Super cheap dedicated servers
Go to: https://oneprovider.com/search
As you can see, they are offering dedicated servers at unbelievably low prices. Yes, the specs sucks and no ipv6 support, but this still cheaper then most dedicated servers I've seen around.
So what are some of the other cheap but reliable dedicated server providers?
Please ignore all atom or x86 processors as well as ARM processors. Dedicated servers preferred cause I like it. No other reason.
Minimum specs is:
4 core w/ 8 threads CPU
16 GB ram ddr
64 GB SSD + 1TB HDD
1 ipv4 ( + /64 ipv6 preffered)
1gbps network w/ 5TB bandwidth
IPMI or any automated/free OS reinstall
99.9% uptime SLA
I have not set a budget as I'll compare the prices offered with that on the link I posted above and choose accordingly.
Usecase is receiving emails or creating temp email service + hosting personal sites. Do not need outgoing email ip/port unblocked as I use third party email relay server to send emails.
I know our LES members are always on the hunt for a good deal so feel free to response with any good deals you have seen around.
OP is just a reseller, most of the stuff is more expensive.
Kimsufi still has the cheapest dedi deals.
KS-LE, nothing beats that.
Next would be prob. Hetzner.
Some old hardware, not sure if it's worth it:
https://www.wholesaleinternet.net/dedicated/
https://www.nocix.net/dedicated/
https://www.ikoula.com/en/dedicated-server
If not x86 nor ARM, do you only require RISC-V?
Guessing he's distinguishing x86 from x86-64
Have you seen any 32-bit-only x86 dedicated servers being offered? In the past 15 years?
As already mentioned One Provider is just a reseller of various well-known providers while the actual provider behind each offer is not always obvious to see. If in doubt you can open a ticket and ask before buying.
The OVH boxes like Kimsufi are often easy to spot based on their specs.
Most offers in Paris or Amsterdam with unmetered traffic are just Online.net/Scaleway with mixed network quality.
Recently I grabbed a 30 EUR dedi in Amsterdam with a certain amount of traffic included which surprisingly popped up in Leaseweb's datacenter delivering excellent network connectivity.
Support is simply forwarding tickets between you and the actual provider which introduces some delay but my last two tickets regarding IPv6 and IPMI have been fully answered within 24h.
One should know what you are actually buying with One Provider, but I would say they are within realistic expectations and sometimes there are some decent deals around like those 30'ish Leaseweb dedis.
Thank you all for responding. I knew I could count on you guys to help me find a good deal!
That's what @Not_Oles mentioned. Unfortunately I do not know who they are reselling for. If possible, I would go directly to the source instead of going to the reseller for more money. That's why If you do know who they are reselling for, let me know.
Thank you! I'll take a look.
Yes.
x86 = 32 bit CPU (usually intel atom based or extreamly old hardwares)
ARM = ARM, Ampere, RISC-V and all that.
I should have mentioned that I am only looking for x86_64 CPU, intel or AMD based...
Yes, I have seem a few Intel Atom offerings with only 32 bit CPUs. VERY old hardwares...
Aren't OVH's Kimsufi servers difficult to use as they do not have a proper OS installer (read somewhere on the internet).
I had used Leaseweb in the past. Very good service, but the prices seem higher then that on the oneprovider's website.
My bad. I thought the Core2Duo/Opterons were the switch over point. I never bought anything between like early Pentium 4 and my AMD 8320. ;-)
After looking around (and spending money here and there), still looking for a good cheap server.
At least have finalized on what I want.
Old Xeon CPU
16 GB RAM
US West location (better peering with Singapore)
256 GB SSD
Price around $30 USD
Everything else is flexible requirement.
Also realized that Europe is a REALLY bad option for people in SG...
Can @crunchbits hook you up with something?
ECC?
DDR3 okay?
Network connection speed?
Bandwidth?
Could you share a server with one or with just a few guys? What do you want to run?
That's not "super cheap", super would be sub-$10, which are indeed a rarity.
Optional as my servers are all double backed up and all deployed apps are dockerized for easy/fast deployment.
Yep, that what my current server is anyway.
100+ Mbps is fine.
I cant even hit 1 TB bandwidth on my servers as of now....
I usually have the dedi to myself. I usually run ubuntu 22.04 (or latest LTS release). If the host do not provide the latest release, I usually upgrade it myself from whatever version is available. Failing that, I'm fine with debian as well.
I had a $10 dedi, but their price is now $12 due to inflation and increased running costs. That's my primary backup server. My current in-use dedi with oneprovider is $17 per month. I got a new one recently for month at $32 but that's in europe with bad peering so wont continue with it....
Just checked and https://oneprovider.com/configure/dediconf/6914 still seems available. Fails your specs cuz no SSD. This also used to be listed for $18.00 on the Psychz website at https://www.psychz.net/dashboard/client/web/order/special-dedicated-servers#.
CPU: Intel Xeon E3-1230 v2 3.3GHz 4c/8t
PassMark Benchmark: 6202
RAM:16 GB DDR3
Bandwidth: Unmetered @ 1 Gbps
Base IP Amount: 1
Price: + $17.99 /mo
Setup Fees: + $0.00
IPMI: Generic + $0.00 /mo
Main Storage: 1x 1 TB (HDD SATA) + $0.00 /mo
Quantity: x 1
Billing Cycle: Monthly
Sub Total: + $17.99
Ugh. Kimsufi with the 100 Mbps network.
That's the one I've got now from oneprovider.
Anyone know if Kimsufi got US based DC with automated OS installer or IPMI or something similar?
