anyone got wireguard working on khanwebhost NAT VPS?
im on the OVZ one and used
https://github.com/Nyr/wireguard-install
can't get it to work even though I set the WG port to the one that was forwarded (not 51820)
thanks in advance.
They have some weird filtering going on, so need to open a ticket with them to get it working.
I have it working one two nodes, but I had to put a ticket in for one of them. Not sure what it was that he changed, some backend thing needed doing and it started working right away after that.
You can also try wireguard-go:
☰ Storage — AMD EPYC VDS (ref) up to 4TB NVMe & 10TB SAN disk / Big HDD VPS (ref) from $2.42/TB/month
Iirc, wireguard requires UDP only and UDP ports are blocked by default by KWH. I used OpenVPN and I had to send in a ticket to request unblocking UDP ports.
@AK_KWH we need UDP!!!!
UDP or chargeback!
Waiting refuge offer for JoshIdeas $6/year 1C2G40G plan. affbrr
yes!!!!
Do any one share the Wireguard Configuration for Ipv6 only vps ?
in most of the VPS UDP are enabled we just need to restart the iptable sometime to get it resolved but i will add the udp rules against all ips
thanks! working perfect now.
Glad to know its resolved
WireGuard on Khanwebhost NAT VPS might be difficult due to port restrictions.
Checking with Khanwebhost for workarounds.
Using non-standard ports
Considering a different VPS provider with public IPs or VPN support.
i used the script and set WG port to the opened one and it just works
Added to my Headscale tailnet. Meh. Not thrilled.
@AK_KWH i tried installing wireguard. I disable the ufw. But wireguard didn’t work. What should i do? Thanks
just submit ticket i will check
