@Not_Oles said: Before I do anything, though, I just want to double check with @cmeerw because he's been working on the NetBSD images. If there is anything that @cmeerw might want to do or check or ask me to do or check, I want to make sure that whatever @cmeerw wants is done.
I believe your version of the image might actually just resize the partition and file system on the next reboot (that's because in the first version I didn't mount the filesystem with the "log" option).
Later versions now use the "log" option - this is preferable, but it means that resizing (after the first boot) gets more complicated (or even dangerous).
So I think, just try a restart of the machine and see if the filesystem gets resized.
After that, I think it still makes sense to move to the new image to get some more useful block sizes and inode counts for the filesystem (it should get resized to the full capacity on the first boot, but further resizes won't be automatic).
BTW, I actually tried booting into the OpenBSD 7.6 installer (via netboot.xyz) when it was released, but it did hang just before getting to user space.
I've upgraded a handful of my 7.5 instances to 7.6 thus far with no issues. I haven't done my Linveo VM yet but when I do if I run into any problems I'll let you know. I didn't have any problems getting 7.5 installed using netboot.xyz though so I don't expect any issues with 7.6 either.
How come only 40880 1M-blocks total when @linveo increased the size to 50GB? Does using so many extra inodes somehow take up a substantial portion of the "missing" 9120 blocks?
Since there now is more disk space and since the system still seems to be working okay, it might be fun to continue the system build, just to see whether it breaks, and, if so, where and how and why. Of course, after retrying the system build, we can go ahead and reinstall.
@Not_Oles said: How come only 40880 1M-blocks total when @linveo increased the size to 50GB? Does using so many extra inodes somehow take up a substantial portion of the "missing" 9120 blocks?
Yes, that's the inodes/filesystem overhead (and there is a 512 MB swap partition).
BTW, you can also look at the partitions with gpt show ld0 and dkctl ld0 listwedges
It's probably very simple, but I have to figure out how to install the newly built distribution and then see if the VM will reboot.
Then we can reinstall from @cmeerw's new image to fix the inode issue.
Hmm. I wonder if there might be a way to fix the inode issue without reinstalling the VM from the new image. Like, for example, create and move critical parts of the OS into a memory resident filesystem, then wipe and reinstall the disk based filesystem, download full NetBDSD to the new disk based filesystem, get sources, and rebuild.
Since everything "just works" every day and night, there's not much to report but 100% uptime across the board!
FreeBSD 14.2 is going to arrive in early December, so that'll bring some new excitement and bunch of work to get all the systems updated, but not expecting any hiccups there.
People have been very busy with this thread and I am super happy to see that. Thank you @linveo for providing these great resources to the community and @cmeerw for the excellent work on NetBSD!
Also I wanted to add a tip of the day, check out this great command line utility with an awesome modern approach: https://github.com/aristocratos/bpytop
@Not_Oles said: It looks like we only needed a little more space than we had.
So it would have worked with the new filesystem settings with the original disk space allocation.
@Not_Oles said: Hmm. I wonder if there might be a way to fix the inode issue without reinstalling the VM from the new image. Like, for example, create and move critical parts of the OS into a memory resident filesystem, then wipe and reinstall the disk based filesystem, download full NetBDSD to the new disk based filesystem, get sources, and rebuild.
Well... there is a 512 MB swap partition you could use as a temporary alternative root filesystem.
Thanks @linveo! The OpenBSD install post looks great! From the above linked overview, there are links to a step-by-step walkthrough, which links to a page about setting up a desktop environment.
I hope to try the OpenBSD install after I get NetBSD to rebuild itself as -current (done), install the newly rebuilt kernel (upcoming), and reboot (upcoming), and then install (upcoming) the already built, -current userland (done).
@linveo If you haven't already, maybe you could kindly pass on to your customer our invitation to join us here in the LES BSD thread? Thanks again!
Here is moving our previous faithful and hard working kernel to "retired" status, copying the newly compiled kernel from the /obj directory to /, and adjusting the mode to match the previous kernel.
