64GB RAM and 1TB SSD server
imokimok OG
edited August 4 in Requests
And a /29. Dallas preferred, but I can consider any other place in USA.
I need a dedicated server for a month. Do you think I can find something for $60 or less?
E3 or E5, just not that old.
Not sure if an hourly paid VPS would run Proxmox without issues.
  • AuroraZeroAuroraZero Moderator
    Talk to @host_c I am pretty positive he may be able to help
    Thanked by (2)imok host_c
  • I'm looking for a service in US, I forgot to mention that (added)
    Thanked by (1)host_c
  • edited August 4
    Sounds like WSI/Nocix may fit the requirements (Kansas)
    Thanked by (1)imok
    Dedicated.com has Dallas servers available. $60/m for E5-1650v3, 64GB, 1TB SSD or $50 for E3-1270v5, 64GB, 2x512GB SSD.
    Thanked by (1)imok
    Are they reliable? I don't remember them.
    I haven't heard good things about them.
    edited August 4
    I use their network with colo. One of the most reliable networks I've used, if you're asking about the network. They are in Evocative (ex. INAP) Plano.
    Thanked by (1)imok
    3 years customer of them, they're good (ticket answer almost instantly) at most of time,
    Only too old spec machine is painful.
    I use it for production.
     05:04:13 up 145 days, 23:08,  1 user,  load average: 0.89, 0.88, 0.90
    Thanked by (1)imok
    if you have a budget around 90$ i can offer something in Dallas with dual CPU E5-26xxx
  • edited August 4
    If $60 is a hard limit, then check if these storage VDS can be stacked:
    Try CANADA_VDS_35 and CANADA_WILDBEAST_10 codes during checkout for a discount.
    If the first coupon is still active, then buy 3 of those VDSes to get 96 GB RAM and 900 GB NVME for $58.5.
  • imokimok OG
    edited August 4
    Too bad the 64GB machine is OOS now :(
    But then the problem is the additional IPs. @servarica_hani is it possible to get 5 usable IPs? Do you know if Xen supports nested virtualization?
  • edited August 4
    Contact them. As far as I remember, they usually have just a few dedicated servers in stock.
    A couple of years ago extra IPs were $2/m. Less for a bulk purchase.
    P.S.
    Dedicated EPYC cores, RAM, and NVMe space for storage VDS above are stackable for all plans — this and smaller ones.
  • jayjayjayjay Hosting Provider
    Got plenty of Xeon's available in the Netherlands: https://www.millenial.host/portal/store/dedicated-servers
    Any of them can be upgraded to a 1 TB SSD, some already have 64 GB RAM by default. Would any of these work?
    Drop me a line if you're interested or have any questions
    Thanks!
    coupon is expired. :sleeping:
    We can offer monthly VPS, should run ProxMox no issues.
    Check out Civilized Hosting!
    Web Hosting, VPS Servers, Dedicated Servers, Colocation, IP Transit, IP Subnets, and more!
