It is not recommended to use any bank card to pay with them as it may be charged to no balance for sanctioned reasons and they do not receive the payment.
They accept payments through Stripe directly, to their UK-based company.
My bank has blocked me multiple times for trying to pay to providers from RU and haven't had a single issue with Aéza.
If what you say is true, I would only pay with a debit card with a lower limit to avoid unnecessary risk.
Maybe they run out of IPv6 blocks or something, my instances have IPv6 setup by default and it works just fine.
You may want to try talking to their support via Telegram.
IPv6 started working automagically today. I didn't make any changes (the VPS is currently idler).
So far so good, my box has 100% uptime and works just fine.
How is people's experience with it? Any complaints so far? I'm just curious, obviously not affiliated with Aeza in any shape or form.
Same here, 100% uptime so far on the SWE promo. No steal on load, does not look oversold, I'm getting the same performance I got on day 1.
I'm a sucker for a good deal and I love AMD powered servers so I bought one. I paid for 6 months in advance because 5 euros was the minimum in order to use Stripe. Thanks for the tip, so far so good.
Keep me updated this is cheap enough I could buy a year and use it to build packages and stuffs.
I have an HetrixTools agent running on it. Will post some stats in a few days for you to check. Also running a public Smokeping instance on it, because I can
This is a YABS of my SWE-PROMO which has been running since June 2023 (most likely on the first SWE-PROMO node).
GB6 scores are quite lower than what anyone would expect from seeing tests from other ppl here, however the instance has given me 0 issues and they're restocking frequently, so I guess they're just adding people to the empty nodes before and then filling up the gaps.
# Yet-Another-Bench-Script #
# v2024-04-22 #
Tue 23 Apr 2024 10:58:28 PM CEST
Uptime : 25 days, 8 hours, 54 minutes
Processor : AMD Ryzen 5 3600 6-Core Processor
CPU cores : 1 @ 3593.248 MHz
AES-NI : ✔ Enabled
VM-x/AMD-V : ❌ Disabled
RAM : 3.8 GiB
Swap : 512.0 MiB
Disk : 9.8 GiB
Distro : Debian GNU/Linux 11 (bullseye)
Kernel : 5.10.0-28-amd64
VM Type : KVM
ISP : Aeza International LTD
ASN : AS210644 AEZA INTERNATIONAL LTD
Host : Aeza International LTD
Country : Sweden
fio Disk Speed Tests (Mixed R/W 50/50) (Partition /dev/vda2):
Read | 3.97 MB/s (994) | 63.66 MB/s (994)
Write | 4.00 MB/s (1.0k) | 64.07 MB/s (1.0k)
Total | 7.98 MB/s (1.9k) | 127.74 MB/s (1.9k)
Read | 491.31 MB/s (959) | 992.45 MB/s (969)
Write | 517.41 MB/s (1.0k) | 1.05 GB/s (1.0k)
Total | 1.00 GB/s (1.9k) | 2.05 GB/s (2.0k)
Clouvider | London, UK (10G) | 122 Mbits/sec | 144 Mbits/sec | 40.4 ms
Eranium | Amsterdam, NL (100G) | 50.6 Mbits/sec | 473 Mbits/sec | 31.7 ms
Telia | Helsinki, FI (10G) | busy | busy | 37.5 ms
Uztelecom | Tashkent, UZ (10G) | 70.9 Mbits/sec | 239 Mbits/sec | 84.9 ms
Leaseweb | Singapore, SG (10G) | busy | 226 Mbits/sec | 323 ms
Clouvider | Los Angeles, CA, US (10G) | busy | busy | 162 ms
Leaseweb | NYC, NY, US (10G) | 100 Mbits/sec | 298 Mbits/sec | 115 ms
Edgoo | Sao Paulo, BR (1G) | 89.3 Mbits/sec | 103 Mbits/sec | 222 ms
Clouvider | London, UK (10G) | 76.6 Mbits/sec | 127 Mbits/sec | 36.4 ms
Eranium | Amsterdam, NL (100G) | busy | busy | 29.6 ms
Uztelecom | Tashkent, UZ (10G) | 360 Mbits/sec | 83.5 Mbits/sec | 84.5 ms
Leaseweb | Singapore, SG (10G) | busy | 74.6 Mbits/sec | 322 ms
Clouvider | Los Angeles, CA, US (10G) | busy | busy | 166 ms
Leaseweb | NYC, NY, US (10G) | 346 Mbits/sec | busy | 105 ms
Edgoo | Sao Paulo, BR (1G) | 295 Mbits/sec | 35.2 Mbits/sec | 218 ms
Test | Value
Single Core | 758
Multi Core | 754
Full Test | https://browser.geekbench.com/v6/cpu/5834384
YABS completed in 27 min 35 sec
? it's stripe...
Use Stripe then Gpay option.
https://microlxc.net/
Whats with the weird ass email they sent out this morning?
Da hail????
Can you guys check if mail ports are blocked on your Swe promo?
Amadex • Hosting Forums • root.hr
Ports 25 465 587 are open on my box.
Could you run
iperf3vs this Chicago server?Sure, here you go:
And
Thank you so much
Back in stock, no issues with my vps so far
Are they DMCA tolerant?
They ignore DMCA
Please stop posting these deals.
I am too weak.
Have you confirmed that with support?
Safe to say if they host malware, botnets, phish and provide "bulletproof" hosting, they don't care about DMCA.
I know who they are and what they do
I wouldn't expect them to ignore all abuse reports at this price, but they ignore DMCA for sure.
Most of these companies are Aeza themselves, https://zelenka.guru/forums/763/
http://109.120.135.146/smokeping/
Jikes - hadn't realized they're that shaky. Guess I'm using this for a squid proxy instead
Amazing value for the price, very satisfied so far. 0% CPU steal. Nice
what monitoring service is this ?
Hetrixtools
