Test | Value
Single Core | 983
Multi Core | 3089
Full Test | https://browser.geekbench.com/v6/cpu/5821615
Someone smarter than me please interpret them. 🤓
I am no way smarter than you. I am just putting my thoughts (worth 1.99 cents, not even 2 cents)
Assuming cpu vCore resources are allocated 25-30% FUP, it is a pretty powerful VPS
And @Advin Servers are stable, high performance and excellent support
This VPS is strong enough for Windows RDP as well.
1 AMD EPYC vCORE
2Gb DDR4 RAM
30GB NVMe Raid 1
1.5Tb Monthly Bandwidth
Hyderabad India DC
rDNS/PTR option
Linux OS , Windows on request
Port 25 Blocked
Zero Abuse Tolerance
MS said:
DigiRDP - Hyderabad, India - $15.12 Annually.
1 AMD EPYC vCORE
2Gb DDR4 RAM
30GB NVMe Raid 1
Hyderabad India DC
rDNS/PTR option
Port 25 Blocked
Why does your plan come with 2GB? Mine comes with just 1GB.... @DigiRDP
And double disk space... plus 500GB more bandwidth. I paid exactly the same, plan name are the same as well?
LunaNode 3.5$/m
ServerStatus , slackvpn , linux mirrors
Recommended Providers: Servarica(aff) | HostBRR(aff) | SolidVPS(aff) | RackNerd(aff) | KuroIT(aff) | AlphaVPS(aff) | HostDare(aff)
Crunchbits 1.5GB Yearly PA - 11.69$/yr
https://akile.net/shop/server
99¥/y / 12€/y SG DEAL
VirMach: Customer’s Service cannot use more than 10% of the monthly allocated bandwidth in under twenty-four (24) hours.
https://virmach.com/terms-conditions/#aup
Virmach LAX - $11/yr
new beast!
109¥/y / 14€/y Akile
Nvidia Jetson Nano
Nvidia Jetson AGX Orin
Virmach after migration to AMSD031T36
Provider: Layer7
Package: Mid CPU 3Cores-16GB-120GB FRA1
Price: € 3,91 / month
c1vhosting 10 Euro/year flash
Wed Apr 17 01:39:10 UTC 2024 Basic System Information: --------------------------------- Uptime : 0 days, 8 hours, 46 minutes Processor : Intel(R) Xeon(R) CPU E5-2697A v4 @ 2.60GHz CPU cores : 2 @ 2596.990 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ✔ Enabled RAM : 7.6 GiB Swap : 0.0 KiB Disk : 68.8 GiB Distro : Debian GNU/Linux 12 (bookworm) Kernel : 6.1.0-13-amd64 VM Type : KVM IPv4/IPv6 : ✔ Online / ✔ Online IPv6 Network Information: --------------------------------- ISP : Cinzia Tocci trading as C1V ASN : AS212271 Cinzia Tocci trading as C1V Host : C1V Hosting Location : Milan, Lombardy (25) Country : Italy fio Disk Speed Tests (Mixed R/W 50/50) (Partition /dev/sda1): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 41.07 MB/s (10.2k) | 426.25 MB/s (6.6k) Write | 41.15 MB/s (10.2k) | 428.50 MB/s (6.6k) Total | 82.22 MB/s (20.5k) | 854.75 MB/s (13.3k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 736.43 MB/s (1.4k) | 656.81 MB/s (641) Write | 775.56 MB/s (1.5k) | 700.56 MB/s (684) Total | 1.51 GB/s (2.9k) | 1.35 GB/s (1.3k) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | Ping ----- | ----- | ---- | ---- | ---- Clouvider | London, UK (10G) | busy | 578 Mbits/sec | 36.2 ms Eranium | Amsterdam, NL (10G) | 421 Mbits/sec | 547 Mbits/sec | 31.6 ms Telia | Helsinki, FI (10G) | busy | busy | 53.5 ms Uztelecom | Tashkent, UZ (10G) | 296 Mbits/sec | 915 Mbits/sec | 116 ms Leaseweb | Singapore, SG (10G) | busy | busy | 164 ms Clouvider | Los Angeles, CA, US (10G) | busy | busy | 166 ms Leaseweb | NYC, NY, US (10G) | busy | 843 Mbits/sec | 94.6 ms Edgoo | Sao Paulo, BR (1G) | busy | 339 Mbits/sec | 203 ms iperf3 Network Speed Tests (IPv6): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | Ping ----- | ----- | ---- | ---- | ---- Clouvider | London, UK (10G) | 376 Mbits/sec | 945 Mbits/sec | 36.1 ms Eranium | Amsterdam, NL (10G) | 398 Mbits/sec | 941 Mbits/sec | 31.5 ms Uztelecom | Tashkent, UZ (10G) | 299 Mbits/sec | busy | 116 ms Leaseweb | Singapore, SG (10G) | 54.0 Mbits/sec | 732 Mbits/sec | -- Clouvider | Los Angeles, CA, US (10G) | 324 Mbits/sec | 837 Mbits/sec | 166 ms Leaseweb | NYC, NY, US (10G) | 239 Mbits/sec | 800 Mbits/sec | 94.6 ms Edgoo | Sao Paulo, BR (1G) | 190 Mbits/sec | 806 Mbits/sec | 203 ms Geekbench 6 Benchmark Test: --------------------------------- Test | Value | Single Core | 282 Multi Core | 622 Full Test | https://browser.geekbench.com/v6/cpu/5748114 YABS completed in 35 min 39 sec Edit: A second YABS run gave better Scores for single core but lower for multi Geekbench 6 Benchmark Test: --------------------------------- Test | Value | Single Core | 494 Multi Core | 558 Full Test | https://browser.geekbench.com/v6/cpu/5748485blog | exploring visually |
OWN.TN UY-VM 3G hosted in Uruguay 🇺🇾.
Hosted under the ASN of the biggest ISP in Uruguay 🇺🇾, residential IP.
OWN.TN KZ-VM 3G hosted in Pavlodar, Kazakhstan 🇰🇿
Hosted under the ASN of the biggest ISP in Kazakhstan 🇰🇿, residential IP.
Advin Servers KVM Standard XS
AMD EPYC CPU (4 vCores)
0 dedicated, 4 burstable cores
8GB DDR4 ECC Memory
60GB NVMe SSD Storage
2TB Bandwidth (10 Gbps)
Los Angeles
$6.99/month
It's pronounced hacker.
@LowHosting
Awesome. Thank you so much!
GreenCloudVPS 9999 / KVM / 5 CPU / 9GB RAM / 99GB NVMe / 9TB BW / 99 USD triennially / San Jose
It works well except IPv6.
Aéza LNDs-1 in London, United Kingdom 🇬🇧 for 8.51€/month.
Such a beast for the price tbh
This plan was offered as Flash Sale.
Ah, clear. Thanks
@Hosteroid London, United Kingdom 🇬🇧
Bucharest, Romania 🇷🇴
HostHatch old deal in Singapore 🇸🇬