Spoiler
linveo# date
Tue Oct 22 18:55:26 UTC 2024
linveo# pwd
/home/tom/obj/sys/arch/amd64/compile/GENERIC
linveo# ls -l netbsd
-rwxr-xr-x 1 tom users 29572928 Oct 19 23:56 netbsd
linveo# ls -l /netbsd
-rw-r--r-- 1 root wheel 29572760 Oct 5 00:39 /netbsd
linveo# mv /netbsd /netbsd-old
linveo# cp netbsd /
linveo# ls -l /netbsd*
-rwxr-xr-x 1 root wheel 29572928 Oct 22 18:59 /netbsd
-rw-r--r-- 1 root wheel 29572760 Oct 5 00:39 /netbsd-old
linveo# chmod 644 /netbsd
-rw-r--r-- 1 root wheel 29572928 Oct 22 18:59 /netbsd
linveo# date; shutdown -r now
Tue Oct 22 19:07:28 UTC 2024
Shutdown NOW!
shutdown: [pid 5108]
linveo#
*** FINAL System shutdown message from root@linveo.metalvps.com ***
System going down IMMEDIATELY
System shutdown time has arrived
About to run shutdown hooks...
Stopping cron.
Stopping inetd.
Saved entropy to /var/db/entropy-file.
Forcibly unmounting /tmp
Forcibly unmounting /var/shm
Removing block-type swap devices
swapctl: removing /dev/dk1 as swap device
Tue Oct 22 19:07:33 UTC 2024
Done running shutdown hooks.
Connection to xxx.xxx.xxx.xxx closed by remote host.
Connection to xxx.xxx.xxx.xxx closed.
chronos@penguin:~/servers/linveo$
Now to reboot and hopefully come back up running our self-compiled NetBSD-current GENERIC kernel.
Did it work?
Spoiler
chronos@penguin:~/servers/linveo$ `head -n 1 login`
Last login: Tue Oct 22 18:17:38 2024 from xxx.xxx.xxx.xxx
NetBSD 10.99.12 (GENERIC) #1: Sat Oct 19 23:52:58 UTC 2024
Welcome to NetBSD!
We recommend that you create a non-root account and use su(1) for root access.
linveo# date
Tue Oct 22 19:09:54 UTC 2024
linveo#
Next up is to install and, if changes are needed, to adjust the configuration of our newly compiled NetBSD-current userland. When the new userland has been installed, we will have reached our goal of running self-compiled NetBSD-current! All the sources will be really handy -- we can look at or change anything. If we get the userland up, then maybe we can try @AlwaysSkint's risky method of restructuring the filesystem to fix the inodes issue, or just reinstall from an ISO where the inodes issue already is fixed.
Thanks to @linveo for the really nice VPS! Thanks to @cmeerw, @AlwaysSkint and the other guys here for suggestions and for catching my mistakes.
I tweak the superblock allocation on some filesystems to eke out a little more space
egs. tune2fs -m0 /dev/system-backups and tune2fs -m1 /dev/system-tmp
Typically, I don't reduce root, however.
@cmeerw said:
BTW, a few weeks ago I mentioned the cpuid tool - as of cpuid 20241023 my changes for NetBSD have been integrated, so it now also works on NetBSD.
For convenient reference, here is a link to the mention of cpuid by @cmeerw on September 24:
finally, today, I got around to trying to install the a-few-days-ago compiled userland.
I think I am in the same /home/tom/src directory that I used to build the distribution, but some things don't seem quite right. For example, build.sh is empty.
Spoiler
Welcome to NetBSD!
linveo# cd /home/tom
linveo# cd src
linveo# pwd
/home/tom/src
linveo# ls
BUILDING Successful common doc lib share usr.sbin
CVS Summary compat etc libexec sys
Makefile UPDATING crypto external regress tests
Makefile.inc bin dist games rescue tools
README.md build.sh distrib include sbin usr.bin
linveo# date
Sat Oct 26 23:17:34 UTC 2024
linveo# time ./build.sh -O ../obj -T ../tools -U install=/
0.00 real 0.00 user 0.00 sys
linveo# linveo# wc S*
0 0 0 Successful
0 0 0 Summary
0 0 0 total
linveo# wc build.sh
0 0 0 build.sh
linveo# cat build.sh
linveo#
I do have
Spoiler
linveo# pwd
/home/tom/obj
linveo# linveo# ls -l releasedir/amd64/binary/sets/
total 205996
-rw-r--r-- 1 tom users 954 Oct 20 00:10 MD5
-rw-r--r-- 1 tom users 2637 Oct 20 00:10 SHA512
-rw-r--r-- 1 tom users 38278856 Oct 20 00:06 base.tar.xz
-rw-r--r-- 1 tom users 10913096 Oct 20 00:05 base32.tar.xz
