nat_manager.py - manage NAT port forwarding for Proxmox VMs and containers
The following code and its documentation were generated using ChatGPT model (o1-preview). I had considered writing this code myself some time ago but hadn’t found the time to do so. Here is the code along with an overview written by ChatGPT. I would appreciate any feedback on how it can be further improved or if there are any mistakes.
Code available at:
https://pastebin.com/cdrxhUSU
nat_manager.py Quick Start Guide
nat_manager.py is a Python script designed to manage NAT (Network Address Translation) and port forwarding rules for VMs and containers in a Proxmox environment. The script utilizes iptables to configure NAT rules and allows for easy addition, removal, listing, updating, exporting, and importing of port mappings.
This guide provides step-by-step instructions for setting up the network, using the script, and provides examples for common operations.
Network Setup in Proxmox
To use nat_manager.py effectively, you need to set up a bridge network (vmbr1) on your Proxmox server. This bridge will use a private IP range and manage the NAT and port forwarding for your VMs and containers.
1. Configure the Bridge Network (vmbr1)
Edit the /etc/network/interfaces file to configure the bridge network interface vmbr1:
sudo nano /etc/network/interfaces
Add the following configuration:
auto vmbr1
iface vmbr1 inet static
address 10.0.0.1/24
bridge-ports none
bridge-stp off
bridge-fd 0
post-up iptables -t nat -A POSTROUTING -s 10.0.0.0/24 -o <YOUR_PUBLIC_INTERFACE> -j MASQUERADE
post-down iptables -t nat -D POSTROUTING -s 10.0.0.0/24 -o <YOUR_PUBLIC_INTERFACE> -j MASQUERADE
<YOUR_PUBLIC_INTERFACE>: Replace this with your network interface that has a public IP (e.g.,enp0s3).
2. Enable IP Forwarding
To ensure IP forwarding is enabled permanently, add the following line to /etc/sysctl.conf:
net.ipv4.ip_forward = 1
Apply the changes:
sudo sysctl -p
3. Restart Networking Service
Restart the networking service to apply the changes:
sudo systemctl restart networking
4. Install Required Packages
To ensure iptables rules persist across reboots, install iptables-persistent and other required packages:
sudo apt-get update
sudo apt-get install iptables-persistent python3 python3-pip sqlite3 -y
iptables-persistent: Allowsiptablesrules to be saved and restored on boot.python3andsqlite3: Required for running thenat_manager.pyscript.
Using nat_manager.py
Run nat_manager.py using Python3. Below are the various usage instructions for managing NAT and port forwarding rules for your VMs and containers.
python3 nat_manager.py -h
usage: nat_manager.py [-h]
{add,remove,list,update,reserve,unreserve,list-reserved,export,import,backup,restore,rebuild-db}
NAT Manager Script
positional arguments:
Available actions
add Add port mappings for a container
remove Remove port mappings for a container
list List port mappings
update Update port mappings for a container
reserve Reserve ports for the host machine
unreserve Unreserve ports
list-reserved List reserved ports
export Export port mappings to a JSON file
import Import port mappings from a JSON file
backup Backup current configuration
restore Restore configuration from backup
rebuild-db Rebuild the database from existing iptables rules
options:
-h, --help show this help message and exit
1. Add Port Mappings
To add NAT port forwarding rules for a VM or container with an internal IP address (e.g., 10.0.0.5):
sudo python3 nat_manager.py add <container_ip> --mode <automatic|manual> --num-ports <N>
- Parameters:
<container_ip>: Internal IP address of the VM/container (e.g.,10.0.0.5).--mode: Mode for adding ports,automatic(default) ormanual.--num-ports <N>: Number of ports to forward (default:6).
Examples:
Automatic Mode:
sudo python3 nat_manager.py add 10.0.0.5 --mode automatic --num-ports 4This command automatically assigns 4 external ports (starting from
50000) to forward traffic to standard internal ports (e.g.,22,80,443,8080) on10.0.0.5.Manual Mode:
sudo python3 nat_manager.py add 10.0.0.5 --mode manual --external-ports 50000 50001 --internal-ports 22 80 --protocols tcp udpThis command manually assigns external ports
50000(TCP) and50001(UDP) to forward to internal ports22(SSH) and80(HTTP) on10.0.0.5.
