IncogNET allows Tor exit, see policy: https://incognet.io/tor-exits
$9/month for 1GB RAM and 10TB traffic.
Realistically you won't run out of traffic.
To qualify for an onion shirt, you are looking at $27.
[SE] https://keff.org/ (free speech, dmca and pretty much everything ignored unless coming from Swedish court)
[RO] https://cockbox.org/ (free speech, dmca and pretty much everything ignored unless coming from Seychelles/Romanian court, reported poor node performance - so be aware)
[CH] https://privatealps.net/ (free speech, dmca and pretty much everything ignored unless highly illegal)
[SHIT TON LOC] @HostZea10t - https://www.hostzealot.com/ (free speech)
[UA] @UrDN - https://www.urdn.com.ua (free speech, dmca and much ignored unless highly illegal/illegal in Ukraine)
[MY] https://www.shinjiru.com/ (free speech, dmca and much ignored unless highly illegal/illegal in Malaysia)
[UA/NL] @vsys_host - https://vsys.host/ (free speech, dmca and much ignored unless highly illegal/illegal in Ukraine)
[PL] https://hosteam.pl/ (no crypto payments , mixed node performance, everything is forwarded but they wont suspend you if you reply to them and no Court order comes to them directly(Poland))
[NL/HK] @KoDDoS - https://koddos.net/ (expensive, free speech, dmca and pretty much everything ignored unless coming from Hong Kong court)
[PL] @Mevspace - https://mevspace.com (everything is forwarded but they wont suspend you if you reply to them and no Court order comes to them directly(Poland))
[SE] @swedendedicated - https://swedendedicated.com/ - (could give you a good offer, free speech, dmca and much ignored unless highly illegal/illegal in Sweden)
[NL] @dmzhost - https://dmzhost.co (free speech, dmca and pretty much everything ignored unless coming from Dutch court)
[UA/DE] @hostiko - https://hostiko.com.ua/ (takes care of abuse reports in most cases)
[NL] @HostSlick - https://hostslick.com/ (free speech, dmca and much ignored unless highly illegal/illegal in Netherlands)
[CH/NL] https://nicevps.net/ (free speech, dmca and pretty much everything ignored unless coming from Dominican court)
[NO/NL/USA] @terrahost - https://terrahost.com/ (free speech, much ignored unless highly illegal/illegal in Norway)
[SHIT TON LOC] @M247sales / @m247paul - https://vps247.com/ (could give you a good offer, forwards everything)
These new Cheap VPS boxes from VSYS would be nice for it too, but sadly no crypto payment for them.
They got 200Mbps 95th each I believe on 1Gbps port.
8 GB Ram DDr4 ECC
4 Dedicated CPU (Intel® Xeon® Gold 6138)
Nested Virtualization Enabled
100 GB SSD SAS RAID 10
rDNS/PTR Record (Ticket for request)
16 TB Bandwidth/month
Romania/Hunedoara/Orastie Location
1 Gbps speed
Port 25 open permanently
99.97% Uptime
1 Dedicated IPv4
KVM VIrtualization
Upload own ISO
Linux or Windows
Seedbox Allow
Allow plex or others
Public torrents Allow
ADULT Websites Allow
Web 3.0 / Free Speech Allow
TOR EXIT ALLOW
vsys.host, confirmed by their support, allows tor exit nodes and tor as a whole (though not sure if outside UA).
I've been using them for a few months, have been working flawlessly. Not a single minute of downtime and their antiddos is actually quite good.
We can do TOR Exit on some VPS, but you will need to contact us first. It's only supported in some locations and IP ranges due to laws and agreements that we have from IP vendors that we lease from.
Sure can you list me a couple of plans i can choose from. As i am only going to run tor i don’t really need much cpu, ram etc
Any plan from our site is honestly fine. I believe that our Los Angeles KVM Standard XS at $6.99/month with 5TB bandwidth would be the most cost effective, but it comes with 8GB RAM and 4 vCPU. There could be cheaper hosts out there, though
...is flokinet-powered. this circumstance is a total exclusion criterion for me. and in my opinion can never be recommended.
It used to be M247 from what I remember, as i said, the list is old. If its Flokinet/Voxility now, then it sucks.
Their Moldova location is Alexhost(Voxility and RETN).