-rw-r--r-- 1 tom users 82581160 Oct 20 00:10 comp.tar.xz
-rw-r--r-- 1 tom users 510172 Oct 20 00:06 etc.tar.xz
-rw-r--r-- 1 tom users 2550444 Oct 20 00:06 games.tar.xz
-rw-r--r-- 1 tom users 4143972 Oct 20 00:06 gpufw.tar.xz
-rw-r--r-- 1 tom users 8910200 Oct 19 23:58 kern-GENERIC.tar.xz
-rw-r--r-- 1 tom users 9135068 Oct 19 23:58 kern-GENERIC_KASLR.tar.xz
-rw-r--r-- 1 tom users 6645472 Oct 19 23:58 kern-XEN3_DOM0.tar.xz
-rw-r--r-- 1 tom users 2533980 Oct 19 23:58 kern-XEN3_DOMU.tar.xz
-rw-r--r-- 1 tom users 5705380 Oct 20 00:07 man.tar.xz
-rw-r--r-- 1 tom users 3488776 Oct 20 00:07 manhtml.tar.xz
-rw-r--r-- 1 tom users 4167024 Oct 20 00:07 misc.tar.xz
-rw-r--r-- 1 tom users 10104552 Oct 20 00:07 modules.tar.xz
-rw-r--r-- 1 tom users 3517528 Oct 20 00:07 rescue.tar.xz
-rw-r--r-- 1 tom users 15288428 Oct 20 00:08 tests.tar.xz
-rw-r--r-- 1 tom users 1921928 Oct 20 00:08 text.tar.xz
linveo#
I think I could just go extract base, comp, etc, games, man, misc, modules, rescue, tests, and text from /. Then run postinstall and etcupdate. But, what happened to build.sh in /home/tom/src? That's the same build.sh that was used to build the kernel. Maybe the loss of the build.sh file had something to do with running out of filesystem space? Maybe something to do with the inode issue? Did I make a mistake?
It's getting about time to reinstall. But it's fun to mess around with stuff!
So . . . the NetBSD-current VM still reboots successfully. I want to work more on etcupdate. And everything else. But maybe we have arrived at the goal of building and running NetBSD-current. Maybe it's time to reinstall with @cmeerw's newer image that has the number of inodes fixed.
If I rebuild NetBSD-current a few dozen more times, maybe I can start to remember to build as tom instead of root. It seems also that I can use "-j 2" with build.sh, and maybe that will decrease the build times.
If anybody catches other mistakes that I am making, I'd be glad to learn more!
Thanks to @linveo for a very fast, very nice VPS! Thanks to NetBSD! Thanks to the guys here in the LES BSD thread and to everyone else at LES!
Spoiler
linveo# shutdown -r now
Shutdown NOW!
shutdown: [pid 19887]
linveo#
Stopping cron.
Stopping inetd.
Mon Oct 28 17:14:44 UTC 2024
chronos@penguin:~/servers/linveo$ sleep 60
chronos@penguin:~/servers/linveo$ `head -n 1 login` | tee -a 20241027-build.sh-usr-src
Last login: Mon Oct 28 03:57:04 2024 from xxx.xxx.xxx.xxx
Welcome to NetBSD!
linveo# date
Mon Oct 28 17:16:24 UTC 2024
linveo#
make distribution started at: Mon Oct 28 03:21:47 UTC 2024
make distribution finished at: Mon Oct 28 08:04:55 UTC 2024
The procedure for investigating was that /usr/src, /usr/tools, and /usr/obj were moved aside and replaced by new versions. The new /usr/src was extracted from the same tar file as previously used without the -j 2 option.
This time the job was run by user tom instead of by root.
Here is the full command:
linveo$ date; time ./build.sh -j 2 -O ../obj -T ../tools -U distribution; date
And here is the result summary showing that make distribution took 2 hours and 57 minutes:
Spoiler
make distribution started at: Mon Oct 28 22:27:46 UTC 2024
make distribution finished at: Tue Oct 29 01:24:08 UTC 2024
===> Successful make distribution
===> build.sh ended: Tue Oct 29 01:24:08 UTC 2024
===> Summary of results:
build.sh command: ./build.sh -j 2 -O ../obj -T ../tools -U distribution
build.sh started: Mon Oct 28 22:27:46 UTC 2024
NetBSD version: 10.99.12
MACHINE: amd64
MACHINE_ARCH: x86_64
Build platform: NetBSD 10.99.12 amd64
HOST_SH: /bin/sh
share/mk MAKECONF: /etc/mk.conf
MAKECONF file: /etc/mk.conf (File not found)
TOOLDIR path: /usr/src/../tools
DESTDIR path: /usr/src/../obj/destdir.amd64
RELEASEDIR path: /usr/src/../obj/releasedir
Updated makewrapper: /usr/src/../tools/bin/nbmake-amd64
10582.23 real 7028.72 user 1949.24 sys
linveo$
So, -j 2 saved 1 hour and 46 minutes or 37%.
