Comprehensive Speedtest Script | nws.sh | Share your bench
1910121415
  • @lapua said:
    > lapua@xxxFFM:~# curl -sL network-speed.xyz | bash -s -- -r eu
    > bash: line 1: error: command not found
    From Crunchbits Discord:
    Partial outage of some servers (likely localized network related) is being investigated right now.
    Tech en-route to DC.
    Thanked by (1)lapua
  • @lapua it's back up now.
    Papa Crunchbits is fast!
    Thanked by (1)lapua
    Well.
    ---------------------------- network-speed.xyz ----------------------------
          A simple script to test network performance using speedtest-cli
     Version            : v2024.03.15
     Global Speedtest   : wget -qO- network-speed.xyz | bash
     Region Speedtest   : wget -qO- network-speed.xyz | bash -s -- -r <region>
     Basic System Info
     CPU Model          : Intel(R) Xeon(R) CPU E5-2690 v4 @ 2.60GHz
     CPU Cores          : 1 @ 2599.996 MHz
     CPU Cache          : 35840 KB
     AES-NI             : ✔ Enabled
     VM-x/AMD-V         : ✔ Enabled
     Total Disk         : 9.8 GB (1.6 GB Used)
     Total RAM          : 475.5 MB (97.0 MB Used)
     System uptime      : 0 days, 0 hour 24 min
     Load average       : 0.00, 0.05, 0.06
     OS                 : Debian GNU/Linux 11
     Arch               : x86_64 (64 Bit)
     Kernel             : 5.10.0-14-cloud-amd64
     Virtualization     : KVM
     TCP Control        : bbr
     Basic Network Info
     Primary Network    : IPv6
     IPv6 Access        : ✔ Online
     IPv4 Access        : ✔ Online
     ISP                : Cloudie Limited
     ASN                : AS55933 Cloudie Limited
     Host               : Cloudie Limited
     Location (IPv4)    : Hong Kong, Hong Kong, HK
     Speedtest.net (Region: CHINA | 中華人民共和國)
     Location         Latency     Loss    DL Speed       UP Speed       Server
     ISP:
     Nearest          FAILED
     CU - Shanghai    FAILED
     CM - Beijing     FAILED
     CU - Beijing     FAILED
     CT - Nanjing     FAILED
     CT - Shenzen     FAILED
     CU - Shenyang    FAILED
     CT - Suzhou      FAILED
     CT - Yangzhou    FAILED
     CM - Hangzhou    FAILED
     CT - Hangzhou    FAILED
     CU - Zhengzhou   FAILED
     CT - Changsha    FAILED
     CU - Changsha    FAILED
     CM - Chengdu     FAILED
     CM - Xi an       FAILED
     CT - Hefei       FAILED
     CT - TianJin     FAILED
     CT - XiNing      FAILED
     CT - NingBo      FAILED
     CM - Guangzhou   FAILED
     CM - Kwai Chung  FAILED
     CM - Hong Kong   FAILED
     CUG - Hong Kong  FAILED
     Hong Kong        FAILED
     Hong Kong        FAILED
     CUG - Tokyo      FAILED
     CUG - Singapore  FAILED
     CUG - LosAngeles FAILED
     CUG - London     FAILED
     Avg DL Speed       : 0.00 Mbps
     Avg UL Speed       : 0.00 Mbps
     Total DL Data      : 0.00 GB
     Total UL Data      : 0.00 GB
     Total Data         : 0.00 GB
     Duration           : 3 sec
     System Time        : 03/04/2024 - 19:07:08 UTC
     Total Script Runs  : 39802
     Result             : https://result.network-speed.xyz/r/1712170912_JII0BK_CHINA.txt
    Thanked by (1)carlin0
  • @Neoon oof, that doesn't look good.
    Does the speedtest-cli work when you try it from bash?
    edited April 2024
    It does.
    Retrieving speedtest.net configuration...
    Testing from HKDF (122.10.89.xxx)...
    Retrieving speedtest.net server list...
    Selecting best server based on ping...
    Hosted by STC (Hong Kong) [0.87 km]: 4.854 ms
    Testing download speed................................................................................
    Download: 95.33 Mbit/s
    Testing upload speed......................................................................................................
    Upload: 190.64 Mbit/s
  • @Neoon said:
    It does.
    Nah, not this one.
    If possible, could you test with this
    https://www.speedtest.net/apps/cli
    @sh97 said:
    Nah, not this one.
    Yea turns out, the VPS had no resolvable hostname.
    Thanked by (1)sh97
    edited April 2024
    15Y roughly 1.8€ CN2 VPS
    https://www.yanhuoidc.com/cart
     Basic System Info
     AES-NI             : ✔ Enabled
     Total RAM          : 475.7 MB (90.1 MB Used)
     System uptime      : 0 days, 0 hour 0 min
     Load average       : 0.06, 0.02, 0.00
     Kernel             : 5.10.0-28-cloud-amd64
     TCP Control        : bbr
     Basic Network Info
     ISP: HKDF
     Nearest          2.00 ms     0.0%    94.00 Mbps     213.38 Mbps    i3D.net - Hong Kong
     CU - Shanghai    39.23 ms    N/A     19.85 Mbps     176.42 Mbps    China Unicom 5G - Shanghai
     CM - Beijing     217.37 ms   0.0%    99.46 Mbps     212.92 Mbps    China Mobile Group Beijing Co.Ltd - Beijing
     CU - Beijing     FAILED
     CT - Nanjing     226.50 ms           2.15 Mbps      FAILED         China Telecom JiangSu 5G - Nanjing
     CT - Shenzen     FAILED
     CT - Suzhou      FAILED
     CM - Hangzhou    34.11 ms    0.4%    95.61 Mbps     176.41 Mbps    China Mobile Zhejiang 5G - Hangzhou
     CT - Hangzhou    30.51 ms    N/A     20.48 Mbps     169.41 Mbps    浙江电信 - HangZhou
     CM - Chengdu     FAILED
     CM - Xi an       FAILED
     CT - Hefei       43.94 ms    0.0%    13.29 Mbps     177.97 Mbps    China Telecom AnHui 5G - Hefei
     CT - TianJin     FAILED
     CT - XiNing      FAILED
     CT - NingBo      38.46 ms    N/A     95.83 Mbps     174.35 Mbps    浙江电信 - NingBo
     CM - Kwai Chung  2.71 ms     0.0%    95.66 Mbps     214.57 Mbps    CMHK Mobile Service - Hong Kong
     CM - Hong Kong   2.72 ms     0.0%    95.61 Mbps     215.88 Mbps    CMHK Broadband - Hong Kong
     CUG - Hong Kong  3.56 ms     0.0%    94.16 Mbps     219.99 Mbps    China Unicom Global Ltd - Hong Kong
     Hong Kong        2.61 ms     N/A     95.33 Mbps     220.03 Mbps    fdcservers.net - Hong Kong
     Hong Kong        2.36 ms     0.0%    95.39 Mbps     113.12 Mbps    Misaka Network, Inc. - Hong Kong
     CUG - Tokyo      201.24 ms   0.0%    100.05 Mbps    152.26 Mbps    China Unicom Global Ltd - Tokyo
     CUG - Singapore  123.38 ms   0.0%    97.43 Mbps     209.04 Mbps    China Unicom Global Ltd - Singapore
     CUG - London     199.40 ms   0.0%    96.03 Mbps     199.94 Mbps    China Unicom Global Ltd - London
     Avg DL Speed       : 75.65 Mbps
     Avg UL Speed       : 177.86 Mbps
     Total DL Data      : 1.21 GB
     Total UL Data      : 3.44 GB
     Total Data         : 4.65 GB
     Duration           : 6 min 40 sec
     System Time        : 03/04/2024 - 19:46:56 UTC
     Total Script Runs  : 39806
     Result             : https://result.network-speed.xyz/r/1712173298_22GDPQ_CHINA.txt
    2.6€ Akile Cloud Taiwan VPS
     Basic System Info
     CPU Model          : AMD EPYC 7D12 32-Core Processor
     CPU Cores          : 1 @ 1097.937 MHz
     CPU Cache          : 512 KB
     AES-NI             : ✔ Enabled
     Total Disk         : 9.8 GB (871.5 MB Used)
     Total RAM          : 1.9 GB (60.5 MB Used)
     System uptime      : 0 days, 0 hour 1 min
     Load average       : 0.19, 0.10, 0.04
     Kernel             : 5.10.0-26-cloud-amd64
     TCP Control        : bbr
     Basic Network Info
     ISP                : Akari Networks
     ASN                : AS38136 Akari Networks
     ASN (IPv4)         : AS61112 AKILE LTD
     Host               : Akari TW Tpe1
     Speedtest.net (Region: ASIA)
     ISP: Akile
     Nearest          0.51 ms     0.0%    4836.66 Mbps   7059.97 Mbps   Starverse Network - Taipei City
     Tokyo, JP        35.11 ms    0.0%    2310.92 Mbps   2134.86 Mbps   Rakuten Mobile, Inc - Tokyo
     Tapei, TW        FAILED
     China Telecom    FAILED
     China Unicom     FAILED
     China Mobile     FAILED
     Hong Kong, CN    76.38 ms    0.0%    2902.30 Mbps   1072.66 Mbps   i3D.net - Hong Kong
     Ho Chi Minh, VN  116.65 ms   0.0%    1442.51 Mbps   680.42 Mbps    VNPT-NET - Ho Chi Minh
     Hanoi, VN        100.87 ms   0.0%    999.25 Mbps    747.32 Mbps    FPT Telecom - Hanoi
     Bangkok, TH      117.17 ms   0.0%    970.06 Mbps    650.04 Mbps    3BB - Bangkok
     Manila, PH       102.64 ms   N/A     968.65 Mbps    780.20 Mbps    PLDT - Manila
     Singapore, SG    105.57 ms   0.0%    943.20 Mbps    745.54 Mbps    MyRepublic Singapore - Singapore
     Singapore, SG    115.03 ms   N/A     966.08 Mbps    682.65 Mbps    StarHub Ltd - Singapore
     Jakarta, ID      107.92 ms   0.0%    914.89 Mbps    589.23 Mbps    PT Indosat Tbk - Jakarta
     Surabaya, ID     130.92 ms   N/A     959.17 Mbps    587.76 Mbps    PT. Indonesia Comnets Plus - Surabaya
     Kuala Lum, MY    101.72 ms   0.0%    964.01 Mbps    780.17 Mbps    Telekom Malaysia Berhad - Kuala Lumpur
     Mumbai, IN       161.52 ms   0.0%    969.87 Mbps    511.34 Mbps    i3D.net - Mumbai
     Chennai, IN      225.63 ms   N/A     954.36 Mbps    342.06 Mbps    Jio - Chennai
     Bangalore, IN    301.96 ms   0.0%    950.77 Mbps    283.11 Mbps    Bharti Airtel Ltd - Bangalore
     Karachi, PK      277.11 ms   0.0%    932.45 Mbps    176.62 Mbps    JAZZ - Karachi
     Islamabad, PK    203.69 ms   0.0%    971.83 Mbps    363.49 Mbps    Ufone - Islamabad
     Kathmandu, NP    293.89 ms   0.0%    942.33 Mbps    362.09 Mbps    Ncell Axiata Ltd - Kathmandu
     Colombo, SL      136.60 ms   N/A     961.38 Mbps    592.19 Mbps    Airtel Lanka - Colombo
     Dhaka, BD        146.73 ms   N/A     958.61 Mbps    536.76 Mbps    Grameenphone Ltd - Dhaka
     Novosibirsk, RU  323.48 ms   0.0%    828.23 Mbps    240.71 Mbps    MegaFon - Novosibirsk
     Almaty, KZ       248.53 ms   0.0%    920.20 Mbps    322.20 Mbps    Kazakhtelecom - Almaty
     Tehran, IR       380.35 ms   0.0%    955.31 Mbps    152.18 Mbps    Irancell - Tehran
     Dubai, AE        187.17 ms   N/A     948.43 Mbps    380.80 Mbps    ETISALAT-UAE - Dubai
     Jeddah, SA       279.73 ms   0.0%    1004.12 Mbps   285.48 Mbps    Mobily - Jeddah
     Istanbul, TR     289.60 ms   0.0%    985.13 Mbps    276.53 Mbps    Vodafone TR - Istanbul
     Avg DL Speed       : 1248.49 Mbps
     Avg UL Speed       : 820.63 Mbps
     Total DL Data      : 45.80 GB
     Total UL Data      : 24.38 GB
     Total Data         : 70.18 GB
     Duration           : 14 min 9 sec
     System Time        : 03/04/2024 - 17:17:33 EDT
     Total Script Runs  : 39810
     Result             : https://result.network-speed.xyz/r/1712178736_8I09TE_ASIA.txt
  • @sh97:
    what is the problem here? these errors only occur with avoro / dataforest!
     Version            : v2024.04.04
     Basic System Info
     CPU Model          : AMD Ryzen Threadripper 3970X 32-Core Processor
     CPU Cores          : 1 @ 3699.940 MHz
     CPU Cache          : 512 KB
     AES-NI             : ✔ Enabled
     Total Disk         : 47,2 GB (6,7 GB Used)
     Total RAM          : 1,9 GB (233,6 MB Used)
     Total Swap         : 4,0 GB (1,5 MB Used)
     System uptime      : 53 days, 17 hour 22 min
     Load average       : 0.00, 0.00, 0.00
     OS                 : Debian GNU/Linux 12
     Kernel             : 6.1.0-18-amd64
     TCP Control        : cubic
     Basic Network Info
     ISP                : dataforest GmbH
     ASN                : AS58212 dataforest GmbH
     Host               : Harmony Solutions GmbH
     Speedtest.net (Region: EUROPE)
     ISP: dataforest
     Nearest          0.54 ms     0.0%    6214.45 Mbps   6217.38 Mbps   FynnCraft Minecraft Network - Dortmund
     London, UK       10.87 ms    0.0%    9175.87 Mbps   3793.64 Mbps   M247 Ltd - London
     Manchester, UK   20.69 ms    N/A     8488.43 Mbps   2581.18 Mbps   Vodafone UK - Manchester
     Dublin, IE       26.78 ms    0.0%    9116.57 Mbps   2546.51 Mbps   Three Ireland - Dublin
     Amsterdam, NL    7.11 ms     0.0%    8609.48 Mbps   6056.65 Mbps   Melbicom - Amsterdam
     Eygelshoen, NL   10.91 ms    0.0%    6334.56 Mbps   2913.68 Mbps   SkyLink Data Center BV - Eygelshoven
    awk: line 1: 21492e+119159 : decimal overflow
    awk: line 1: 21738e+112564 : decimal overflow
     Paris, FR        8.72 ms     N/A     6258.50 Mbps   2868.36 Mbps   ORANGE FRANCE - Paris
     Marseille, FR    16.44 ms    0.0%    8707.60 Mbps   3195.38 Mbps   GSL Networks - Marseille
     Madrid, ES       28.66 ms    0.0%    7926.76 Mbps   2814.66 Mbps   Orange - Madrid
    awk: line 1: 601e+1044 : decimal overflow
    awk: line 1: 3122e+1381 : decimal overflow
     Barcelona, ES    25.04 ms    0.0%    9335.31 Mbps   2971.13 Mbps   Adamo - Barcelona
    awk: line 1: syntax error at or near ;
     Lisbon, PT       38.79 ms    0.0%    4906.00 Mbps   1835.28 Mbps   Edgoo Networks - Lisbon
     Rome, IT         25.80 ms    0.0%    8589.44 Mbps   1876.57 Mbps   TIM SpA - Rome
    awk: line 1: 25887e+119411 : decimal overflow
    awk: line 1: 86832e+113037 : decimal overflow
     Milan, IT        21.72 ms    0.0%    3260.63 Mbps   2308.20 Mbps   Fastweb SpA - Milan
     Zurich, CH       9.38 ms     0.0%    7759.97 Mbps   4502.49 Mbps   Sunrise Communication AG - Zurich
     Frankfurt, DE    0.82 ms     3.0%    7180.93 Mbps   6006.11 Mbps   Deutsche Telekom - Frankfurt am Main
     Berlin, DE       11.38 ms    N/A     8232.92 Mbps   871.67 Mbps    Misaka Network, Inc. - Berlin
     Vienna, AT       15.73 ms    0.0%    9305.56 Mbps   3726.91 Mbps   A1 Telekom Austria AG - Vienna
     Budapest, HU     14.16 ms    0.0%    6463.39 Mbps   2324.60 Mbps   ATW Internet Kft. - Budapest
    awk: line 1: 26078e+118325 : decimal overflow
    awk: line 1: 30845e+11882 : decimal overflow
     Gdansk, PL       28.94 ms    0.0%    338.42 Mbps    2629.28 Mbps   T-Mobile Polska S.A. - Gdańsk
     Warsaw, PL       18.55 ms    0.0%    8278.06 Mbps   3320.70 Mbps   Orange Polska S.A. - Warsaw
     Lviv, UA         24.23 ms    0.0%    9381.30 Mbps   1601.98 Mbps   Kyivstar - Lviv
     Kyiv, UA         28.94 ms    0.0%    9105.40 Mbps   1171.56 Mbps   O3 - Kyiv
     Minsk, BY        27.54 ms    0.0%    6423.28 Mbps   2290.79 Mbps   A1 - Minsk
     Bucharest, RO    27.61 ms    0.0%    4561.76 Mbps   2323.45 Mbps   Orange Romania SA - Bucuresti
    awk: line 1: 38832e+109108 : decimal overflow
    awk: line 1: 62933e+111269 : decimal overflow
     Timisoara, RO    31.10 ms    0.0%    7923.18 Mbps   2418.12 Mbps   Digi
     Helsinki, FI     22.50 ms    0.0%    8548.65 Mbps   3659.54 Mbps   Elisa Oyj - Helsinki
     Stockholm, SE    29.19 ms    0.0%    7985.60 Mbps   2710.00 Mbps   i3D.net - Stockholm
     Oslo, NO         23.16 ms    0.0%    8630.41 Mbps   2419.63 Mbps   Speedtest.net - Oslo
     Moscow, RU       44.53 ms    0.0%    6947.99 Mbps   1653.63 Mbps   MTS - Moscow
     Petersburg, RU   31.44 ms    0.0%    8266.10 Mbps   1953.06 Mbps   MegaFon - Saint Petersburg
    awk: line 1: 92386e+118636 : decimal overflow
     Istanbul, TR     FAILED - IP has been rate limited. Try again after 1 hour.
