Didn't realize my VPS on NYCB048 was also affected. I saw this on the Network Status page, looks like a larger migration:
LAX2 to LAX Migrations (Reported)Critical
Affecting System - LAX2Z018, LAX2Z020, LAX2Z021, NYCB042, NYCB048, NYCB006R
06/30/2024 00:05 - 07/03/2024 00:00 Last Updated 07/01/2024 02:01
There has been a delay in migration of approximately 60 individual virtual servers on LAX2Z020 and LAX2Z021. Originally planned for June 29th, these migrations will occur on June 30th. Services scheduled for migration on LAX2Z018 have also been delayed. ETA will be posted here when available.
All services have been credited 2 weeks instead of the original 1 week due to delayed notifications.
The following servers will be physically migrated on July 2nd:
NYCB006R
NYCB042
NYCB048
LAX2Z020
LAX2Z021
Anyone physically migrated will keep their original IPv4 address and remain on the same server. There may be an extended period of downtime should there be any issues or delays related to migration of IPv4 addresses or physical installation of servers. There is a small possibility that IPv4 addresses may be changed to reduce downtime should there be any unexpected delays or issues with networking.
Update: LAX2Z018 will be physically migrated on July 2nd instead of the original planned data transfer. We've made this decision as it would be a better experience to remain on the existing physical server, with a higher access to bursting resources.
(and this from yesterday):
VPShared -- LAX2Z017 (Outage)Critical
Affecting System - VPShared
07/01/2024 02:01 Last Updated 07/01/2024 02:06
Several attempts to stabilize the server have failed in the previous weeks, with the node continuing to face many novel issues consecutively. While it is online, these issues have essentially rendered your shared hosting service unusable.
We will begin performing further physical troubleshooting on July 2nd after the server is moved to a new datacenter location, and will likely need to perform emergency data recovery and migration to a stable node. We are determining the appropriate level of service extension given the scenarios faced on this server over an extended period of time, but you will likely receive several months of extension to make up for these previous issues.
Thu, 04 Jul 2024 08:47:00 -0700 We're investigating an outage in NYC. This appears to be a connectivity issue related to routing. We are communicating with the datacenter to resolve the issue.
Had to rent a server from another provider, due to NYC fiasco.
As said to client just 5 mins ago: Sod's Law back up just as I changed the DNS to the newly built replacement server. As I predicted.
so did you go back to it and cancel your replacement server?
@JoeMerit said: so did you go back to it and cancel your replacement server?
I did revert to the NYC one but given upcoming CHI and MIA shenanigans, the newly built server may prove useful. It's significantly annoying due to me virtually idling the NYC server since BF 2019, to confirm its stability, which WAS solid as a rock.
The NYC issue wasn't that complicated, but unfortunately it took very long to resolve just because of timing.
The amazing tech that usually helps with NYC was unavailable on the 4th so we were at the mercy of whoever happened to be on duty at the datacenter and as a result... let's just say if I was there, our usual tech was there, anyone from the direct partner we're using for NYC was there, or even if I was on a phone call with pretty much any of my non-technical friends or family members at the DC, it would have confidently been resolved in a couple hours.
@VirMach said: The NYC issue wasn't that complicated.. etc.
I hope that this is some form of reassurance. This specific NYC (multi-IP) has been excellent up to this point.
Awaiting the Sh1t to do the bad thing, when my BF'19 in CHI gets its IP change : pre-warned a client on that one. Still not clear on whether my MIA one will suffer be affected, during this bout of migrations.
193.29.97.0/24 is losing visibility.
MIAZ001 moving to Atlanta was scheduled for July 06 but I don't see new IP in SolusVM.
I'm glad that I didn't trust the "3-hoir downtime" and moved out most of the services on July 05.
Just you wait.. actually the migration is for CHIZ001 and CHIZ002 - guess where my VPS are?
@VirMach > Approximately 2 to 3 hours of downtime while your service is migrated.
You having a laugh? !
Looks as though I'm going to need to restore to that new competitor's server. What a bloody PITA. :-(
NYCB006R
NYCB042
NYCB048
LAX2Z020
LAX2Z021
We apologize for the bad experience.
My main NYC VPS is now inaccessible - node unknown; 185.221.22.0 subnet.
[Edit; All NYC down for me!]
You are in the endless void man!!!!
DALZ005 in virmach had been offlined.
DALZ005 was retired around 8 months ago. You're likely on another node, and if it went down today the highest likelihood is it's in NYC.
Hello @VirMach i'm write you more times to PM but I'm write in same time here , you are interested to sell you company? Or a subvention ?
Regards
OOOuuuuuuu
i like you are dreaming big
now i worry about you .... calm down .... slow and easy.
If you take over Virmach,please take care of these frustrated customers
What? Virmach for sale? I'll take it. $7
I promise to destroy the company in a few days.
26+ hours and counting
Powerful AMD Ryzen VPS (aff)
So, we can migrate down servers to another DC ? xD
As I predicted.
Back for 1.5 hours already.
Damn 4th of July.
You're in for a long counting spree!!
Yay! The interface is back up. Now I can cancel it.
CHi has bitten the dust.
Japan is the last one standing strong
CHI is still working for me.
Ah, that explains it. I'm not on those nodes. ...New Yoik?
on the bright side, my long offline NY server is back up and I got credited for all the downtime and then some.
