YABS closes without completing
Hi! I have a racknerd vps (1 core, 2 gb) and I have tried running yabs five times. The server closes connection before completing the benchmark.
I also tried saving the output to a file, but yabs seems to be terminating entirely.
How can I make sure that yabs gets completed?
wget -qO- yabs.sh | bash | tee yabs.txt
    reboot and try
  • I restarted the server and tried running yabs again. The ssh freezes after some time. This is the output for the second attempt:
    wget -qO- yabs.sh | bash | tee yabs$(date +%d%b%Y).txt
    Yet-Another-Bench-Script
    v2024-06-09
    Sun Aug 25 08:53:12 AM UTC 2024
    Uptime : 0 days, 0 hours, 41 minutes
    Processor : Intel(R) Xeon(R) CPU E5-2690 v2 @ 3.00GHz
    CPU cores : 1 @ 2999.998 MHz
    AES-NI : ✔ Enabled
    VM-x/AMD-V : ❌ Disabled
    RAM : 1.9 GiB
    Swap : 1024.0 MiB
    Disk : 28.5 GiB
    Distro : Ubuntu 22.04.4 LTS
    Kernel : 5.15.0-119-generic
    VM Type : KVM
    ISP : HostPapa
    ASN : AS36352 HostPapa
    Host : RackNerd LLC
    Country : United States
    fio Disk Speed Tests (Mixed R/W 50/50) (Partition /dev/vda2):
    Read 54.08 MB/s (13.5k) 711.44 MB/s (11.1k)
    Write 54.20 MB/s (13.5k) 715.18 MB/s (11.1k)
    Total 108.28 MB/s (27.0k) 1.42 GB/s (22.2k)
    Read 1.01 GB/s (1.9k) 965.54 MB/s (942)
    Write 1.07 GB/s (2.0k) 1.02 GB/s (1.0k)
    Total 2.09 GB/s (4.0k) 1.99 GB/s (1.9k)
    Provider Location (Link) Send Speed Recv Speed Ping
    Clouvider London, UK (10G) 789 Mbits/sec 224 Mbits/sec 87.6 ms
    Eranium Amsterdam, NL (100G) 767 Mbits/sec 758 Mbits/sec 96.9 ms
    Uztelecom Tashkent, UZ (10G) 619 Mbits/sec 155 Mbits/sec 225 ms
    Leaseweb Singapore, SG (10G) 586 Mbits/sec 510 Mbits/sec 214 ms
    Clouvider Los Angeles, CA, US (10G) 866 Mbits/sec 335 Mbits/sec 47.9 ms
    Leaseweb NYC, NY, US (10G) 898 Mbits/sec 765 Mbits/sec 18.4 ms
    Edgoo Sao Paulo, BR (1G) 748 Mbits/sec 288 Mbits/sec 129 ms
    Running GB6 benchmark test... cue elevator music
  • @tototo said:
    screen
    Sorry, I didn't understand. Do I pass screen to yabs?
  • @nikhm2n said:
    @tototo said:
    screen
    That is what he is saying to do but most likely the node is oversold and you are hitting the wall or there is someone abusing resources
  • edited August 2024
    run 'screen', (install if necessary) and then run yabs inside of screen. if you get disconnected you can reconnect and re-attach to your screen and youll see the yabs results. I had a cloudcone and some other VMs that would disconnect me during yabs, but it would complete every time if i used screen.
    I tended to not keep the VMs that would drop me during yabs without using screen.
    Thanked by (2)AuroraZero tototo
    Run GB5 test instead of GB6
  • I think the server was having some excessive use, too. The server was sluggish and the ping time was bad. My vps is currently being migrated to a new location. Fingers crossed that the new location isn't the same.
    And, thank you for helping me.
    I am going to have a look at screen and run some yabs on GB5.
  • Run your command with -x, to get more details about what happens behind the scene
    curl -sL yabs.sh | bash -x
