Crypto Wallet Recommendation
edited October 2024 in General
Which Crypto wallet you use and recommend for personal use.
Should support all major trending crypto BTC, LTC, XMR etc
Note: KYC is not an issue and should have Mobile App
Currently Using Namecrane and Lowendrack
  • I recommend Ledger. OGs in the crypto space. Been using mine since 2011.
    Thanks but look like these are paid hardware wallets, i need free one :wink:
  • What's wrong with metamask?
    How's Trust Wallet?
    Metamask loads too slow for me also less coins options.
  • If Monero support is a must, your options are limited, with Cake Wallet being the only decent option.
  • Trezor Wallet all the best. They don't have an official app in the market just to watch your wallet but if you use Android all you need is a dongle and you can access your wallet via Chrome.
  • I would go with Cake Wallet.