Below is the output of top during the -j 2 compile.
@linveo Thanks again for the fast VPS! Are you happy to see this usage sustained for three of four hours at a time multiple times per week or even per day? If this usage is too much, I can go run it on a dedi, no problem at all.
I am happy when people are using the VMs for a good purpose like this!
Hi bsd guys, new freebsd user here, taking advantage of Linveo's offer to learn a little FreeBSD and soon OpenBSD.
I have a question: which firewall should I use when learning freebsd? I have read the documentation and I see that there are at least 3 firewalls available. However, I don't know which one is recommended for FreeBSD, or which one is used by most people who use FreeBSD. At the moment I am learning PF firewall since I see that if I am not mistaken it is the one used by PFSense and the one that seems to me to be the most used among the FreeBSD community, however, since it is developed for OpenBSD, I do not know if it is the most indicated to use in FreeBSD.
My doubt here is really which is the firewall that integrates better with the operating system?
@Crab What's up in the FreeBDSD world?
@FrankCastle And in the OpenBSD world?
A new version just came out a couple weeks ago so I've been slowing upgrading all of my VMs to this latest version.
Rebooting from the Linveo panel worked!
Inode check for @cmeerw
gpt show ld0
anddkctl ld0 listwedges
Finally I got around to retrying build.sh from where the file system became full, above.
The rebuild seems to be running okay. I will post again when it either breaks or completes.
Thanks to @linveo for a nice VPS and for additional disk space!
Thanks to @cmeerw for his NetBSD images, help, and encouragement!
Wow!
Um . . . what now?
When we ran out of file space before the size increase:
Now, after the filesystem size increase and after finishing the build:
Risky:
One of our awesome customers put together a guide on installing OpenBSD via ISO on our services. Take a look!
https://btxx.org/posts/openbsd-linveo/
Interesting, I only ever get as far as this with OpenBSD:
Not that I really want to use OpenBSD, was just curious...
/obj
directory to/
, and adjusting the mode to match the previous kernel.Now to reboot and hopefully come back up running our self-compiled NetBSD-current GENERIC kernel.
Did it work?
You mean the
tunefs -m
? That won't do anything to fix the inodes issue - it only allows non-root users to use a bit more of the filesystem space.My bad, I'm old skool:
This is the problem with x86_64 image. Regular x86 works fine.
https://btxx.org/posts/openbsd-linveo/ actually seems to use the amd64 image.
https://lowendspirit.com/discussion/comment/186451/#Comment_186451
where @cmeerw said:
There are several more mentions of cpuid in additional posts which can be seen by scrolling further down on September 24.
Congrats to @cmeerw on getting his patch accepted!
Reference: https://www.netbsd.org/docs/guide/en/chap-updating.html
After what a few days ago seemed like a successful build and reboot of a new kernel,
I do have
Just for fun, trying again, as root, to build and install the userland.
Build
Install
Example Results In /bin
Run postinstall
Run etcupdate
Tried etcupdate for the first time, as far as I recall. It has lots of output! Left it for later.
Thanks to NetBSD!
How effective was adding
-j 2
at reducingbuild.sh
compile time?From above at https://lowendspirit.com/discussion/comment/188830/#Comment_188830 we can see that the time taken to compile the NetBSD-current distribution without any "jobs"
-j
flag was about 4 hours and 43 minutes:The procedure for investigating was that
/usr/src
,/usr/tools
, and/usr/obj
were moved aside and replaced by new versions. The new/usr/src
was extracted from the same tar file as previously used without the-j 2
option.This time the job was run by user
tom
instead of byroot
.Here is the full command:
So,
-j 2
saved 1 hour and 46 minutes or 37%.Below is the output of
top
during the-j 2
compile.@linveo Thanks again for the fast VPS!
Reinstalled with NetBSD 10 image.
Thanks to @cmeerw for creating the image!
Thanks to @linveo for making @cmeerw's NetBSD 10 image available!
Note the significant change in inodes available.
Formerly:
After NetBSD 10 reinstall:
