Which Crypto wallet you use and recommend for personal use.
Should support all major trending crypto BTC, LTC, XMR etc
Note: KYC is not an issue and should have Mobile App
I recommend Ledger. OGs in the crypto space. Been using mine since 2011.
LinuxFreek.com β Hosted on πͺπΊ OVH KS-LE-B - E3 1270v6 - 64GB RAM - 2x 1.2TB NVMe - 500Mbps/1Gbps - GRA (FR)
@Freek said: I recommend Ledger. OGs in the crypto space. Been using mine since 2011.
Thanks but look like these are paid hardware wallets, i need free one
What's wrong with metamask?
@Freek said: What's wrong with metamask?
How's Trust Wallet? Metamask loads too slow for me also less coins options.
If Monero support is a must, your options are limited, with Cake Wallet being the only decent option.
Trezor Wallet all the best. They don't have an official app in the market just to watch your wallet but if you use Android all you need is a dongle and you can access your wallet via Chrome.
I would go with Cake Wallet.
Filen.io - use this link to signup and we both get extra 10GB free. https://filen.io/r/4d472d5cdb57f6663621a251065e0b51
How's Trust Wallet?
