@sh97 said: @Neoon oof, that doesn't look good.
Does the speedtest-cli work when you try it from bash?
It does.
Retrieving speedtest.net configuration...
Testing from HKDF (122.10.89.xxx)...
Retrieving speedtest.net server list...
Selecting best server based on ping...
Hosted by STC (Hong Kong) [0.87 km]: 4.854 ms
Testing download speed................................................................................
Download: 95.33 Mbit/s
Testing upload speed......................................................................................................
Upload: 190.64 Mbit/s
It does.
It does.
---------------------------- network-speed.xyz ----------------------------
A simple script to test network performance using speedtest-cli
Version : v2024.03.15
Global Speedtest : wget -qO- network-speed.xyz | bash
Region Speedtest : wget -qO- network-speed.xyz | bash -s -- -r <region>
Basic System Info
CPU Model : Intel(R) Xeon(R) CPU E5-2690 v4 @ 2.60GHz
CPU Cores : 1 @ 2599.996 MHz
CPU Cache : 35840 KB
AES-NI : ✔ Enabled
Total Disk : 9.8 GB (1.6 GB Used)
Total RAM : 475.7 MB (90.1 MB Used)
System uptime : 0 days, 0 hour 0 min
Load average : 0.06, 0.02, 0.00
OS : Debian GNU/Linux 11
Arch : x86_64 (64 Bit)
Kernel : 5.10.0-28-cloud-amd64
Virtualization : KVM
TCP Control : bbr
Basic Network Info
Primary Network : IPv6
IPv6 Access : ✔ Online
IPv4 Access : ✔ Online
ISP : Cloudie Limited
ASN : AS55933 Cloudie Limited
Host : Cloudie Limited
Location (IPv4) : Hong Kong, Hong Kong, HK
Speedtest.net (Region: CHINA | 中華人民共和國)
Location Latency Loss DL Speed UP Speed Server
ISP: HKDF
Nearest 2.00 ms 0.0% 94.00 Mbps 213.38 Mbps i3D.net - Hong Kong
CU - Shanghai 39.23 ms N/A 19.85 Mbps 176.42 Mbps China Unicom 5G - Shanghai
CM - Beijing 217.37 ms 0.0% 99.46 Mbps 212.92 Mbps China Mobile Group Beijing Co.Ltd - Beijing
CU - Beijing FAILED
CT - Nanjing 226.50 ms 2.15 Mbps FAILED China Telecom JiangSu 5G - Nanjing
CT - Shenzen FAILED
CU - Shenyang FAILED
CT - Suzhou FAILED
CT - Yangzhou FAILED
CM - Hangzhou 34.11 ms 0.4% 95.61 Mbps 176.41 Mbps China Mobile Zhejiang 5G - Hangzhou
CT - Hangzhou 30.51 ms N/A 20.48 Mbps 169.41 Mbps 浙江电信 - HangZhou
CU - Zhengzhou FAILED
CT - Changsha FAILED
CU - Changsha FAILED
CM - Chengdu FAILED
CM - Xi an FAILED
CT - Hefei 43.94 ms 0.0% 13.29 Mbps 177.97 Mbps China Telecom AnHui 5G - Hefei
CT - TianJin FAILED
CT - XiNing FAILED
CT - NingBo 38.46 ms N/A 95.83 Mbps 174.35 Mbps 浙江电信 - NingBo
CM - Guangzhou FAILED
CM - Kwai Chung 2.71 ms 0.0% 95.66 Mbps 214.57 Mbps CMHK Mobile Service - Hong Kong
CM - Hong Kong 2.72 ms 0.0% 95.61 Mbps 215.88 Mbps CMHK Broadband - Hong Kong
CUG - Hong Kong 3.56 ms 0.0% 94.16 Mbps 219.99 Mbps China Unicom Global Ltd - Hong Kong
Hong Kong 2.61 ms N/A 95.33 Mbps 220.03 Mbps fdcservers.net - Hong Kong
Hong Kong 2.36 ms 0.0% 95.39 Mbps 113.12 Mbps Misaka Network, Inc. - Hong Kong
CUG - Tokyo 201.24 ms 0.0% 100.05 Mbps 152.26 Mbps China Unicom Global Ltd - Tokyo
CUG - Singapore 123.38 ms 0.0% 97.43 Mbps 209.04 Mbps China Unicom Global Ltd - Singapore
CUG - LosAngeles FAILED
CUG - London 199.40 ms 0.0% 96.03 Mbps 199.94 Mbps China Unicom Global Ltd - London
Avg DL Speed : 75.65 Mbps
Avg UL Speed : 177.86 Mbps
Total DL Data : 1.21 GB
Total UL Data : 3.44 GB
Total Data : 4.65 GB
Duration : 6 min 40 sec
System Time : 03/04/2024 - 19:46:56 UTC
Total Script Runs : 39806
Result : https://result.network-speed.xyz/r/1712173298_22GDPQ_CHINA.txt
@sh97:
what is the problem here? these errors only occur with avoro / dataforest!
Version : v2024.04.04
Basic System Info
CPU Model : AMD Ryzen Threadripper 3970X 32-Core Processor
CPU Cores : 1 @ 3699.940 MHz
CPU Cache : 512 KB
AES-NI : ✔ Enabled
Total Disk : 47,2 GB (6,7 GB Used)
Total RAM : 1,9 GB (233,6 MB Used)
Total Swap : 4,0 GB (1,5 MB Used)
System uptime : 53 days, 17 hour 22 min
Load average : 0.00, 0.00, 0.00
OS : Debian GNU/Linux 12
Kernel : 6.1.0-18-amd64
TCP Control : cubic
Basic Network Info
ISP : dataforest GmbH
ASN : AS58212 dataforest GmbH
Host : Harmony Solutions GmbH
Speedtest.net (Region: EUROPE)
ISP: dataforest
Nearest 0.54 ms 0.0% 6214.45 Mbps 6217.38 Mbps FynnCraft Minecraft Network - Dortmund
London, UK 10.87 ms 0.0% 9175.87 Mbps 3793.64 Mbps M247 Ltd - London
Manchester, UK 20.69 ms N/A 8488.43 Mbps 2581.18 Mbps Vodafone UK - Manchester
Dublin, IE 26.78 ms 0.0% 9116.57 Mbps 2546.51 Mbps Three Ireland - Dublin
Amsterdam, NL 7.11 ms 0.0% 8609.48 Mbps 6056.65 Mbps Melbicom - Amsterdam
Eygelshoen, NL 10.91 ms 0.0% 6334.56 Mbps 2913.68 Mbps SkyLink Data Center BV - Eygelshoven
awk: line 1: 21492e+119159 : decimal overflow
awk: line 1: 21738e+112564 : decimal overflow
Paris, FR 8.72 ms N/A 6258.50 Mbps 2868.36 Mbps ORANGE FRANCE - Paris
Marseille, FR 16.44 ms 0.0% 8707.60 Mbps 3195.38 Mbps GSL Networks - Marseille
Madrid, ES 28.66 ms 0.0% 7926.76 Mbps 2814.66 Mbps Orange - Madrid
awk: line 1: 601e+1044 : decimal overflow
awk: line 1: 3122e+1381 : decimal overflow
Barcelona, ES 25.04 ms 0.0% 9335.31 Mbps 2971.13 Mbps Adamo - Barcelona
awk: line 1: syntax error at or near ;
Lisbon, PT 38.79 ms 0.0% 4906.00 Mbps 1835.28 Mbps Edgoo Networks - Lisbon
Rome, IT 25.80 ms 0.0% 8589.44 Mbps 1876.57 Mbps TIM SpA - Rome
awk: line 1: 25887e+119411 : decimal overflow
awk: line 1: 86832e+113037 : decimal overflow
Milan, IT 21.72 ms 0.0% 3260.63 Mbps 2308.20 Mbps Fastweb SpA - Milan
Zurich, CH 9.38 ms 0.0% 7759.97 Mbps 4502.49 Mbps Sunrise Communication AG - Zurich
Frankfurt, DE 0.82 ms 3.0% 7180.93 Mbps 6006.11 Mbps Deutsche Telekom - Frankfurt am Main
Berlin, DE 11.38 ms N/A 8232.92 Mbps 871.67 Mbps Misaka Network, Inc. - Berlin
Vienna, AT 15.73 ms 0.0% 9305.56 Mbps 3726.91 Mbps A1 Telekom Austria AG - Vienna
Budapest, HU 14.16 ms 0.0% 6463.39 Mbps 2324.60 Mbps ATW Internet Kft. - Budapest
awk: line 1: 26078e+118325 : decimal overflow
awk: line 1: 30845e+11882 : decimal overflow
Gdansk, PL 28.94 ms 0.0% 338.42 Mbps 2629.28 Mbps T-Mobile Polska S.A. - Gdańsk
Warsaw, PL 18.55 ms 0.0% 8278.06 Mbps 3320.70 Mbps Orange Polska S.A. - Warsaw
Lviv, UA 24.23 ms 0.0% 9381.30 Mbps 1601.98 Mbps Kyivstar - Lviv
Kyiv, UA 28.94 ms 0.0% 9105.40 Mbps 1171.56 Mbps O3 - Kyiv
Minsk, BY 27.54 ms 0.0% 6423.28 Mbps 2290.79 Mbps A1 - Minsk
Bucharest, RO 27.61 ms 0.0% 4561.76 Mbps 2323.45 Mbps Orange Romania SA - Bucuresti
awk: line 1: 38832e+109108 : decimal overflow
awk: line 1: 62933e+111269 : decimal overflow
Timisoara, RO 31.10 ms 0.0% 7923.18 Mbps 2418.12 Mbps Digi
Helsinki, FI 22.50 ms 0.0% 8548.65 Mbps 3659.54 Mbps Elisa Oyj - Helsinki
Stockholm, SE 29.19 ms 0.0% 7985.60 Mbps 2710.00 Mbps i3D.net - Stockholm
Oslo, NO 23.16 ms 0.0% 8630.41 Mbps 2419.63 Mbps Speedtest.net - Oslo
Moscow, RU 44.53 ms 0.0% 6947.99 Mbps 1653.63 Mbps MTS - Moscow
Petersburg, RU 31.44 ms 0.0% 8266.10 Mbps 1953.06 Mbps MegaFon - Saint Petersburg
awk: line 1: 92386e+118636 : decimal overflow
Istanbul, TR FAILED - IP has been rate limited. Try again after 1 hour.
Tbilisi, GE FAILED - IP has been rate limited. Try again after 1 hour.
Avg DL Speed : 0,00 Mbps
Avg UL Speed : 0,07 Mbps
Total DL Data : 0,00 GB
Total UL Data : 0,00 GB
Total Data : 0,00 GB
Duration : 12 min 17 sec
System Time : 05/04/2024 - 14:44:24 CEST
Total Script Runs : 39940
Result : https://result.network-speed.xyz/r/1712320733_VQVEH1_EU.txt
I'll take a look @carlin0 and @febryanvaldo have previously told me about this, but I've never been able to replicate this issue.
Probably some issue with awk version dependencies is my guess, but let's see.
Dallas, Texas
ping 1.28 ms
DL speed 8181.00 Mbps
UL speed 7255.91 Mbps
Server - Hivelocity - Dallas, Texas
Speedtest.net (Region: NORTH AMERICA)
ISP: EGIHosting
Nearest 9.12 ms 0.0% 5776.92 Mbps 1580.05 Mbps Cox - Wichita - Wichita, KS
Vancouver, BC 47.98 ms N/A 6539.79 Mbps 1497.35 Mbps TELUS - Vancouver, BC
Calgary, AB 53.58 ms N/A 6217.37 Mbps 454.09 Mbps Shaw Communications - Calgary, AB
Winnipeg, MB 30.78 ms 0.0% 7663.87 Mbps 2482.70 Mbps Voyageur Internet - Winnipeg, MB
Toronto, ON 33.40 ms 0.0% 7845.08 Mbps 2610.09 Mbps Bell Canada - Toronto, ON
Montreal, QC 56.17 ms 0.0% 7402.70 Mbps 1254.88 Mbps Rogers Wireless - Montréal, QC
New York, NY 35.38 ms 0.0% 5365.43 Mbps 657.77 Mbps Surfshark Ltd - New York, NY
Ashburn, VA 33.51 ms 0.0% 6465.18 Mbps 2013.33 Mbps Rackdog - Ashburn, VA
Charlotte, NC 33.29 ms 0.0% 5562.24 Mbps 615.11 Mbps Windstream - Charlotte, NC
Atlanta, GA 16.46 ms 0.0% 8136.62 Mbps 2873.86 Mbps i3D.net - Atlanta, GA
Miami, FL 31.63 ms 0.0% 5226.27 Mbps 2510.52 Mbps Hivelocity - Miami, FL
Dallas, TX 1.28 ms 0.0% 8181.00 Mbps 7255.91 Mbps Hivelocity - Dallas, TX
Houston, TX 8.23 ms 0.0% 7371.61 Mbps 4595.02 Mbps Ezee Fiber - Houston, TX
Kansas, MO 12.63 ms 0.0% 6524.93 Mbps 1313.40 Mbps Nocix - Kansas City, MO
Minneapolis, MN 22.28 ms 0.0% 7940.77 Mbps 1253.15 Mbps US Internet - Minneapolis, MN
Chicago, IL 22.26 ms 1.0% 7944.13 Mbps 1971.11 Mbps Enzu.com - Chicago, IL
Cleveland, OH 36.03 ms 0.0% 5524.58 Mbps 597.24 Mbps Windstream - Cleveland, OH
Albuquerque, NM 23.37 ms N/A 9235.49 Mbps 2609.04 Mbps Comcast - Albuquerque, NM
Denver, CO 32.70 ms 0.0% 7538.92 Mbps 1596.76 Mbps T-Mobile Fiber | Intrepid - Denver, CO
Portland, OR 49.40 ms N/A 6047.56 Mbps 1297.85 Mbps CenturyLink - Portland, OR
Las Vegas, NV 47.37 ms N/A 3723.74 Mbps 442.97 Mbps Dish Wireless - Las Vegas, NV
Salt Lake, UT 29.20 ms N/A 2217.48 Mbps 1917.58 Mbps Novva Data Centers - Salt Lake City, UT
Phoenix, AZ 19.65 ms 0.0% 6168.63 Mbps 2992.11 Mbps Xiber LLC - Phoenix, AZ
Los Angeles, CA 29.26 ms 0.0% 7448.07 Mbps 1066.90 Mbps ReliableSite Hosting - Los Angeles, CA
San Jose, CA 40.07 ms 0.0% 4637.96 Mbps 1468.45 Mbps Misaka Network, Inc. - San Jose, CA
Spokane, WA 52.39 ms 0.0% 4530.86 Mbps 1428.75 Mbps Crunchbits - Spokane, WA
Seattle, WA 48.25 ms 0.0% 2277.00 Mbps 1403.79 Mbps Misaka Network, Inc. - Seattle, WA
Hermosillo, MX 42.48 ms 0.0% 7338.48 Mbps 1554.12 Mbps Megacable - Hermosillo
Guadalajara, MX 29.74 ms 0.0% 1875.87 Mbps 1286.94 Mbps AT&T México - Guadalajara
Mexico City, MX FAILED - IP has been rate limited. Try again after 1 hour.
