything except for non-working IPv6 seems fine so far.
Oh, sorry. I wanted to say that IPv6 is enabled by default (but IPv4 is preferred).
Not here ... (I commented out precedence ::ffff/ as you suggested as well)
So what was the catch? There has to some trick with such offers.
How are you... online?
my old AMS-PROMO has been alive for almost a year now, not sure about any catch there.
Mine also works just fine.
on seemingly all requests, making evenapt update
impossible.Is this type of thing common? Has anyone else gotten a 451?
