Seeking Free cPanel Alternatives for WordPress Hosting
Hello
I’m reaching out to seek your advice on finding a reliable, free alternative to cPanel for hosting WordPress websites. I've been using HestiaCP, but I find that it requires a lot of manual setup for each site, especially since SSL isn’t enabled by default. As someone who spins up dozens of sites a week, the current setup process has become too time-consuming and is slowing down my workflow.
Could anyone recommend a control panel solution that is:
Free
WordPress-friendly
Capable of quick, automated setups – particularly for enabling SSL certificates right from the get-go
My main goal is to dramatically reduce the time it takes to launch new sites, aiming for a more efficient and less labor-intensive process.
Your suggestions and insights based on your experiences would be incredibly valuable to me.
Thank you so much in advance for your help!
  • edited April 11
    Would CloudPanel or ISPConfig work for you?
  • edited April 12
    Should Enhance work for you? It isn't free though but might worth give it a try.
  • Search is your friend. About two or three weeks ago, similar question was asked, plenty of good responses were posted.
    Squats are the new Push-ups
  • edited April 12
  • I have good experience with Fastpanel but I have never tried running Wordpress in it.
    But it is supported according to documentation.
    https://kb.fastpanel.direct/sites/how-to-create-a-wordpress-based-site/
    CloudPanel is just what I need, thank you!
    Much better than hestia for my use case
    Thanked by (1)Joseph
    please tell us more about your experience of using CloudPanel in a couple of days,
    i had use hestia in the past (it was good btw) & never had a chance of using CloudPanel.
    really appreciate if you can give comparison between them
  • Free
    WordPress-friendly
    https://wordops.net/
    Wordops. It automates your wp installs and is highly configurable. With one command I can spin up a new wp instance. No GUI though. If all you're doing is WP this is your best bet.
