@AuroraZero said: @localhost https://github.com/DomiStyle/docker-idrac6
HP systems use iLO. But will try this too if possible. Thnx for sharing
@localhost said: show previous quotes @AuroraZero said: @localhost https://github.com/DomiStyle/docker-idrac6 HP systems use iLO. But will try this too if possible. Thnx for sharing
@localhost said:
Looks like there is a similar container for ILO - https://github.com/sshnaidm/docker-ilo-client
lex.st - Free Shared Hosting in 4 Locations. fk ipv6.
@beanman109 said: show previous quotes @localhost said: @AuroraZero said: @localhost https://github.com/DomiStyle/docker-idrac6 HP systems use iLO. But will try this too if possible. Thnx for sharing Looks like there is a similar container for ILO - https://github.com/sshnaidm/docker-ilo-client
Oo great!! Will check this out
$13 still available??
➤ cPanel Hosting $1.49/mo from The Online aff
@webhostingservers said: $13 still available??
It comes & goes - check the link every few hours & it should eventually be back in stock.
@beanman109 said: check the link every few hours
Slap this bad boy on your docker host and let it do the heavy lifting for ya
E3-1230 v2 dedi in LA for $18 for those who prefer a non European location
CPU: Xeon E3-1230 v2 RAM: 16 GB DDR3 Storage: x1 1TB HDD Bandwidth: 'Unmetered' @ 1 Gbps https://oneprovider.com/configure/dediconf/6914
@beanman109 said: E3-1230 v2 dedi in LA for $18 for those who prefer a non European location CPU: Xeon E3-1230 v2 RAM: 16 GB DDR3 Storage: x1 1TB HDD Bandwidth: 'Unmetered' @ 1 Gbps https://oneprovider.com/configure/dediconf/6914
Psychz right?
@mikewazar said: show previous quotes @beanman109 said: E3-1230 v2 dedi in LA for $18 for those who prefer a non European location CPU: Xeon E3-1230 v2 RAM: 16 GB DDR3 Storage: x1 1TB HDD Bandwidth: 'Unmetered' @ 1 Gbps https://oneprovider.com/configure/dediconf/6914 Psychz right?
@mikewazar said:
Haven't got one but at that price/spec/location I'm 90% sure it's Psychz
RAM: 16 GB DDR3
Storage: x1 1TB HDD
Psychz right?