Avg DL Speed : 6163.07 Mbps
Avg UL Speed : 1882.78 Mbps
Total DL Data : 240.20 GB
Total UL Data : 71.42 GB
Total Data : 311.62 GB
That issue has always existed, at least on Debian...
F. Battiato ---
60% of my servers run on debian, have never seen it once unfortunately.
I'll contact you both when I get time to look into this.
The fix could be as trivial as OFMT="%.0f" or something like that if you're using mawk (at least you'll be able to verify if the hunch is in the right direction).
Hope this helps...
Wow, thanks a lot for that.
I wouldn't have thought about it, tbh.
I'll be getting some time in a couple of weeks, will have a look then.
Hope this helps...
Basic System Info
CPU Model : AMD Ryzen 9 3900X 12-Core Processor
CPU Cores : 3 @ 3799.998 MHz
CPU Cache : 512 KB
AES-NI : ✔ Enabled
Total Disk : 51.6 GB (2.2 GB Used)
Total RAM : 1.9 GB (62.8 MB Used)
Total Swap : 256.0 MB (0 Used)
System uptime : 3 days, 19 hour 4 min
Load average : 0.08, 0.16, 0.14
Kernel : 5.10.0-8-amd64
TCP Control : cubic
Basic Network Info
Primary Network : IPv4
IPv6 Access : ❌ Offline
ISP : QuadraNet Enterprises LLC
ASN : AS8100 QuadraNet Enterprises LLC
Host : Virtual Machine Solutions LLC
Location (IPv4) : Los Angeles, California, US
ISP: Sprint
Nearest 58.15 ms 0.0% 952.36 Mbps 881.34 Mbps GSL Networks - New York, NY
Kochi, IN 349.66 ms 0.0% 32.78 Mbps 251.73 Mbps Asianet Broadband - Cochin
Bangalore, IN 270.59 ms 0.0% 477.51 Mbps 343.31 Mbps Bharti Airtel Ltd - Bangalore
Chennai, IN 205.65 ms N/A 689.17 Mbps 432.75 Mbps Jio - Chennai
Mumbai, IN 255.12 ms 0.0% 592.68 Mbps 295.47 Mbps i3D.net - Mumbai
Delhi, IN 274.88 ms 0.0% 539.17 Mbps 253.22 Mbps Tata Play Fiber - New Delhi
Seattle, US 28.68 ms N/A 900.61 Mbps 846.92 Mbps Comcast - Seattle, WA
Los Angeles, US 0.89 ms 0.0% 933.47 Mbps 930.13 Mbps ReliableSite Hosting - Los Angeles, CA
Dallas, US 32.90 ms 0.0% 807.97 Mbps 884.30 Mbps Hivelocity - Dallas, TX
Miami, US 62.62 ms N/A 762.80 Mbps 872.24 Mbps Dish Wireless - Miami, FL
New York, US 58.07 ms 0.0% 955.25 Mbps 858.87 Mbps GSL Networks - New York, NY
Toronto, CA 61.65 ms 0.0% 861.82 Mbps 875.08 Mbps Rogers - Toronto, ON
Mexico City, MX 52.19 ms N/A 926.58 Mbps 563.95 Mbps INFINITUM - Mexico City
London, UK 140.72 ms 0.0% 947.31 Mbps 649.77 Mbps VeloxServ Communications - London
Amsterdam, NL 149.35 ms 0.0% 954.64 Mbps 258.55 Mbps 31173 Services AB - Amsterdam
Paris, FR 141.79 ms N/A 936.70 Mbps 225.84 Mbps Axione - Paris
Frankfurt, DE 140.17 ms 0.0% 576.91 Mbps 286.40 Mbps Clouvider Ltd - Frankfurt am Main
Warsaw, PL 183.62 ms 0.0% 928.20 Mbps 514.44 Mbps Play - Warszawa
Bucharest, RO 171.66 ms 0.0% 575.46 Mbps 444.93 Mbps Vodafone Romania Fixed – Bucharest - Bucharest
Moscow, RU 182.23 ms 0.0% 829.71 Mbps 474.32 Mbps MegaFon - Moscow
Jeddah, SA 197.85 ms 0.0% 846.54 Mbps 411.16 Mbps Saudi Telecom Company
Dubai, AE 254.62 ms 0.0% 750.39 Mbps 330.34 Mbps du - Dubai
Fujairah, AE 269.70 ms 0.0% 807.62 Mbps 293.23 Mbps ETISALAT-UAE - Fujairah
Istanbul, TR 175.62 ms 0.0% 836.61 Mbps 502.22 Mbps Turkcell - Istanbul
Tehran, IR 221.97 ms 0.0% 501.22 Mbps 339.39 Mbps Asiatech - Tehran
Tokyo, JP 102.97 ms N/A 714.28 Mbps 307.62 Mbps fdcservers.net - Tokyo
Shanghai, CU-CN 176.11 ms 0.0% 652.34 Mbps 169.12 Mbps China Unicom 5G - Shanghai
Nanjing, CT-CN 146.76 ms 1.0% 586.65 Mbps 33.53 Mbps China Telecom JiangSu 5G - Nanjing
Hong Kong, CN 156.64 ms N/A 680.58 Mbps 522.88 Mbps STC - Hong Kong
Singapore, SG 269.52 ms 2.3% 510.89 Mbps 475.17 Mbps i3D.net - Singapore
Jakarta, ID 185.26 ms 0.0% 610.55 Mbps 471.42 Mbps PT Solnet Indonesia - Jakarta
Avg DL Speed : 731.57 Mbps
Avg UL Speed : 483.85 Mbps
Total DL Data : 31.64 GB
Total UL Data : 19.77 GB
Total Data : 51.41 GB
Duration : 15 min 55 sec
System Time : 09/04/2024 - 06:55:00 EDT
Total Script Runs : 40229
Result : https://result.network-speed.xyz/r/1712659733_ZND9YX_GLOBAL.txt
ISP : Advin Services LLC
ASN : AS206216 Advin Services LLC
Host : MB \
ISP: Advin Services
Nearest 13.07 ms 0.0% 418.40 Mbps 940.96 Mbps NetCologne - Cologne
London, UK 20.19 ms 0.0% 4775.08 Mbps 3567.31 Mbps M247 Ltd - London
Manchester, UK 27.46 ms N/A 6992.93 Mbps 3092.35 Mbps Vodafone UK - Manchester
Dublin, IE 30.16 ms 0.0% 6633.56 Mbps 2848.02 Mbps Three Ireland - Dublin
Amsterdam, NL 15.30 ms 0.0% 6268.21 Mbps 1503.61 Mbps Melbicom - Amsterdam
Eygelshoen, NL 18.40 ms 0.0% 5331.74 Mbps 1745.16 Mbps SkyLink Data Center BV - Eygelshoven
Paris, FR 17.46 ms N/A 8029.06 Mbps 3872.42 Mbps ORANGE FRANCE - Paris
Marseille, FR 22.31 ms 0.0% 8453.86 Mbps 3789.36 Mbps GSL Networks - Marseille
Madrid, ES 39.28 ms 0.0% 6801.77 Mbps 2170.42 Mbps Orange - Madrid
Barcelona, ES 27.34 ms 0.0% 4783.19 Mbps 2461.62 Mbps Adamo - Barcelona
Lisbon, PT 47.00 ms 0.0% 7571.78 Mbps 1853.24 Mbps Edgoo Networks - Lisbon
Rome, IT 32.33 ms 0.0% 6752.72 Mbps 2830.80 Mbps TIM SpA - Rome
Milan, IT 24.75 ms 0.0% 5273.34 Mbps 4189.45 Mbps Fastweb SpA - Milan
Zurich, CH 13.47 ms 0.0% 6463.70 Mbps 5616.26 Mbps Sunrise Communication AG - Zurich
Frankfurt, DE 8.48 ms 6.0% 5336.22 Mbps 265.91 Mbps Deutsche Telekom - Frankfurt am Main
Berlin, DE 25.14 ms 0.0% 4426.05 Mbps 1330.38 Mbps Misaka Network, Inc. - Berlin
Vienna, AT 14.02 ms 0.0% 6650.82 Mbps 4555.40 Mbps A1 Telekom Austria AG - Vienna
Budapest, HU 22.46 ms 0.0% 8983.74 Mbps 2549.50 Mbps ATW Internet Kft. - Budapest
Gdansk, PL 29.74 ms 0.0% 3029.16 Mbps 892.95 Mbps T-Mobile Polska S.A. - Gdańsk
Warsaw, PL 26.28 ms 0.0% 4800.26 Mbps 3270.88 Mbps Orange Polska S.A. - Warsaw
Lviv, UA 34.09 ms 0.0% 5589.92 Mbps 1597.21 Mbps Kyivstar - Lviv
Kyiv, UA 32.35 ms 0.0% 4561.77 Mbps 842.61 Mbps O3 - Kyiv
Minsk, BY 35.10 ms 0.0% 5936.06 Mbps 2528.45 Mbps A1 - Minsk
Bucharest, RO 32.21 ms 0.0% 8145.13 Mbps 2787.35 Mbps Orange Romania SA - Bucuresti
Timisoara, RO 45.76 ms 0.0% 5801.55 Mbps 2762.58 Mbps Digi
Helsinki, FI 29.38 ms 0.0% 7393.96 Mbps 3002.35 Mbps Elisa Oyj - Helsinki
Stockholm, SE 32.51 ms 0.0% 5677.35 Mbps 2741.12 Mbps i3D.net - Stockholm
Oslo, NO FAILED
Moscow, RU 59.58 ms 0.0% 3667.31 Mbps 1500.01 Mbps MTS - Moscow
Petersburg, RU 41.21 ms 0.0% 5711.79 Mbps 2202.67 Mbps MegaFon - Saint Petersburg
Avg DL Speed : 5871.07 Mbps
Avg UL Speed : 2527.94 Mbps
Total DL Data : 232.27 GB
Total UL Data : 89.89 GB
Total Data : 322.15 GB
Duration : 18 min 22 sec
System Time : 14/04/2024 - 09:31:24 UTC
Total Script Runs : 40651
Host : MB \
ISP: Advin Services
Nearest 13.02 ms 0.0% 854.74 Mbps 936.74 Mbps hotspot.koeln - Cologne
London, UK 20.34 ms 0.0% 4589.68 Mbps 3995.17 Mbps M247 Ltd - London
Manchester, UK 28.07 ms N/A 6940.85 Mbps 3116.27 Mbps Vodafone UK - Manchester
Dublin, IE 30.21 ms 0.0% 5905.39 Mbps 2831.98 Mbps Three Ireland - Dublin
Amsterdam, NL 16.28 ms 0.0% 6041.80 Mbps 1584.54 Mbps Melbicom - Amsterdam
Eygelshoen, NL 18.17 ms 0.0% 7613.25 Mbps 1795.15 Mbps SkyLink Data Center BV - Eygelshoven
Paris, FR 17.19 ms N/A 7140.99 Mbps 4520.07 Mbps ORANGE FRANCE - Paris
Marseille, FR 21.78 ms 0.0% 7120.47 Mbps 4107.68 Mbps GSL Networks - Marseille
Madrid, ES 39.32 ms 0.0% 5883.81 Mbps 2484.87 Mbps Orange - Madrid
Barcelona, ES 27.11 ms 0.0% 5982.95 Mbps 2738.67 Mbps Adamo - Barcelona
Lisbon, PT 47.20 ms 0.0% 6537.88 Mbps 1852.89 Mbps Edgoo Networks - Lisbon
Rome, IT 27.69 ms 0.0% 6531.79 Mbps 3203.41 Mbps TIM SpA - Rome
Milan, IT 25.72 ms 0.0% 3542.23 Mbps 4117.56 Mbps Fastweb SpA - Milan
Zurich, CH 13.04 ms 0.0% 7390.39 Mbps 6013.72 Mbps Sunrise Communication AG - Zurich
Frankfurt, DE 9.47 ms 4.0% 6301.92 Mbps 2832.64 Mbps Deutsche Telekom - Frankfurt am Main
Berlin, DE 26.08 ms N/A 5517.48 Mbps 608.20 Mbps Misaka Network, Inc. - Berlin
Vienna, AT 14.28 ms 0.0% 6271.04 Mbps 6004.38 Mbps A1 Telekom Austria AG - Vienna
