Survey: Low-end VPS
synthohosting
Hosting Provider
HI!
I hope you are all well, today we wanted to ask your opinion, would you like a configuration like this:
1 core shared (4.60 GHz)
2GB RAM DDR4
30GB SSD
1Gbps @ 1TB (if exceeded, you are limited to 100Mbps so as not to interrupt service continuity)
1x Dedicated IPv4 address
1x Dedicated /64 IPv6
Advanced DDoS Protection
99.8% Monthly Uptime (best-effort, if not respected, compensation in addition of days to the expiry)
€3/month VAT included
Would you get it?
Survey: Low-end VPS
- Would you buy this VPS?32 votes
- Yes18.75%
- No71.88%
- Maybe yes, for a little less and without IPv4  9.38%
SynthoHosting: DDoS Protected IP Transit, Dedicated Servers and VPS
I'd you did yearly, share the IPv4, and let me run a vpn depending on location then yes.
Hello, the location is Germany, if you want a test IP here it is: 194.36.26.254
ICMP may loss as it’s a router
You can run a VPN
It's a good offer but if its in Germany, then no. Totally saturated market, there are plenty of providers there already.
Also, you mean "1TB @ 1Gbps", not "1Gbps @ 1TB".
Dang Ashburn would be Coolio for me and YetiNode.
Hello,
thanks for giving us a feedback.
We do not have presence in USA, but we will have presence in Milan within the end of the month.
I’ll be more than happy sharing photos of the datacenter as soon as I’ll get in
