Transfer - Virtono SG, Virmach Ryzen LAX
Transferring out these idlers!
Virmach - $11/year
* 3x Ryzen 3900X
* 2GB RAM
* 52GB NVMe SSD
* 1x IPv4
* 3TB@1Gbps
* Los Angeles, US (RYZE.LAX-A011.VMS)
* Uptime for the last 30 days - 100%
Paid until: 25-Mar-2025
Asking Price: $10 ($7+$3 transfer)
As it's Virmach, I have no idea how long the transfer will take. The last one I made early this year was processed in 3 days.
# Yet-Another-Bench-Script #
# v2024-06-09 #
Sun Aug 18 01:19:02 PM UTC 2024
Uptime : 47 days, 23 hours, 3 minutes
Processor : AMD Ryzen 9 3900X 12-Core Processor
CPU cores : 3 @ 3799.998 MHz
AES-NI : ✔ Enabled
RAM : 1.9 GiB
Swap : 0.0 KiB
Disk : 50.9 GiB
Distro : Ubuntu 22.04.4 LTS
Kernel : 5.15.0-113-generic
VM Type : KVM
ISP : QuadraNet Enterprises LLC
ASN : AS8100 QuadraNet Enterprises LLC
Host : Virtual Machine Solutions LLC
Country : United States
fio Disk Speed Tests (Mixed R/W 50/50) (Partition /dev/vda2):
Read | 333.18 MB/s (83.2k) | 243.81 MB/s (3.8k)
Write | 334.06 MB/s (83.5k) | 245.09 MB/s (3.8k)
Total | 667.24 MB/s (166.8k) | 488.90 MB/s (7.6k)
Read | 2.71 GB/s (5.2k) | 3.14 GB/s (3.0k)
Write | 2.85 GB/s (5.5k) | 3.35 GB/s (3.2k)
Total | 5.57 GB/s (10.8k) | 6.49 GB/s (6.3k)
Geekbench 5 Benchmark Test:
Test | Value
Single Core | 1017
Multi Core | 2678
Full Test | https://browser.geekbench.com/v5/cpu/22790395
YABS completed in 2 min 56 sec
Basic System Info
CPU Model : AMD Ryzen 9 3900X 12-Core Processor
CPU Cores : 3 @ 3799.998 MHz
CPU Cache : 512 KB
AES-NI : ✔ Enabled
Total Disk : 50.9 GB (6.7 GB Used)
Total RAM : 1.9 GB (191.8 MB Used)
System uptime : 47 days, 22 hour 46 min
Load average : 0.00, 0.00, 0.00
OS : Ubuntu 22.04.4 LTS
Arch : x86_64 (64 Bit)
Virtualization : KVM
TCP Control : cubic
Basic Network Info
Primary Network : IPv4
IPv6 Access : ❌ Offline
IPv4 Access : ✔ Online
Location Latency Loss DL Speed UP Speed Server
ISP: QuadraNet
Nearest 130.49 ms 0.0% 839.53 Mbps 665.58 Mbps Sewan - Paris
Kochi, IN 216.35 ms 0.0% 432.56 Mbps 407.54 Mbps Asianet Broadband - Cochin
Bangalore, IN 209.36 ms 0.0% 524.23 Mbps 413.30 Mbps Bharti Airtel Ltd - Bangalore
Chennai, IN 256.92 ms N/A 633.23 Mbps 314.10 Mbps Jio - Chennai
Mumbai, IN 243.45 ms 0.0% 418.36 Mbps 305.53 Mbps i3D.net - Mumbai
Delhi, IN 244.85 ms 0.0% 637.71 Mbps 281.87 Mbps Tata Play Fiber - New Delhi
Seattle, US 26.17 ms N/A 861.47 Mbps 834.61 Mbps Comcast - Seattle, WA
Los Angeles, US 0.91 ms 0.0% 928.75 Mbps 920.09 Mbps ReliableSite Hosting - Los Angeles, CA
Dallas, US 29.45 ms 0.0% 911.47 Mbps 908.50 Mbps i3D.net - Dallas, TX
Miami, US 65.54 ms N/A 771.11 Mbps 695.99 Mbps Dish Wireless - Miami, FL