Budapest, HU 22.56 ms 0.0% 8310.19 Mbps 2793.18 Mbps ATW Internet Kft. - Budapest
Gdansk, PL 33.46 ms 0.0% 3538.56 Mbps 2625.86 Mbps T-Mobile Polska S.A. - Gdańsk
Warsaw, PL 26.09 ms 0.0% 5840.38 Mbps 3401.31 Mbps Orange Polska S.A. - Warsaw
Lviv, UA 34.39 ms 0.0% 5477.29 Mbps 1935.28 Mbps Kyivstar - Lviv
Kyiv, UA 32.60 ms 0.0% 5237.61 Mbps 1307.27 Mbps O3 - Kyiv
Minsk, BY 35.03 ms 0.0% 6061.11 Mbps 2722.68 Mbps A1 - Minsk
Bucharest, RO 28.87 ms 0.0% 7712.98 Mbps 2917.18 Mbps Orange Romania SA - Bucuresti
Timisoara, RO 33.62 ms 0.0% 6207.53 Mbps 2938.70 Mbps Digi
Helsinki, FI 29.32 ms 0.0% 7659.94 Mbps 3048.24 Mbps Elisa Oyj - Helsinki
Stockholm, SE 32.40 ms 0.0% 7279.43 Mbps 2747.21 Mbps i3D.net - Stockholm
Oslo, NO FAILED
Moscow, RU 61.02 ms 0.0% 4708.84 Mbps 1763.60 Mbps MTS - Moscow
Petersburg, RU 42.41 ms 0.0% 5247.34 Mbps 2256.14 Mbps MegaFon - Saint Petersburg
Avg DL Speed : 5980.97 Mbps
Avg UL Speed : 2868.99 Mbps
Total DL Data : 241.10 GB
Total UL Data : 102.29 GB
Total Data : 343.39 GB
Duration : 18 min 16 sec
System Time : 14/04/2024 - 09:31:32 UTC
Total Script Runs : 40652
ISP: dataforest
Nearest 0.26 ms 0.0% 9163.35 Mbps 8532.18 Mbps TCP-SYN - A part of RetardHub - Offenbach am Main
London, UK 10.98 ms 0.0% 9381.84 Mbps 4128.06 Mbps M247 Ltd - London
Manchester, UK FAILED
Dublin, IE FAILED
Amsterdam, NL 7.16 ms 0.0% 8544.80 Mbps 7704.98 Mbps Melbicom - Amsterdam
Eygelshoen, NL 11.05 ms 0.0% 8457.66 Mbps 2142.30 Mbps SkyLink Data Center BV - Eygelshoven
Paris, FR 13.50 ms N/A 7589.51 Mbps 2808.63 Mbps ORANGE FRANCE - Paris
Marseille, FR FAILED
Madrid, ES 29.61 ms 0.0% 7462.86 Mbps 2617.01 Mbps Orange - Madrid
Barcelona, ES FAILED
Lisbon, PT 38.54 ms 0.0% 5390.82 Mbps 1434.48 Mbps Edgoo Networks - Lisbon
Rome, IT FAILED
Milan, IT FAILED
Zurich, CH 9.96 ms 0.0% 2037.55 Mbps 6152.98 Mbps Sunrise Communication AG - Zurich
Frankfurt, DE FAILED
Berlin, DE 11.50 ms 0.0% 7300.25 Mbps 1679.11 Mbps Misaka Network, Inc. - Berlin
Vienna, AT FAILED
Budapest, HU 15.10 ms 0.0% 8199.66 Mbps 2379.06 Mbps ATW Internet Kft. - Budapest
Gdansk, PL FAILED
Warsaw, PL FAILED
Lviv, UA FAILED
Kyiv, UA FAILED
Minsk, BY 22.53 ms 0.0% 6532.04 Mbps 1807.15 Mbps A1 - Minsk
Bucharest, RO FAILED
Timisoara, RO 31.05 ms 0.0% 8063.11 Mbps 1716.87 Mbps Digi
Helsinki, FI 22.55 ms 0.0% 8670.66 Mbps 3366.03 Mbps Elisa Oyj - Helsinki
Stockholm, SE 29.52 ms 0.0% 8406.20 Mbps 2710.88 Mbps i3D.net - Stockholm
Oslo, NO FAILED
Moscow, RU 38.50 ms 0.0% 7430.31 Mbps 1559.01 Mbps MTS - Moscow
Petersburg, RU 31.04 ms 0.0% 8060.09 Mbps 1879.76 Mbps MegaFon - Saint Petersburg
Avg DL Speed : 54192795464,50 Mbps
Avg UL Speed : 21039195727,94 Mbps
Duration : 7 min 36 sec
System Time : 14/04/2024 - 11:21:15 CEST
Total Script Runs : 40640
Host : DF Cloud
ISP: dataforest
Nearest 0.28 ms 0.0% 12746.05 Mbps 11487.41 Mbps TCP-SYN - A part of RetardHub - Offenbach am Main
London, UK 10.93 ms 0.0% 3993.46 Mbps 3373.82 Mbps M247 Ltd - London
Manchester, UK 20.20 ms N/A 5290.37 Mbps 3727.47 Mbps Vodafone UK - Manchester
Dublin, IE 27.65 ms 0.0% 5757.06 Mbps 1746.32 Mbps Three Ireland - Dublin
Amsterdam, NL 6.61 ms 0.0% 8373.53 Mbps 9251.44 Mbps Melbicom - Amsterdam
Eygelshoen, NL 10.08 ms 0.0% 8519.40 Mbps 2583.67 Mbps SkyLink Data Center BV - Eygelshoven
Paris, FR 13.76 ms N/A 7295.54 Mbps 3307.94 Mbps ORANGE FRANCE - Paris
Marseille, FR 16.07 ms 0.0% 6337.02 Mbps 4122.06 Mbps GSL Networks - Marseille
Madrid, ES 29.70 ms 0.0% 7565.46 Mbps 2451.60 Mbps Orange - Madrid
Barcelona, ES 25.82 ms 0.0% 5941.39 Mbps 3183.72 Mbps Adamo - Barcelona
Lisbon, PT 37.24 ms 0.0% 5902.80 Mbps 1472.50 Mbps Edgoo Networks - Lisbon
Rome, IT 24.86 ms 0.0% 6597.41 Mbps 2805.23 Mbps TIM SpA - Rome
Milan, IT 20.82 ms 0.0% 523.23 Mbps 1352.06 Mbps Fastweb SpA - Milan
Zurich, CH 9.29 ms 0.0% 4847.62 Mbps 2289.53 Mbps Sunrise Communication AG - Zurich
Frankfurt, DE 1.98 ms 23.9% 2667.96 Mbps 1869.41 Mbps Deutsche Telekom - Frankfurt am Main
Berlin, DE 11.46 ms 0.0% 7074.42 Mbps 1431.65 Mbps Misaka Network, Inc. - Berlin
Vienna, AT 13.94 ms 0.0% 7368.26 Mbps 2634.09 Mbps A1 Telekom Austria AG - Vienna
Budapest, HU 13.95 ms 0.0% 8036.96 Mbps 2042.00 Mbps ATW Internet Kft. - Budapest
Gdansk, PL 19.71 ms 0.0% 2996.73 Mbps 567.45 Mbps T-Mobile Polska S.A. - Gdańsk
Warsaw, PL 20.34 ms 0.0% 3172.48 Mbps 4280.77 Mbps Orange Polska S.A. - Warsaw
Lviv, UA 24.26 ms 0.0% 4588.44 Mbps 2128.87 Mbps Kyivstar - Lviv
Kyiv, UA 28.78 ms 0.0% 3297.76 Mbps 702.75 Mbps O3 - Kyiv
Minsk, BY 22.42 ms 0.0% 6058.73 Mbps 2536.33 Mbps A1 - Minsk
Bucharest, RO 27.53 ms 0.0% 2588.03 Mbps 2088.08 Mbps Orange Romania SA - Bucuresti
Timisoara, RO 30.40 ms 0.0% 8083.78 Mbps 3133.42 Mbps Digi
Helsinki, FI 22.57 ms 0.0% 8385.15 Mbps 3526.40 Mbps Elisa Oyj - Helsinki
Stockholm, SE 29.35 ms 0.0% 8339.67 Mbps 2900.76 Mbps i3D.net - Stockholm
Oslo, NO FAILED
Moscow, RU 38.40 ms 0.0% 6293.23 Mbps 2148.65 Mbps MTS - Moscow
Petersburg, RU 36.30 ms 0.0% 8080.54 Mbps 2515.68 Mbps MegaFon - Saint Petersburg
Avg DL Speed : 6093.90 Mbps
Avg UL Speed : 3022.80 Mbps
Total DL Data : 244.17 GB
Total UL Data : 113.07 GB
Total Data : 357.24 GB
Duration : 12 min 45 sec
System Time : 14/04/2024 - 11:26:48 CEST
Total Script Runs : 40643
ISP : Clouvider Limited
ASN : AS62240 Clouvider
Host : Clouvider Limited
ISP: Clouvider
Nearest 0.60 ms 0.0% 6517.17 Mbps 7729.97 Mbps 23M GmbH - Frankfurt am Main
London, UK 11.16 ms 0.0% 282.90 Mbps 5600.70 Mbps M247 Ltd - London
Manchester, UK 21.66 ms N/A 4789.29 Mbps 4259.01 Mbps Vodafone UK - Manchester
Dublin, IE 24.35 ms 0.0% 3819.84 Mbps 3730.60 Mbps Three Ireland - Dublin
Amsterdam, NL 6.94 ms N/A 5577.74 Mbps 2885.11 Mbps Melbicom - Amsterdam
Eygelshoen, NL 12.66 ms 0.0% 4858.51 Mbps 2922.83 Mbps SkyLink Data Center BV - Eygelshoven
Paris, FR 9.67 ms N/A 5451.12 Mbps 7513.30 Mbps ORANGE FRANCE - Paris
Marseille, FR 16.22 ms 0.0% 4185.25 Mbps 4997.85 Mbps GSL Networks - Marseille
Madrid, ES 25.18 ms 0.0% 5091.51 Mbps 3742.65 Mbps Orange - Madrid
Barcelona, ES 23.49 ms 0.0% 3352.03 Mbps 1582.16 Mbps Adamo - Barcelona
Lisbon, PT 113.51 ms 0.0% 3396.61 Mbps 800.63 Mbps Edgoo Networks - Lisbon
Rome, IT 30.56 ms 0.0% 4356.18 Mbps 2708.42 Mbps TIM SpA - Rome
Milan, IT 16.47 ms 0.0% 4093.12 Mbps 4689.79 Mbps Fastweb SpA - Milan
Zurich, CH 9.17 ms 0.0% 5468.82 Mbps 4861.09 Mbps Sunrise Communication AG - Zurich
Frankfurt, DE 1.28 ms 23.0% 2317.32 Mbps 2592.36 Mbps Deutsche Telekom - Frankfurt am Main
Berlin, DE 9.87 ms 0.0% 4990.17 Mbps 782.70 Mbps Misaka Network, Inc. - Berlin
Vienna, AT 11.71 ms 0.0% 5454.01 Mbps 7093.56 Mbps A1 Telekom Austria AG - Vienna
Budapest, HU 13.90 ms 0.0% 5734.49 Mbps 1576.56 Mbps ATW Internet Kft. - Budapest
Gdansk, PL 41.26 ms 0.0% 1766.94 Mbps 930.30 Mbps T-Mobile Polska S.A. - Gdańsk
Warsaw, PL 19.10 ms 0.0% 3976.14 Mbps 4434.18 Mbps Orange Polska S.A. - Warsaw
Lviv, UA 26.49 ms 0.0% 4212.22 Mbps 1337.00 Mbps Kyivstar - Lviv
Kyiv, UA 27.40 ms 0.3% 3942.26 Mbps 683.01 Mbps O3 - Kyiv
Minsk, BY 22.05 ms 0.0% 4497.58 Mbps 2895.97 Mbps A1 - Minsk
Bucharest, RO 28.58 ms 0.0% 3844.61 Mbps 3072.90 Mbps Orange Romania SA - Bucuresti
Timisoara, RO 30.94 ms 0.0% 2754.43 Mbps 2956.88 Mbps Digi
Helsinki, FI 36.32 ms 0.0% 4308.18 Mbps 2430.74 Mbps Elisa Oyj - Helsinki
Stockholm, SE 29.18 ms 0.0% 3949.13 Mbps 2998.20 Mbps i3D.net - Stockholm
Oslo, NO FAILED
Moscow, RU 43.34 ms 0.0% 5526.30 Mbps 2147.03 Mbps MTS - Moscow
Petersburg, RU 32.26 ms 0.0% 4635.17 Mbps 2809.38 Mbps MegaFon - Saint Petersburg
Avg DL Speed : 4246.48 Mbps
Avg UL Speed : 3336.72 Mbps
Total DL Data : 170.15 GB
Total UL Data : 119.70 GB
Total Data : 289.85 GB
Duration : 12 min 48 sec
System Time : 14/04/2024 - 11:27:05 CEST
Total Script Runs : 40644
greencloud - supreme network!
