NatVPS KVM / Tips & Tricks
Hi,
Wondering how some manage to use the new "nat-kvm" from NatVPS.... In France for now if I understood correctly.
The idea is not to complain, so far cpu and network are pretty good!
By the way I'm only a windows dev. so I'm far from a knowledgeable Linux user!
  • Impossible to install anything from a CD (netboot.xyz, etc) => memory errors
  • so, use of the "bullseye template", sorry I only know and work with Debian
    • impossible to install and then upgrade properly without a small swap, the memory is not 256 but 174MiB
  • Finally Caddy and wireguard (i only need these) are working... But that was a lot of work!
Uptime     : 0 days, 0 hours, 41 minutes
Processor  : Intel Xeon E3-12xx v2 (Ivy Bridge, IBRS)
CPU cores  : 1 @ 3392.294 MHz
RAM        : 173.8 MiB
Swap       : 128.0 MiB
Disk       : 3.9 GiB
Kernel     : 5.10.0-33-amd64
Anyone did better? Has any tips to share?
  • edited November 2024
    https://wiki.debian.org/ReduceDebian
    Reduce the size of the initramfs
    create /etc/initramfs-tools/conf.d/compress with the content
    COMPRESS=xz
    reduce it further with
    sed -i s,MODULES=most,MODULES=dep,g /etc/initramfs-tools/initramfs.conf
    update-initramfs -u
  • @TigersWay said:
    Hi,
    RAM        : 173.8 MiB
    Swap       : 128.0 MiB
    Disk       : 3.9 GiB
    Where to buy mini nat vps :#
  • @TigersWay said: the memory is not 256 but 174MiB
    Your service actually does have 256mb of RAM; the difference is because of how KVM virtualization works (having dedicated linux kernel rather than a shared one)
    see here:
    https://clients.webhorizon.net/?/knowledgebase/article/53/why-is-the-total-memory-less-than-expected-/
    Thanked by (1)bliss
    I'm a host rep for WebHorizon [AS149020] - VPS, Dedicated Servers, Web & Email Hosting
    Singapore, Japan, India, Netherlands & Norway
    Don't worry, I never called anyone a liar... And after years and years playing with VPS I known and clearly saw every time that simple difference.
    But it doesn't change the fact that in that instance the total of memory left I can use is then VERY short, and make it very difficult to manage that box, reason why I am not looking for explanation but for tricks =)
    Mm, if there's a NatVPS LXC plan, you could apply/request for a transfer there. It would give you the full 256 MB.
  • @Ayyub , Any time table for other locations? Thank you.