New York, US 68.79 ms N/A 632.38 Mbps 779.99 Mbps fdcservers.net - New York, NY
Toronto, CA 68.80 ms 0.0% 797.95 Mbps 777.94 Mbps Rogers - Toronto, ON
Mexico City, MX 51.40 ms N/A 869.16 Mbps 797.90 Mbps INFINITUM - Mexico City
London, UK 136.11 ms 0.0% 936.64 Mbps 615.37 Mbps VeloxServ Communications - London
Amsterdam, NL 148.58 ms 0.0% 938.66 Mbps 565.94 Mbps 31173 Services AB - Amsterdam
Paris, FR 140.32 ms N/A 941.99 Mbps 617.95 Mbps Axione - Paris
Frankfurt, DE 150.50 ms 0.0% 759.03 Mbps 564.47 Mbps Clouvider Ltd - Frankfurt am Main
Warsaw, PL 165.97 ms 0.0% 943.57 Mbps 502.69 Mbps Play - Warszawa
Bucharest, RO 172.24 ms 0.0% 686.02 Mbps 491.06 Mbps Vodafone Romania Fixed – Bucharest - Bucharest
Moscow, RU 193.61 ms 0.0% 557.68 Mbps 431.05 Mbps Rostelecom - Moscow
Jeddah, SA 208.50 ms 0.0% 913.26 Mbps 403.78 Mbps Saudi Telecom Company
Dubai, AE 250.38 ms 0.0% 817.07 Mbps 343.06 Mbps du - Dubai
Fujairah, AE 248.39 ms 0.0% 760.66 Mbps 349.64 Mbps e& UAE - Fujairah
Istanbul, TR 189.46 ms 0.0% 845.28 Mbps 376.77 Mbps Turkcell - Istanbul
Tehran, IR 227.95 ms 0.3% 483.44 Mbps 188.35 Mbps Asiatech - Tehran
Tokyo, JP 114.25 ms 0.0% 953.67 Mbps 711.33 Mbps IPA CyberLab 400G - Tokyo
Shanghai, CU-CN FAILED
Nanjing, CT-CN 189.74 ms 0.3% 628.00 Mbps 9.58 Mbps China Telecom JiangSu 5G - Nanjing
Hong Kong, CN 158.29 ms N/A 590.73 Mbps 559.51 Mbps STC - Hong Kong
Singapore, SG 173.94 ms 0.0% 562.42 Mbps 475.99 Mbps i3D.net - Singapore
Jakarta, ID FAILED - IP has been rate limited. Try again after 1 hour.
Avg DL Speed : 744.00 Mbps
Avg UL Speed : 527.91 Mbps
Total DL Data : 30.67 GB
Total UL Data : 19.17 GB
Total Data : 49.84 GB
Duration : 14 min 25 sec
System Time : 18/08/2024 - 13:16:06 UTC
Total Script Runs : 78001
Virtono - EUR14.97/year
* 1 vCPU (Gold 5218)
* 1GB RAM
* 15GB SSD
* 1x IPv4, /64 IPv6
* 1TB@500Mbps
* Singapore
Paid until: 05-June-2025
Asking Price: $14
# v2024-06-09 #
Sun Aug 18 09:18:45 AM EDT 2024
Uptime : 73 days, 21 hours, 37 minutes
Processor : Intel(R) Xeon(R) Gold 5218 CPU @ 2.30GHz
CPU cores : 1 @ 2299.990 MHz
AES-NI : ✔ Enabled
RAM : 960.7 MiB
Swap : 1.2 GiB
Disk : 14.4 GiB
Kernel : 6.1.0-21-amd64
VM Type : KVM
ISP : M247 Europe SRL
ASN : AS9009 M247 Europe SRL
Country : Singapore
Read | 58.59 MB/s (14.6k) | 310.19 MB/s (4.8k)
Write | 58.69 MB/s (14.6k) | 311.82 MB/s (4.8k)
Total | 117.29 MB/s (29.3k) | 622.02 MB/s (9.7k)
Read | 296.49 MB/s (579) | 295.98 MB/s (289)
Write | 312.25 MB/s (609) | 315.69 MB/s (308)
Total | 608.75 MB/s (1.1k) | 611.68 MB/s (597)
Geekbench test failed and low memory was detected. Add at least 1GB of SWAP or use GB4 instead (higher compatibility with low memory systems).
