@Calypso said:
According to C1V AI it should be capable of at least 60 VPSes with 2 cores and 4G RAM...
C1V can do it 💪: compress memory, compress file system, compress swap, compress network, and compress the hopes than no one will use more than 5% of their nominal slice size; if they do, the AI would further compress the fractional reserve.
Is this self-awareness..?
Cloudron.io - Lovely self hosted management suite [aff]
HetrixTools - Highly recommended uptime monitor [aff]
@dev_vps
That garage is pretty cool by the way, yours?
No, that garage is not mine.
It won't pass city safety inspections and likely to be non-compliant with 2-3 city ordinances and regulations
That is why I am highly appreciative of help I get from providers like @host_c
This is my home pc
https://www.amazon.com/BOSGAME-B100-Computers-2500Mbps-Ethernet/dp/B0CLV3KJFD/
small enough to be placed in the basket under the table and helps in keeping my workstation clean (just wireless kb/mouse and two 4k monitors)
This is the smallest pc ... perfect for putting at a datacenter colocation
https://www.amazon.com/MeLE-Mini-Quieter-4C-Astrophotography/dp/B0CP3YL6J7
just one type c cable to charge and a network cable to connect
AI algorithm
put 20 more VPS at every "restock event" until GB6 score > 200
Add 240 GB HDD (4 GB * 60), setup swap (or swap over network/CIFS?), done.
LTstats resource monitoring system | Recommended providers: Layer7, dataforest (Avoro/PHP-Friends), @host_c
