Hot VPS Deal! Get a Supercharged KVM for ONLY $3.2/Month! 2 CPU, 4GB RAM, 50GB SSD – Don't Miss Out!
Unbeatable VPS Deals! Get 4GB KVM VPS and Up to 2TB Bandwidth in Huston Texas Starting at Just $3.20/Month!
Hey, tech friends! Have you heard joke about VPS that can't cook eggs because it's too cold? Well, we have HOT VPS deal for you! For only $3.2/Month, get a KVM that's not only supercharged with 2 CPU, 4GB RAM, and 50GB SSD, but also hot enough to maybe fry your breakfast eggs! 😉 Quick, grab this deal before VPS cools down and our eggs remain uncooked. Don't miss out, make your virtual life eggstra special today!
VPS KVM - 4GB Ram Huston Texas
50GB SSD Disk
4GB RAM DDR-4
2 vCPU (Fair Use)
1 IPV4 Dedicated
Order USA Texas- $3.20 / Month ++2TB BW @ 10Gbps
** SMTP ports are blocked permanently
**No abuse of resources or any kind of abuse. Fair usage on CPU. The rule of thumb is, if it's illegal, attract DDoS, then it's NOT okay! Abusers will be terminated without notice or refund.
LookingGlass: https://texaslg.khanwebhost.com
Payment Method : Only  Paypal,Cypto,Debit/Credit Card,Unionpay, Alipay Payments will be accepted for this promotion
Terms of Service/AUP : https://khanwebhost.com/tos.php
Discord Channel: https://discord.gg/hfMuNwv
+1 for KWH loving their NAT VPS
Yet-Another-Bench-Script
v2024-06-09
Fri Aug 30 06:56:20 CST 2024
Uptime : 0 days, 0 hours, 6 minutes
Processor : Intel(R) Xeon(R) CPU E5-2699 v4 @ 2.20GHz
CPU cores : 2 @ 2199.998 MHz
AES-NI : ✔ Enabled
RAM : 3.8 GiB
Swap : 1024.0 MiB
Disk : 48.1 GiB
Distro : AlmaLinux 8.8 (Sapphire Caracal)
Kernel : 4.18.0-477.13.1.el8_8.x86_64
VM Type : KVM
ISP : Dfdb LLC
ASN : AS401104 Cyber Planet LLC
Host : KhanWebHost LTD
Country : United States
Geekbench 6 test failed. Run manually to determine cause.
GB6 test should not fail if the memory is 2.5gb+