YABS completed in 3 min 21 sec
Basic System Info
CPU Model : Intel(R) Xeon(R) Gold 5218 CPU @ 2.30GHz
CPU Cores : 1 @ 2299.990 MHz
CPU Cache : 22528 KB
AES-NI : ✔ Enabled
Total Disk : 14.4 GB (5.1 GB Used)
Total RAM : 960.7 MB (369.7 MB Used)
Total Swap : 1.2 GB (27.0 MB Used)
System uptime : 73 days, 21 hour 20 min
OS : Debian GNU/Linux 12
TCP Control : cubic
Basic Network Info
Primary Network : IPv6
IPv6 Access : ✔ Online
Host : Virtono Networks SRL
ISP: M247 Europe
Nearest 0.45 ms N/A 246.47 Mbps 658.02 Mbps fdcservers.net - Singapore
Kochi, IN 45.46 ms 0.0% 307.26 Mbps 356.79 Mbps Asianet Broadband - Cochin
Bangalore, IN 37.40 ms 0.0% 238.70 Mbps 372.00 Mbps Bharti Airtel Ltd - Bangalore
Chennai, IN 33.98 ms N/A 233.28 Mbps 342.21 Mbps Jio - Chennai
Mumbai, IN 89.24 ms 0.0% 269.14 Mbps 384.66 Mbps i3D.net - Mumbai
Delhi, IN 201.73 ms 0.0% 281.35 Mbps 195.99 Mbps Tata Play Fiber - New Delhi
Seattle, US 162.81 ms N/A 247.68 Mbps 214.57 Mbps Comcast - Seattle, WA
Los Angeles, US 171.48 ms 0.0% 266.81 Mbps 110.97 Mbps ReliableSite Hosting - Los Angeles, CA
Dallas, US 204.86 ms 0.0% 320.46 Mbps 132.96 Mbps i3D.net - Dallas, TX
Miami, US 341.52 ms N/A 271.07 Mbps 76.62 Mbps Dish Wireless - Miami, FL
New York, US 237.37 ms N/A 247.84 Mbps 165.44 Mbps fdcservers.net - New York, NY
Toronto, CA 218.36 ms 0.0% 290.94 Mbps 199.21 Mbps Rogers - Toronto, ON
Mexico City, MX 206.97 ms N/A 312.82 Mbps 231.66 Mbps INFINITUM - Mexico City
London, UK 220.50 ms 0.0% 436.76 Mbps 101.20 Mbps VeloxServ Communications - London
Amsterdam, NL 235.43 ms 0.0% 458.33 Mbps 132.99 Mbps 31173 Services AB - Amsterdam
Paris, FR 229.72 ms N/A 522.08 Mbps 163.11 Mbps Axione - Paris
Frankfurt, DE 340.92 ms 0.0% 74.13 Mbps 237.53 Mbps Clouvider Ltd - Frankfurt am Main
Warsaw, PL 183.31 ms 0.0% 493.26 Mbps 243.61 Mbps Play - Warszawa
Bucharest, RO 252.26 ms 0.0% 245.35 Mbps 180.15 Mbps Vodafone Romania Fixed – Bucharest - Bucharest
Moscow, RU 194.00 ms 0.7% 269.72 Mbps 134.64 Mbps Rostelecom - Moscow
Jeddah, SA 264.24 ms 0.0% 404.29 Mbps 189.42 Mbps Saudi Telecom Company
Dubai, AE 81.45 ms 1.0% 570.94 Mbps 183.62 Mbps du - Dubai
Fujairah, AE 76.32 ms 0.0% 510.91 Mbps 155.06 Mbps e& UAE - Fujairah
Istanbul, TR 197.04 ms 0.0% 328.74 Mbps 193.64 Mbps Turkcell - Istanbul
Tehran, IR 336.47 ms 0.0% 229.25 Mbps 160.51 Mbps Asiatech - Tehran
Tokyo, JP 173.67 ms 0.0% 481.63 Mbps 216.60 Mbps IPA CyberLab 400G - Tokyo
Nanjing, CT-CN FAILED
Hong Kong, CN 31.63 ms N/A 204.26 Mbps 342.84 Mbps STC - Hong Kong
Singapore, SG 1.21 ms 0.0% 217.81 Mbps 588.67 Mbps i3D.net - Singapore
Avg DL Speed : 320.76 Mbps
Avg UL Speed : 238.02 Mbps
Total DL Data : 12.28 GB
Total UL Data : 9.33 GB
Total Data : 21.61 GB
Duration : 15 min 24 sec
System Time : 18/08/2024 - 09:16:48 EDT
Total Script Runs : 78002
Payment via UPI (preferred) and PayPal only.
If PayPal, then gateway charges are extra.
If the transfer fails due to reasons outside the seller's control, the amount will be refunded after deducting transaction fees from PayPal. A full refund will be given for UPI.
Got any 3GB Yearly to transfer?
haha, nah just got one (Crunchbits Gentleman VPS) which I am using
@sh97 GLWS! /s
Thanks, all transferred out. Forgot to post a message here!
VirTRASH is 30 day of 100% uptime gattered since you got it 3 years ago ?
I got it in March through a transfer. Since I haven't added it on hetrix, I only have stats from Uptime Kuma which has only 30 days history.
It's been fine for me the last 5 months, just that I don't have a use for it.