     Tbilisi, GE      FAILED - IP has been rate limited. Try again after 1 hour.
     Avg DL Speed       : 0,00 Mbps
     Avg UL Speed       : 0,07 Mbps
     Total DL Data      : 0,00 GB
     Total UL Data      : 0,00 GB
     Total Data         : 0,00 GB
     Duration           : 12 min 17 sec
     System Time        : 05/04/2024 - 14:44:24 CEST
     Total Script Runs  : 39940
     Result             : https://result.network-speed.xyz/r/1712320733_VQVEH1_EU.txt
    interesting: https://result.network-speed.xyz/r/1712320733_VQVEH1_EU.txt show the results without the errors / overflow e.g. but no avg dl/up speed etc.
  • I'll take a look
    @carlin0 and @febryanvaldo have previously told me about this, but I've never been able to replicate this issue.
    Probably some issue with awk version dependencies is my guess, but let's see.
    Thanked by (1)lapua
  • if you need more details, just let me know.
    Thanked by (2)sh97 arirang
     Speedtest.net (Region: INDIA | भारत)
     ISP: FiberState
     Nearest          1.08 ms     0.0%    939.59 Mbps    941.00 Mbps    SUMOFIBER - Salt Lake City, UT
     Mumbai, MH       244.69 ms   0.0%    458.06 Mbps    347.68 Mbps    Jio - Mumbai
     Mumbai, MH       274.19 ms   0.0%    493.66 Mbps    327.81 Mbps    Airtel Broadband - Mumbai
     Pune, MH         266.68 ms   0.0%    517.59 Mbps    332.03 Mbps    Tata Play Fiber - Pune
     Hyderabad, AP/TL 262.93 ms   N/A     425.06 Mbps    330.79 Mbps    Airtel Broadband - Hyderabad
     Bangalore, KA    291.57 ms   0.0%    418.08 Mbps    310.85 Mbps    Bharti Airtel Ltd - Bangalore
     Bangalore, KA    243.62 ms   0.0%    491.46 Mbps    371.95 Mbps    ACT FIBERNET - Bangalore
     Mangalore, KA    255.69 ms   0.0%    412.76 Mbps    343.56 Mbps    BBNL - Mangalore
     Chennai, TN      219.21 ms   N/A     536.49 Mbps    402.51 Mbps    Jio - Chennai
     Coimbatore, TN   260.78 ms   0.0%    111.78 Mbps    327.66 Mbps    Airtel Broadband - Coimbatore
     Madurai, TN      309.96 ms   0.0%    346.72 Mbps    225.84 Mbps    Vi India - Madurai
     Kochi, KL        240.88 ms   N/A     470.84 Mbps    373.79 Mbps    Jio - Kochi
     Kochi, KL        251.79 ms   0.0%    313.30 Mbps    352.79 Mbps    Asianet Broadband - Cochin
     Trivandrum, KL   244.42 ms   0.0%    384.60 Mbps    353.05 Mbps    Keralavision Broadband Ltd - Trivandrum
     Kolkata, WB      281.19 ms   0.0%    531.27 Mbps    322.43 Mbps    Alliance Broadband Services Pvt Ltd - Kolkata
     Ahmedabad, GJ    289.44 ms   0.0%    428.45 Mbps    314.05 Mbps    GTPL Broadband Pvt Ltd - Ahmedabad
     Jaipur, RJ       288.04 ms   0.0%    434.22 Mbps    304.90 Mbps    RailTel Corporation of India Ltd - Jaipur
     Lucknow, UP      280.24 ms   0.0%    462.72 Mbps    248.42 Mbps    Excitel - Lucknow
     Delhi, DL        274.56 ms   0.0%    399.88 Mbps    142.30 Mbps    Extreme IX - New Delhi
     Gurgaon, HR      265.92 ms   0.0%    479.55 Mbps    306.56 Mbps    Powernet - Gurgaon
     Patna, BH        306.96 ms   N/A     436.57 Mbps    287.26 Mbps    Vi India - Patna
     Avg DL Speed       : 452.03 Mbps
     Avg UL Speed       : 346.06 Mbps
     Total DL Data      : 12.00 GB
     Total UL Data      : 9.58 GB
     Total Data         : 21.58 GB
  • edited April 2024
    @sh97 @linveo
    Dallas, Texas
    ping 1.28 ms
    DL speed 8181.00 Mbps
    UL speed 7255.91 Mbps
    Server - Hivelocity - Dallas, Texas
     Speedtest.net (Region: NORTH AMERICA)
     ISP: EGIHosting
     Nearest          9.12 ms     0.0%    5776.92 Mbps   1580.05 Mbps   Cox - Wichita - Wichita, KS
     Vancouver, BC    47.98 ms    N/A     6539.79 Mbps   1497.35 Mbps   TELUS - Vancouver, BC
     Calgary, AB      53.58 ms    N/A     6217.37 Mbps   454.09 Mbps    Shaw Communications - Calgary, AB
     Winnipeg, MB     30.78 ms    0.0%    7663.87 Mbps   2482.70 Mbps   Voyageur Internet - Winnipeg, MB
     Toronto, ON      33.40 ms    0.0%    7845.08 Mbps   2610.09 Mbps   Bell Canada - Toronto, ON
     Montreal, QC     56.17 ms    0.0%    7402.70 Mbps   1254.88 Mbps   Rogers Wireless - Montréal, QC
     New York, NY     35.38 ms    0.0%    5365.43 Mbps   657.77 Mbps    Surfshark Ltd - New York, NY
     Ashburn, VA      33.51 ms    0.0%    6465.18 Mbps   2013.33 Mbps   Rackdog - Ashburn, VA
     Charlotte, NC    33.29 ms    0.0%    5562.24 Mbps   615.11 Mbps    Windstream - Charlotte, NC
     Atlanta, GA      16.46 ms    0.0%    8136.62 Mbps   2873.86 Mbps   i3D.net - Atlanta, GA
     Miami, FL        31.63 ms    0.0%    5226.27 Mbps   2510.52 Mbps   Hivelocity - Miami, FL
     Dallas, TX       1.28 ms     0.0%    8181.00 Mbps   7255.91 Mbps   Hivelocity - Dallas, TX
     Houston, TX      8.23 ms     0.0%    7371.61 Mbps   4595.02 Mbps   Ezee Fiber - Houston, TX
     Kansas, MO       12.63 ms    0.0%    6524.93 Mbps   1313.40 Mbps   Nocix - Kansas City, MO
     Minneapolis, MN  22.28 ms    0.0%    7940.77 Mbps   1253.15 Mbps   US Internet - Minneapolis, MN
     Chicago, IL      22.26 ms    1.0%    7944.13 Mbps   1971.11 Mbps   Enzu.com - Chicago, IL
     Cleveland, OH    36.03 ms    0.0%    5524.58 Mbps   597.24 Mbps    Windstream - Cleveland, OH
     Albuquerque, NM  23.37 ms    N/A     9235.49 Mbps   2609.04 Mbps   Comcast - Albuquerque, NM
     Denver, CO       32.70 ms    0.0%    7538.92 Mbps   1596.76 Mbps   T-Mobile Fiber | Intrepid - Denver, CO
     Portland, OR     49.40 ms    N/A     6047.56 Mbps   1297.85 Mbps   CenturyLink - Portland, OR
     Las Vegas, NV    47.37 ms    N/A     3723.74 Mbps   442.97 Mbps    Dish Wireless - Las Vegas, NV
     Salt Lake, UT    29.20 ms    N/A     2217.48 Mbps   1917.58 Mbps   Novva Data Centers - Salt Lake City, UT
     Phoenix, AZ      19.65 ms    0.0%    6168.63 Mbps   2992.11 Mbps   Xiber LLC - Phoenix, AZ
     Los Angeles, CA  29.26 ms    0.0%    7448.07 Mbps   1066.90 Mbps   ReliableSite Hosting - Los Angeles, CA
     San Jose, CA     40.07 ms    0.0%    4637.96 Mbps   1468.45 Mbps   Misaka Network, Inc. - San Jose, CA
     Spokane, WA      52.39 ms    0.0%    4530.86 Mbps   1428.75 Mbps   Crunchbits - Spokane, WA
     Seattle, WA      48.25 ms    0.0%    2277.00 Mbps   1403.79 Mbps   Misaka Network, Inc. - Seattle, WA
     Hermosillo, MX   42.48 ms    0.0%    7338.48 Mbps   1554.12 Mbps   Megacable - Hermosillo
     Guadalajara, MX  29.74 ms    0.0%    1875.87 Mbps   1286.94 Mbps   AT&T México - Guadalajara
     Mexico City, MX  FAILED - IP has been rate limited. Try again after 1 hour.
     Avg DL Speed       : 6163.07 Mbps
     Avg UL Speed       : 1882.78 Mbps
     Total DL Data      : 240.20 GB
     Total UL Data      : 71.42 GB
     Total Data         : 311.62 GB
    Thanked by (1)linveo
  • @sh97 said:
    I'll take a look
    That issue has always existed, at least on Debian...
    F. Battiato ---
    60% of my servers run on debian, have never seen it once unfortunately.
    I'll contact you both when I get time to look into this.
    Thanks!
  • @sh97 said: Probably some issue with awk version dependencies is my guess, but let's see.
    My hunch is that it is a mawk vs gawk issue.
    A quick check via realpath /bin/awk should help identify which one is being used.
    @sh97 could be using gawk while @lapua @carlin0 and @febryanvaldo may be using mawk (all due to distro defaults also).
    The fix could be as trivial as OFMT="%.0f" or something like that if you're using mawk (at least you'll be able to verify if the hunch is in the right direction).
    Hope this helps...
    @sh97 who peed in your Cheerios man?
    Hope this helps...
    Wow, thanks a lot for that.
    I wouldn't have thought about it, tbh.
    I'll be getting some time in a couple of weeks, will have a look then.
    No hablo inglis.
    No hablo inglis.
    je ne parle pas français
     Basic System Info
     CPU Model          : AMD EPYC 7402P 24-Core Processor
     CPU Cores          : 1 @ 2794.748 MHz
     CPU Cache          : 512 KB
     AES-NI             : ✔ Enabled
     Total Disk         : 4.9 GB (2.0 GB Used)
     Total RAM          : 977.2 MB (158.9 MB Used)
     Total Swap         : 1024.0 MB (17.2 MB Used)
     System uptime      : 0 days, 0 hour 46 min
     Load average       : 0.16, 0.66, 0.71
     Kernel             : 6.1.0-13-cloud-amd64
     TCP Control        : bbr
     Basic Network Info
     ISP                : Akile LTD
     ASN                : AS61112 AKILE LTD
     Host               : Akile
     ISP: Akile
     Nearest          0.34 ms     0.0%    489.65 Mbps    521.63 Mbps    NewMedia Express - Singapore
     Tokyo, JP        69.25 ms    0.0%    524.96 Mbps    500.25 Mbps    Rakuten Mobile, Inc - Tokyo
     Tapei, TW        87.22 ms    N/A     511.15 Mbps    497.00 Mbps    Chunghwa Mobile - Taipei
     China Telecom    288.27 ms   43.5%   5.86 Mbps      0.87 Mbps      China Telecom JiangSu 5G - Nanjing
     China Unicom     FAILED
     China Mobile     FAILED
     Hong Kong, CN    35.89 ms    0.0%    495.23 Mbps    518.13 Mbps    i3D.net - Hong Kong
     Ho Chi Minh, VN  27.73 ms    0.0%    494.66 Mbps    523.93 Mbps    VNPT-NET - Ho Chi Minh
     Hanoi, VN        50.33 ms    0.0%    506.60 Mbps    510.90 Mbps    FPT Telecom - Hanoi
     Bangkok, TH      23.53 ms    56.5%   493.24 Mbps    521.79 Mbps    3BB - Bangkok
     Manila, PH       47.83 ms    N/A     503.27 Mbps    522.65 Mbps    PLDT - Manila
     Singapore, SG    0.36 ms     0.0%    497.93 Mbps    522.03 Mbps    MyRepublic Singapore - Singapore
     Singapore, SG    0.64 ms     N/A     498.40 Mbps    523.27 Mbps    StarHub Ltd - Singapore
     Jakarta, ID      12.55 ms    0.0%    498.90 Mbps    521.25 Mbps    PT Indosat Tbk - Jakarta
     Surabaya, ID     25.20 ms    N/A     502.54 Mbps    523.12 Mbps    PT. Indonesia Comnets Plus - Surabaya
     Kuala Lum, MY    10.67 ms    0.0%    500.23 Mbps    522.47 Mbps    Telekom Malaysia Berhad - Kuala Lumpur
     Mumbai, IN       52.58 ms    0.0%    495.70 Mbps    515.09 Mbps    i3D.net - Mumbai
     Chennai, IN      34.17 ms    N/A     495.31 Mbps    526.07 Mbps    Jio - Chennai
     Bangalore, IN    161.86 ms   0.0%    498.58 Mbps    391.98 Mbps    Bharti Airtel Ltd - Bangalore
     Karachi, PK      171.44 ms   0.0%    486.69 Mbps    264.44 Mbps    JAZZ - Karachi
     Islamabad, PK    110.36 ms   0.0%    507.71 Mbps    412.26 Mbps    Ufone - Islamabad
     Kathmandu, NP    76.99 ms    0.0%    495.17 Mbps    407.34 Mbps    Ncell Axiata Ltd - Kathmandu
     Colombo, SL      80.76 ms    N/A     505.23 Mbps    464.74 Mbps    Airtel Lanka - Colombo
     Dhaka, BD        44.73 ms    N/A     502.12 Mbps    508.01 Mbps    Grameenphone Ltd - Dhaka
     Novosibirsk, RU  226.40 ms   0.0%    385.10 Mbps    337.50 Mbps    MegaFon - Novosibirsk
     Almaty, KZ       245.97 ms   0.0%    486.44 Mbps    305.26 Mbps    Kazakhtelecom - Almaty
     Tehran, IR       236.01 ms   0.0%    508.33 Mbps    261.56 Mbps    Irancell - Tehran
     Dubai, AE        73.06 ms    N/A     523.40 Mbps    492.65 Mbps    ETISALAT-UAE - Dubai
     Jeddah, SA       165.72 ms   0.0%    24.73 Mbps     359.04 Mbps    Mobily - Jeddah
     Istanbul, TR     195.65 ms   0.0%    516.74 Mbps    364.87 Mbps    Vodafone TR - Istanbul
     Avg DL Speed       : 462.63 Mbps
     Avg UL Speed       : 440.72 Mbps
     Total DL Data      : 16.44 GB
     Total UL Data      : 14.31 GB
     Total Data         : 30.75 GB
     Duration           : 12 min 36 sec
     System Time        : 08/04/2024 - 15:34:29 EDT
     Total Script Runs  : 40201
     Result             : https://result.network-speed.xyz/r/1712604510_OAN7O3_ASIA.txt
    Thanked by (1)sh97
  • Virmach LAX - $11/yr
     Basic System Info
     CPU Model          : AMD Ryzen 9 3900X 12-Core Processor
     CPU Cores          : 3 @ 3799.998 MHz
     CPU Cache          : 512 KB
     AES-NI             : ✔ Enabled
     Total Disk         : 51.6 GB (2.2 GB Used)
     Total RAM          : 1.9 GB (62.8 MB Used)
     Total Swap         : 256.0 MB (0 Used)
     System uptime      : 3 days, 19 hour 4 min
     Load average       : 0.08, 0.16, 0.14
     Kernel             : 5.10.0-8-amd64
     TCP Control        : cubic
     Basic Network Info
     Primary Network    : IPv4
     IPv6 Access        : ❌ Offline
     ISP                : QuadraNet Enterprises LLC
     ASN                : AS8100 QuadraNet Enterprises LLC
     Host               : Virtual Machine Solutions LLC
     Location (IPv4)    : Los Angeles, California, US
     ISP: Sprint
     Nearest          58.15 ms    0.0%    952.36 Mbps    881.34 Mbps    GSL Networks - New York, NY
     Kochi, IN        349.66 ms   0.0%    32.78 Mbps     251.73 Mbps    Asianet Broadband - Cochin
     Bangalore, IN    270.59 ms   0.0%    477.51 Mbps    343.31 Mbps    Bharti Airtel Ltd - Bangalore
     Chennai, IN      205.65 ms   N/A     689.17 Mbps    432.75 Mbps    Jio - Chennai
     Mumbai, IN       255.12 ms   0.0%    592.68 Mbps    295.47 Mbps    i3D.net - Mumbai
     Delhi, IN        274.88 ms   0.0%    539.17 Mbps    253.22 Mbps    Tata Play Fiber - New Delhi
     Seattle, US      28.68 ms    N/A     900.61 Mbps    846.92 Mbps    Comcast - Seattle, WA