ISP : 365 Online Technology Joint Stock Company
ASN : AS202602 365 Online Technology Joint Stock Company
Host : 365 Online Technology Joint Stock Company
ISP: 365 Online Technology Joint Stock Company
Nearest 0.47 ms 0.0% 9110.01 Mbps 9218.95 Mbps ServerRoom.net - Amsterdam
London, UK 7.10 ms 0.0% 9161.73 Mbps 7365.14 Mbps M247 Ltd - London
Manchester, UK 13.46 ms N/A 7670.44 Mbps 5942.98 Mbps Vodafone UK - Manchester
Dublin, IE 13.32 ms 0.0% 8070.86 Mbps 6290.78 Mbps Three Ireland - Dublin
Amsterdam, NL 1.28 ms 0.0% 9207.84 Mbps 7027.01 Mbps Melbicom - Amsterdam
Eygelshoen, NL 5.05 ms 0.0% 8979.06 Mbps 7873.11 Mbps SkyLink Data Center BV - Eygelshoven
Paris, FR 8.58 ms N/A 9225.39 Mbps 7756.99 Mbps ORANGE FRANCE - Paris
Marseille, FR 18.44 ms 0.0% 9178.37 Mbps 4855.42 Mbps GSL Networks - Marseille
Madrid, ES 28.47 ms 0.0% 7835.99 Mbps 3422.14 Mbps Orange - Madrid
Barcelona, ES 27.72 ms 0.0% 7294.94 Mbps 3121.36 Mbps Adamo - Barcelona
Lisbon, PT 32.31 ms 0.0% 8781.66 Mbps 2567.74 Mbps Edgoo Networks - Lisbon
Rome, IT 25.47 ms 0.0% 7550.13 Mbps 3407.71 Mbps TIM SpA - Rome
Milan, IT 15.58 ms 0.0% 7853.45 Mbps 4525.03 Mbps Fastweb SpA - Milan
Zurich, CH 17.85 ms 0.0% 9198.19 Mbps 3164.37 Mbps Sunrise Communication AG - Zurich
Frankfurt, DE 21.09 ms 26.4% 5223.22 Mbps 150.90 Mbps Deutsche Telekom - Frankfurt am Main
Berlin, DE 14.38 ms 0.0% 8523.11 Mbps 1070.61 Mbps Misaka Network, Inc. - Berlin
Vienna, AT 19.96 ms 0.0% 6840.52 Mbps 4390.64 Mbps A1 Telekom Austria AG - Vienna
Budapest, HU 21.84 ms 0.0% 8860.99 Mbps 1998.23 Mbps ATW Internet Kft. - Budapest
Gdansk, PL 53.45 ms 0.0% 2573.65 Mbps 1001.06 Mbps T-Mobile Polska S.A. - Gdańsk
Warsaw, PL 29.46 ms 0.0% 8798.47 Mbps 3012.64 Mbps Orange Polska S.A. - Warsaw
Lviv, UA 25.18 ms 0.0% 7229.68 Mbps 1715.88 Mbps Kyivstar - Lviv
Kyiv, UA 34.99 ms 0.0% 7346.96 Mbps 723.07 Mbps O3 - Kyiv
Minsk, BY 39.43 ms 0.0% 7974.22 Mbps 1986.30 Mbps A1 - Minsk
Bucharest, RO 34.88 ms 0.0% 7632.04 Mbps 2413.03 Mbps Orange Romania SA - Bucuresti
Timisoara, RO 43.33 ms 0.0% 9142.07 Mbps 3162.33 Mbps Digi
Helsinki, FI 23.06 ms 0.0% 9273.60 Mbps 3798.73 Mbps Elisa Oyj - Helsinki
Stockholm, SE 21.19 ms 0.0% 9224.80 Mbps 4070.27 Mbps i3D.net - Stockholm
Oslo, NO FAILED
Moscow, RU 43.20 ms 0.0% 7022.05 Mbps 841.14 Mbps MTS - Moscow
Petersburg, RU 36.33 ms 0.0% 8857.01 Mbps 2511.42 Mbps MegaFon - Saint Petersburg
Avg DL Speed : 8056.55 Mbps
Avg UL Speed : 3771.86 Mbps
Total DL Data : 303.80 GB
Total UL Data : 116.39 GB
Total Data : 420.19 GB
Duration : 12 min 50 sec
System Time : 14/04/2024 - 11:27:27 CEST
Total Script Runs : 40647
ISP : Hetzner Online GmbH - HostBRR
ASN : AS24940 Hetzner Online GmbH
ISP: Hetzner Online
Nearest 3.34 ms 0.0% 903.76 Mbps 858.83 Mbps Twerion.net | Minecraft Server - Frankfurt
London, UK 17.60 ms 0.0% 920.18 Mbps 915.02 Mbps M247 Ltd - London
Manchester, UK 31.25 ms N/A 914.97 Mbps 888.76 Mbps Vodafone UK - Manchester
Dublin, IE 26.37 ms 0.0% 949.31 Mbps 909.56 Mbps Three Ireland - Dublin
Amsterdam, NL 11.86 ms 0.0% 920.45 Mbps 228.44 Mbps Melbicom - Amsterdam
Eygelshoen, NL FAILED
Paris, FR FAILED
Madrid, ES FAILED
Lisbon, PT FAILED
Rome, IT FAILED
Milan, IT FAILED
Zurich, CH FAILED
Berlin, DE FAILED
Vienna, AT FAILED
Budapest, HU FAILED
Gdansk, PL FAILED
Warsaw, PL FAILED
Lviv, UA FAILED
Kyiv, UA FAILED
Minsk, BY FAILED
Timisoara, RO FAILED
Helsinki, FI FAILED
Stockholm, SE FAILED
Oslo, NO FAILED
Moscow, RU FAILED
Petersburg, RU FAILED
Avg DL Speed : 921.73 Mbps
Avg UL Speed : 760.12 Mbps
Total DL Data : 5.10 GB
Total UL Data : 4.43 GB
Total Data : 9.52 GB
Duration : 3 min 36 sec
System Time : 14/04/2024 - 10:18:30 BST
Total Script Runs : 40638
ISP : ip-network
ASN : AS48314 Michael Sebastian Schinzel trading as IP-Projects GmbH & Co. KG - HostBRR
ASN (IPv4) : AS48314 Michael Sebastian Schinzel trading as IP-Projects GmbH & Co. KG
Host : HostBrr Solutions
ISP: GHOSTnet
Nearest 0.82 ms 0.0% 926.58 Mbps 938.46 Mbps IP-Projects GmbH & Co. KG - Frankfurt
London, UK 13.76 ms 0.0% 938.03 Mbps 904.07 Mbps M247 Ltd - London
Manchester, UK 18.84 ms N/A 936.73 Mbps 929.06 Mbps Vodafone UK - Manchester
Dublin, IE 22.96 ms 0.0% 937.39 Mbps 925.10 Mbps Three Ireland - Dublin
Amsterdam, NL 8.05 ms N/A 935.83 Mbps 227.39 Mbps Melbicom - Amsterdam
Eygelshoen, NL 19.52 ms 0.0% 936.86 Mbps 912.09 Mbps SkyLink Data Center BV - Eygelshoven
Paris, FR 12.84 ms N/A 940.82 Mbps 928.17 Mbps ORANGE FRANCE - Paris
Marseille, FR 21.89 ms 0.0% 936.41 Mbps 923.25 Mbps GSL Networks - Marseille
Madrid, ES 31.27 ms 0.0% 942.82 Mbps 894.05 Mbps Orange - Madrid
Barcelona, ES 30.79 ms 0.0% 933.79 Mbps 906.15 Mbps Adamo - Barcelona
Lisbon, PT 111.82 ms 0.0% 938.49 Mbps 773.26 Mbps Edgoo Networks - Lisbon
Rome, IT 29.59 ms 0.0% 952.88 Mbps 895.05 Mbps TIM SpA - Rome
Milan, IT 19.65 ms 0.0% 959.08 Mbps 894.89 Mbps Fastweb SpA - Milan
Zurich, CH 9.95 ms 0.0% 932.09 Mbps 922.60 Mbps Sunrise Communication AG - Zurich
Frankfurt, DE 34.78 ms 20.3% 935.95 Mbps 763.99 Mbps Deutsche Telekom - Frankfurt am Main
Berlin, DE 12.76 ms 0.0% 934.62 Mbps 664.25 Mbps Misaka Network, Inc. - Berlin
Vienna, AT 32.61 ms 0.0% 940.40 Mbps 919.21 Mbps A1 Telekom Austria AG - Vienna
Budapest, HU 15.55 ms 0.0% 938.71 Mbps 706.53 Mbps ATW Internet Kft. - Budapest
Gdansk, PL 32.80 ms 0.0% 926.26 Mbps 595.17 Mbps T-Mobile Polska S.A. - Gdańsk
Warsaw, PL 23.63 ms 0.0% 939.60 Mbps 930.07 Mbps Orange Polska S.A. - Warsaw
Lviv, UA 29.04 ms 0.0% 945.86 Mbps 633.04 Mbps Kyivstar - Lviv
Kyiv, UA 40.71 ms 0.3% 509.04 Mbps 665.22 Mbps O3 - Kyiv
Minsk, BY 45.96 ms 0.0% 942.85 Mbps 786.90 Mbps A1 - Minsk
Bucharest, RO 42.20 ms 0.0% 941.34 Mbps 907.00 Mbps Orange Romania SA - Bucuresti
Timisoara, RO 19.12 ms 0.0% 936.82 Mbps 931.61 Mbps Digi
Helsinki, FI 30.02 ms 0.0% 939.97 Mbps 914.39 Mbps Elisa Oyj - Helsinki
Stockholm, SE 28.70 ms 0.0% 938.82 Mbps 920.47 Mbps i3D.net - Stockholm
Oslo, NO FAILED
Moscow, RU 46.31 ms 0.0% 931.03 Mbps 906.93 Mbps MTS - Moscow
Petersburg, RU 36.20 ms 0.0% 951.84 Mbps 892.92 Mbps MegaFon - Saint Petersburg
Avg DL Speed : 924.17 Mbps
Avg UL Speed : 831.42 Mbps
Total DL Data : 33.99 GB
Total UL Data : 28.65 GB
Total Data : 62.64 GB
Duration : 11 min 33 sec
System Time : 14/04/2024 - 10:26:08 BST
Total Script Runs : 40642
ISP : ColocationX Ltd.
ASN : AS208046 ColocationX Ltd. - HostSlick
Host : ColocationX Ltd
Location (IPv4) : Amsterdam, North Holland, NL
ISP: ColocationX
Nearest 8.04 ms N/A 835.28 Mbps 893.93 Mbps SYNLINQ - Frankfurt am Main
London, UK 7.74 ms 0.0% 873.02 Mbps 905.64 Mbps M247 Ltd - London
Manchester, UK 13.95 ms N/A 686.96 Mbps 877.43 Mbps Vodafone UK - Manchester
Dublin, IE 15.01 ms 0.0% 938.37 Mbps 872.27 Mbps Three Ireland - Dublin
Amsterdam, NL 2.19 ms 0.0% 925.59 Mbps 451.30 Mbps Melbicom - Amsterdam
Eygelshoen, NL 4.78 ms 0.0% 896.90 Mbps 928.87 Mbps SkyLink Data Center BV - Eygelshoven
Paris, FR 17.10 ms N/A 702.92 Mbps 915.37 Mbps ORANGE FRANCE - Paris
Marseille, FR 19.84 ms 0.0% 929.68 Mbps 804.13 Mbps GSL Networks - Marseille
Madrid, ES 38.13 ms 0.0% 953.56 Mbps 631.68 Mbps Orange - Madrid
Barcelona, ES 39.03 ms 0.0% 568.49 Mbps 855.99 Mbps Adamo - Barcelona
Lisbon, PT 35.11 ms 0.0% 524.63 Mbps 471.74 Mbps Edgoo Networks - Lisbon
Rome, IT 38.01 ms 0.5% 954.38 Mbps 573.33 Mbps TIM SpA - Rome
Milan, IT 17.07 ms 0.0% 572.41 Mbps 696.81 Mbps Fastweb SpA - Milan
Zurich, CH 16.77 ms 0.0% 637.75 Mbps 882.31 Mbps Sunrise Communication AG - Zurich
Berlin, DE 11.74 ms N/A 851.13 Mbps 648.35 Mbps Misaka Network, Inc. - Berlin
Vienna, AT 22.57 ms 0.0% 850.83 Mbps 801.32 Mbps A1 Telekom Austria AG - Vienna
Budapest, HU 28.00 ms 0.0% 415.26 Mbps 801.86 Mbps ATW Internet Kft. - Budapest
Gdansk, PL 26.42 ms 0.0% 572.08 Mbps 635.47 Mbps T-Mobile Polska S.A. - Gdańsk
Warsaw, PL 29.35 ms 0.0% 697.40 Mbps 679.58 Mbps Orange Polska S.A. - Warsaw
Lviv, UA 37.32 ms 0.0% 912.70 Mbps 755.67 Mbps Kyivstar - Lviv
Kyiv, UA 36.48 ms 0.0% 634.19 Mbps 877.25 Mbps O3 - Kyiv
Minsk, BY 40.48 ms 0.0% 940.41 Mbps 552.31 Mbps A1 - Minsk
Bucharest, RO 39.26 ms 0.0% 515.28 Mbps 732.45 Mbps Orange Romania SA - Bucuresti
Timisoara, RO 29.95 ms 0.0% 869.06 Mbps 379.33 Mbps Digi
Helsinki, FI 26.53 ms 0.0% 769.08 Mbps 731.55 Mbps Elisa Oyj - Helsinki
Stockholm, SE 23.71 ms 0.0% 621.15 Mbps 721.72 Mbps i3D.net - Stockholm
Oslo, NO FAILED
Moscow, RU 45.79 ms 0.0% 954.84 Mbps 913.80 Mbps MTS - Moscow
Petersburg, RU 39.26 ms 0.0% 944.52 Mbps 792.07 Mbps MegaFon - Saint Petersburg
Avg DL Speed : 769.57 Mbps
Avg UL Speed : 742.27 Mbps
Total DL Data : 27.34 GB
Total UL Data : 23.53 GB
Total Data : 50.88 GB
Duration : 10 min 51 sec
System Time : 14/04/2024 - 11:26:16 CEST
Total Script Runs : 40641
ISP : IONOS SE
ASN : AS8560 IONOS SE
Host : Strato AG
ISP: 1&1 Internet AG
Nearest 11.32 ms 0.0% 1219.29 Mbps 1796.17 Mbps KRHS.de Krefeld - Frankfurt
London, UK 25.00 ms 0.0% 2147.46 Mbps 1818.78 Mbps M247 Ltd - London
Manchester, UK 26.25 ms N/A 2129.74 Mbps 1881.62 Mbps Vodafone UK - Manchester
Dublin, IE 31.39 ms 0.0% 1079.56 Mbps 1735.88 Mbps Three Ireland - Dublin
Amsterdam, NL 21.61 ms 0.0% 1310.55 Mbps 508.56 Mbps Melbicom - Amsterdam
Eygelshoen, NL 24.73 ms 0.0% 1587.63 Mbps 1272.77 Mbps SkyLink Data Center BV - Eygelshoven
Paris, FR 25.05 ms N/A 2075.52 Mbps 1849.42 Mbps ORANGE FRANCE - Paris
Madrid, ES 47.33 ms 0.0% 1000.04 Mbps 1702.70 Mbps Orange - Madrid
Barcelona, ES 42.36 ms 0.0% 468.97 Mbps 1665.90 Mbps Adamo - Barcelona
