Provider with US and EU locations with anycast (Already using BuyVM)
Already using BuyVM and it's working great, but need a second provider with both US and EU locations with an anycast network option.
Provider should be considered 'production quality', since this will be part of a larger PowerDNS setup.
[ IncogNET  LLC ] - Since 2020
As mentioned on LET, we do provide anycast-as-a-service
Auth DNS and anycast provider Rage4
I'm a bit confused as to how it works. I was looking for a service where I just get several VMs of the required specifications that I need (RAM/CPU/DISK/BW) and would be assigned an anycast IP in the same fashion as I do with BuyVM. I just didn't see any documentation on your site that cleared up how one would go about configuring the tunnels to the servers we'd use.
Seems interesting, and would actually allow us to deploy something more robust if it means we're not limited to just using the locations offered by a single server provider. Do you have any public documentation on the setup of things just so I can take a glance before signing up for a month just to tinker?
EDIT: I've registered an account, will poke around.
Zilore offers Anycast DNS and there is an API so it might be an option for ya
I think you will find more providers if you search for floating IP.
The following Vultr guide might be useful.
https://docs.vultr.com/high-availability-on-vultr-with-floating-ip-and-bgp
Many cloud providers that use OpenStack offer floating IP addresses. E.g. vexxhost.com
Floating IPs generally can only point to instances in the same location, so does not match the use case here.
@MannDude feel free to play with it, we offer 30 day free trial. Regarding docs, yeah I onow it sucks, we are working on a new docs site, in the meantime you can check wiki https://github.com/rage4/AnycastIP/wiki
The idea is that your can mix'n'match between providers keeping your anycast IP with us.
Awesome, I'll take a gander!