     Los Angeles, US  0.89 ms     0.0%    933.47 Mbps    930.13 Mbps    ReliableSite Hosting - Los Angeles, CA
     Dallas, US       32.90 ms    0.0%    807.97 Mbps    884.30 Mbps    Hivelocity - Dallas, TX
     Miami, US        62.62 ms    N/A     762.80 Mbps    872.24 Mbps    Dish Wireless - Miami, FL
     New York, US     58.07 ms    0.0%    955.25 Mbps    858.87 Mbps    GSL Networks - New York, NY
     Toronto, CA      61.65 ms    0.0%    861.82 Mbps    875.08 Mbps    Rogers - Toronto, ON
     Mexico City, MX  52.19 ms    N/A     926.58 Mbps    563.95 Mbps    INFINITUM - Mexico City
     London, UK       140.72 ms   0.0%    947.31 Mbps    649.77 Mbps    VeloxServ Communications - London
     Amsterdam, NL    149.35 ms   0.0%    954.64 Mbps    258.55 Mbps    31173 Services AB - Amsterdam
     Paris, FR        141.79 ms   N/A     936.70 Mbps    225.84 Mbps    Axione - Paris
     Frankfurt, DE    140.17 ms   0.0%    576.91 Mbps    286.40 Mbps    Clouvider Ltd - Frankfurt am Main
     Warsaw, PL       183.62 ms   0.0%    928.20 Mbps    514.44 Mbps    Play - Warszawa
     Bucharest, RO    171.66 ms   0.0%    575.46 Mbps    444.93 Mbps    Vodafone Romania Fixed – Bucharest - Bucharest
     Moscow, RU       182.23 ms   0.0%    829.71 Mbps    474.32 Mbps    MegaFon - Moscow
     Jeddah, SA       197.85 ms   0.0%    846.54 Mbps    411.16 Mbps    Saudi Telecom Company
     Dubai, AE        254.62 ms   0.0%    750.39 Mbps    330.34 Mbps    du - Dubai
     Fujairah, AE     269.70 ms   0.0%    807.62 Mbps    293.23 Mbps    ETISALAT-UAE - Fujairah
     Istanbul, TR     175.62 ms   0.0%    836.61 Mbps    502.22 Mbps    Turkcell - Istanbul
     Tehran, IR       221.97 ms   0.0%    501.22 Mbps    339.39 Mbps    Asiatech - Tehran
     Tokyo, JP        102.97 ms   N/A     714.28 Mbps    307.62 Mbps    fdcservers.net - Tokyo
     Shanghai, CU-CN  176.11 ms   0.0%    652.34 Mbps    169.12 Mbps    China Unicom 5G - Shanghai
     Nanjing, CT-CN   146.76 ms   1.0%    586.65 Mbps    33.53 Mbps     China Telecom JiangSu 5G - Nanjing
     Hong Kong, CN    156.64 ms   N/A     680.58 Mbps    522.88 Mbps    STC - Hong Kong
     Singapore, SG    269.52 ms   2.3%    510.89 Mbps    475.17 Mbps    i3D.net - Singapore
     Jakarta, ID      185.26 ms   0.0%    610.55 Mbps    471.42 Mbps    PT Solnet Indonesia - Jakarta
     Avg DL Speed       : 731.57 Mbps
     Avg UL Speed       : 483.85 Mbps
     Total DL Data      : 31.64 GB
     Total UL Data      : 19.77 GB
     Total Data         : 51.41 GB
     Duration           : 15 min 55 sec
     System Time        : 09/04/2024 - 06:55:00 EDT
     Total Script Runs  : 40229
     Result             : https://result.network-speed.xyz/r/1712659733_ZND9YX_GLOBAL.txt
  •  Primary Network    : IPv4
     ISP                : Advin Services LLC
     ASN                : AS206216 Advin Services LLC
     Host               : MB \
     ISP: Advin Services
     Nearest          13.07 ms    0.0%    418.40 Mbps    940.96 Mbps    NetCologne - Cologne
     London, UK       20.19 ms    0.0%    4775.08 Mbps   3567.31 Mbps   M247 Ltd - London
     Manchester, UK   27.46 ms    N/A     6992.93 Mbps   3092.35 Mbps   Vodafone UK - Manchester
     Dublin, IE       30.16 ms    0.0%    6633.56 Mbps   2848.02 Mbps   Three Ireland - Dublin
     Amsterdam, NL    15.30 ms    0.0%    6268.21 Mbps   1503.61 Mbps   Melbicom - Amsterdam
     Eygelshoen, NL   18.40 ms    0.0%    5331.74 Mbps   1745.16 Mbps   SkyLink Data Center BV - Eygelshoven
     Paris, FR        17.46 ms    N/A     8029.06 Mbps   3872.42 Mbps   ORANGE FRANCE - Paris
     Marseille, FR    22.31 ms    0.0%    8453.86 Mbps   3789.36 Mbps   GSL Networks - Marseille
     Madrid, ES       39.28 ms    0.0%    6801.77 Mbps   2170.42 Mbps   Orange - Madrid
     Barcelona, ES    27.34 ms    0.0%    4783.19 Mbps   2461.62 Mbps   Adamo - Barcelona
     Lisbon, PT       47.00 ms    0.0%    7571.78 Mbps   1853.24 Mbps   Edgoo Networks - Lisbon
     Rome, IT         32.33 ms    0.0%    6752.72 Mbps   2830.80 Mbps   TIM SpA - Rome
     Milan, IT        24.75 ms    0.0%    5273.34 Mbps   4189.45 Mbps   Fastweb SpA - Milan
     Zurich, CH       13.47 ms    0.0%    6463.70 Mbps   5616.26 Mbps   Sunrise Communication AG - Zurich
     Frankfurt, DE    8.48 ms     6.0%    5336.22 Mbps   265.91 Mbps    Deutsche Telekom - Frankfurt am Main
     Berlin, DE       25.14 ms    0.0%    4426.05 Mbps   1330.38 Mbps   Misaka Network, Inc. - Berlin
     Vienna, AT       14.02 ms    0.0%    6650.82 Mbps   4555.40 Mbps   A1 Telekom Austria AG - Vienna
     Budapest, HU     22.46 ms    0.0%    8983.74 Mbps   2549.50 Mbps   ATW Internet Kft. - Budapest
     Gdansk, PL       29.74 ms    0.0%    3029.16 Mbps   892.95 Mbps    T-Mobile Polska S.A. - Gdańsk
     Warsaw, PL       26.28 ms    0.0%    4800.26 Mbps   3270.88 Mbps   Orange Polska S.A. - Warsaw
     Lviv, UA         34.09 ms    0.0%    5589.92 Mbps   1597.21 Mbps   Kyivstar - Lviv
     Kyiv, UA         32.35 ms    0.0%    4561.77 Mbps   842.61 Mbps    O3 - Kyiv
     Minsk, BY        35.10 ms    0.0%    5936.06 Mbps   2528.45 Mbps   A1 - Minsk
     Bucharest, RO    32.21 ms    0.0%    8145.13 Mbps   2787.35 Mbps   Orange Romania SA - Bucuresti
     Timisoara, RO    45.76 ms    0.0%    5801.55 Mbps   2762.58 Mbps   Digi
     Helsinki, FI     29.38 ms    0.0%    7393.96 Mbps   3002.35 Mbps   Elisa Oyj - Helsinki
     Stockholm, SE    32.51 ms    0.0%    5677.35 Mbps   2741.12 Mbps   i3D.net - Stockholm
     Oslo, NO         FAILED
     Moscow, RU       59.58 ms    0.0%    3667.31 Mbps   1500.01 Mbps   MTS - Moscow
     Petersburg, RU   41.21 ms    0.0%    5711.79 Mbps   2202.67 Mbps   MegaFon - Saint Petersburg
     Avg DL Speed       : 5871.07 Mbps
     Avg UL Speed       : 2527.94 Mbps
     Total DL Data      : 232.27 GB
     Total UL Data      : 89.89 GB
     Total Data         : 322.15 GB
     Duration           : 18 min 22 sec
     System Time        : 14/04/2024 - 09:31:24 UTC
     Total Script Runs  : 40651
     Host               : MB \
     ISP: Advin Services
     Nearest          13.02 ms    0.0%    854.74 Mbps    936.74 Mbps    hotspot.koeln - Cologne
     London, UK       20.34 ms    0.0%    4589.68 Mbps   3995.17 Mbps   M247 Ltd - London
     Manchester, UK   28.07 ms    N/A     6940.85 Mbps   3116.27 Mbps   Vodafone UK - Manchester
     Dublin, IE       30.21 ms    0.0%    5905.39 Mbps   2831.98 Mbps   Three Ireland - Dublin
     Amsterdam, NL    16.28 ms    0.0%    6041.80 Mbps   1584.54 Mbps   Melbicom - Amsterdam
     Eygelshoen, NL   18.17 ms    0.0%    7613.25 Mbps   1795.15 Mbps   SkyLink Data Center BV - Eygelshoven
     Paris, FR        17.19 ms    N/A     7140.99 Mbps   4520.07 Mbps   ORANGE FRANCE - Paris
     Marseille, FR    21.78 ms    0.0%    7120.47 Mbps   4107.68 Mbps   GSL Networks - Marseille
     Madrid, ES       39.32 ms    0.0%    5883.81 Mbps   2484.87 Mbps   Orange - Madrid
     Barcelona, ES    27.11 ms    0.0%    5982.95 Mbps   2738.67 Mbps   Adamo - Barcelona
     Lisbon, PT       47.20 ms    0.0%    6537.88 Mbps   1852.89 Mbps   Edgoo Networks - Lisbon
     Rome, IT         27.69 ms    0.0%    6531.79 Mbps   3203.41 Mbps   TIM SpA - Rome
     Milan, IT        25.72 ms    0.0%    3542.23 Mbps   4117.56 Mbps   Fastweb SpA - Milan
     Zurich, CH       13.04 ms    0.0%    7390.39 Mbps   6013.72 Mbps   Sunrise Communication AG - Zurich
     Frankfurt, DE    9.47 ms     4.0%    6301.92 Mbps   2832.64 Mbps   Deutsche Telekom - Frankfurt am Main
     Berlin, DE       26.08 ms    N/A     5517.48 Mbps   608.20 Mbps    Misaka Network, Inc. - Berlin
     Vienna, AT       14.28 ms    0.0%    6271.04 Mbps   6004.38 Mbps   A1 Telekom Austria AG - Vienna
     Budapest, HU     22.56 ms    0.0%    8310.19 Mbps   2793.18 Mbps   ATW Internet Kft. - Budapest
     Gdansk, PL       33.46 ms    0.0%    3538.56 Mbps   2625.86 Mbps   T-Mobile Polska S.A. - Gdańsk
     Warsaw, PL       26.09 ms    0.0%    5840.38 Mbps   3401.31 Mbps   Orange Polska S.A. - Warsaw
     Lviv, UA         34.39 ms    0.0%    5477.29 Mbps   1935.28 Mbps   Kyivstar - Lviv
     Kyiv, UA         32.60 ms    0.0%    5237.61 Mbps   1307.27 Mbps   O3 - Kyiv
     Minsk, BY        35.03 ms    0.0%    6061.11 Mbps   2722.68 Mbps   A1 - Minsk
     Bucharest, RO    28.87 ms    0.0%    7712.98 Mbps   2917.18 Mbps   Orange Romania SA - Bucuresti
     Timisoara, RO    33.62 ms    0.0%    6207.53 Mbps   2938.70 Mbps   Digi
     Helsinki, FI     29.32 ms    0.0%    7659.94 Mbps   3048.24 Mbps   Elisa Oyj - Helsinki
     Stockholm, SE    32.40 ms    0.0%    7279.43 Mbps   2747.21 Mbps   i3D.net - Stockholm
     Oslo, NO         FAILED
     Moscow, RU       61.02 ms    0.0%    4708.84 Mbps   1763.60 Mbps   MTS - Moscow
     Petersburg, RU   42.41 ms    0.0%    5247.34 Mbps   2256.14 Mbps   MegaFon - Saint Petersburg
     Avg DL Speed       : 5980.97 Mbps
     Avg UL Speed       : 2868.99 Mbps
     Total DL Data      : 241.10 GB
     Total UL Data      : 102.29 GB
     Total Data         : 343.39 GB
     Duration           : 18 min 16 sec
     System Time        : 14/04/2024 - 09:31:32 UTC
     Total Script Runs  : 40652
     ISP: dataforest
     Nearest          0.26 ms     0.0%    9163.35 Mbps   8532.18 Mbps   TCP-SYN - A part of RetardHub - Offenbach am Main
     London, UK       10.98 ms    0.0%    9381.84 Mbps   4128.06 Mbps   M247 Ltd - London
     Manchester, UK   FAILED
     Dublin, IE       FAILED
     Amsterdam, NL    7.16 ms     0.0%    8544.80 Mbps   7704.98 Mbps   Melbicom - Amsterdam
     Eygelshoen, NL   11.05 ms    0.0%    8457.66 Mbps   2142.30 Mbps   SkyLink Data Center BV - Eygelshoven
     Paris, FR        13.50 ms    N/A     7589.51 Mbps   2808.63 Mbps   ORANGE FRANCE - Paris
     Marseille, FR    FAILED
     Madrid, ES       29.61 ms    0.0%    7462.86 Mbps   2617.01 Mbps   Orange - Madrid
     Barcelona, ES    FAILED
     Lisbon, PT       38.54 ms    0.0%    5390.82 Mbps   1434.48 Mbps   Edgoo Networks - Lisbon
     Rome, IT         FAILED
     Milan, IT        FAILED
     Zurich, CH       9.96 ms     0.0%    2037.55 Mbps   6152.98 Mbps   Sunrise Communication AG - Zurich
     Frankfurt, DE    FAILED
     Berlin, DE       11.50 ms    0.0%    7300.25 Mbps   1679.11 Mbps   Misaka Network, Inc. - Berlin
     Vienna, AT       FAILED
     Budapest, HU     15.10 ms    0.0%    8199.66 Mbps   2379.06 Mbps   ATW Internet Kft. - Budapest
     Gdansk, PL       FAILED
     Warsaw, PL       FAILED
     Lviv, UA         FAILED
     Kyiv, UA         FAILED
     Minsk, BY        22.53 ms    0.0%    6532.04 Mbps   1807.15 Mbps   A1 - Minsk
     Bucharest, RO    FAILED
     Timisoara, RO    31.05 ms    0.0%    8063.11 Mbps   1716.87 Mbps   Digi
     Helsinki, FI     22.55 ms    0.0%    8670.66 Mbps   3366.03 Mbps   Elisa Oyj - Helsinki
     Stockholm, SE    29.52 ms    0.0%    8406.20 Mbps   2710.88 Mbps   i3D.net - Stockholm
     Oslo, NO         FAILED
     Moscow, RU       38.50 ms    0.0%    7430.31 Mbps   1559.01 Mbps   MTS - Moscow
     Petersburg, RU   31.04 ms    0.0%    8060.09 Mbps   1879.76 Mbps   MegaFon - Saint Petersburg
     Avg DL Speed       : 54192795464,50 Mbps
     Avg UL Speed       : 21039195727,94 Mbps
     Duration           : 7 min 36 sec
     System Time        : 14/04/2024 - 11:21:15 CEST
     Total Script Runs  : 40640
     Host               : DF Cloud
     ISP: dataforest
     Nearest          0.28 ms     0.0%    12746.05 Mbps  11487.41 Mbps  TCP-SYN - A part of RetardHub - Offenbach am Main
     London, UK       10.93 ms    0.0%    3993.46 Mbps   3373.82 Mbps   M247 Ltd - London
     Manchester, UK   20.20 ms    N/A     5290.37 Mbps   3727.47 Mbps   Vodafone UK - Manchester
     Dublin, IE       27.65 ms    0.0%    5757.06 Mbps   1746.32 Mbps   Three Ireland - Dublin
     Amsterdam, NL    6.61 ms     0.0%    8373.53 Mbps   9251.44 Mbps   Melbicom - Amsterdam
     Eygelshoen, NL   10.08 ms    0.0%    8519.40 Mbps   2583.67 Mbps   SkyLink Data Center BV - Eygelshoven
     Paris, FR        13.76 ms    N/A     7295.54 Mbps   3307.94 Mbps   ORANGE FRANCE - Paris
     Marseille, FR    16.07 ms    0.0%    6337.02 Mbps   4122.06 Mbps   GSL Networks - Marseille
     Madrid, ES       29.70 ms    0.0%    7565.46 Mbps   2451.60 Mbps   Orange - Madrid
     Barcelona, ES    25.82 ms    0.0%    5941.39 Mbps   3183.72 Mbps   Adamo - Barcelona
     Lisbon, PT       37.24 ms    0.0%    5902.80 Mbps   1472.50 Mbps   Edgoo Networks - Lisbon
     Rome, IT         24.86 ms    0.0%    6597.41 Mbps   2805.23 Mbps   TIM SpA - Rome
     Milan, IT        20.82 ms    0.0%    523.23 Mbps    1352.06 Mbps   Fastweb SpA - Milan
     Zurich, CH       9.29 ms     0.0%    4847.62 Mbps   2289.53 Mbps   Sunrise Communication AG - Zurich
     Frankfurt, DE    1.98 ms     23.9%   2667.96 Mbps   1869.41 Mbps   Deutsche Telekom - Frankfurt am Main
     Berlin, DE       11.46 ms    0.0%    7074.42 Mbps   1431.65 Mbps   Misaka Network, Inc. - Berlin
     Vienna, AT       13.94 ms    0.0%    7368.26 Mbps   2634.09 Mbps   A1 Telekom Austria AG - Vienna
     Budapest, HU     13.95 ms    0.0%    8036.96 Mbps   2042.00 Mbps   ATW Internet Kft. - Budapest
     Gdansk, PL       19.71 ms    0.0%    2996.73 Mbps   567.45 Mbps    T-Mobile Polska S.A. - Gdańsk
     Warsaw, PL       20.34 ms    0.0%    3172.48 Mbps   4280.77 Mbps   Orange Polska S.A. - Warsaw
     Lviv, UA         24.26 ms    0.0%    4588.44 Mbps   2128.87 Mbps   Kyivstar - Lviv
     Kyiv, UA         28.78 ms    0.0%    3297.76 Mbps   702.75 Mbps    O3 - Kyiv
     Minsk, BY        22.42 ms    0.0%    6058.73 Mbps   2536.33 Mbps   A1 - Minsk
     Bucharest, RO    27.53 ms    0.0%    2588.03 Mbps   2088.08 Mbps   Orange Romania SA - Bucuresti
     Timisoara, RO    30.40 ms    0.0%    8083.78 Mbps   3133.42 Mbps   Digi
     Helsinki, FI     22.57 ms    0.0%    8385.15 Mbps   3526.40 Mbps   Elisa Oyj - Helsinki
     Stockholm, SE    29.35 ms    0.0%    8339.67 Mbps   2900.76 Mbps   i3D.net - Stockholm
     Oslo, NO         FAILED
     Moscow, RU       38.40 ms    0.0%    6293.23 Mbps   2148.65 Mbps   MTS - Moscow
     Petersburg, RU   36.30 ms    0.0%    8080.54 Mbps   2515.68 Mbps   MegaFon - Saint Petersburg
     Avg DL Speed       : 6093.90 Mbps
     Avg UL Speed       : 3022.80 Mbps
     Total DL Data      : 244.17 GB
     Total UL Data      : 113.07 GB
     Total Data         : 357.24 GB
     Duration           : 12 min 45 sec
     System Time        : 14/04/2024 - 11:26:48 CEST
     Total Script Runs  : 40643
     ISP                : Clouvider Limited
     ASN                : AS62240 Clouvider
     Host               : Clouvider Limited
     ISP: Clouvider
     Nearest          0.60 ms     0.0%    6517.17 Mbps   7729.97 Mbps   23M GmbH - Frankfurt am Main
     London, UK       11.16 ms    0.0%    282.90 Mbps    5600.70 Mbps   M247 Ltd - London
     Manchester, UK   21.66 ms    N/A     4789.29 Mbps   4259.01 Mbps   Vodafone UK - Manchester
     Dublin, IE       24.35 ms    0.0%    3819.84 Mbps   3730.60 Mbps   Three Ireland - Dublin
     Amsterdam, NL    6.94 ms     N/A     5577.74 Mbps   2885.11 Mbps   Melbicom - Amsterdam
     Eygelshoen, NL   12.66 ms    0.0%    4858.51 Mbps   2922.83 Mbps   SkyLink Data Center BV - Eygelshoven
     Paris, FR        9.67 ms     N/A     5451.12 Mbps   7513.30 Mbps   ORANGE FRANCE - Paris
     Marseille, FR    16.22 ms    0.0%    4185.25 Mbps   4997.85 Mbps   GSL Networks - Marseille
     Madrid, ES       25.18 ms    0.0%    5091.51 Mbps   3742.65 Mbps   Orange - Madrid
     Barcelona, ES    23.49 ms    0.0%    3352.03 Mbps   1582.16 Mbps   Adamo - Barcelona
     Lisbon, PT       113.51 ms   0.0%    3396.61 Mbps   800.63 Mbps    Edgoo Networks - Lisbon
     Rome, IT         30.56 ms    0.0%    4356.18 Mbps   2708.42 Mbps   TIM SpA - Rome
     Milan, IT        16.47 ms    0.0%    4093.12 Mbps   4689.79 Mbps   Fastweb SpA - Milan
     Zurich, CH       9.17 ms     0.0%    5468.82 Mbps   4861.09 Mbps   Sunrise Communication AG - Zurich
     Frankfurt, DE    1.28 ms     23.0%   2317.32 Mbps   2592.36 Mbps   Deutsche Telekom - Frankfurt am Main
     Berlin, DE       9.87 ms     0.0%    4990.17 Mbps   782.70 Mbps    Misaka Network, Inc. - Berlin
     Vienna, AT       11.71 ms    0.0%    5454.01 Mbps   7093.56 Mbps   A1 Telekom Austria AG - Vienna
     Budapest, HU     13.90 ms    0.0%    5734.49 Mbps   1576.56 Mbps   ATW Internet Kft. - Budapest
     Gdansk, PL       41.26 ms    0.0%    1766.94 Mbps   930.30 Mbps    T-Mobile Polska S.A. - Gdańsk
     Warsaw, PL       19.10 ms    0.0%    3976.14 Mbps   4434.18 Mbps   Orange Polska S.A. - Warsaw
     Lviv, UA         26.49 ms    0.0%    4212.22 Mbps   1337.00 Mbps   Kyivstar - Lviv
     Kyiv, UA         27.40 ms    0.3%    3942.26 Mbps   683.01 Mbps    O3 - Kyiv
     Minsk, BY        22.05 ms    0.0%    4497.58 Mbps   2895.97 Mbps   A1 - Minsk
     Bucharest, RO    28.58 ms    0.0%    3844.61 Mbps   3072.90 Mbps   Orange Romania SA - Bucuresti
     Timisoara, RO    30.94 ms    0.0%    2754.43 Mbps   2956.88 Mbps   Digi
     Helsinki, FI     36.32 ms    0.0%    4308.18 Mbps   2430.74 Mbps   Elisa Oyj - Helsinki
     Stockholm, SE    29.18 ms    0.0%    3949.13 Mbps   2998.20 Mbps   i3D.net - Stockholm
     Oslo, NO         FAILED
     Moscow, RU       43.34 ms    0.0%    5526.30 Mbps   2147.03 Mbps   MTS - Moscow
     Petersburg, RU   32.26 ms    0.0%    4635.17 Mbps   2809.38 Mbps   MegaFon - Saint Petersburg
     Avg DL Speed       : 4246.48 Mbps
     Avg UL Speed       : 3336.72 Mbps
     Total DL Data      : 170.15 GB
     Total UL Data      : 119.70 GB
     Total Data         : 289.85 GB
     Duration           : 12 min 48 sec
     System Time        : 14/04/2024 - 11:27:05 CEST
     Total Script Runs  : 40644
    greencloud - supreme network!
     ISP                : 365 Online Technology Joint Stock Company
     ASN                : AS202602 365 Online Technology Joint Stock Company
     Host               : 365 Online Technology Joint Stock Company
     ISP: 365 Online Technology Joint Stock Company
     Nearest          0.47 ms     0.0%    9110.01 Mbps   9218.95 Mbps   ServerRoom.net - Amsterdam
     London, UK       7.10 ms     0.0%    9161.73 Mbps   7365.14 Mbps   M247 Ltd - London
     Manchester, UK   13.46 ms    N/A     7670.44 Mbps   5942.98 Mbps   Vodafone UK - Manchester
     Dublin, IE       13.32 ms    0.0%    8070.86 Mbps   6290.78 Mbps   Three Ireland - Dublin
     Amsterdam, NL    1.28 ms     0.0%    9207.84 Mbps   7027.01 Mbps   Melbicom - Amsterdam
     Eygelshoen, NL   5.05 ms     0.0%    8979.06 Mbps   7873.11 Mbps   SkyLink Data Center BV - Eygelshoven
     Paris, FR        8.58 ms     N/A     9225.39 Mbps   7756.99 Mbps   ORANGE FRANCE - Paris
     Marseille, FR    18.44 ms    0.0%    9178.37 Mbps   4855.42 Mbps   GSL Networks - Marseille
     Madrid, ES       28.47 ms    0.0%    7835.99 Mbps   3422.14 Mbps   Orange - Madrid
     Barcelona, ES    27.72 ms    0.0%    7294.94 Mbps   3121.36 Mbps   Adamo - Barcelona
     Lisbon, PT       32.31 ms    0.0%    8781.66 Mbps   2567.74 Mbps   Edgoo Networks - Lisbon
     Rome, IT         25.47 ms    0.0%    7550.13 Mbps   3407.71 Mbps   TIM SpA - Rome
     Milan, IT        15.58 ms    0.0%    7853.45 Mbps   4525.03 Mbps   Fastweb SpA - Milan
     Zurich, CH       17.85 ms    0.0%    9198.19 Mbps   3164.37 Mbps   Sunrise Communication AG - Zurich
     Frankfurt, DE    21.09 ms    26.4%   5223.22 Mbps   150.90 Mbps    Deutsche Telekom - Frankfurt am Main
     Berlin, DE       14.38 ms    0.0%    8523.11 Mbps   1070.61 Mbps   Misaka Network, Inc. - Berlin
     Vienna, AT       19.96 ms    0.0%    6840.52 Mbps   4390.64 Mbps   A1 Telekom Austria AG - Vienna
     Budapest, HU     21.84 ms    0.0%    8860.99 Mbps   1998.23 Mbps   ATW Internet Kft. - Budapest
     Gdansk, PL       53.45 ms    0.0%    2573.65 Mbps   1001.06 Mbps   T-Mobile Polska S.A. - Gdańsk
     Warsaw, PL       29.46 ms    0.0%    8798.47 Mbps   3012.64 Mbps   Orange Polska S.A. - Warsaw
     Lviv, UA         25.18 ms    0.0%    7229.68 Mbps   1715.88 Mbps   Kyivstar - Lviv
     Kyiv, UA         34.99 ms    0.0%    7346.96 Mbps   723.07 Mbps    O3 - Kyiv
     Minsk, BY        39.43 ms    0.0%    7974.22 Mbps   1986.30 Mbps   A1 - Minsk
     Bucharest, RO    34.88 ms    0.0%    7632.04 Mbps   2413.03 Mbps   Orange Romania SA - Bucuresti
     Timisoara, RO    43.33 ms    0.0%    9142.07 Mbps   3162.33 Mbps   Digi
     Helsinki, FI     23.06 ms    0.0%    9273.60 Mbps   3798.73 Mbps   Elisa Oyj - Helsinki
     Stockholm, SE    21.19 ms    0.0%    9224.80 Mbps   4070.27 Mbps   i3D.net - Stockholm
     Oslo, NO         FAILED
     Moscow, RU       43.20 ms    0.0%    7022.05 Mbps   841.14 Mbps    MTS - Moscow
     Petersburg, RU   36.33 ms    0.0%    8857.01 Mbps   2511.42 Mbps   MegaFon - Saint Petersburg
     Avg DL Speed       : 8056.55 Mbps
     Avg UL Speed       : 3771.86 Mbps
     Total DL Data      : 303.80 GB
     Total UL Data      : 116.39 GB
     Total Data         : 420.19 GB
     Duration           : 12 min 50 sec
     System Time        : 14/04/2024 - 11:27:27 CEST
     Total Script Runs  : 40647
     ISP                : Hetzner Online GmbH - HostBRR
     ASN                : AS24940 Hetzner Online GmbH
     ISP: Hetzner Online
     Nearest          3.34 ms     0.0%    903.76 Mbps    858.83 Mbps    Twerion.net | Minecraft Server - Frankfurt
     London, UK       17.60 ms    0.0%    920.18 Mbps    915.02 Mbps    M247 Ltd - London
     Manchester, UK   31.25 ms    N/A     914.97 Mbps    888.76 Mbps    Vodafone UK - Manchester
     Dublin, IE       26.37 ms    0.0%    949.31 Mbps    909.56 Mbps    Three Ireland - Dublin
     Amsterdam, NL    11.86 ms    0.0%    920.45 Mbps    228.44 Mbps    Melbicom - Amsterdam
     Eygelshoen, NL   FAILED
     Paris, FR        FAILED
     Madrid, ES       FAILED
     Lisbon, PT       FAILED
     Rome, IT         FAILED
     Milan, IT        FAILED
     Zurich, CH       FAILED
     Berlin, DE       FAILED
     Vienna, AT       FAILED
     Budapest, HU     FAILED
     Gdansk, PL       FAILED
     Warsaw, PL       FAILED
     Lviv, UA         FAILED
     Kyiv, UA         FAILED
     Minsk, BY        FAILED
     Timisoara, RO    FAILED
     Helsinki, FI     FAILED
     Stockholm, SE    FAILED
     Oslo, NO         FAILED
     Moscow, RU       FAILED
     Petersburg, RU   FAILED
     Avg DL Speed       : 921.73 Mbps
     Avg UL Speed       : 760.12 Mbps
     Total DL Data      : 5.10 GB
     Total UL Data      : 4.43 GB
     Total Data         : 9.52 GB
     Duration           : 3 min 36 sec
     System Time        : 14/04/2024 - 10:18:30 BST
     Total Script Runs  : 40638
     ISP                : ip-network
     ASN                : AS48314 Michael Sebastian Schinzel trading as IP-Projects GmbH & Co. KG - HostBRR
     ASN (IPv4)         : AS48314 Michael Sebastian Schinzel trading as IP-Projects GmbH & Co. KG
     Host               : HostBrr Solutions
     ISP: GHOSTnet
     Nearest          0.82 ms     0.0%    926.58 Mbps    938.46 Mbps    IP-Projects GmbH & Co. KG - Frankfurt
     London, UK       13.76 ms    0.0%    938.03 Mbps    904.07 Mbps    M247 Ltd - London
     Manchester, UK   18.84 ms    N/A     936.73 Mbps    929.06 Mbps    Vodafone UK - Manchester
     Dublin, IE       22.96 ms    0.0%    937.39 Mbps    925.10 Mbps    Three Ireland - Dublin
     Amsterdam, NL    8.05 ms     N/A     935.83 Mbps    227.39 Mbps    Melbicom - Amsterdam
     Eygelshoen, NL   19.52 ms    0.0%    936.86 Mbps    912.09 Mbps    SkyLink Data Center BV - Eygelshoven
     Paris, FR        12.84 ms    N/A     940.82 Mbps    928.17 Mbps    ORANGE FRANCE - Paris
     Marseille, FR    21.89 ms    0.0%    936.41 Mbps    923.25 Mbps    GSL Networks - Marseille
     Madrid, ES       31.27 ms    0.0%    942.82 Mbps    894.05 Mbps    Orange - Madrid
     Barcelona, ES    30.79 ms    0.0%    933.79 Mbps    906.15 Mbps    Adamo - Barcelona
     Lisbon, PT       111.82 ms   0.0%    938.49 Mbps    773.26 Mbps    Edgoo Networks - Lisbon
     Rome, IT         29.59 ms    0.0%    952.88 Mbps    895.05 Mbps    TIM SpA - Rome
     Milan, IT        19.65 ms    0.0%    959.08 Mbps    894.89 Mbps    Fastweb SpA - Milan
     Zurich, CH       9.95 ms     0.0%    932.09 Mbps    922.60 Mbps    Sunrise Communication AG - Zurich
     Frankfurt, DE    34.78 ms    20.3%   935.95 Mbps    763.99 Mbps    Deutsche Telekom - Frankfurt am Main
     Berlin, DE       12.76 ms    0.0%    934.62 Mbps    664.25 Mbps    Misaka Network, Inc. - Berlin
     Vienna, AT       32.61 ms    0.0%    940.40 Mbps    919.21 Mbps    A1 Telekom Austria AG - Vienna
     Budapest, HU     15.55 ms    0.0%    938.71 Mbps    706.53 Mbps    ATW Internet Kft. - Budapest
     Gdansk, PL       32.80 ms    0.0%    926.26 Mbps    595.17 Mbps    T-Mobile Polska S.A. - Gdańsk
     Warsaw, PL       23.63 ms    0.0%    939.60 Mbps    930.07 Mbps    Orange Polska S.A. - Warsaw
     Lviv, UA         29.04 ms    0.0%    945.86 Mbps    633.04 Mbps    Kyivstar - Lviv
     Kyiv, UA         40.71 ms    0.3%    509.04 Mbps    665.22 Mbps    O3 - Kyiv
     Minsk, BY        45.96 ms    0.0%    942.85 Mbps    786.90 Mbps    A1 - Minsk
     Bucharest, RO    42.20 ms    0.0%    941.34 Mbps    907.00 Mbps    Orange Romania SA - Bucuresti
     Timisoara, RO    19.12 ms    0.0%    936.82 Mbps    931.61 Mbps    Digi
     Helsinki, FI     30.02 ms    0.0%    939.97 Mbps    914.39 Mbps    Elisa Oyj - Helsinki
     Stockholm, SE    28.70 ms    0.0%    938.82 Mbps    920.47 Mbps    i3D.net - Stockholm
     Oslo, NO         FAILED
     Moscow, RU       46.31 ms    0.0%    931.03 Mbps    906.93 Mbps    MTS - Moscow
     Petersburg, RU   36.20 ms    0.0%    951.84 Mbps    892.92 Mbps    MegaFon - Saint Petersburg
     Avg DL Speed       : 924.17 Mbps
     Avg UL Speed       : 831.42 Mbps
     Total DL Data      : 33.99 GB
     Total UL Data      : 28.65 GB
     Total Data         : 62.64 GB
     Duration           : 11 min 33 sec
     System Time        : 14/04/2024 - 10:26:08 BST
     Total Script Runs  : 40642
     ISP                : ColocationX Ltd.
     ASN                : AS208046 ColocationX Ltd. - HostSlick
     Host               : ColocationX Ltd
     Location (IPv4)    : Amsterdam, North Holland, NL
     ISP: ColocationX
     Nearest          8.04 ms     N/A     835.28 Mbps    893.93 Mbps    SYNLINQ - Frankfurt am Main
     London, UK       7.74 ms     0.0%    873.02 Mbps    905.64 Mbps    M247 Ltd - London
     Manchester, UK   13.95 ms    N/A     686.96 Mbps    877.43 Mbps    Vodafone UK - Manchester
     Dublin, IE       15.01 ms    0.0%    938.37 Mbps    872.27 Mbps    Three Ireland - Dublin
     Amsterdam, NL    2.19 ms     0.0%    925.59 Mbps    451.30 Mbps    Melbicom - Amsterdam
     Eygelshoen, NL   4.78 ms     0.0%    896.90 Mbps    928.87 Mbps    SkyLink Data Center BV - Eygelshoven
     Paris, FR        17.10 ms    N/A     702.92 Mbps    915.37 Mbps    ORANGE FRANCE - Paris
     Marseille, FR    19.84 ms    0.0%    929.68 Mbps    804.13 Mbps    GSL Networks - Marseille
     Madrid, ES       38.13 ms    0.0%    953.56 Mbps    631.68 Mbps    Orange - Madrid
     Barcelona, ES    39.03 ms    0.0%    568.49 Mbps    855.99 Mbps    Adamo - Barcelona
     Lisbon, PT       35.11 ms    0.0%    524.63 Mbps    471.74 Mbps    Edgoo Networks - Lisbon
     Rome, IT         38.01 ms    0.5%    954.38 Mbps    573.33 Mbps    TIM SpA - Rome
     Milan, IT        17.07 ms    0.0%    572.41 Mbps    696.81 Mbps    Fastweb SpA - Milan
     Zurich, CH       16.77 ms    0.0%    637.75 Mbps    882.31 Mbps    Sunrise Communication AG - Zurich
     Berlin, DE       11.74 ms    N/A     851.13 Mbps    648.35 Mbps    Misaka Network, Inc. - Berlin
     Vienna, AT       22.57 ms    0.0%    850.83 Mbps    801.32 Mbps    A1 Telekom Austria AG - Vienna
     Budapest, HU     28.00 ms    0.0%    415.26 Mbps    801.86 Mbps    ATW Internet Kft. - Budapest
     Gdansk, PL       26.42 ms    0.0%    572.08 Mbps    635.47 Mbps    T-Mobile Polska S.A. - Gdańsk
     Warsaw, PL       29.35 ms    0.0%    697.40 Mbps    679.58 Mbps    Orange Polska S.A. - Warsaw
     Lviv, UA         37.32 ms    0.0%    912.70 Mbps    755.67 Mbps    Kyivstar - Lviv
     Kyiv, UA         36.48 ms    0.0%    634.19 Mbps    877.25 Mbps    O3 - Kyiv
     Minsk, BY        40.48 ms    0.0%    940.41 Mbps    552.31 Mbps    A1 - Minsk
     Bucharest, RO    39.26 ms    0.0%    515.28 Mbps    732.45 Mbps    Orange Romania SA - Bucuresti
     Timisoara, RO    29.95 ms    0.0%    869.06 Mbps    379.33 Mbps    Digi
     Helsinki, FI     26.53 ms    0.0%    769.08 Mbps    731.55 Mbps    Elisa Oyj - Helsinki
     Stockholm, SE    23.71 ms    0.0%    621.15 Mbps    721.72 Mbps    i3D.net - Stockholm
     Oslo, NO         FAILED
     Moscow, RU       45.79 ms    0.0%    954.84 Mbps    913.80 Mbps    MTS - Moscow
     Petersburg, RU   39.26 ms    0.0%    944.52 Mbps    792.07 Mbps    MegaFon - Saint Petersburg
     Avg DL Speed       : 769.57 Mbps
     Avg UL Speed       : 742.27 Mbps
     Total DL Data      : 27.34 GB
     Total UL Data      : 23.53 GB
     Total Data         : 50.88 GB
     Duration           : 10 min 51 sec
     System Time        : 14/04/2024 - 11:26:16 CEST
     Total Script Runs  : 40641
     ISP                : IONOS SE
     ASN                : AS8560 IONOS SE
     Host               : Strato AG
     ISP: 1&1 Internet AG
     Nearest          11.32 ms    0.0%    1219.29 Mbps   1796.17 Mbps   KRHS.de Krefeld - Frankfurt
     London, UK       25.00 ms    0.0%    2147.46 Mbps   1818.78 Mbps   M247 Ltd - London
     Manchester, UK   26.25 ms    N/A     2129.74 Mbps   1881.62 Mbps   Vodafone UK - Manchester
     Dublin, IE       31.39 ms    0.0%    1079.56 Mbps   1735.88 Mbps   Three Ireland - Dublin
     Amsterdam, NL    21.61 ms    0.0%    1310.55 Mbps   508.56 Mbps    Melbicom - Amsterdam
     Eygelshoen, NL   24.73 ms    0.0%    1587.63 Mbps   1272.77 Mbps   SkyLink Data Center BV - Eygelshoven
     Paris, FR        25.05 ms    N/A     2075.52 Mbps   1849.42 Mbps   ORANGE FRANCE - Paris
     Madrid, ES       47.33 ms    0.0%    1000.04 Mbps   1702.70 Mbps   Orange - Madrid
     Barcelona, ES    42.36 ms    0.0%    468.97 Mbps    1665.90 Mbps   Adamo - Barcelona
     Lisbon, PT       52.10 ms    0.0%    1644.00 Mbps   1597.15 Mbps   Edgoo Networks - Lisbon
     Rome, IT         30.99 ms    0.0%    1065.44 Mbps   1788.69 Mbps   TIM SpA - Rome
     Milan, IT        19.95 ms    0.0%    2010.56 Mbps   1814.41 Mbps   Fastweb SpA - Milan
     Zurich, CH       16.49 ms    0.0%    1930.01 Mbps   1843.38 Mbps   Sunrise Communication AG - Zurich
     Frankfurt, DE    9.66 ms     0.0%    1469.78 Mbps   1812.89 Mbps   Deutsche Telekom - Frankfurt am Main
     Berlin, DE       0.86 ms     N/A     2697.96 Mbps   823.96 Mbps    Misaka Network, Inc. - Berlin
     Vienna, AT       22.32 ms    0.0%    1700.67 Mbps   1863.38 Mbps   A1 Telekom Austria AG - Vienna
     Budapest, HU     22.97 ms    0.0%    2537.95 Mbps   1840.75 Mbps   ATW Internet Kft. - Budapest
     Gdansk, PL       40.44 ms    0.0%    1489.27 Mbps   1703.46 Mbps   T-Mobile Polska S.A. - Gdańsk
     Warsaw, PL       41.23 ms    0.0%    1667.07 Mbps   1786.87 Mbps   Orange Polska S.A. - Warsaw
     Lviv, UA         43.51 ms    0.0%    1136.04 Mbps   1596.18 Mbps   Kyivstar - Lviv
     Kyiv, UA         38.43 ms    0.0%    1010.59 Mbps   1706.65 Mbps   O3 - Kyiv
     Minsk, BY        25.09 ms    0.0%    1088.73 Mbps   1859.31 Mbps   A1 - Minsk
     Bucharest, RO    39.17 ms    0.0%    2248.11 Mbps   1785.67 Mbps   Orange Romania SA - Bucuresti
     Timisoara, RO    64.40 ms    0.0%    1326.49 Mbps   1585.85 Mbps   Digi
     Helsinki, FI     31.94 ms    0.0%    1894.34 Mbps   1798.22 Mbps   Elisa Oyj - Helsinki
     Stockholm, SE    44.91 ms    0.0%    1947.84 Mbps   1642.68 Mbps   i3D.net - Stockholm
     Oslo, NO         FAILED
     Moscow, RU       59.19 ms    0.0%    1192.04 Mbps   1378.17 Mbps   MTS - Moscow
     Petersburg, RU   50.62 ms    0.0%    1114.39 Mbps   1061.61 Mbps   MegaFon - Saint Petersburg
     Avg DL Speed       : 1578.21 Mbps
     Avg UL Speed       : 1625.76 Mbps
     Total DL Data      : 51.70 GB
     Total UL Data      : 59.01 GB
     Total Data         : 110.71 GB
     Duration           : 11 min 27 sec
     System Time        : 14/04/2024 - 09:27:13 UTC
     Total Script Runs  : 40646
     ISP                : IP Interactive
     ASN                : AS29551 Aixit GmbH - Layer7
     Host               : IP Interactive UG (haftungsbeschraenkt)
     ISP: Aixit
     Nearest          3.61 ms     0.0%    3953.74 Mbps   4926.14 Mbps   Netcom Kassel Gesellschaft für Telekommunikation mbH - Kassel
     London, UK       12.02 ms    0.0%    3993.57 Mbps   2018.38 Mbps   M247 Ltd - London
     Manchester, UK   18.75 ms    N/A     4207.98 Mbps   1340.09 Mbps   Vodafone UK - Manchester
     Dublin, IE       18.98 ms    0.0%    3673.67 Mbps   1512.87 Mbps   Three Ireland - Dublin
     Amsterdam, NL    7.09 ms     0.0%    3632.73 Mbps   3082.36 Mbps   Melbicom - Amsterdam
     Eygelshoen, NL   12.90 ms    0.0%    3504.83 Mbps   2349.50 Mbps   SkyLink Data Center BV - Eygelshoven
     Paris, FR        9.40 ms     N/A     2407.74 Mbps   1407.47 Mbps   ORANGE FRANCE - Paris
     Madrid, ES       29.68 ms    0.0%    3768.05 Mbps   948.91 Mbps    Orange - Madrid
     Barcelona, ES    35.33 ms    0.0%    2390.32 Mbps   882.63 Mbps    Adamo - Barcelona
     Lisbon, PT       110.27 ms   0.0%    2403.29 Mbps   392.59 Mbps    Edgoo Networks - Lisbon
     Rome, IT         22.96 ms    0.0%    3804.15 Mbps   1024.71 Mbps   TIM SpA - Rome
     Milan, IT        9.73 ms     0.0%    4208.25 Mbps   2054.11 Mbps   Fastweb SpA - Milan
     Zurich, CH       8.73 ms     0.0%    4123.68 Mbps   2501.14 Mbps   Sunrise Communication AG - Zurich
     Frankfurt, DE    0.90 ms     0.0%    4218.58 Mbps   4405.78 Mbps   Deutsche Telekom - Frankfurt am Main
     Berlin, DE       11.62 ms    0.0%    3899.29 Mbps   1487.74 Mbps   Misaka Network, Inc. - Berlin
     Vienna, AT       11.55 ms    0.0%    4012.79 Mbps   2361.21 Mbps   A1 Telekom Austria AG - Vienna
     Budapest, HU     14.22 ms    0.0%    4356.81 Mbps   1491.06 Mbps   ATW Internet Kft. - Budapest
     Gdansk, PL       20.03 ms    0.0%    3448.17 Mbps   1121.17 Mbps   T-Mobile Polska S.A. - Gdańsk
     Warsaw, PL       20.41 ms    0.0%    3850.58 Mbps   1539.03 Mbps   Orange Polska S.A. - Warsaw
     Lviv, UA         23.47 ms    0.3%    3667.91 Mbps   1106.57 Mbps   Kyivstar - Lviv
     Kyiv, UA         30.38 ms    0.0%    3738.80 Mbps   728.03 Mbps    O3 - Kyiv
     Minsk, BY        23.37 ms    0.0%    183.97 Mbps    1434.85 Mbps   A1 - Minsk
     Bucharest, RO    28.73 ms    0.0%    4044.37 Mbps   981.26 Mbps    Orange Romania SA - Bucuresti
     Timisoara, RO    24.75 ms    0.0%    3566.76 Mbps   1455.48 Mbps   Digi
     Helsinki, FI     26.49 ms    20.0%   2590.74 Mbps   107.95 Mbps    Elisa Oyj - Helsinki
     Stockholm, SE    24.38 ms    0.0%    4082.32 Mbps   916.45 Mbps    i3D.net - Stockholm
     Oslo, NO         FAILED
     Moscow, RU       37.85 ms    0.0%    3260.00 Mbps   826.22 Mbps    MTS - Moscow
     Petersburg, RU   31.81 ms    0.0%    3827.44 Mbps   935.66 Mbps    MegaFon - Saint Petersburg
     Avg DL Speed       : 3529.30 Mbps
     Avg UL Speed       : 1619.26 Mbps
     Total DL Data      : 123.68 GB
     Total UL Data      : 54.34 GB
     Total Data         : 178.02 GB
     Duration           : 11 min 11 sec
     System Time        : 14/04/2024 - 09:27:10 UTC
     Total Script Runs  : 40645
     ISP                : Hosting Bot, LLC
     ASN                : AS400402 Hosting Bot, LLC - Linveo
     ASN (IPv4)         : AS62564 LINVEO, LLC
     Host               : Hosting Bot, LLC
     ISP: EGIHosting
     Nearest          8.34 ms     0.0%    7283.81 Mbps   2399.93 Mbps   Cox - Wichita - Wichita, KS
     London, UK       114.10 ms   0.0%    1.21 Mbps      698.84 Mbps    M247 Ltd - London
     Manchester, UK   135.78 ms   N/A     409.34 Mbps    440.09 Mbps    Vodafone UK - Manchester
    Network error: Software caused connection abort
     ISP                : Ian David Klemm
     ASN                : AS200461 Ian David Klemm - v6node
     Host               : Ian David Klemm
     Location (IPv4)    : Frankfurt am Main, Hesse, DE
     ISP: combahton IT Services
     Nearest          4.27 ms     0.0%    778.72 Mbps    722.09 Mbps    Jonas de Vries
     London, UK       11.23 ms    0.0%    6636.07 Mbps   3179.66 Mbps   M247 Ltd - London
     Manchester, UK   20.28 ms    N/A     6720.64 Mbps   2070.34 Mbps   Vodafone UK - Manchester
     Dublin, IE       28.67 ms    0.0%    6387.33 Mbps   1299.89 Mbps   Three Ireland - Dublin
     Amsterdam, NL    6.92 ms     0.0%    6178.44 Mbps   4436.47 Mbps   Melbicom - Amsterdam
     Eygelshoen, NL   7.95 ms     0.6%    6724.10 Mbps   3061.14 Mbps   SkyLink Data Center BV - Eygelshoven
     Paris, FR        8.94 ms     N/A     2918.24 Mbps   864.69 Mbps    ORANGE FRANCE - Paris
     Madrid, ES       28.87 ms    0.0%    6136.78 Mbps   1239.85 Mbps   Orange - Madrid
     Barcelona, ES    30.80 ms    0.0%    5877.80 Mbps   1685.43 Mbps   Adamo - Barcelona
     Lisbon, PT       40.73 ms    0.0%    5737.40 Mbps   1369.17 Mbps   Edgoo Networks - Lisbon
     Rome, IT         28.62 ms    0.0%    6325.54 Mbps   1416.84 Mbps   TIM SpA - Rome
     Milan, IT        10.19 ms    0.0%    6358.33 Mbps   2736.72 Mbps   Fastweb SpA - Milan
     Zurich, CH       8.93 ms     0.0%    6749.82 Mbps   4086.78 Mbps   Sunrise Communication AG - Zurich
     Frankfurt, DE    1.37 ms     10.2%   5776.25 Mbps   3209.18 Mbps   Deutsche Telekom - Frankfurt am Main
     Berlin, DE       11.51 ms    0.0%    6163.28 Mbps   1993.57 Mbps   Misaka Network, Inc. - Berlin
     Vienna, AT       12.68 ms    0.0%    6388.18 Mbps   2794.22 Mbps   A1 Telekom Austria AG - Vienna
     Budapest, HU     14.05 ms    0.0%    6675.06 Mbps   2258.26 Mbps   ATW Internet Kft. - Budapest
     Gdansk, PL       20.23 ms    0.0%    3432.17 Mbps   1661.58 Mbps   T-Mobile Polska S.A. - Gdańsk
     Warsaw, PL       28.38 ms    0.0%    6180.64 Mbps   1136.38 Mbps   Orange Polska S.A. - Warsaw
     Lviv, UA         25.47 ms    0.0%    6615.85 Mbps   1740.11 Mbps   Kyivstar - Lviv
     Kyiv, UA         29.40 ms    0.0%    5552.14 Mbps   1205.23 Mbps   O3 - Kyiv
     Minsk, BY        FAILED
     Bucharest, RO    27.74 ms    0.0%    6093.80 Mbps   1562.35 Mbps   Orange Romania SA - Bucuresti
     Timisoara, RO    29.85 ms    0.0%    6158.35 Mbps   1616.01 Mbps   Digi
     Helsinki, FI     30.03 ms    0.0%    6816.96 Mbps   1327.56 Mbps   Elisa Oyj - Helsinki
     Stockholm, SE    28.11 ms    1.0%    6451.32 Mbps   1633.01 Mbps   i3D.net - Stockholm
     Oslo, NO         FAILED
     Moscow, RU       34.05 ms    0.0%    6148.26 Mbps   1304.24 Mbps   MTS - Moscow
     Petersburg, RU   33.10 ms    0.0%    5653.92 Mbps   1343.46 Mbps   MegaFon - Saint Petersburg
     Avg DL Speed       : 5838.33 Mbps
     Avg UL Speed       : 1961.27 Mbps
     Total DL Data      : 207.00 GB
     Total UL Data      : 74.78 GB
     Total Data         : 281.78 GB
     Duration           : 11 min 38 sec
     System Time        : 14/04/2024 - 09:28:06 UTC
     Total Script Runs  : 40648
     ISP                : xTom GmbH
     ASN                : AS3214 xTom GmbH
     Host               : xTom Customer - Frankfurt
     ISP: xTom
     Nearest          0.92 ms     N/A     1843.87 Mbps   1815.01 Mbps   Deutsche Glasfaser - Frankfurt
     London, UK       13.16 ms    0.0%    939.38 Mbps    870.32 Mbps    M247 Ltd - London
     Manchester, UK   18.98 ms    N/A     1798.19 Mbps   710.62 Mbps    Vodafone UK - Manchester
     Dublin, IE       29.06 ms    0.0%    1723.28 Mbps   1301.70 Mbps   Three Ireland - Dublin
     Amsterdam, NL    8.64 ms     0.0%    925.87 Mbps    1794.96 Mbps   Melbicom - Amsterdam
     Eygelshoen, NL   11.59 ms    0.0%    1825.04 Mbps   1607.87 Mbps   SkyLink Data Center BV - Eygelshoven
     Paris, FR        8.87 ms     N/A     1672.66 Mbps   787.67 Mbps    ORANGE FRANCE - Paris
     Madrid, ES       28.82 ms    0.0%    1831.48 Mbps   1520.70 Mbps   Orange - Madrid
     Barcelona, ES    30.98 ms    0.0%    1694.37 Mbps   632.94 Mbps    Adamo - Barcelona
     Lisbon, PT       40.05 ms    0.0%    1508.24 Mbps   1028.22 Mbps   Edgoo Networks - Lisbon
     Rome, IT         22.70 ms    0.0%    1861.59 Mbps   937.81 Mbps    TIM SpA - Rome
     Milan, IT        12.36 ms    0.0%    448.03 Mbps    1221.85 Mbps   Fastweb SpA - Milan
     Zurich, CH       11.03 ms    0.0%    933.22 Mbps    1794.78 Mbps   Sunrise Communication AG - Zurich
     Frankfurt, DE    20.34 ms    1.0%    1820.71 Mbps   1059.43 Mbps   Deutsche Telekom - Frankfurt am Main
     Berlin, DE       11.75 ms    N/A     1813.10 Mbps   916.61 Mbps    Misaka Network, Inc. - Berlin
     Vienna, AT       11.77 ms    0.0%    1850.45 Mbps   1806.26 Mbps   A1 Telekom Austria AG - Vienna
     Budapest, HU     14.37 ms    0.0%    1060.91 Mbps   1788.53 Mbps   ATW Internet Kft. - Budapest
     Gdansk, PL       45.37 ms    0.0%    1484.41 Mbps   557.63 Mbps    T-Mobile Polska S.A. - Gdańsk
     Warsaw, PL       19.71 ms    0.0%    1054.77 Mbps   1806.05 Mbps   Orange Polska S.A. - Warsaw
     Lviv, UA         28.42 ms    0.0%    1843.10 Mbps   1817.15 Mbps   Kyivstar - Lviv
     Kyiv, UA         27.80 ms    0.0%    1816.71 Mbps   1640.22 Mbps   O3 - Kyiv
     Minsk, BY        22.73 ms    0.0%    1853.22 Mbps   1584.36 Mbps   A1 - Minsk
     Bucharest, RO    29.01 ms    0.0%    1870.76 Mbps   1616.03 Mbps   Orange Romania SA - Bucuresti
     Timisoara, RO    27.83 ms    0.0%    1769.23 Mbps   1576.24 Mbps   Digi
     Helsinki, FI     22.63 ms    43.0%   1688.80 Mbps   62.99 Mbps     Elisa Oyj - Helsinki
     Stockholm, SE    29.01 ms    0.0%    1754.30 Mbps   1589.51 Mbps   i3D.net - Stockholm
     Oslo, NO         FAILED
     Moscow, RU       43.81 ms    0.0%    1588.65 Mbps   1346.64 Mbps   MTS - Moscow
     Petersburg, RU   41.22 ms    0.0%    1663.59 Mbps   1383.67 Mbps   MegaFon - Saint Petersburg
     Avg DL Speed       : 1569.21 Mbps
     Avg UL Speed       : 1306.27 Mbps
     Total DL Data      : 60.43 GB
     Total UL Data      : 43.53 GB
     Total Data         : 103.96 GB
     Duration           : 11 min 32 sec
     System Time        : 14/04/2024 - 05:28:14 EDT
     Total Script Runs  : 40649
  • Aéza LNDs-1 in London, United Kingdom 🇬🇧 for 8.51€/month.
    Test to Europe. (spoiler: 27Gbps :O)
    Spoiler
     Version            : v2024.04.14
     Basic System Info
     CPU Model          : AMD Ryzen 9 7950X3D 16-Core Processor
     CPU Cores          : 1 @ 4191.860 MHz
     CPU Cache          : 512 KB
     AES-NI             : ✔ Enabled
     VM-x/AMD-V         : ❌ Disabled
     Total Disk         : 29.4 GB (2.8 GB Used)
     Total RAM          : 1.9 GB (253.0 MB Used)
     Total Swap         : 512.0 MB (780.0 KB Used)
     Load average       : 0.00, 0.13, 0.19
     OS                 : Ubuntu 24.04 LTS
     Kernel             : 6.8.0-31-generic
     TCP Control        : bbr
     Basic Network Info
     ISP                : Aeza International LTD
     ASN                : AS210644 AEZA INTERNATIONAL LTD
     Host               : Aeza International LTD
     ISP: Aeza International
     Nearest          0.20 ms     0.0%    27891.14 Mbps  18874.47 Mbps  Aeza.net - London
     London, UK       10.79 ms    0.0%    2779.37 Mbps   7477.46 Mbps   M247 Ltd - London
     Manchester, UK   6.45 ms     N/A     9296.00 Mbps   9202.51 Mbps   Vodafone UK - Manchester
     Dublin, IE       10.70 ms    0.0%    9295.33 Mbps   7735.91 Mbps   Three Ireland - Dublin
     Amsterdam, NL    6.02 ms     0.0%    8666.46 Mbps   10388.04 Mbps  Melbicom - Amsterdam
     Eygelshoen, NL   11.75 ms    0.0%    11631.78 Mbps  2725.36 Mbps   SkyLink Data Center BV - Eygelshoven
     Paris, FR        7.82 ms     N/A     10265.42 Mbps  8889.48 Mbps   ORANGE FRANCE - Paris
     Madrid, ES       27.42 ms    0.0%    9734.06 Mbps   3077.65 Mbps   Orange - Madrid
     Barcelona, ES    27.85 ms    0.0%    7758.20 Mbps   2950.37 Mbps   Adamo - Barcelona
     Lisbon, PT       34.01 ms    0.0%    10507.48 Mbps  2361.54 Mbps   Edgoo Networks - Lisbon
     Rome, IT         34.50 ms    0.0%    8818.58 Mbps   2433.43 Mbps   TIM SpA - Rome
     Milan, IT        27.44 ms    0.0%    4388.42 Mbps   3017.06 Mbps   Fastweb SpA - Milan
     Zurich, CH       20.14 ms    0.0%    11161.08 Mbps  3982.62 Mbps   Sunrise Communication AG - Zurich
     Frankfurt, DE    12.69 ms    21.4%   6904.82 Mbps   3807.66 Mbps   Deutsche Telekom - Frankfurt am Main
     Berlin, DE       20.16 ms    0.0%    7167.54 Mbps   4060.86 Mbps   Misaka Network, Inc. - Berlin
     Vienna, AT       23.43 ms    0.0%    9285.30 Mbps   3511.45 Mbps   A1 Telekom Austria AG - Vienna
     Budapest, HU     26.42 ms    0.0%    12613.43 Mbps  3318.11 Mbps   ATW Internet Kft. - Budapest
     Gdansk, PL       31.95 ms    0.0%    4501.28 Mbps   2664.00 Mbps   T-Mobile Polska S.A. - Gdańsk
     Warsaw, PL       30.01 ms    0.0%    9124.60 Mbps   2720.15 Mbps   Orange Polska S.A. - Warsaw
     Lviv, UA         FAILED
     Kyiv, UA         42.67 ms    0.0%    8472.30 Mbps   1986.12 Mbps   O3 - Kyiv
     Bucharest, RO    44.37 ms    0.0%    11714.05 Mbps  1881.65 Mbps   Orange Romania SA - Bucuresti
     Timisoara, RO    40.60 ms    0.0%    9524.03 Mbps   1965.28 Mbps   Digi
     Helsinki, FI     34.71 ms    0.0%    10027.70 Mbps  2360.11 Mbps   Elisa Oyj - Helsinki
     Stockholm, SE    26.89 ms    0.0%    8149.80 Mbps   3114.97 Mbps   i3D.net - Stockholm
     Oslo, NO         26.15 ms    0.0%    3071.46 Mbps   3215.61 Mbps   Telia Norge AS - Oslo
     Moscow, RU       46.90 ms    0.0%    6483.29 Mbps   1749.81 Mbps   MTS - Moscow
     Petersburg, RU   39.39 ms    0.0%    8737.30 Mbps   2085.79 Mbps   MegaFon - Saint Petersburg
     Istanbul, TR     56.62 ms    N/A     7127.97 Mbps   1729.32 Mbps   Turkcell - Istanbul
     Avg DL Speed       : 9110.61 Mbps
     Avg UL Speed       : 4403.11 Mbps
     Total DL Data      : 312.50 GB
     Total UL Data      : 158.80 GB
     Total Data         : 471.30 GB
     Duration           : 11 min 35 sec
     System Time        : 26/04/2024 - 11:33:26 BST
     Total Script Runs  : 41684
     Result             : https://result.network-speed.xyz/r/1714127091_AK2YOV_EU.txt
    Thanked by (2)lapua sh97
  • DigiRDP India
     Basic System Info
     CPU Model          : AMD EPYC 7352 24-Core Processor
     CPU Cores          : 1 @ 2295.636 MHz
     CPU Cache          : 512 KB
     AES-NI             : ✔ Enabled
     Total Disk         : 29.4 GB (4.6 GB Used)
     Total RAM          : 1.9 GB (147.5 MB Used)
     System uptime      : 0 days, 3 hour 48 min
     OS                 : Ubuntu 22.04.4 LTS
     Kernel             : 5.15.0-105-generic
     TCP Control        : cubic
     Basic Network Info
     ISP                : ReadyDedis, LLC
     ASN                : AS140543 ReadyDedis, LLC
     Host               : Bconnect
     Location (IPv4)    : Hyderābād, Telangana, IN
     ISP: ReadyDedis
     Nearest          9.66 ms     N/A     716.34 Mbps    842.78 Mbps    Jio - Nagpur
     Tokyo, JP        126.84 ms   0.0%    557.35 Mbps    255.00 Mbps    Rakuten Mobile, Inc - Tokyo
     Tapei, TW        214.30 ms   N/A     550.11 Mbps    260.45 Mbps    Chunghwa Mobile - Taipei
     China Telecom    296.71 ms           3.36 Mbps      FAILED         China Telecom JiangSu 5G - Nanjing
     China Unicom     109.01 ms   1.3%    482.25 Mbps    539.32 Mbps    China Unicom 5G - Shanghai
     China Mobile     FAILED
     Hong Kong, CN    77.22 ms    0.0%    565.48 Mbps    771.53 Mbps    i3D.net - Hong Kong
     Ho Chi Minh, VN  72.38 ms    0.0%    763.06 Mbps    735.86 Mbps    VNPT-NET - Ho Chi Minh
     Hanoi, VN        82.08 ms    0.0%    921.33 Mbps    772.72 Mbps    FPT Telecom - Hanoi
     Bangkok, TH      69.83 ms    0.0%    547.52 Mbps    579.54 Mbps    3BB - Bangkok
     Manila, PH       91.45 ms    N/A     361.22 Mbps    738.38 Mbps    PLDT - Manila
     Singapore, SG    44.86 ms    0.0%    633.37 Mbps    807.49 Mbps    MyRepublic Singapore - Singapore
     Singapore, SG    47.55 ms    N/A     710.41 Mbps    785.13 Mbps    StarHub Ltd - Singapore
     Jakarta, ID      55.11 ms    0.0%    607.84 Mbps    696.99 Mbps    PT Indosat Tbk - Jakarta
     Surabaya, ID     69.37 ms    N/A     619.00 Mbps    748.17 Mbps    PT. Indonesia Comnets Plus - Surabaya
     Kuala Lum, MY    49.28 ms    0.5%    610.65 Mbps    785.15 Mbps    Telekom Malaysia Berhad - Kuala Lumpur
     Mumbai, IN       12.94 ms    0.0%    751.07 Mbps    844.44 Mbps    i3D.net - Mumbai
     Chennai, IN      12.19 ms    N/A     686.05 Mbps    830.10 Mbps    Jio - Chennai
     Bangalore, IN    29.72 ms    0.0%    687.24 Mbps    821.64 Mbps    Bharti Airtel Ltd - Bangalore
     Karachi, PK      289.61 ms   0.0%    26.09 Mbps     155.11 Mbps    JAZZ - Karachi
     Islamabad, PK    141.37 ms   4.3%    517.12 Mbps    605.92 Mbps    Ufone - Islamabad
     Kathmandu, NP    61.79 ms    1.1%    620.42 Mbps    832.22 Mbps    Ncell Axiata Ltd - Kathmandu
     Colombo, SL      170.15 ms   N/A     460.59 Mbps    448.50 Mbps    Airtel Lanka - Colombo
     Dhaka, BD        47.25 ms    N/A     514.17 Mbps    765.68 Mbps    Grameenphone Ltd - Dhaka
     Novosibirsk, RU  225.45 ms   3.0%    538.34 Mbps    4.19 Mbps      MegaFon - Novosibirsk
     Almaty, KZ       316.31 ms   0.0%    485.68 Mbps    250.95 Mbps    Kazakhtelecom - Almaty
     Tehran, IR       215.39 ms   5.3%    525.70 Mbps    293.47 Mbps    Irancell - Tehran
     Dubai, AE        63.01 ms    N/A     906.21 Mbps    249.11 Mbps    ETISALAT-UAE - Dubai
     Jeddah, SA       174.61 ms   0.3%    622.78 Mbps    491.77 Mbps    Mobily - Jeddah
     Istanbul, TR     175.96 ms   0.7%    696.53 Mbps    462.74 Mbps    Vodafone TR - Istanbul
     Avg DL Speed       : 575.42 Mbps
     Avg UL Speed       : 564.63 Mbps
     Total DL Data      : 21.86 GB
     Total UL Data      : 20.72 GB
     Total Data         : 42.59 GB
     Duration           : 14 min 15 sec
     System Time        : 29/04/2024 - 09:06:43 UTC
     Total Script Runs  : 41915
     Result             : https://result.network-speed.xyz/r/1714381064_C4NI9S_ASIA.txt
     Basic System Info
     CPU Cache          : 512 KB
     AES-NI             : ✔ Enabled
     Total RAM          : 1.9 GB (177.9 MB Used)
     System uptime      : 0 days, 2 hour 30 min
     TCP Control        : cubic
     Basic Network Info
     Host               : Bconnect
     ISP: ReadyDedis
     Nearest          10.20 ms    N/A     767.91 Mbps    842.65 Mbps    Jio - Nagpur
     Kochi, IN        24.93 ms    0.0%    581.83 Mbps    845.22 Mbps    Asianet Broadband - Cochin
     Bangalore, IN    27.07 ms    0.0%    442.09 Mbps    843.08 Mbps    Bharti Airtel Ltd - Bangalore
     Chennai, IN      12.81 ms    N/A     695.60 Mbps    849.70 Mbps    Jio - Chennai
     Mumbai, IN       12.00 ms    0.0%    619.91 Mbps    818.66 Mbps    i3D.net - Mumbai
     Delhi, IN        62.48 ms    0.0%    568.82 Mbps    448.45 Mbps    Tata Play Fiber - New Delhi
     Seattle, US      262.49 ms   N/A     528.48 Mbps    245.53 Mbps    Comcast - Seattle, WA
     Los Angeles, US  216.16 ms   0.0%    452.00 Mbps    350.25 Mbps    ReliableSite Hosting - Los Angeles, CA
     Dallas, US       241.83 ms   0.0%    405.79 Mbps    263.59 Mbps    Hivelocity - Dallas, TX
     Miami, US        260.78 ms   N/A     407.69 Mbps    326.69 Mbps    Dish Wireless - Miami, FL
     New York, US     233.60 ms   0.7%    872.12 Mbps    385.46 Mbps    GSL Networks - New York, NY
     Toronto, CA      252.55 ms   0.0%    559.24 Mbps    265.42 Mbps    Rogers - Toronto, ON
     Mexico City, MX  288.38 ms   N/A     426.64 Mbps    302.52 Mbps    INFINITUM - Mexico City
     London, UK       143.77 ms   0.0%    920.49 Mbps    575.53 Mbps    VeloxServ Communications - London
     Amsterdam, NL    132.30 ms   1.0%    915.31 Mbps    534.80 Mbps    31173 Services AB - Amsterdam
     Paris, FR        150.88 ms   N/A     903.51 Mbps    394.80 Mbps    Axione - Paris
     Frankfurt, DE    139.44 ms   3.5%    366.43 Mbps    399.05 Mbps    Clouvider Ltd - Frankfurt am Main
     Warsaw, PL       141.16 ms   0.3%    911.93 Mbps    540.87 Mbps    Play - Warszawa
     Bucharest, RO    165.83 ms   7.7%    512.53 Mbps    254.53 Mbps    Vodafone Romania Fixed – Bucharest - Bucharest
     Moscow, RU       166.61 ms   0.0%    742.89 Mbps    390.22 Mbps    MegaFon - Moscow
     Jeddah, SA       160.84 ms   1.0%    911.87 Mbps    308.01 Mbps    Saudi Telecom Company
     Dubai, AE        257.87 ms   0.7%    805.15 Mbps    322.87 Mbps    du - Dubai
     Fujairah, AE     62.49 ms    0.3%    927.10 Mbps    773.97 Mbps    ETISALAT-UAE - Fujairah
     Istanbul, TR     162.27 ms   7.7%    601.49 Mbps    529.17 Mbps    Turkcell - Istanbul
     Tehran, IR       222.89 ms   0.0%    429.13 Mbps    357.69 Mbps    Asiatech - Tehran
     Tokyo, JP        140.37 ms   N/A     634.07 Mbps    568.18 Mbps    fdcservers.net - Tokyo
     Shanghai, CU-CN  FAILED
     Nanjing, CT-CN   FAILED
     Hong Kong, CN    89.01 ms    N/A     583.54 Mbps    685.80 Mbps    STC - Hong Kong
     Singapore, SG    42.32 ms    0.5%    605.22 Mbps    764.97 Mbps    i3D.net - Singapore
     Jakarta, ID      FAILED - IP has been rate limited. Try again after 1 hour.
     Avg DL Speed       : 646.38 Mbps
     Avg UL Speed       : 506.71 Mbps
     Total DL Data      : 25.02 GB
     Total UL Data      : 18.43 GB
     Total Data         : 43.45 GB
     Duration           : 14 min 36 sec
     System Time        : 29/04/2024 - 07:49:35 UTC
     Total Script Runs  : 41912
     Result             : https://result.network-speed.xyz/r/1714376437_5WYBMV_GLOBAL.txt
  • ---------------------------- network-speed.xyz ----------------------------
          A simple script to test network performance using speedtest-cli
     Global Speedtest   : wget -qO- network-speed.xyz | bash
     Region Speedtest   : wget -qO- network-speed.xyz | bash -s -- -r
     Basic System Info
     CPU Model          : AMD EPYC 9374F 32-Core Processor
     CPU Cores          : 4 @ 3699.958 MHz
     CPU Cache          : 512 KB
     AES-NI             : ✔ Enabled
     VM-x/AMD-V         : ✔ Enabled
     Total Disk         : 49.1 GB (4.9 GB Used)
     Total RAM          : 15.6 GB (342.0 MB Used)
     Total Swap         : 1024.0 MB (0 Used)
     System uptime      : 0 days, 0 hour 16 min
     Load average       : 0.06, 0.33, 0.21
     Arch               : x86_64 (64 Bit)
     Kernel             : 6.1.0-20-amd64
     Virtualization     : KVM
     TCP Control        : cubic
     Basic Network Info
     Primary Network    : IPv6
     IPv6 Access        : ✔ Online
     IPv4 Access        : ✔ Online
     Host               : DF Cloud
     Location         Latency     Loss    DL Speed       UP Speed       Server
     ISP: dataforest
     Nearest          0.21 ms     0.0%    8758.48 Mbps   7594.46 Mbps   FynnCraft Minecraft Network - Dortmund
     London, UK       17.23 ms    0.0%    5.90 Mbps      3617.22 Mbps   M247 Ltd - London
     Manchester, UK   20.87 ms    N/A     9371.39 Mbps   1523.66 Mbps   Vodafone UK - Manchester
     Dublin, IE       27.47 ms    0.0%    7547.79 Mbps   1134.08 Mbps   Three Ireland - Dublin
     Amsterdam, NL    6.77 ms     0.0%    8382.05 Mbps   7690.21 Mbps   Melbicom - Amsterdam
     Eygelshoen, NL   10.45 ms    0.0%    8905.64 Mbps   1680.87 Mbps   SkyLink Data Center BV - Eygelshoven
     Paris, FR        8.84 ms     N/A     2013.15 Mbps   1439.09 Mbps   ORANGE FRANCE - Paris
     Madrid, ES       28.67 ms    0.0%    7531.00 Mbps   2423.23 Mbps   Orange - Madrid
     Barcelona, ES    29.81 ms    0.0%    9403.52 Mbps   1789.38 Mbps   Adamo - Barcelona
     Lisbon, PT       37.71 ms    0.0%    6062.01 Mbps   1982.42 Mbps   Edgoo Networks - Lisbon
     Rome, IT         21.39 ms    0.0%    7679.66 Mbps   2341.42 Mbps   TIM SpA - Rome
     Milan, IT        10.15 ms    0.0%    3058.32 Mbps   1599.70 Mbps   Fastweb SpA - Milan
     Zurich, CH       9.30 ms     0.0%    5826.14 Mbps   4411.60 Mbps   Sunrise Communication AG - Zurich
     Frankfurt, DE    0.90 ms     0.0%    6227.18 Mbps   3492.77 Mbps   Deutsche Telekom - Frankfurt am Main
     Berlin, DE       15.43 ms    0.0%    6917.74 Mbps   1524.23 Mbps   Misaka Network, Inc. - Berlin
     Vienna, AT       13.55 ms    0.0%    8883.91 Mbps   2143.01 Mbps   A1 Telekom Austria AG - Vienna
     Budapest, HU     14.06 ms    0.0%    6433.33 Mbps   2391.11 Mbps   ATW Internet Kft. - Budapest
     Gdansk, PL       19.99 ms    0.0%    3330.44 Mbps   3325.72 Mbps   T-Mobile Polska S.A. - Gdańsk
     Warsaw, PL       18.50 ms    0.0%    9389.85 Mbps   4362.70 Mbps   Orange Polska S.A. - Warsaw
     Lviv, UA         29.73 ms    0.0%    6822.90 Mbps   1089.00 Mbps   Kyivstar - Lviv
     Kyiv, UA         29.13 ms    0.0%    3018.08 Mbps   677.39 Mbps    O3 - Kyiv
     Bucharest, RO    33.81 ms    0.0%    2929.15 Mbps   1915.34 Mbps   Orange Romania SA - Bucuresti
     Timisoara, RO    30.35 ms    0.0%    7341.71 Mbps   3299.24 Mbps   Digi
     Helsinki, FI     22.68 ms    0.0%    8795.47 Mbps   3073.69 Mbps   Elisa Oyj - Helsinki
     Stockholm, SE    28.85 ms    0.0%    8871.80 Mbps   2375.37 Mbps   i3D.net - Stockholm
     Oslo, NO         22.26 ms    0.0%    7474.19 Mbps   3342.73 Mbps   Telia Norge AS - Oslo
     Moscow, RU       44.72 ms    0.0%    5488.78 Mbps   1862.47 Mbps   MTS - Moscow
     Petersburg, RU   35.56 ms    0.0%    8806.57 Mbps   2085.01 Mbps   MegaFon - Saint Petersburg
     Istanbul, TR     35.48 ms    0.0%    1648.08 Mbps   1435.84 Mbps   Turkcell - Istanbul
     Tbilisi, GE      62.56 ms    0.0%    9413.81 Mbps   1025.61 Mbps   Silknet JSC - Tbilisi
     Avg DL Speed       : 6544.60 Mbps
     Avg UL Speed       : 2621.62 Mbps
     Total DL Data      : 282.11 GB
     Total UL Data      : 89.41 GB
     Total Data         : 371.52 GB
     Duration           : 12 min 19 sec
     System Time        : 02/05/2024 - 21:05:34 CEST
     Total Script Runs  : 42300
    0.85€ JP
     Region Speedtest   : wget -qO- network-speed.xyz | bash -s -- -r <region>
     Basic System Info
     CPU Cores          : 1 @ 2794.750 MHz
     CPU Cache          : 512 KB
     AES-NI             : ✔ Enabled
     Total Disk         : 4.9 GB (1.9 GB Used)
     Total RAM          : 977.2 MB (139.1 MB Used)
     Total Swap         : 1024.0 MB (16.7 MB Used)
     System uptime      : 0 days, 1 hour 5 min
     Load average       : 0.00, 0.02, 0.15
     TCP Control        : bbr
     Basic Network Info
     ISP                : NPO G
     ASN                : AS51847 Nearoute Limited
     ASN (IPv4)         : AS61112 AKILE LTD
     Host               : NPO G
     Speedtest.net (Region: ASIA)
     ISP: Akile
     Nearest          1.82 ms     0.0%    500.63 Mbps    521.88 Mbps    サーバーならDDPS.jp - Tokyo
     Tokyo, JP        4.37 ms     0.0%    476.97 Mbps    520.92 Mbps    Rakuten Mobile, Inc - Tokyo
     Tapei, TW        35.44 ms    N/A     504.89 Mbps    524.75 Mbps    Chunghwa Mobile - Taipei
     China Telecom    234.06 ms   16.1%   5.50 Mbps      18.25 Mbps     China Telecom JiangSu 5G - Nanjing
     China Unicom     89.59 ms    0.4%    392.23 Mbps    421.26 Mbps    China Unicom 5G - Shanghai
     China Mobile     FAILED
     Hong Kong, CN    54.31 ms    0.0%    497.54 Mbps    508.03 Mbps    i3D.net - Hong Kong
     Ho Chi Minh, VN  95.09 ms    0.0%    496.60 Mbps    432.83 Mbps    VNPT-NET - Ho Chi Minh
     Hanoi, VN        73.78 ms    0.0%    501.38 Mbps    499.45 Mbps    FPT Telecom - Hanoi
     Bangkok, TH      92.36 ms    0.0%    500.97 Mbps    465.41 Mbps    3BB - Bangkok
     Manila, PH       78.37 ms    N/A     450.04 Mbps    480.61 Mbps    PLDT - Manila
     Singapore, SG    82.45 ms    0.0%    495.67 Mbps    449.53 Mbps    MyRepublic Singapore - Singapore
     Singapore, SG    98.65 ms    N/A     497.98 Mbps    451.17 Mbps    StarHub Ltd - Singapore
     Jakarta, ID      90.18 ms    0.0%    498.88 Mbps    407.47 Mbps    PT Indosat Tbk - Jakarta
     Surabaya, ID     88.14 ms    N/A     482.92 Mbps    444.30 Mbps    PT. Indonesia Comnets Plus - Surabaya
     Kuala Lum, MY    111.37 ms   0.0%    396.28 Mbps    416.37 Mbps    Telekom Malaysia Berhad - Kuala Lumpur
     Mumbai, IN       155.71 ms   0.0%    498.56 Mbps    362.17 Mbps    i3D.net - Mumbai
     Chennai, IN      393.26 ms   N/A     0.83 Mbps      147.50 Mbps    Jio - Chennai
     Bangalore, IN    274.28 ms   0.0%    1.23 Mbps      255.88 Mbps    Bharti Airtel Ltd - Bangalore
     Karachi, PK      280.72 ms   0.0%    1.17 Mbps      156.71 Mbps    JAZZ - Karachi
     Islamabad, PK    178.30 ms   0.0%    490.17 Mbps    416.21 Mbps    Ufone - Islamabad
     Kathmandu, NP    316.93 ms   0.0%    495.22 Mbps    299.96 Mbps    Ncell Axiata Ltd - Kathmandu
     Colombo, SL      145.10 ms   N/A     311.09 Mbps    367.67 Mbps    Airtel Lanka - Colombo
     Dhaka, BD        115.13 ms   N/A     503.17 Mbps    382.84 Mbps    Grameenphone Ltd - Dhaka
     Novosibirsk, RU  371.30 ms   15.2%   0.60 Mbps      38.27 Mbps     MegaFon - Novosibirsk
     Almaty, KZ       232.31 ms   2.3%    72.77 Mbps     186.08 Mbps    Kazakhtelecom - Almaty
     Tehran, IR       326.25 ms   0.0%    11.18 Mbps     235.95 Mbps    Irancell - Tehran
     Dubai, AE        255.26 ms   N/A     446.54 Mbps    63.72 Mbps     ETISALAT-UAE - Dubai
     Jeddah, SA       307.86 ms   0.0%    1.41 Mbps      184.89 Mbps    Mobily - Jeddah
     Istanbul, TR     290.08 ms   0.0%    476.37 Mbps    260.20 Mbps    Vodafone TR - Istanbul
     Avg DL Speed       : 345.13 Mbps
     Avg UL Speed       : 342.08 Mbps
     Total DL Data      : 13.91 GB
     Total UL Data      : 12.65 GB
     Total Data         : 26.56 GB
     Duration           : 14 min 33 sec
     System Time        : 03/05/2024 - 12:04:40 EDT
     Total Script Runs  : 42372
     Result             : https://result.network-speed.xyz/r/1714751703_HTABTN_ASIA.txt
    1.80€ UK
     Basic System Info
     CPU Model          : AMD Ryzen 9 7900 12-Core Processor
     CPU Cores          : 1 @ 3699.982 MHz
     CPU Cache          : 512 KB
     AES-NI             : ✔ Enabled
     Total Disk         : 9.8 GB (2.0 GB Used)
     Total RAM          : 977.2 MB (148.5 MB Used)
     System uptime      : 0 days, 0 hour 42 min
     Load average       : 0.00, 0.00, 0.06
     OS                 : Debian GNU/Linux 12
     TCP Control        : bbr
     Basic Network Info
     ISP                : GCI Network Solutions Limited
     ASN                : AS8851 GCI Network Solutions Limited
     Host               : GCI Network Solutions Limited
     Speedtest.net (Region: EUROPE)
     ISP: GCI Network Solutions
     Nearest          3.73 ms     N/A     500.81 Mbps    522.49 Mbps    YouFibre - London
     London, UK       10.78 ms    0.0%    500.83 Mbps    522.50 Mbps    M247 Ltd - London
     Manchester, UK   13.09 ms    N/A     501.39 Mbps    522.91 Mbps    Vodafone UK - Manchester
     Dublin, IE       17.37 ms    0.0%    506.54 Mbps    522.63 Mbps    Three Ireland - Dublin
     Amsterdam, NL    10.45 ms    N/A     501.33 Mbps    136.56 Mbps    Melbicom - Amsterdam
     Eygelshoen, NL   14.50 ms    0.0%    500.20 Mbps    523.64 Mbps    SkyLink Data Center BV - Eygelshoven
     Paris, FR        10.95 ms    N/A     496.39 Mbps    523.16 Mbps    ORANGE FRANCE - Paris
     Madrid, ES       30.77 ms    0.0%    522.44 Mbps    525.19 Mbps    Orange - Madrid
     Barcelona, ES    30.77 ms    0.0%    513.00 Mbps    523.91 Mbps    Adamo - Barcelona
     Lisbon, PT       36.13 ms    0.0%    503.71 Mbps    523.80 Mbps    Edgoo Networks - Lisbon
     Rome, IT         34.94 ms    0.0%    522.21 Mbps    526.69 Mbps    TIM SpA - Rome
     Milan, IT        25.48 ms    0.0%    505.28 Mbps    522.77 Mbps    Fastweb SpA - Milan
     Zurich, CH       23.04 ms    0.0%    501.77 Mbps    523.34 Mbps    Sunrise Communication AG - Zurich
     Frankfurt, DE    29.72 ms    0.0%    504.04 Mbps    521.51 Mbps    Deutsche Telekom - Frankfurt am Main
     Berlin, DE       28.67 ms    N/A     500.95 Mbps    390.55 Mbps    Misaka Network, Inc. - Berlin
     Vienna, AT       28.91 ms    0.0%    501.99 Mbps    523.54 Mbps    A1 Telekom Austria AG - Vienna
     Budapest, HU     32.84 ms    0.0%    500.26 Mbps    522.49 Mbps    ATW Internet Kft. - Budapest
     Gdansk, PL       62.56 ms    0.0%    502.47 Mbps    514.54 Mbps    T-Mobile Polska S.A. - Gdańsk
     Warsaw, PL       34.14 ms    0.0%    503.87 Mbps    515.73 Mbps    Orange Polska S.A. - Warsaw
     Lviv, UA         42.68 ms    0.0%    506.95 Mbps    514.91 Mbps    Kyivstar - Lviv
     Kyiv, UA         43.03 ms    0.0%    504.84 Mbps    511.82 Mbps    O3 - Kyiv
     Bucharest, RO    41.68 ms    0.0%    502.34 Mbps    522.11 Mbps    Orange Romania SA - Bucuresti
     Timisoara, RO    47.35 ms    0.0%    506.74 Mbps    519.45 Mbps    Digi
     Helsinki, FI     39.12 ms    0.0%    503.13 Mbps    519.33 Mbps    Elisa Oyj - Helsinki
     Stockholm, SE    34.02 ms    0.0%    504.57 Mbps    522.66 Mbps    i3D.net - Stockholm
     Oslo, NO         29.11 ms    0.0%    504.42 Mbps    521.22 Mbps    Telia Norge AS - Oslo
     Moscow, RU       53.51 ms    0.0%    518.55 Mbps    517.20 Mbps    MTS - Moscow
     Petersburg, RU   44.90 ms    0.0%    516.10 Mbps    523.20 Mbps    MegaFon - Saint Petersburg
     Istanbul, TR     52.16 ms    0.0%    513.76 Mbps    527.31 Mbps    Turkcell - Istanbul
     Tbilisi, GE      80.66 ms    0.0%    514.05 Mbps    477.32 Mbps    Silknet JSC - Tbilisi
     Avg DL Speed       : 506.16 Mbps
     Avg UL Speed       : 502.81 Mbps
     Total DL Data      : 18.18 GB
     Total UL Data      : 17.67 GB
     Total Data         : 35.85 GB
     System Time        : 03/05/2024 - 12:02:00 EDT
     Total Script Runs  : 42369
     Result             : https://result.network-speed.xyz/r/1714751543_JA3V8K_EU.txt
  • Inception Hosting NL-SSD-KVM-2048
     Basic System Info
     CPU Model          : Intel(R) Xeon(R) E-2278G CPU @ 3.40GHz
     CPU Cores          : 2 @ 3408.032 MHz
     CPU Cache          : 16384 KB
     AES-NI             : ✔ Enabled
     Total Disk         : 29.8 GB (1.5 GB Used)
     Total RAM          : 1.9 GB (73.7 MB Used)
     System uptime      : 0 days, 0 hour 51 min
     Load average       : 0.29, 0.78, 0.60
     OS                 : Debian GNU/Linux 11
     TCP Control        : cubic
     Basic Network Info
     Host               : Inception
     ISP: Clouvider Limited
     Nearest          0.42 ms     0.0%    6513.56 Mbps   5683.13 Mbps   Clouvider Ltd - Amsterdam
     Kochi, IN        160.74 ms   0.0%    2761.20 Mbps   246.22 Mbps    Asianet Broadband - Cochin
     Bangalore, IN    148.12 ms   0.0%    3240.58 Mbps   146.43 Mbps    Bharti Airtel Ltd - Bangalore
     Chennai, IN      141.73 ms   N/A     3425.86 Mbps   5.66 Mbps      Jio - Chennai
     Mumbai, IN       129.97 ms   0.0%    2845.33 Mbps   345.25 Mbps    i3D.net - Mumbai
     Delhi, IN        168.47 ms   0.0%    3904.20 Mbps   313.44 Mbps    Tata Play Fiber - New Delhi
     Seattle, US      141.28 ms   N/A     2593.06 Mbps   294.97 Mbps    Comcast - Seattle, WA
     Los Angeles, US  135.10 ms   0.0%    2958.21 Mbps   376.52 Mbps    ReliableSite Hosting - Los Angeles, CA
     Dallas, US       109.90 ms   0.0%    1686.83 Mbps   277.66 Mbps    Hivelocity - Dallas, TX
     Miami, US        112.15 ms   N/A     1569.53 Mbps   216.10 Mbps    Dish Wireless - Miami, FL
     New York, US     72.02 ms    0.0%    4677.23 Mbps   109.17 Mbps    GSL Networks - New York, NY
     Toronto, CA      91.85 ms    0.0%    1477.65 Mbps   248.16 Mbps    Rogers - Toronto, ON
     Mexico City, MX  153.45 ms   N/A     2426.51 Mbps   268.53 Mbps    INFINITUM - Mexico City
     London, UK       5.83 ms     0.4%    6413.49 Mbps   880.24 Mbps    VeloxServ Communications - London
     Amsterdam, NL    1.06 ms     0.0%    4597.49 Mbps   2975.38 Mbps   31173 Services AB - Amsterdam
     Paris, FR        11.13 ms    N/A     7960.83 Mbps   495.50 Mbps    Axione - Paris
     Frankfurt, DE    5.94 ms     0.0%    3046.94 Mbps   848.35 Mbps    Clouvider Ltd - Frankfurt am Main
     Warsaw, PL       21.83 ms    4.3%    6112.54 Mbps   324.05 Mbps    Play - Warszawa
     Bucharest, RO    34.37 ms    0.0%    2192.63 Mbps   243.62 Mbps    Vodafone Romania Fixed – Bucharest - Bucharest
     Moscow, RU       39.39 ms    0.0%    3479.42 Mbps   449.07 Mbps    MegaFon - Moscow
     Jeddah, SA       68.27 ms    1.0%    4528.93 Mbps   331.86 Mbps    Saudi Telecom Company
     Dubai, AE        121.91 ms   0.0%    3105.98 Mbps   290.87 Mbps    du - Dubai
     Fujairah, AE     113.27 ms   0.0%    3574.67 Mbps   212.00 Mbps    ETISALAT-UAE - Fujairah
     Istanbul, TR     44.45 ms    0.0%    3288.14 Mbps   335.60 Mbps    Turkcell - Istanbul
     Tehran, IR       85.20 ms    0.0%    2044.27 Mbps   170.84 Mbps    Asiatech - Tehran
     Tokyo, JP        259.34 ms   N/A     266.84 Mbps    60.10 Mbps     fdcservers.net - Tokyo
     Shanghai, CU-CN  237.67 ms   0.0%    1206.60 Mbps   192.25 Mbps    China Unicom 5G - Shanghai
     Nanjing, CT-CN   429.82 ms   7.7%    1615.36 Mbps   0.72 Mbps      China Telecom JiangSu 5G - Nanjing
     Hong Kong, CN    181.06 ms   N/A     2685.02 Mbps   83.91 Mbps     STC - Hong Kong
     Singapore, SG    331.01 ms   3.0%    2389.45 Mbps   120.71 Mbps    i3D.net - Singapore
     Avg DL Speed       : 3286.27 Mbps
     Avg UL Speed       : 551.54 Mbps
     Total DL Data      : 139.31 GB
     Total UL Data      : 26.41 GB
     Total Data         : 165.72 GB
     Duration           : 15 min 45 sec
     System Time        : 04/05/2024 - 14:34:34 UTC
     Total Script Runs  : 42450
     curl is not installed, Unable to share result online
     Result stored locally in /root/network-speed.txt
    Hello world.
  • HYBULA NL to ASIA
    pretty strange UP speed tho.
     Basic System Info
     CPU Model          : AMD EPYC 9554 64-Core Processor
     CPU Cores          : 2 @ 3099.998 MHz
     CPU Cache          : 1024 KB
     AES-NI             : ✔ Enabled
     Total Disk         : 22.6 GB (5.5 GB Used)
     Total RAM          : 1.9 GB (574.0 MB Used)
     Total Swap         : 1.9 GB (170.4 MB Used)
     System uptime      : 3 days, 23 hour 40 min
     Load average       : 0.00, 0.00, 0.00
     TCP Control        : cubic
     Basic Network Info
     ISP                : Hybula B.V.
     ASN                : AS35133 Hybula B.V.
     Host               : Hybula B.V
     ISP: Hybula B.V.
     Nearest          0.59 ms     0.0%    942.91 Mbps    992.03 Mbps    Odido - Amsterdam
     Tokyo, JP        250.62 ms   0.0%    838.04 Mbps    280.69 Mbps    Rakuten Mobile, Inc - Tokyo
     Tapei, TW        265.79 ms   N/A     722.10 Mbps    359.07 Mbps    Chunghwa Mobile - Taipei
     China Telecom    147.81 ms   0.0%    795.61 Mbps    201.19 Mbps    China Telecom JiangSu 5G - Nanjing
     China Unicom     190.83 ms   0.0%    745.78 Mbps    516.73 Mbps    China Unicom 5G - Shanghai
     China Mobile     FAILED
     Hong Kong, CN    293.87 ms   9.5%    752.13 Mbps    0.77 Mbps      i3D.net - Hong Kong
     Ho Chi Minh, VN  237.61 ms   1.7%    600.03 Mbps    134.32 Mbps    VNPT-NET - Ho Chi Minh
     Hanoi, VN        389.12 ms   26.3%   732.46 Mbps    0.50 Mbps      FPT Telecom - Hanoi
     Bangkok, TH      212.66 ms   0.0%    853.28 Mbps    430.81 Mbps    3BB - Bangkok
     Manila, PH       322.71 ms   N/A     713.44 Mbps    0.72 Mbps      PLDT - Manila
     Singapore, SG    292.06 ms   0.0%    610.99 Mbps    6.88 Mbps      MyRepublic Singapore - Singapore
     Singapore, SG    294.90 ms   N/A     670.03 Mbps    383.85 Mbps    StarHub Ltd - Singapore
     Jakarta, ID      322.33 ms   16.7%   373.83 Mbps    0.31 Mbps      PT Indosat Tbk - Jakarta
     Surabaya, ID     282.32 ms   N/A     568.84 Mbps    306.39 Mbps    PT. Indonesia Comnets Plus - Surabaya
     Kuala Lum, MY    245.53 ms   0.0%    612.25 Mbps    329.60 Mbps    Telekom Malaysia Berhad - Kuala Lumpur
     Mumbai, IN       140.28 ms   0.0%    745.02 Mbps    567.89 Mbps    i3D.net - Mumbai
     Chennai, IN      163.21 ms   N/A     928.61 Mbps    625.44 Mbps    Jio - Chennai
     Bangalore, IN    289.61 ms   29.3%   788.86 Mbps    1.62 Mbps      Bharti Airtel Ltd - Bangalore
     Karachi, PK      284.31 ms   0.3%    206.18 Mbps    88.82 Mbps     JAZZ - Karachi
     Islamabad, PK    302.93 ms   7.3%    637.45 Mbps    1.25 Mbps      Ufone - Islamabad
     Kathmandu, NP    181.43 ms   0.0%    667.06 Mbps    425.54 Mbps    Ncell Axiata Ltd - Kathmandu
     Colombo, SL      239.50 ms   N/A     764.08 Mbps    0.76 Mbps      Airtel Lanka - Colombo
     Dhaka, BD        402.52 ms   N/A     10.92 Mbps     0.55 Mbps      Grameenphone Ltd - Dhaka
     Novosibirsk, RU  85.77 ms    0.0%    942.71 Mbps    1054.95 Mbps   MegaFon - Novosibirsk
     Almaty, KZ       95.35 ms    0.0%    956.07 Mbps    577.49 Mbps    Kazakhtelecom - Almaty
     Tehran, IR       94.05 ms    9.9%    954.73 Mbps    369.74 Mbps    Irancell - Tehran
     Dubai, AE        115.80 ms   N/A     989.60 Mbps    630.48 Mbps    ETISALAT-UAE - Dubai
     Jeddah, SA       74.23 ms    0.0%    957.30 Mbps    1098.50 Mbps   Mobily - Jeddah
     Istanbul, TR     44.58 ms    0.0%    919.23 Mbps    985.27 Mbps    Vodafone TR - Istanbul
     Avg DL Speed       : 724.12 Mbps
     Avg UL Speed       : 357.66 Mbps
     Total DL Data      : 28.71 GB
     Total UL Data      : 16.72 GB
     Total Data         : 45.43 GB
     Duration           : 16 min 8 sec
     System Time        : 05/05/2024 - 12:07:20 EDT
     Total Script Runs  : 42533
     Result             : https://result.network-speed.xyz/r/1714924645_TFQGRT_ASIA.txt