Lisbon, PT 52.10 ms 0.0% 1644.00 Mbps 1597.15 Mbps Edgoo Networks - Lisbon
Rome, IT 30.99 ms 0.0% 1065.44 Mbps 1788.69 Mbps TIM SpA - Rome
Milan, IT 19.95 ms 0.0% 2010.56 Mbps 1814.41 Mbps Fastweb SpA - Milan
Zurich, CH 16.49 ms 0.0% 1930.01 Mbps 1843.38 Mbps Sunrise Communication AG - Zurich
Frankfurt, DE 9.66 ms 0.0% 1469.78 Mbps 1812.89 Mbps Deutsche Telekom - Frankfurt am Main
Berlin, DE 0.86 ms N/A 2697.96 Mbps 823.96 Mbps Misaka Network, Inc. - Berlin
Vienna, AT 22.32 ms 0.0% 1700.67 Mbps 1863.38 Mbps A1 Telekom Austria AG - Vienna
Budapest, HU 22.97 ms 0.0% 2537.95 Mbps 1840.75 Mbps ATW Internet Kft. - Budapest
Gdansk, PL 40.44 ms 0.0% 1489.27 Mbps 1703.46 Mbps T-Mobile Polska S.A. - Gdańsk
Warsaw, PL 41.23 ms 0.0% 1667.07 Mbps 1786.87 Mbps Orange Polska S.A. - Warsaw
Lviv, UA 43.51 ms 0.0% 1136.04 Mbps 1596.18 Mbps Kyivstar - Lviv
Kyiv, UA 38.43 ms 0.0% 1010.59 Mbps 1706.65 Mbps O3 - Kyiv
Minsk, BY 25.09 ms 0.0% 1088.73 Mbps 1859.31 Mbps A1 - Minsk
Bucharest, RO 39.17 ms 0.0% 2248.11 Mbps 1785.67 Mbps Orange Romania SA - Bucuresti
Timisoara, RO 64.40 ms 0.0% 1326.49 Mbps 1585.85 Mbps Digi
Helsinki, FI 31.94 ms 0.0% 1894.34 Mbps 1798.22 Mbps Elisa Oyj - Helsinki
Stockholm, SE 44.91 ms 0.0% 1947.84 Mbps 1642.68 Mbps i3D.net - Stockholm
Oslo, NO FAILED
Moscow, RU 59.19 ms 0.0% 1192.04 Mbps 1378.17 Mbps MTS - Moscow
Petersburg, RU 50.62 ms 0.0% 1114.39 Mbps 1061.61 Mbps MegaFon - Saint Petersburg
Avg DL Speed : 1578.21 Mbps
Avg UL Speed : 1625.76 Mbps
Total DL Data : 51.70 GB
Total UL Data : 59.01 GB
Total Data : 110.71 GB
Duration : 11 min 27 sec
System Time : 14/04/2024 - 09:27:13 UTC
Total Script Runs : 40646
ISP : IP Interactive
ASN : AS29551 Aixit GmbH - Layer7
Host : IP Interactive UG (haftungsbeschraenkt)
ISP: Aixit
Nearest 3.61 ms 0.0% 3953.74 Mbps 4926.14 Mbps Netcom Kassel Gesellschaft für Telekommunikation mbH - Kassel
London, UK 12.02 ms 0.0% 3993.57 Mbps 2018.38 Mbps M247 Ltd - London
Manchester, UK 18.75 ms N/A 4207.98 Mbps 1340.09 Mbps Vodafone UK - Manchester
Dublin, IE 18.98 ms 0.0% 3673.67 Mbps 1512.87 Mbps Three Ireland - Dublin
Amsterdam, NL 7.09 ms 0.0% 3632.73 Mbps 3082.36 Mbps Melbicom - Amsterdam
Eygelshoen, NL 12.90 ms 0.0% 3504.83 Mbps 2349.50 Mbps SkyLink Data Center BV - Eygelshoven
Paris, FR 9.40 ms N/A 2407.74 Mbps 1407.47 Mbps ORANGE FRANCE - Paris
Madrid, ES 29.68 ms 0.0% 3768.05 Mbps 948.91 Mbps Orange - Madrid
Barcelona, ES 35.33 ms 0.0% 2390.32 Mbps 882.63 Mbps Adamo - Barcelona
Lisbon, PT 110.27 ms 0.0% 2403.29 Mbps 392.59 Mbps Edgoo Networks - Lisbon
Rome, IT 22.96 ms 0.0% 3804.15 Mbps 1024.71 Mbps TIM SpA - Rome
Milan, IT 9.73 ms 0.0% 4208.25 Mbps 2054.11 Mbps Fastweb SpA - Milan
Zurich, CH 8.73 ms 0.0% 4123.68 Mbps 2501.14 Mbps Sunrise Communication AG - Zurich
Frankfurt, DE 0.90 ms 0.0% 4218.58 Mbps 4405.78 Mbps Deutsche Telekom - Frankfurt am Main
Berlin, DE 11.62 ms 0.0% 3899.29 Mbps 1487.74 Mbps Misaka Network, Inc. - Berlin
Vienna, AT 11.55 ms 0.0% 4012.79 Mbps 2361.21 Mbps A1 Telekom Austria AG - Vienna
Budapest, HU 14.22 ms 0.0% 4356.81 Mbps 1491.06 Mbps ATW Internet Kft. - Budapest
Gdansk, PL 20.03 ms 0.0% 3448.17 Mbps 1121.17 Mbps T-Mobile Polska S.A. - Gdańsk
Warsaw, PL 20.41 ms 0.0% 3850.58 Mbps 1539.03 Mbps Orange Polska S.A. - Warsaw
Lviv, UA 23.47 ms 0.3% 3667.91 Mbps 1106.57 Mbps Kyivstar - Lviv
Kyiv, UA 30.38 ms 0.0% 3738.80 Mbps 728.03 Mbps O3 - Kyiv
Minsk, BY 23.37 ms 0.0% 183.97 Mbps 1434.85 Mbps A1 - Minsk
Bucharest, RO 28.73 ms 0.0% 4044.37 Mbps 981.26 Mbps Orange Romania SA - Bucuresti
Timisoara, RO 24.75 ms 0.0% 3566.76 Mbps 1455.48 Mbps Digi
Helsinki, FI 26.49 ms 20.0% 2590.74 Mbps 107.95 Mbps Elisa Oyj - Helsinki
Stockholm, SE 24.38 ms 0.0% 4082.32 Mbps 916.45 Mbps i3D.net - Stockholm
Oslo, NO FAILED
Moscow, RU 37.85 ms 0.0% 3260.00 Mbps 826.22 Mbps MTS - Moscow
Petersburg, RU 31.81 ms 0.0% 3827.44 Mbps 935.66 Mbps MegaFon - Saint Petersburg
Avg DL Speed : 3529.30 Mbps
Avg UL Speed : 1619.26 Mbps
Total DL Data : 123.68 GB
Total UL Data : 54.34 GB
Total Data : 178.02 GB
Duration : 11 min 11 sec
System Time : 14/04/2024 - 09:27:10 UTC
Total Script Runs : 40645
ISP : Hosting Bot, LLC
ASN : AS400402 Hosting Bot, LLC - Linveo
ASN (IPv4) : AS62564 LINVEO, LLC
Host : Hosting Bot, LLC
ISP: EGIHosting
Nearest 8.34 ms 0.0% 7283.81 Mbps 2399.93 Mbps Cox - Wichita - Wichita, KS
London, UK 114.10 ms 0.0% 1.21 Mbps 698.84 Mbps M247 Ltd - London
Manchester, UK 135.78 ms N/A 409.34 Mbps 440.09 Mbps Vodafone UK - Manchester
Network error: Software caused connection abort
ISP : Ian David Klemm
ASN : AS200461 Ian David Klemm - v6node
Host : Ian David Klemm
Location (IPv4) : Frankfurt am Main, Hesse, DE
ISP: combahton IT Services
Nearest 4.27 ms 0.0% 778.72 Mbps 722.09 Mbps Jonas de Vries
London, UK 11.23 ms 0.0% 6636.07 Mbps 3179.66 Mbps M247 Ltd - London
Manchester, UK 20.28 ms N/A 6720.64 Mbps 2070.34 Mbps Vodafone UK - Manchester
Dublin, IE 28.67 ms 0.0% 6387.33 Mbps 1299.89 Mbps Three Ireland - Dublin
Amsterdam, NL 6.92 ms 0.0% 6178.44 Mbps 4436.47 Mbps Melbicom - Amsterdam
Eygelshoen, NL 7.95 ms 0.6% 6724.10 Mbps 3061.14 Mbps SkyLink Data Center BV - Eygelshoven
Paris, FR 8.94 ms N/A 2918.24 Mbps 864.69 Mbps ORANGE FRANCE - Paris
Madrid, ES 28.87 ms 0.0% 6136.78 Mbps 1239.85 Mbps Orange - Madrid
Barcelona, ES 30.80 ms 0.0% 5877.80 Mbps 1685.43 Mbps Adamo - Barcelona
Lisbon, PT 40.73 ms 0.0% 5737.40 Mbps 1369.17 Mbps Edgoo Networks - Lisbon
Rome, IT 28.62 ms 0.0% 6325.54 Mbps 1416.84 Mbps TIM SpA - Rome
Milan, IT 10.19 ms 0.0% 6358.33 Mbps 2736.72 Mbps Fastweb SpA - Milan
Zurich, CH 8.93 ms 0.0% 6749.82 Mbps 4086.78 Mbps Sunrise Communication AG - Zurich
Frankfurt, DE 1.37 ms 10.2% 5776.25 Mbps 3209.18 Mbps Deutsche Telekom - Frankfurt am Main
Berlin, DE 11.51 ms 0.0% 6163.28 Mbps 1993.57 Mbps Misaka Network, Inc. - Berlin
Vienna, AT 12.68 ms 0.0% 6388.18 Mbps 2794.22 Mbps A1 Telekom Austria AG - Vienna
Budapest, HU 14.05 ms 0.0% 6675.06 Mbps 2258.26 Mbps ATW Internet Kft. - Budapest
Gdansk, PL 20.23 ms 0.0% 3432.17 Mbps 1661.58 Mbps T-Mobile Polska S.A. - Gdańsk
Warsaw, PL 28.38 ms 0.0% 6180.64 Mbps 1136.38 Mbps Orange Polska S.A. - Warsaw
Lviv, UA 25.47 ms 0.0% 6615.85 Mbps 1740.11 Mbps Kyivstar - Lviv
Kyiv, UA 29.40 ms 0.0% 5552.14 Mbps 1205.23 Mbps O3 - Kyiv
Minsk, BY FAILED
Bucharest, RO 27.74 ms 0.0% 6093.80 Mbps 1562.35 Mbps Orange Romania SA - Bucuresti
Timisoara, RO 29.85 ms 0.0% 6158.35 Mbps 1616.01 Mbps Digi
Helsinki, FI 30.03 ms 0.0% 6816.96 Mbps 1327.56 Mbps Elisa Oyj - Helsinki
Stockholm, SE 28.11 ms 1.0% 6451.32 Mbps 1633.01 Mbps i3D.net - Stockholm
Oslo, NO FAILED
Moscow, RU 34.05 ms 0.0% 6148.26 Mbps 1304.24 Mbps MTS - Moscow
Petersburg, RU 33.10 ms 0.0% 5653.92 Mbps 1343.46 Mbps MegaFon - Saint Petersburg
Avg DL Speed : 5838.33 Mbps
Avg UL Speed : 1961.27 Mbps
Total DL Data : 207.00 GB
Total UL Data : 74.78 GB
Total Data : 281.78 GB
Duration : 11 min 38 sec
System Time : 14/04/2024 - 09:28:06 UTC
Total Script Runs : 40648
ISP : xTom GmbH
ASN : AS3214 xTom GmbH
Host : xTom Customer - Frankfurt
ISP: xTom
Nearest 0.92 ms N/A 1843.87 Mbps 1815.01 Mbps Deutsche Glasfaser - Frankfurt
London, UK 13.16 ms 0.0% 939.38 Mbps 870.32 Mbps M247 Ltd - London
Manchester, UK 18.98 ms N/A 1798.19 Mbps 710.62 Mbps Vodafone UK - Manchester
Dublin, IE 29.06 ms 0.0% 1723.28 Mbps 1301.70 Mbps Three Ireland - Dublin
Amsterdam, NL 8.64 ms 0.0% 925.87 Mbps 1794.96 Mbps Melbicom - Amsterdam
Eygelshoen, NL 11.59 ms 0.0% 1825.04 Mbps 1607.87 Mbps SkyLink Data Center BV - Eygelshoven
Paris, FR 8.87 ms N/A 1672.66 Mbps 787.67 Mbps ORANGE FRANCE - Paris
Madrid, ES 28.82 ms 0.0% 1831.48 Mbps 1520.70 Mbps Orange - Madrid
Barcelona, ES 30.98 ms 0.0% 1694.37 Mbps 632.94 Mbps Adamo - Barcelona
Lisbon, PT 40.05 ms 0.0% 1508.24 Mbps 1028.22 Mbps Edgoo Networks - Lisbon
Rome, IT 22.70 ms 0.0% 1861.59 Mbps 937.81 Mbps TIM SpA - Rome
Milan, IT 12.36 ms 0.0% 448.03 Mbps 1221.85 Mbps Fastweb SpA - Milan
Zurich, CH 11.03 ms 0.0% 933.22 Mbps 1794.78 Mbps Sunrise Communication AG - Zurich
Frankfurt, DE 20.34 ms 1.0% 1820.71 Mbps 1059.43 Mbps Deutsche Telekom - Frankfurt am Main
Berlin, DE 11.75 ms N/A 1813.10 Mbps 916.61 Mbps Misaka Network, Inc. - Berlin
Vienna, AT 11.77 ms 0.0% 1850.45 Mbps 1806.26 Mbps A1 Telekom Austria AG - Vienna
Budapest, HU 14.37 ms 0.0% 1060.91 Mbps 1788.53 Mbps ATW Internet Kft. - Budapest
Gdansk, PL 45.37 ms 0.0% 1484.41 Mbps 557.63 Mbps T-Mobile Polska S.A. - Gdańsk
Warsaw, PL 19.71 ms 0.0% 1054.77 Mbps 1806.05 Mbps Orange Polska S.A. - Warsaw
Lviv, UA 28.42 ms 0.0% 1843.10 Mbps 1817.15 Mbps Kyivstar - Lviv
Kyiv, UA 27.80 ms 0.0% 1816.71 Mbps 1640.22 Mbps O3 - Kyiv
Minsk, BY 22.73 ms 0.0% 1853.22 Mbps 1584.36 Mbps A1 - Minsk
Bucharest, RO 29.01 ms 0.0% 1870.76 Mbps 1616.03 Mbps Orange Romania SA - Bucuresti
Timisoara, RO 27.83 ms 0.0% 1769.23 Mbps 1576.24 Mbps Digi
Helsinki, FI 22.63 ms 43.0% 1688.80 Mbps 62.99 Mbps Elisa Oyj - Helsinki
Stockholm, SE 29.01 ms 0.0% 1754.30 Mbps 1589.51 Mbps i3D.net - Stockholm
Oslo, NO FAILED
Moscow, RU 43.81 ms 0.0% 1588.65 Mbps 1346.64 Mbps MTS - Moscow
Petersburg, RU 41.22 ms 0.0% 1663.59 Mbps 1383.67 Mbps MegaFon - Saint Petersburg
Avg DL Speed : 1569.21 Mbps
Avg UL Speed : 1306.27 Mbps
Total DL Data : 60.43 GB
Total UL Data : 43.53 GB
Total Data : 103.96 GB
Duration : 11 min 32 sec
System Time : 14/04/2024 - 05:28:14 EDT
Total Script Runs : 40649
Aéza LNDs-1 in London, United Kingdom 🇬🇧 for 8.51€/month.
