Proxmox "VMware import wizard"
wankelwankel OG
edited March 2024 in General
Most of you are probably aware, but as a heads-up for those who missed it: Proxmox introduced an import wizard for ESXi.
Any experiences? I'm not so fond of commercial software, so never gave VMware a spin and thus lack any testcase.
edit: I managed to botch the poll, have some patience with me....
Escape routes
  1. Did you migrate away from VMware?12 votes
    1. No, should I?
        0.00%
    2. Yes, I did. I manually migrated my VM from VMware to Proxmox.
      41.67%
    3. Yes... went back to bare metal.
        0.00%
    4. Other, see thread below
      25.00%
    5. What's a VM?
      33.33%
Thanked by (1)Falzo
  • georgedatacentergeorgedatacenter Hosting ProviderOG
    We are moving from VMware to Virtualizor.
    That option that proxmox has released looks interesting, but I haven't done any testing with it.
    George Datacenter LLC
    www.georgedatacenter.com
    Owner Hardware
    Are you sure you want to move to Virtualizor?
    The old nodes we have in VMware are already a headache, for now if it is the closest option we have.
    Owner Hardware
  • FalzoFalzo Senpai
    I wrote a bash script for that purpose a few months ago. Nice to see an integrated solution now, but have to read up on it, if and how it might handle IP remapping and such.
  • Backup your data, scrap the VM and set it up anew in proxmox. You'll lose all the fat and none of the data.
  • wankelwankel OG
    edited March 2024
    in another time and place, @somik said: So people now a days require to be told that something is sarcasm? Just 15 years back, people would know how to properly use sarcasm and you dont have to tell/flag it so both you and the reader knows it is sarcasm.
    Example:
    (courtesy of @somik)
    This wasn't sarcasm though. It is a real advice I always follow. When it's time to change server, I always backup, wipe, reinstall proxmox, setup VM, and copy back all my data.
    Thanked by (1)wankel
    edited March 2024
    Hy @wankel
    Before folowing our recomandation, take your time and read:
    https://pve.proxmox.com/wiki/Migrate_to_Proxmox_VE
    Migration from VMware to proxmox is pretty simple, this is option A:
    1- do a backup of the VM in VMware , so if shit hits the fan, you won’t loose it
    2- after the backup uninstall VMware guest agent, now this step is a must, and install QEMU-GUEST-AGENT
    3- create the vm in proxmox node, same specs, emulation Q35 not FX440, disk type SATA for windows VM, SCSI for Linux and if you run centos 7 you have to use IDE
    4- copy the VM drive file from VMware to proxmox, put in in /mnt/pve/tmp for example
    5- ssh to proxmox and run :
    qm disk import {target VMID} {vmdk file} {target storage}, for example
    qm disk import 102 windows10.vmdk local-lvme
    6 - go to GUI, and you will see an un-allocated disk image, atach it ( scsi, sata, ide )
    Boot, now 80% of the cases this works, if not,
    Option B: ( this worked best on sub windows 10 VM's and centos 7 )
    This step requires that you have a 'lan' connection between proxmox and vmware!
    3- create the vm in proxmox node, same specs, emulation Q35 not FX440, disk tipe sata for windows VM, scsi for Linux and if you run centos 7 you have to use IDE
    Boot CLONEZILA on both VM's
    https://clonezilla.org/downloads/download.php?branch=stable
    https://www.google.com/search?client=firefox-b-d&q=clonezila+network+cloning#fpstate=ive&vld=cid:01ac8a23,vid:8UGR_RLCptQ,st:0
    3- select device to device cloning, the vmware vm is the surce, and on proxmox VM you select destination.
    4- wait for things to finish,
    We recommend you select a small VM and run some tests before you dive in the Production VM's.
  • Hi HC,
    That's quite an in-depth howto,
    @host_c said: Before folowing our recomandation, take your time and read:
    thanks for the wiki-link as well!
    edited March 2024
    @wankel
    Sure thing, altho, option B always worked, well 99.9% of the time.
    @host_c said: 3- select device to device cloning, the vmware vm is the surce, and on proxmox VM you select destination.
    Watch out, not to mix the source and destination =) , you might end up with a "empty OS " . Do backup always on source.!
  • rskrsk Hosting Provider
    Go for virtfusion and never look back! Forget about virtualizor. That’s my advice :)
    Thanked by (2)VirtFusion host_c