2. Remove Port Mappings
To remove all port forwarding rules associated with a specific container IP:
sudo python3 nat_manager.py remove <container_ip>
Example:
sudo python3 nat_manager.py remove 10.0.0.5This command removes all port mappings associated with the IP
10.0.0.5.
3. List Current Port Mappings
To list all current port mappings or those for a specific container IP:
sudo python3 nat_manager.py list [container_ip]
Examples:
- List All Mappings:
sudo python3 nat_manager.py listLists all port mappings currently configured on the Proxmox server.
- List Mappings for a Specific Container:
sudo python3 nat_manager.py list 10.0.0.5Lists the port mappings for the container with IP
10.0.0.5.
4. Update Port Mappings
To update existing port mappings for a VM or container:
sudo python3 nat_manager.py update <container_ip>
Examples:
- Interactive Mode:
sudo python3 nat_manager.py update 10.0.0.5This command will prompt you to update the internal ports or protocols for each external port currently mapped to
10.0.0.5. Leave input blank to keep the current mapping.- Non-Interactive Mode:
sudo python3 nat_manager.py update 10.0.0.5 --external-ports 50000 50001 --internal-ports 2222 8081 --protocols tcp udpThis command updates the external port
50000to forward to internal port2222(TCP) and50001to forward to8081(UDP) on10.0.0.5.
5. Export and Import Port Mappings
You can export current port mappings to a JSON file for backup purposes or import them from a JSON file.
Export Port Mappings:
sudo python3 nat_manager.py export /path/to/export.jsonThis command exports the current port mappings to
export.json.Import Port Mappings:
sudo python3 nat_manager.py import /path/to/export.jsonThis command imports port mappings from
export.json.
6. Backup and Restore Configuration
You can backup the current configuration of iptables and port mappings or restore from a backup.
Backup Current Configuration:
sudo python3 nat_manager.py backupThis creates a backup of the current
iptablesrules and port mappings database.Restore Configuration from Backup:
sudo python3 nat_manager.py restore <timestamp>Replace
<timestamp>with the desired backup timestamp (e.g.,backup_20230917123045).
7. Rebuild the Database from Existing iptables Rules
If the SQLite database is lost or out of sync with iptables rules, you can rebuild it:
sudo python3 nat_manager.py rebuild-db
This command scans existing iptables rules and reconstructs the database for consistency.
Important Notes
- IP Forwarding: Ensure IP forwarding is enabled by adding
net.ipv4.ip_forward = 1to/etc/sysctl.confand runningsudo sysctl -p. - Save
iptablesRules: To ensure the rules persist after reboot, useiptables-save > /etc/iptables/rules.v4andiptables-restore < /etc/iptables/rules.v4. Check
iptables-persistent: Ensureiptables-persistentis installed and enabled to manage rule persistence:sudo apt-get install iptables-persistent -y sudo netfilter-persistent save
Network Configuration for VM/Container in Proxmox
When creating a VM or container in Proxmox that will use NAT:
Assign an Internal IP Address:
- Assign an IP within the
vmbr1subnet, such as10.0.0.5. - This IP will be used for internal communication and NAT port forwarding.
Connect to
vmbr1Network Bridge:- Ensure the VM/container network interface is attached to
vmbr1to use the internal network managed by NAT. - In Proxmox, select
vmbr1as the network bridge when creating or configuring the VM/container.
Configure Gateway (Optional):
- Set the gateway to
10.0.0.1(thevmbr1address) to route all outbound traffic through the Proxmox host.
This setup allows VMs/containers to communicate internally using 10.0.0.x IPs and be accessed externally via port forwarding rules defined by nat_manager.py.
Wow, this is useful!
C1V Hosting: Low cost Italian Cloud & Data Center Solutions 🚀 | Contact us for special offers. | Our deals on Telegram
Interesting I have been playing with this myself lately.
@Not_Oles you might be interested in this!
Thanks @loay and appreciated!
I was doing it manually but I guess it'll be easier now that I'll be using this script. Thanks for doing this!