Test to Europe. (spoiler: 27Gbps :O)
Version : v2024.04.14
Basic System Info
CPU Model : AMD Ryzen 9 7950X3D 16-Core Processor
CPU Cores : 1 @ 4191.860 MHz
CPU Cache : 512 KB
AES-NI : ✔ Enabled
VM-x/AMD-V : ❌ Disabled
Total Disk : 29.4 GB (2.8 GB Used)
Total RAM : 1.9 GB (253.0 MB Used)
Total Swap : 512.0 MB (780.0 KB Used)
System uptime : 0 days, 0 hour 24 min
Load average : 0.00, 0.13, 0.19
OS : Ubuntu 24.04 LTS
Kernel : 6.8.0-31-generic
TCP Control : bbr
Basic Network Info
ISP : Aeza International LTD
ASN : AS210644 AEZA INTERNATIONAL LTD
Host : Aeza International LTD
ISP: Aeza International
Nearest 0.20 ms 0.0% 27891.14 Mbps 18874.47 Mbps Aeza.net - London
London, UK 10.79 ms 0.0% 2779.37 Mbps 7477.46 Mbps M247 Ltd - London
Manchester, UK 6.45 ms N/A 9296.00 Mbps 9202.51 Mbps Vodafone UK - Manchester
Dublin, IE 10.70 ms 0.0% 9295.33 Mbps 7735.91 Mbps Three Ireland - Dublin
Amsterdam, NL 6.02 ms 0.0% 8666.46 Mbps 10388.04 Mbps Melbicom - Amsterdam
Eygelshoen, NL 11.75 ms 0.0% 11631.78 Mbps 2725.36 Mbps SkyLink Data Center BV - Eygelshoven
Paris, FR 7.82 ms N/A 10265.42 Mbps 8889.48 Mbps ORANGE FRANCE - Paris
Madrid, ES 27.42 ms 0.0% 9734.06 Mbps 3077.65 Mbps Orange - Madrid
Barcelona, ES 27.85 ms 0.0% 7758.20 Mbps 2950.37 Mbps Adamo - Barcelona
Lisbon, PT 34.01 ms 0.0% 10507.48 Mbps 2361.54 Mbps Edgoo Networks - Lisbon
Rome, IT 34.50 ms 0.0% 8818.58 Mbps 2433.43 Mbps TIM SpA - Rome
Milan, IT 27.44 ms 0.0% 4388.42 Mbps 3017.06 Mbps Fastweb SpA - Milan
Zurich, CH 20.14 ms 0.0% 11161.08 Mbps 3982.62 Mbps Sunrise Communication AG - Zurich
Frankfurt, DE 12.69 ms 21.4% 6904.82 Mbps 3807.66 Mbps Deutsche Telekom - Frankfurt am Main
Berlin, DE 20.16 ms 0.0% 7167.54 Mbps 4060.86 Mbps Misaka Network, Inc. - Berlin
Vienna, AT 23.43 ms 0.0% 9285.30 Mbps 3511.45 Mbps A1 Telekom Austria AG - Vienna
Budapest, HU 26.42 ms 0.0% 12613.43 Mbps 3318.11 Mbps ATW Internet Kft. - Budapest
Gdansk, PL 31.95 ms 0.0% 4501.28 Mbps 2664.00 Mbps T-Mobile Polska S.A. - Gdańsk
Warsaw, PL 30.01 ms 0.0% 9124.60 Mbps 2720.15 Mbps Orange Polska S.A. - Warsaw
Lviv, UA FAILED
Kyiv, UA 42.67 ms 0.0% 8472.30 Mbps 1986.12 Mbps O3 - Kyiv
Bucharest, RO 44.37 ms 0.0% 11714.05 Mbps 1881.65 Mbps Orange Romania SA - Bucuresti
Timisoara, RO 40.60 ms 0.0% 9524.03 Mbps 1965.28 Mbps Digi
Helsinki, FI 34.71 ms 0.0% 10027.70 Mbps 2360.11 Mbps Elisa Oyj - Helsinki
Stockholm, SE 26.89 ms 0.0% 8149.80 Mbps 3114.97 Mbps i3D.net - Stockholm
Oslo, NO 26.15 ms 0.0% 3071.46 Mbps 3215.61 Mbps Telia Norge AS - Oslo
Moscow, RU 46.90 ms 0.0% 6483.29 Mbps 1749.81 Mbps MTS - Moscow
Petersburg, RU 39.39 ms 0.0% 8737.30 Mbps 2085.79 Mbps MegaFon - Saint Petersburg
Istanbul, TR 56.62 ms N/A 7127.97 Mbps 1729.32 Mbps Turkcell - Istanbul
Avg DL Speed : 9110.61 Mbps
Avg UL Speed : 4403.11 Mbps
Total DL Data : 312.50 GB
Total UL Data : 158.80 GB
Total Data : 471.30 GB
Duration : 11 min 35 sec
System Time : 26/04/2024 - 11:33:26 BST
Total Script Runs : 41684
Result : https://result.network-speed.xyz/r/1714127091_AK2YOV_EU.txt
Basic System Info
CPU Model : AMD EPYC 7352 24-Core Processor
CPU Cores : 1 @ 2295.636 MHz
CPU Cache : 512 KB
AES-NI : ✔ Enabled
Total Disk : 29.4 GB (4.6 GB Used)
Total RAM : 1.9 GB (147.5 MB Used)
System uptime : 0 days, 3 hour 48 min
OS : Ubuntu 22.04.4 LTS
Kernel : 5.15.0-105-generic
TCP Control : cubic
Basic Network Info
ISP : ReadyDedis, LLC
ASN : AS140543 ReadyDedis, LLC
Host : Bconnect
Location (IPv4) : Hyderābād, Telangana, IN
Speedtest.net (Region: ASIA)
ISP: ReadyDedis
Nearest 9.66 ms N/A 716.34 Mbps 842.78 Mbps Jio - Nagpur
Tokyo, JP 126.84 ms 0.0% 557.35 Mbps 255.00 Mbps Rakuten Mobile, Inc - Tokyo
Tapei, TW 214.30 ms N/A 550.11 Mbps 260.45 Mbps Chunghwa Mobile - Taipei
China Telecom 296.71 ms 3.36 Mbps FAILED China Telecom JiangSu 5G - Nanjing
China Unicom 109.01 ms 1.3% 482.25 Mbps 539.32 Mbps China Unicom 5G - Shanghai
China Mobile FAILED
Hong Kong, CN 77.22 ms 0.0% 565.48 Mbps 771.53 Mbps i3D.net - Hong Kong
Ho Chi Minh, VN 72.38 ms 0.0% 763.06 Mbps 735.86 Mbps VNPT-NET - Ho Chi Minh
Hanoi, VN 82.08 ms 0.0% 921.33 Mbps 772.72 Mbps FPT Telecom - Hanoi
Bangkok, TH 69.83 ms 0.0% 547.52 Mbps 579.54 Mbps 3BB - Bangkok
Manila, PH 91.45 ms N/A 361.22 Mbps 738.38 Mbps PLDT - Manila
Singapore, SG 44.86 ms 0.0% 633.37 Mbps 807.49 Mbps MyRepublic Singapore - Singapore
Singapore, SG 47.55 ms N/A 710.41 Mbps 785.13 Mbps StarHub Ltd - Singapore
Jakarta, ID 55.11 ms 0.0% 607.84 Mbps 696.99 Mbps PT Indosat Tbk - Jakarta
Surabaya, ID 69.37 ms N/A 619.00 Mbps 748.17 Mbps PT. Indonesia Comnets Plus - Surabaya
Kuala Lum, MY 49.28 ms 0.5% 610.65 Mbps 785.15 Mbps Telekom Malaysia Berhad - Kuala Lumpur
Mumbai, IN 12.94 ms 0.0% 751.07 Mbps 844.44 Mbps i3D.net - Mumbai
Chennai, IN 12.19 ms N/A 686.05 Mbps 830.10 Mbps Jio - Chennai
Bangalore, IN 29.72 ms 0.0% 687.24 Mbps 821.64 Mbps Bharti Airtel Ltd - Bangalore
Karachi, PK 289.61 ms 0.0% 26.09 Mbps 155.11 Mbps JAZZ - Karachi
Islamabad, PK 141.37 ms 4.3% 517.12 Mbps 605.92 Mbps Ufone - Islamabad
Kathmandu, NP 61.79 ms 1.1% 620.42 Mbps 832.22 Mbps Ncell Axiata Ltd - Kathmandu
Colombo, SL 170.15 ms N/A 460.59 Mbps 448.50 Mbps Airtel Lanka - Colombo
Dhaka, BD 47.25 ms N/A 514.17 Mbps 765.68 Mbps Grameenphone Ltd - Dhaka
Novosibirsk, RU 225.45 ms 3.0% 538.34 Mbps 4.19 Mbps MegaFon - Novosibirsk
Almaty, KZ 316.31 ms 0.0% 485.68 Mbps 250.95 Mbps Kazakhtelecom - Almaty
Tehran, IR 215.39 ms 5.3% 525.70 Mbps 293.47 Mbps Irancell - Tehran
Dubai, AE 63.01 ms N/A 906.21 Mbps 249.11 Mbps ETISALAT-UAE - Dubai
Jeddah, SA 174.61 ms 0.3% 622.78 Mbps 491.77 Mbps Mobily - Jeddah
Istanbul, TR 175.96 ms 0.7% 696.53 Mbps 462.74 Mbps Vodafone TR - Istanbul
Avg DL Speed : 575.42 Mbps
Avg UL Speed : 564.63 Mbps
Total DL Data : 21.86 GB
Total UL Data : 20.72 GB
Total Data : 42.59 GB
Duration : 14 min 15 sec
System Time : 29/04/2024 - 09:06:43 UTC
Total Script Runs : 41915
Result : https://result.network-speed.xyz/r/1714381064_C4NI9S_ASIA.txt
Basic System Info
CPU Cache : 512 KB
AES-NI : ✔ Enabled
Total RAM : 1.9 GB (177.9 MB Used)
System uptime : 0 days, 2 hour 30 min
TCP Control : cubic
Basic Network Info
Host : Bconnect
ISP: ReadyDedis
Nearest 10.20 ms N/A 767.91 Mbps 842.65 Mbps Jio - Nagpur
Kochi, IN 24.93 ms 0.0% 581.83 Mbps 845.22 Mbps Asianet Broadband - Cochin
Bangalore, IN 27.07 ms 0.0% 442.09 Mbps 843.08 Mbps Bharti Airtel Ltd - Bangalore
Chennai, IN 12.81 ms N/A 695.60 Mbps 849.70 Mbps Jio - Chennai
Mumbai, IN 12.00 ms 0.0% 619.91 Mbps 818.66 Mbps i3D.net - Mumbai
Delhi, IN 62.48 ms 0.0% 568.82 Mbps 448.45 Mbps Tata Play Fiber - New Delhi
Seattle, US 262.49 ms N/A 528.48 Mbps 245.53 Mbps Comcast - Seattle, WA
Los Angeles, US 216.16 ms 0.0% 452.00 Mbps 350.25 Mbps ReliableSite Hosting - Los Angeles, CA
Dallas, US 241.83 ms 0.0% 405.79 Mbps 263.59 Mbps Hivelocity - Dallas, TX
Miami, US 260.78 ms N/A 407.69 Mbps 326.69 Mbps Dish Wireless - Miami, FL
New York, US 233.60 ms 0.7% 872.12 Mbps 385.46 Mbps GSL Networks - New York, NY
Toronto, CA 252.55 ms 0.0% 559.24 Mbps 265.42 Mbps Rogers - Toronto, ON
Mexico City, MX 288.38 ms N/A 426.64 Mbps 302.52 Mbps INFINITUM - Mexico City
London, UK 143.77 ms 0.0% 920.49 Mbps 575.53 Mbps VeloxServ Communications - London
Amsterdam, NL 132.30 ms 1.0% 915.31 Mbps 534.80 Mbps 31173 Services AB - Amsterdam
Paris, FR 150.88 ms N/A 903.51 Mbps 394.80 Mbps Axione - Paris
Frankfurt, DE 139.44 ms 3.5% 366.43 Mbps 399.05 Mbps Clouvider Ltd - Frankfurt am Main
Warsaw, PL 141.16 ms 0.3% 911.93 Mbps 540.87 Mbps Play - Warszawa
Bucharest, RO 165.83 ms 7.7% 512.53 Mbps 254.53 Mbps Vodafone Romania Fixed – Bucharest - Bucharest
Moscow, RU 166.61 ms 0.0% 742.89 Mbps 390.22 Mbps MegaFon - Moscow
Jeddah, SA 160.84 ms 1.0% 911.87 Mbps 308.01 Mbps Saudi Telecom Company
Dubai, AE 257.87 ms 0.7% 805.15 Mbps 322.87 Mbps du - Dubai
Fujairah, AE 62.49 ms 0.3% 927.10 Mbps 773.97 Mbps ETISALAT-UAE - Fujairah
Istanbul, TR 162.27 ms 7.7% 601.49 Mbps 529.17 Mbps Turkcell - Istanbul
Tehran, IR 222.89 ms 0.0% 429.13 Mbps 357.69 Mbps Asiatech - Tehran
Tokyo, JP 140.37 ms N/A 634.07 Mbps 568.18 Mbps fdcservers.net - Tokyo
Shanghai, CU-CN FAILED
Nanjing, CT-CN FAILED
Hong Kong, CN 89.01 ms N/A 583.54 Mbps 685.80 Mbps STC - Hong Kong
Singapore, SG 42.32 ms 0.5% 605.22 Mbps 764.97 Mbps i3D.net - Singapore
Jakarta, ID FAILED - IP has been rate limited. Try again after 1 hour.
