Super cheap dedicated servers
Go to: https://oneprovider.com/search
As you can see, they are offering dedicated servers at unbelievably low prices. Yes, the specs sucks and no ipv6 support, but this still cheaper then most dedicated servers I've seen around.
So what are some of the other cheap but reliable dedicated server providers?
Please ignore all atom or x86 processors as well as ARM processors. Dedicated servers preferred cause I like it. No other reason.
Minimum specs is:
4 core w/ 8 threads CPU
16 GB ram ddr
64 GB SSD + 1TB HDD
1 ipv4 ( + /64 ipv6 preffered)
1gbps network w/ 5TB bandwidth
IPMI or any automated/free OS reinstall
99.9% uptime SLA
I have not set a budget as I'll compare the prices offered with that on the link I posted above and choose accordingly.
Usecase is receiving emails or creating temp email service + hosting personal sites. Do not need outgoing email ip/port unblocked as I use third party email relay server to send emails.
I know our LES members are always on the hunt for a good deal so feel free to response with any good deals you have seen around.
OP is just a reseller, most of the stuff is more expensive.
Kimsufi still has the cheapest dedi deals.
KS-LE, nothing beats that.
Next would be prob. Hetzner.
Some old hardware, not sure if it's worth it:
https://www.wholesaleinternet.net/dedicated/
https://www.nocix.net/dedicated/
https://www.ikoula.com/en/dedicated-server
If not x86 nor ARM, do you only require RISC-V?
Guessing he's distinguishing x86 from x86-64
Have you seen any 32-bit-only x86 dedicated servers being offered? In the past 15 years?
As already mentioned One Provider is just a reseller of various well-known providers while the actual provider behind each offer is not always obvious to see. If in doubt you can open a ticket and ask before buying.
The OVH boxes like Kimsufi are often easy to spot based on their specs.
Most offers in Paris or Amsterdam with unmetered traffic are just Online.net/Scaleway with mixed network quality.
Recently I grabbed a 30 EUR dedi in Amsterdam with a certain amount of traffic included which surprisingly popped up in Leaseweb's datacenter delivering excellent network connectivity.
Support is simply forwarding tickets between you and the actual provider which introduces some delay but my last two tickets regarding IPv6 and IPMI have been fully answered within 24h.
One should know what you are actually buying with One Provider, but I would say they are within realistic expectations and sometimes there are some decent deals around like those 30'ish Leaseweb dedis.
Thank you all for responding. I knew I could count on you guys to help me find a good deal!
That's what @Not_Oles mentioned. Unfortunately I do not know who they are reselling for. If possible, I would go directly to the source instead of going to the reseller for more money. That's why If you do know who they are reselling for, let me know.
Thank you! I'll take a look.
Yes.
x86 = 32 bit CPU (usually intel atom based or extreamly old hardwares)
ARM = ARM, Ampere, RISC-V and all that.
I should have mentioned that I am only looking for x86_64 CPU, intel or AMD based...
Yes, I have seem a few Intel Atom offerings with only 32 bit CPUs. VERY old hardwares...
Aren't OVH's Kimsufi servers difficult to use as they do not have a proper OS installer (read somewhere on the internet).
I had used Leaseweb in the past. Very good service, but the prices seem higher then that on the oneprovider's website.
My bad. I thought the Core2Duo/Opterons were the switch over point. I never bought anything between like early Pentium 4 and my AMD 8320. ;-)
After looking around (and spending money here and there), still looking for a good cheap server.
At least have finalized on what I want.
Old Xeon CPU
16 GB RAM
US West location (better peering with Singapore)
256 GB SSD
Price around $30 USD
Everything else is flexible requirement.
Also realized that Europe is a REALLY bad option for people in SG...
Can @crunchbits hook you up with something?
ECC?
DDR3 okay?
Network connection speed?
Bandwidth?
Could you share a server with one or with just a few guys? What do you want to run?
That's not "super cheap", super would be sub-$10, which are indeed a rarity.
Optional as my servers are all double backed up and all deployed apps are dockerized for easy/fast deployment.
Yep, that what my current server is anyway.
100+ Mbps is fine.
I cant even hit 1 TB bandwidth on my servers as of now....
I usually have the dedi to myself. I usually run ubuntu 22.04 (or latest LTS release). If the host do not provide the latest release, I usually upgrade it myself from whatever version is available. Failing that, I'm fine with debian as well.
I had a $10 dedi, but their price is now $12 due to inflation and increased running costs. That's my primary backup server. My current in-use dedi with oneprovider is $17 per month. I got a new one recently for month at $32 but that's in europe with bad peering so wont continue with it....
Just checked and https://oneprovider.com/configure/dediconf/6914 still seems available. Fails your specs cuz no SSD. This also used to be listed for $18.00 on the Psychz website at https://www.psychz.net/dashboard/client/web/order/special-dedicated-servers#.
CPU: Intel Xeon E3-1230 v2 3.3GHz 4c/8t
PassMark Benchmark: 6202
RAM:16 GB DDR3
Bandwidth: Unmetered @ 1 Gbps
Base IP Amount: 1
Price: + $17.99 /mo
Setup Fees: + $0.00
IPMI: Generic + $0.00 /mo
Main Storage: 1x 1 TB (HDD SATA) + $0.00 /mo
Quantity: x 1
Billing Cycle: Monthly
Sub Total: + $17.99
Ugh. Kimsufi with the 100 Mbps network.
