Ploi --}elastic search + wordpress on the same server
Hi all!
I need an advice about the installation of an elastic search on the same server as a wordpress server and his management through a plugin.
What i must bear in mind in order to do It? Any advice is welcome.
Which plugin i should use to control It.
I would like to use ploi . It seems to cover them( elastic search and wordpress installation etc)
I used Google before asking but i could not find any guide for It for ploi and i am not sure so asking the community for an advice.
Many thanks!
A bit of a "Solomon's" solution, but I went with implementing Google website search:
How to add Google Programmable Search to WordPress?
Doesn't put any extra load on the hosting server, and gets the job done (just be careful which pages you index, but that is important even if you don't use the GPS).
Nice to have another options. I would give It a try for sure.thanks for the guide.
Couldn't resist, mate.![:) :)](https://lowendspirit.com/plugins/emojiextender/emoji/twitter/smile.png)
the whole ELK stack (Elasticsearch, Logstash, Kibana) can be fit in one docker-compose.yml, and they're typically just setup once and forget. is a full blown management panel is necessary for this?
RAM. get a lot of them. https://downloadmoreram.com/
how about being more descriptive and elaborate what's your use case for it?. nobody is going to play the guessing game with you
Well just asking. I am aware that ploi offers It so just that asking.
Ok i am going to bear in mind to get more RAM for the elastic search
Basically a search engine into wordpress website with many pages around 5000 pages so a search bar IS a must in order to make better experience for the users.
Thanks for your comment