Avg DL Speed : 646.38 Mbps
Avg UL Speed : 506.71 Mbps
Total DL Data : 25.02 GB
Total UL Data : 18.43 GB
Total Data : 43.45 GB
Duration : 14 min 36 sec
System Time : 29/04/2024 - 07:49:35 UTC
Total Script Runs : 41912
Result : https://result.network-speed.xyz/r/1714376437_5WYBMV_GLOBAL.txt
Basic System Info
CPU Model : Intel(R) Xeon(R) E-2278G CPU @ 3.40GHz
CPU Cores : 2 @ 3408.032 MHz
CPU Cache : 16384 KB
AES-NI : ✔ Enabled
Total Disk : 29.8 GB (1.5 GB Used)
Total RAM : 1.9 GB (73.7 MB Used)
System uptime : 0 days, 0 hour 51 min
Load average : 0.29, 0.78, 0.60
TCP Control : cubic
Basic Network Info
Host : Inception
ISP: Clouvider Limited
Nearest 0.42 ms 0.0% 6513.56 Mbps 5683.13 Mbps Clouvider Ltd - Amsterdam
Kochi, IN 160.74 ms 0.0% 2761.20 Mbps 246.22 Mbps Asianet Broadband - Cochin
Bangalore, IN 148.12 ms 0.0% 3240.58 Mbps 146.43 Mbps Bharti Airtel Ltd - Bangalore
Chennai, IN 141.73 ms N/A 3425.86 Mbps 5.66 Mbps Jio - Chennai
Mumbai, IN 129.97 ms 0.0% 2845.33 Mbps 345.25 Mbps i3D.net - Mumbai
Delhi, IN 168.47 ms 0.0% 3904.20 Mbps 313.44 Mbps Tata Play Fiber - New Delhi
Seattle, US 141.28 ms N/A 2593.06 Mbps 294.97 Mbps Comcast - Seattle, WA
Los Angeles, US 135.10 ms 0.0% 2958.21 Mbps 376.52 Mbps ReliableSite Hosting - Los Angeles, CA
Dallas, US 109.90 ms 0.0% 1686.83 Mbps 277.66 Mbps Hivelocity - Dallas, TX
Miami, US 112.15 ms N/A 1569.53 Mbps 216.10 Mbps Dish Wireless - Miami, FL
New York, US 72.02 ms 0.0% 4677.23 Mbps 109.17 Mbps GSL Networks - New York, NY
Toronto, CA 91.85 ms 0.0% 1477.65 Mbps 248.16 Mbps Rogers - Toronto, ON
Mexico City, MX 153.45 ms N/A 2426.51 Mbps 268.53 Mbps INFINITUM - Mexico City
London, UK 5.83 ms 0.4% 6413.49 Mbps 880.24 Mbps VeloxServ Communications - London
Amsterdam, NL 1.06 ms 0.0% 4597.49 Mbps 2975.38 Mbps 31173 Services AB - Amsterdam
Paris, FR 11.13 ms N/A 7960.83 Mbps 495.50 Mbps Axione - Paris
Frankfurt, DE 5.94 ms 0.0% 3046.94 Mbps 848.35 Mbps Clouvider Ltd - Frankfurt am Main
Warsaw, PL 21.83 ms 4.3% 6112.54 Mbps 324.05 Mbps Play - Warszawa
Bucharest, RO 34.37 ms 0.0% 2192.63 Mbps 243.62 Mbps Vodafone Romania Fixed – Bucharest - Bucharest
Moscow, RU 39.39 ms 0.0% 3479.42 Mbps 449.07 Mbps MegaFon - Moscow
Jeddah, SA 68.27 ms 1.0% 4528.93 Mbps 331.86 Mbps Saudi Telecom Company
Dubai, AE 121.91 ms 0.0% 3105.98 Mbps 290.87 Mbps du - Dubai
Fujairah, AE 113.27 ms 0.0% 3574.67 Mbps 212.00 Mbps ETISALAT-UAE - Fujairah
Istanbul, TR 44.45 ms 0.0% 3288.14 Mbps 335.60 Mbps Turkcell - Istanbul
Tehran, IR 85.20 ms 0.0% 2044.27 Mbps 170.84 Mbps Asiatech - Tehran
Tokyo, JP 259.34 ms N/A 266.84 Mbps 60.10 Mbps fdcservers.net - Tokyo
Shanghai, CU-CN 237.67 ms 0.0% 1206.60 Mbps 192.25 Mbps China Unicom 5G - Shanghai
Nanjing, CT-CN 429.82 ms 7.7% 1615.36 Mbps 0.72 Mbps China Telecom JiangSu 5G - Nanjing
Hong Kong, CN 181.06 ms N/A 2685.02 Mbps 83.91 Mbps STC - Hong Kong
Singapore, SG 331.01 ms 3.0% 2389.45 Mbps 120.71 Mbps i3D.net - Singapore
Avg DL Speed : 3286.27 Mbps
Avg UL Speed : 551.54 Mbps
Total DL Data : 139.31 GB
Total UL Data : 26.41 GB
Total Data : 165.72 GB
Duration : 15 min 45 sec
System Time : 04/05/2024 - 14:34:34 UTC
Total Script Runs : 42450
curl is not installed, Unable to share result online
Result stored locally in /root/network-speed.txt
From Crunchbits Discord:
@lapua it's back up now.
Papa Crunchbits is fast!
Well.
It does.
Nah, not this one.
If possible, could you test with this
https://www.speedtest.net/apps/cli
Yea turns out, the VPS had no resolvable hostname.
15Y roughly 1.8€ CN2 VPS
https://www.yanhuoidc.com/cart
2.6€ Akile Cloud Taiwan VPS
@sh97:
---------------------------- network-speed.xyz ---------------------------- A simple script to test network performance using speedtest-cli --------------------------------------------------------------------------- Version : v2024.04.04 Global Speedtest : wget -qO- network-speed.xyz | bash Region Speedtest : wget -qO- network-speed.xyz | bash -s -- -r --------------------------------------------------------------------------- Basic System Info --------------------------------------------------------------------------- CPU Model : AMD Ryzen Threadripper 3970X 32-Core Processor CPU Cores : 1 @ 3699.940 MHz CPU Cache : 512 KB AES-NI : ✔ Enabled VM-x/AMD-V : ✔ Enabled Total Disk : 47,2 GB (6,7 GB Used) Total RAM : 1,9 GB (233,6 MB Used) Total Swap : 4,0 GB (1,5 MB Used) System uptime : 53 days, 17 hour 22 min Load average : 0.00, 0.00, 0.00 OS : Debian GNU/Linux 12 Arch : x86_64 (64 Bit) Kernel : 6.1.0-18-amd64 Virtualization : KVM TCP Control : cubic --------------------------------------------------------------------------- Basic Network Info --------------------------------------------------------------------------- Primary Network : IPv6 IPv6 Access : ✔ Online IPv4 Access : ✔ Online ISP : dataforest GmbH ASN : AS58212 dataforest GmbH Host : Harmony Solutions GmbH Location : Kelkheim, Hesse-HE, Germany --------------------------------------------------------------------------- Speedtest.net (Region: EUROPE) --------------------------------------------------------------------------- Location Latency Loss DL Speed UP Speed Server ISP: dataforest Nearest 0.54 ms 0.0% 6214.45 Mbps 6217.38 Mbps FynnCraft Minecraft Network - Dortmund London, UK 10.87 ms 0.0% 9175.87 Mbps 3793.64 Mbps M247 Ltd - London Manchester, UK 20.69 ms N/A 8488.43 Mbps 2581.18 Mbps Vodafone UK - Manchester Dublin, IE 26.78 ms 0.0% 9116.57 Mbps 2546.51 Mbps Three Ireland - Dublin Amsterdam, NL 7.11 ms 0.0% 8609.48 Mbps 6056.65 Mbps Melbicom - Amsterdam Eygelshoen, NL 10.91 ms 0.0% 6334.56 Mbps 2913.68 Mbps SkyLink Data Center BV - Eygelshoven awk: line 1: 21492e+119159 : decimal overflow awk: line 1: 21738e+112564 : decimal overflow Paris, FR 8.72 ms N/A 6258.50 Mbps 2868.36 Mbps ORANGE FRANCE - Paris Marseille, FR 16.44 ms 0.0% 8707.60 Mbps 3195.38 Mbps GSL Networks - Marseille Madrid, ES 28.66 ms 0.0% 7926.76 Mbps 2814.66 Mbps Orange - Madrid awk: line 1: 601e+1044 : decimal overflow awk: line 1: 3122e+1381 : decimal overflow Barcelona, ES 25.04 ms 0.0% 9335.31 Mbps 2971.13 Mbps Adamo - Barcelona awk: line 1: syntax error at or near ; awk: line 1: syntax error at or near ; Lisbon, PT 38.79 ms 0.0% 4906.00 Mbps 1835.28 Mbps Edgoo Networks - Lisbon awk: line 1: syntax error at or near ; awk: line 1: syntax error at or near ; Rome, IT 25.80 ms 0.0% 8589.44 Mbps 1876.57 Mbps TIM SpA - Rome awk: line 1: syntax error at or near ; awk: line 1: syntax error at or near ; awk: line 1: 25887e+119411 : decimal overflow awk: line 1: 86832e+113037 : decimal overflow Milan, IT 21.72 ms 0.0% 3260.63 Mbps 2308.20 Mbps Fastweb SpA - Milan awk: line 1: syntax error at or near ; awk: line 1: syntax error at or near ; Zurich, CH 9.38 ms 0.0% 7759.97 Mbps 4502.49 Mbps Sunrise Communication AG - Zurich awk: line 1: syntax error at or near ; awk: line 1: syntax error at or near ; Frankfurt, DE 0.82 ms 3.0% 7180.93 Mbps 6006.11 Mbps Deutsche Telekom - Frankfurt am Main awk: line 1: syntax error at or near ; awk: line 1: syntax error at or near ; Berlin, DE 11.38 ms N/A 8232.92 Mbps 871.67 Mbps Misaka Network, Inc. - Berlin awk: line 1: syntax error at or near ; awk: line 1: syntax error at or near ; Vienna, AT 15.73 ms 0.0% 9305.56 Mbps 3726.91 Mbps A1 Telekom Austria AG - Vienna awk: line 1: syntax error at or near ; awk: line 1: syntax error at or near ; Budapest, HU 14.16 ms 0.0% 6463.39 Mbps 2324.60 Mbps ATW Internet Kft. - Budapest awk: line 1: syntax error at or near ; awk: line 1: syntax error at or near ; awk: line 1: 26078e+118325 : decimal overflow awk: line 1: 30845e+11882 : decimal overflow Gdansk, PL 28.94 ms 0.0% 338.42 Mbps 2629.28 Mbps T-Mobile Polska S.A. - Gdańsk awk: line 1: syntax error at or near ; awk: line 1: syntax error at or near ; Warsaw, PL 18.55 ms 0.0% 8278.06 Mbps 3320.70 Mbps Orange Polska S.A. - Warsaw awk: line 1: syntax error at or near ; awk: line 1: syntax error at or near ; Lviv, UA 24.23 ms 0.0% 9381.30 Mbps 1601.98 Mbps Kyivstar - Lviv awk: line 1: syntax error at or near ; awk: line 1: syntax error at or near ; Kyiv, UA 28.94 ms 0.0% 9105.40 Mbps 1171.56 Mbps O3 - Kyiv awk: line 1: syntax error at or near ; awk: line 1: syntax error at or near ; Minsk, BY 27.54 ms 0.0% 6423.28 Mbps 2290.79 Mbps A1 - Minsk awk: line 1: syntax error at or near ; awk: line 1: syntax error at or near ; Bucharest, RO 27.61 ms 0.0% 4561.76 Mbps 2323.45 Mbps Orange Romania SA - Bucuresti awk: line 1: syntax error at or near ; awk: line 1: syntax error at or near ; awk: line 1: 38832e+109108 : decimal overflow awk: line 1: 62933e+111269 : decimal overflow Timisoara, RO 31.10 ms 0.0% 7923.18 Mbps 2418.12 Mbps Digi awk: line 1: syntax error at or near ; awk: line 1: syntax error at or near ; Helsinki, FI 22.50 ms 0.0% 8548.65 Mbps 3659.54 Mbps Elisa Oyj - Helsinki awk: line 1: syntax error at or near ; awk: line 1: syntax error at or near ; Stockholm, SE 29.19 ms 0.0% 7985.60 Mbps 2710.00 Mbps i3D.net - Stockholm awk: line 1: syntax error at or near ; awk: line 1: syntax error at or near ; Oslo, NO 23.16 ms 0.0% 8630.41 Mbps 2419.63 Mbps Speedtest.net - Oslo awk: line 1: syntax error at or near ; awk: line 1: syntax error at or near ; Moscow, RU 44.53 ms 0.0% 6947.99 Mbps 1653.63 Mbps MTS - Moscow awk: line 1: syntax error at or near ; awk: line 1: syntax error at or near ; Petersburg, RU 31.44 ms 0.0% 8266.10 Mbps 1953.06 Mbps MegaFon - Saint Petersburg awk: line 1: syntax error at or near ; awk: line 1: syntax error at or near ; awk: line 1: 92386e+118636 : decimal overflow Istanbul, TR FAILED - IP has been rate limited. Try again after 1 hour. Tbilisi, GE FAILED - IP has been rate limited. Try again after 1 hour. --------------------------------------------------------------------------- Avg DL Speed : 0,00 Mbps Avg UL Speed : 0,07 Mbps Total DL Data : 0,00 GB Total UL Data : 0,00 GB Total Data : 0,00 GB --------------------------------------------------------------------------- Duration : 12 min 17 sec System Time : 05/04/2024 - 14:44:24 CEST Total Script Runs : 39940 --------------------------------------------------------------------------- Result : https://result.network-speed.xyz/r/1712320733_VQVEH1_EU.txt ---------------------------------------------------------------------------interesting: https://result.network-speed.xyz/r/1712320733_VQVEH1_EU.txt show the results without the errors / overflow e.g. but no avg dl/up speed etc.