That's the one I've got now from oneprovider.
Anyone know if Kimsufi got US based DC with automated OS installer or IPMI or something similar?
Where did you get that 10$ dedi lol?
Mentally strong people use MIPS.
vps9hostname is available. affbrrI got it from https://colohouse.com/ (previously turnkeyinternet.net) during their 2019 black friday sale.
But I dont have enough pushups. I mean I can max give 5 if I really try, then be unable to use my arms for the next 5 days!
I have this one for personal use, it costs me 23.99€ /mo
Xeon E3 1231v3 4 Core 3.30 Ghz
32GB RAM
2x480GB SSD
1Gbps Uplink Unlimited
PERC Controller RAID
KVM Console
Basic System Information: --------------------------------- Uptime : 0 days, 0 hours, 7 minutes Processor : Intel(R) Xeon(R) CPU E3-1231 v3 @ 3.40GHz CPU cores : 8 @ 800.000 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ✔ Enabled RAM : 31.1 GiB Swap : 4.0 GiB Disk : 434.9 GiB Distro : Ubuntu 22.04.4 LTS Kernel : 5.15.0-107-generic VM Type : NONE IPv4/IPv6 : ✔ Online / ❌ Offline IPv4 Network Information: --------------------------------- ISP : Seflow S.N.C. Di Marco Brame' \u0026 C. ASN : AS49367 Seflow s.r.l. Host : Seflow Dedicated Location : Arezzo, Tuscany (52) Country : Italy fio Disk Speed Tests (Mixed R/W 50/50) (Partition /dev/mapper/ubuntu--vg-ubuntu--lv): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 66.77 MB/s (16.6k) | 146.55 MB/s (2.2k) Write | 66.91 MB/s (16.7k) | 147.32 MB/s (2.3k) Total | 133.68 MB/s (33.4k) | 293.88 MB/s (4.5k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 203.57 MB/s (397) | 221.61 MB/s (216) Write | 214.39 MB/s (418) | 236.37 MB/s (230) Total | 417.96 MB/s (815) | 457.99 MB/s (446) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | Ping ----- | ----- | ---- | ---- | ---- Clouvider | London, UK (10G) | 921 Mbits/sec | 539 Mbits/sec | 33.4 ms Eranium | Amsterdam, NL (100G) | 925 Mbits/sec | 924 Mbits/sec | 30.1 ms Telia | Helsinki, FI (10G) | busy | busy | 43.2 ms Uztelecom | Tashkent, UZ (10G) | 880 Mbits/sec | 469 Mbits/sec | 97.0 ms Leaseweb | Singapore, SG (10G) | 437 Mbits/sec | 285 Mbits/sec | 307 ms Clouvider | Los Angeles, CA, US (10G) | 799 Mbits/sec | 198 Mbits/sec | 174 ms Leaseweb | NYC, NY, US (10G) | 861 Mbits/sec | 524 Mbits/sec | 101 ms Edgoo | Sao Paulo, BR (1G) | 693 Mbits/sec | 166 Mbits/sec | 209 ms Geekbench 6 Benchmark Test: --------------------------------- Test | Value | Single Core | 1275 Multi Core | 4177 Full Test | https://browser.geekbench.com/v6/cpu/6380796Amadex • Hosting Forums • Wie ist meine IP-Adresse? • AS215325
Yea, europe location got a lot of good servers. Issue is Singapore has very bad peering with europe region
Checkout heymman Kansas, they got a nice dedi for 29$
I have this available in the Netherlands instantly:
1 x Xeon E5-2630L v2
6/12 Cores/Threads
Starting 16 GB DDR3 RAM (Can be upgraded)
Starting 240 GB SSD Storage (Can be upgraded)
Starting 100 Mbit Unmetered Bandwidth (~33 TB, can be upgraded)
1 x IPv4 IP Address
DDoS Protection Included Network
Monthly Cost: $28/mo.
Order Link: Here
Hong Kong, United Kingdom, The Netherlands, Lithuania, Switzerland VPS / Dedicated Servers - DDoS Protected, 1 / 10 Gbit Unmetered, NAT and more
We have Cheap Dedicated Servers, of course nothing like OVH / Hetzner, but you can check our Dedicated Servers and take a look as alternative.
For such who looks for dedicated servers below 30€ monthly
https://alexhost.com/dedicated-servers/
Anything just contact our support.
24h delivery time of dedicated servers due to manual installation.
Best Regards,
Alexhost
As per my personal experience, for cheaper & best options please visit https://www.thewebhostingdir.com/dedicated-servers. There, you can find a list of the best cheap dedicated hosting providers and select the one that best suits your needs.
We have some relatively cheap ones available as well if you're interested: https://www.millenial.host/portal/store/dedicated-servers
All are configurable, and we're able to customise them a little further too if needed e.g. adding HDD's in.
Is US Central okay? I can offer this for $30/mo if you can do 150GB SSD. We use E5v3 and DDR4.
Check out Civilized Hosting!
Web Hosting, VPS Servers, Dedicated Servers, Colocation, IP Transit, IP Subnets, and more!
Requesting mods to close this thread.
Closed at OP request