From what I recall @PulsedMedia was Pro-Tor(please correct me if I'm wrong) so their extremely affordable dedis would work for a Relay or even an Exit.
https://pulsedmedia.com/minidedi-dedicated-servers-finland.php 20 eur for i5 with 1Gbps unmetered dedicated, similar to what you were able to get on Terrahost dedicated servers blackfriday deals.
Since Tor is still single-threaded, it would allow you to run several Exit's using the same IP(it works just fine, you just have to use a different inbound port) and utilize all this bandwidth and cpu
@c4tdrx said:
Tor does not need much ram, cpu or storage just bandwith so dedis arent really needed
Most hosts that allow TOR exits don't allow them on their VPS lineup. Sure, some do let you run TOR relays but not TOR exits. However there are some hosts that will let you run TOR exits if, and only if, you purchase a dedicated server.
So if you're looking for help with something in the future, I'd suggest thanking someone for trying to help you instead of telling someone you know better. If you knew better, you wouldn't be here.
rdp.sh, terrahost(dedicated), buyvm are all unmetered and allow Tor exits.
vps9
hostname is available. affbrr[SE] https://keff.org/ (free speech, dmca and pretty much everything ignored unless coming from Swedish court)
https://incognet.io/ (Relay, Exit, Crypto)
https://keff.org/ (Relay, Exit, Crypto)
https://cockbox.org/ (Relay, Exit, Crypto)
https://privatealps.net/ (privatelayer partner) (Relay, Exit, Crypto)
https://vsys.host/ (Relay, Exit, Crypto)
https://hosteam.pl/ (Relay, Exit)
https://koddos.net/ (Relay, Exit, Crypto)
https://mevspace.com (Relay, Exit, Crypto)
https://hostiko.com.ua/ (Relay, Exit, Crypto)
https://hostslick.com/ (Relay, Exit, Crypto)
https://nicevps.net/ (Relay, Exit, Crypto)
https://svea.net/ (Relay, Exit, Crypto)
https://rdp.sh/ (Relay, Exit, Crypto)
https://liteserver.nl/ (Relay, Exit, Crypto)
https://crunchbits.com/ (Relay, Exit?, Crypto)
https://swedendedicated.com/ (Relay, Exit, Crypto)
https://spectraip.net/ (Relay, Exit, Crypto)
https://hostslim.nl/ (Relay, Exit, Crypto)
https://www.sprintdatacenter.pl/ (Relay, Exit)
https://lolekhosted.net/ (Relay, Exit, Crypto) fuck fbi
https://www.artnet.pl/ (Relay, Exit)
https://fastpipe.io/ (Relay, Crypto)
https://terrahost.com/ (Relay, Exit only on dedis, Crypto)
Just some of them I posted a long time ago on LET, if you have any location in mind, let me know I will figure something out.
Currently you can grab a $1 100Mbps unmtered box you can run Tor exit on from Aeza - https://lowendspirit.com/discussion/7482/aeza-net-ryzen-sweden-1-core-4gb-ram-for-1-eur-per-month-recurring
@c4tdrx
8 GB Ram DDr4 ECC
1 Gbps speed
99.97% Uptime
1 Dedicated IPv4
KVM VIrtualization
Upload own ISO
Linux or Windows
Seedbox Allow
TOR EXIT ALLOW
10$/month
Aéza doesn't allow Tor Exits.
Plenty of exits running for over a year.
https://relays.0x7c0.com/as/AS210644/
All being ran by shadowbrokers.eu, maybe some sort of agreement
However, their support have told me na na.
Possible.
One of the best deals right now for an exit is probably @VSYS_Host
https://vsys.host/cheap-vps-hosting
5 buck for 200Mbps(unmetered guaranteed, 1Gig port) in UA/NL/US
Only "classic" payment methods though, no crypto.
https://relays.0x7c0.com/as/AS30860/
https://relays.0x7c0.com/as/AS43641/
https://clients.advinservers.com/contact.php
dumb question on my part... why do you want to do this? Have you looked into the ramifications of hosting such?
They are overused
I am not stupid i know what i am doing
Hostslick, Crunchbits, or Data Ideas(dataideas.com) maybe
https://clients.advinservers.com/store/los-angeles-kvm-standard-vps/kvm-standard-xs
I'll check if we can provide anything smaller
So neither of them are good for free speech.
is already ok.
floki, however, is thoroughly despicable
@crunchbits allows tor ?
Well I don't see any exit hosts on their ASN but lots of middle relays, so I dunno.