I'll take a look
if you need more details, just let me know.
@sh97 @linveo
Dallas, Texas
ping 1.28 ms
F. Battiato ---
Thanks!
My hunch is that it is a mawk vs gawk issue.
A quick check via
realpath /bin/awkshould help identify which one is being used.@sh97 could be using gawk while @lapua @carlin0 and @febryanvaldo may be using mawk (all due to distro defaults also).
OFMT="%.0f"or something like that if you're using mawk (at least you'll be able to verify if the hunch is in the right direction).Hope this helps...
@sh97 who peed in your Cheerios man?
No hablo inglis.
je ne parle pas français
Virmach LAX - $11/yr
DigiRDP India
---------------------------- network-speed.xyz ---------------------------- A simple script to test network performance using speedtest-cli --------------------------------------------------------------------------- Version : v2024.04.14 Global Speedtest : wget -qO- network-speed.xyz | bash Region Speedtest : wget -qO- network-speed.xyz | bash -s -- -r --------------------------------------------------------------------------- Basic System Info --------------------------------------------------------------------------- CPU Model : AMD EPYC 9374F 32-Core Processor CPU Cores : 4 @ 3699.958 MHz CPU Cache : 512 KB AES-NI : ✔ Enabled VM-x/AMD-V : ✔ Enabled Total Disk : 49.1 GB (4.9 GB Used) Total RAM : 15.6 GB (342.0 MB Used) Total Swap : 1024.0 MB (0 Used) System uptime : 0 days, 0 hour 16 min Load average : 0.06, 0.33, 0.21 OS : Debian GNU/Linux 12 Arch : x86_64 (64 Bit) Kernel : 6.1.0-20-amd64 Virtualization : KVM TCP Control : cubic --------------------------------------------------------------------------- Basic Network Info --------------------------------------------------------------------------- Primary Network : IPv6 IPv6 Access : ✔ Online IPv4 Access : ✔ Online ISP : dataforest GmbH ASN : AS58212 dataforest GmbH Host : DF Cloud Location : Frankfurt am Main, Hesse-HE, Germany --------------------------------------------------------------------------- Speedtest.net (Region: EUROPE) --------------------------------------------------------------------------- Location Latency Loss DL Speed UP Speed Server ISP: dataforest Nearest 0.21 ms 0.0% 8758.48 Mbps 7594.46 Mbps FynnCraft Minecraft Network - Dortmund London, UK 17.23 ms 0.0% 5.90 Mbps 3617.22 Mbps M247 Ltd - London Manchester, UK 20.87 ms N/A 9371.39 Mbps 1523.66 Mbps Vodafone UK - Manchester Dublin, IE 27.47 ms 0.0% 7547.79 Mbps 1134.08 Mbps Three Ireland - Dublin Amsterdam, NL 6.77 ms 0.0% 8382.05 Mbps 7690.21 Mbps Melbicom - Amsterdam Eygelshoen, NL 10.45 ms 0.0% 8905.64 Mbps 1680.87 Mbps SkyLink Data Center BV - Eygelshoven Paris, FR 8.84 ms N/A 2013.15 Mbps 1439.09 Mbps ORANGE FRANCE - Paris Marseille, FR FAILED Madrid, ES 28.67 ms 0.0% 7531.00 Mbps 2423.23 Mbps Orange - Madrid Barcelona, ES 29.81 ms 0.0% 9403.52 Mbps 1789.38 Mbps Adamo - Barcelona Lisbon, PT 37.71 ms 0.0% 6062.01 Mbps 1982.42 Mbps Edgoo Networks - Lisbon Rome, IT 21.39 ms 0.0% 7679.66 Mbps 2341.42 Mbps TIM SpA - Rome Milan, IT 10.15 ms 0.0% 3058.32 Mbps 1599.70 Mbps Fastweb SpA - Milan Zurich, CH 9.30 ms 0.0% 5826.14 Mbps 4411.60 Mbps Sunrise Communication AG - Zurich Frankfurt, DE 0.90 ms 0.0% 6227.18 Mbps 3492.77 Mbps Deutsche Telekom - Frankfurt am Main Berlin, DE 15.43 ms 0.0% 6917.74 Mbps 1524.23 Mbps Misaka Network, Inc. - Berlin Vienna, AT 13.55 ms 0.0% 8883.91 Mbps 2143.01 Mbps A1 Telekom Austria AG - Vienna Budapest, HU 14.06 ms 0.0% 6433.33 Mbps 2391.11 Mbps ATW Internet Kft. - Budapest Gdansk, PL 19.99 ms 0.0% 3330.44 Mbps 3325.72 Mbps T-Mobile Polska S.A. - Gdańsk Warsaw, PL 18.50 ms 0.0% 9389.85 Mbps 4362.70 Mbps Orange Polska S.A. - Warsaw Lviv, UA 29.73 ms 0.0% 6822.90 Mbps 1089.00 Mbps Kyivstar - Lviv Kyiv, UA 29.13 ms 0.0% 3018.08 Mbps 677.39 Mbps O3 - Kyiv Bucharest, RO 33.81 ms 0.0% 2929.15 Mbps 1915.34 Mbps Orange Romania SA - Bucuresti Timisoara, RO 30.35 ms 0.0% 7341.71 Mbps 3299.24 Mbps Digi Helsinki, FI 22.68 ms 0.0% 8795.47 Mbps 3073.69 Mbps Elisa Oyj - Helsinki Stockholm, SE 28.85 ms 0.0% 8871.80 Mbps 2375.37 Mbps i3D.net - Stockholm Oslo, NO 22.26 ms 0.0% 7474.19 Mbps 3342.73 Mbps Telia Norge AS - Oslo Moscow, RU 44.72 ms 0.0% 5488.78 Mbps 1862.47 Mbps MTS - Moscow Petersburg, RU 35.56 ms 0.0% 8806.57 Mbps 2085.01 Mbps MegaFon - Saint Petersburg Istanbul, TR 35.48 ms 0.0% 1648.08 Mbps 1435.84 Mbps Turkcell - Istanbul Tbilisi, GE 62.56 ms 0.0% 9413.81 Mbps 1025.61 Mbps Silknet JSC - Tbilisi --------------------------------------------------------------------------- Avg DL Speed : 6544.60 Mbps Avg UL Speed : 2621.62 Mbps Total DL Data : 282.11 GB Total UL Data : 89.41 GB Total Data : 371.52 GB --------------------------------------------------------------------------- Duration : 12 min 19 sec System Time : 02/05/2024 - 21:05:34 CEST Total Script Runs : 42300 ---------------------------------------------------------------------------0.85€ JP
1.80€ UK
Inception Hosting NL-SSD-KVM-2048
---------------------------- network-speed.xyz ---------------------------- A simple script to test network performance using speedtest-cli --------------------------------------------------------------------------- Version : v2024.04.14 Global Speedtest : wget -qO- network-speed.xyz | bash Region Speedtest : wget -qO- network-speed.xyz | bash -s -- -r --------------------------------------------------------------------------- Basic System Info --------------------------------------------------------------------------- CPU Model : Intel(R) Xeon(R) E-2278G CPU @ 3.40GHz CPU Cores : 2 @ 3408.032 MHz CPU Cache : 16384 KB AES-NI : ✔ Enabled VM-x/AMD-V : ❌ Disabled Total Disk : 29.8 GB (1.5 GB Used) Total RAM : 1.9 GB (73.7 MB Used) System uptime : 0 days, 0 hour 51 min Load average : 0.29, 0.78, 0.60 OS : Debian GNU/Linux 11 Arch : x86_64 (64 Bit) Kernel : 5.10.0-8-amd64 Virtualization : KVM TCP Control : cubic --------------------------------------------------------------------------- Basic Network Info --------------------------------------------------------------------------- Primary Network : IPv6 IPv6 Access : ✔ Online IPv4 Access : ✔ Online ISP : Clouvider Limited ASN : AS62240 Clouvider Host : Inception Location : Amsterdam, North Holland-NH, The Netherlands --------------------------------------------------------------------------- Speedtest.net (Region: GLOBAL) --------------------------------------------------------------------------- Location Latency Loss DL Speed UP Speed Server ISP: Clouvider Limited Nearest 0.42 ms 0.0% 6513.56 Mbps 5683.13 Mbps Clouvider Ltd - Amsterdam Kochi, IN 160.74 ms 0.0% 2761.20 Mbps 246.22 Mbps Asianet Broadband - Cochin Bangalore, IN 148.12 ms 0.0% 3240.58 Mbps 146.43 Mbps Bharti Airtel Ltd - Bangalore Chennai, IN 141.73 ms N/A 3425.86 Mbps 5.66 Mbps Jio - Chennai Mumbai, IN 129.97 ms 0.0% 2845.33 Mbps 345.25 Mbps i3D.net - Mumbai Delhi, IN 168.47 ms 0.0% 3904.20 Mbps 313.44 Mbps Tata Play Fiber - New Delhi Seattle, US 141.28 ms N/A 2593.06 Mbps 294.97 Mbps Comcast - Seattle, WA Los Angeles, US 135.10 ms 0.0% 2958.21 Mbps 376.52 Mbps ReliableSite Hosting - Los Angeles, CA Dallas, US 109.90 ms 0.0% 1686.83 Mbps 277.66 Mbps Hivelocity - Dallas, TX Miami, US 112.15 ms N/A 1569.53 Mbps 216.10 Mbps Dish Wireless - Miami, FL New York, US 72.02 ms 0.0% 4677.23 Mbps 109.17 Mbps GSL Networks - New York, NY Toronto, CA 91.85 ms 0.0% 1477.65 Mbps 248.16 Mbps Rogers - Toronto, ON Mexico City, MX 153.45 ms N/A 2426.51 Mbps 268.53 Mbps INFINITUM - Mexico City London, UK 5.83 ms 0.4% 6413.49 Mbps 880.24 Mbps VeloxServ Communications - London Amsterdam, NL 1.06 ms 0.0% 4597.49 Mbps 2975.38 Mbps 31173 Services AB - Amsterdam Paris, FR 11.13 ms N/A 7960.83 Mbps 495.50 Mbps Axione - Paris Frankfurt, DE 5.94 ms 0.0% 3046.94 Mbps 848.35 Mbps Clouvider Ltd - Frankfurt am Main Warsaw, PL 21.83 ms 4.3% 6112.54 Mbps 324.05 Mbps Play - Warszawa Bucharest, RO 34.37 ms 0.0% 2192.63 Mbps 243.62 Mbps Vodafone Romania Fixed – Bucharest - Bucharest Moscow, RU 39.39 ms 0.0% 3479.42 Mbps 449.07 Mbps MegaFon - Moscow Jeddah, SA 68.27 ms 1.0% 4528.93 Mbps 331.86 Mbps Saudi Telecom Company Dubai, AE 121.91 ms 0.0% 3105.98 Mbps 290.87 Mbps du - Dubai Fujairah, AE 113.27 ms 0.0% 3574.67 Mbps 212.00 Mbps ETISALAT-UAE - Fujairah Istanbul, TR 44.45 ms 0.0% 3288.14 Mbps 335.60 Mbps Turkcell - Istanbul Tehran, IR 85.20 ms 0.0% 2044.27 Mbps 170.84 Mbps Asiatech - Tehran Tokyo, JP 259.34 ms N/A 266.84 Mbps 60.10 Mbps fdcservers.net - Tokyo Shanghai, CU-CN 237.67 ms 0.0% 1206.60 Mbps 192.25 Mbps China Unicom 5G - Shanghai Nanjing, CT-CN 429.82 ms 7.7% 1615.36 Mbps 0.72 Mbps China Telecom JiangSu 5G - Nanjing Hong Kong, CN 181.06 ms N/A 2685.02 Mbps 83.91 Mbps STC - Hong Kong Singapore, SG 331.01 ms 3.0% 2389.45 Mbps 120.71 Mbps i3D.net - Singapore Jakarta, ID FAILED - IP has been rate limited. Try again after 1 hour. --------------------------------------------------------------------------- Avg DL Speed : 3286.27 Mbps Avg UL Speed : 551.54 Mbps Total DL Data : 139.31 GB Total UL Data : 26.41 GB Total Data : 165.72 GB --------------------------------------------------------------------------- Duration : 15 min 45 sec System Time : 04/05/2024 - 14:34:34 UTC Total Script Runs : 42450 --------------------------------------------------------------------------- curl is not installed, Unable to share result online Result stored locally in /root/network-speed.txt ---------------------------------------------------------------------------Hello world.
HYBULA NL to ASIA
pretty strange UP speed tho.
