[Transfer] Layer.ae L512M-SG in Singapore 🇸🇬
Specs of L512M-SG
- 1x AMD Ryzen 9 7950X (4.5 GHz++)
- 512MB DDR5 RAM
- 10GB NVMe (PCIe 4.0)
- 500GB Bandwidth
- 10Gbit Port
- 1x IPv4 Address
- /64 IPv6
- DDOS Watch™
- 5x FREE Backup Slots
- Automated rDNS
- VirtFusion Control Panel
- Singapore, Singapore
- BYOIP Supported
Recurring price: $20 USD / year
Next due date: Tuesday, March 25th, 2025
Since this is a giveaway from the OGF (and I don't need it anymore since I just got a replacement of their 11.11 deal), this is given for free to anyone interested. Only charge is a $5 USD transfer fee by Layer.ae. Payment via PayPal or Crypto (XMR, LTC, ...)
Please be respectful, if you want the transfer, comment that you want it and afterward DM me. If you directly DM me, I won't answer you.
I won't transfer this to new accounts. You must at least have a few non-spammy posts.
YABS
# Yet-Another-Bench-Script #
# v2024-06-09 #
Tue Nov 12 04:40:49 PM +08 2024
Uptime : 0 days, 0 hours, 1 minutes
Processor : AMD Ryzen 9 7950X 16-Core Processor
CPU cores : 1 @ 4500.016 MHz
AES-NI : ✔ Enabled
VM-x/AMD-V : ❌ Disabled
RAM : 422.6 MiB
Swap : 1024.0 MiB
Disk : 9.9 GiB
Kernel : 6.1.0-27-amd64
VM Type : KVM
ISP : Layer Marketing Services L.L.C
ASN : AS216382 LAYER MARKETING SERVICES L.L.C
Host : Layer
Country : Singapore
fio Disk Speed Tests (Mixed R/W 50/50) (Partition /dev/vda3):
Read | 261.89 MB/s (65.4k) | 571.80 MB/s (8.9k)
Write | 262.58 MB/s (65.6k) | 574.81 MB/s (8.9k)
Total | 524.48 MB/s (131.1k) | 1.14 GB/s (17.9k)
Read | 545.64 MB/s (1.0k) | 614.27 MB/s (599)
Write | 574.63 MB/s (1.1k) | 655.18 MB/s (639)
Total | 1.12 GB/s (2.1k) | 1.26 GB/s (1.2k)
Clouvider | London, UK (10G) | 365 Mbits/sec | 332 Mbits/sec | 249 ms
Eranium | Amsterdam, NL (100G) | 853 Mbits/sec | 525 Mbits/sec | 156 ms
Uztelecom | Tashkent, UZ (10G) | 639 Mbits/sec | 685 Mbits/sec | 124 ms
Leaseweb | Singapore, SG (10G) | 3.43 Gbits/sec | 7.70 Gbits/sec | 1.74 ms
Clouvider | Los Angeles, CA, US (10G) | 686 Mbits/sec | 469 Mbits/sec | 184 ms
Leaseweb | NYC, NY, US (10G) | busy | busy | 407 ms
Edgoo | Sao Paulo, BR (1G) | busy | 245 Mbits/sec | 332 ms
Geekbench 5 Benchmark Test:
Test | Value
Single Core | 1707
Multi Core | 1601
Full Test | https://browser.geekbench.com/v5/cpu/23055509
Geekbench test failed and low memory was detected. Add at least 1GB of SWAP or use GB4 instead (higher compatibility with low memory systems).
YABS completed in 15 min 36 sec
NWS Global
---------------------------------- nws.sh ---------------------------------
A simple script to bench network performance using speedtest-cli
Version : v2024.11.03
Global Speedtest : wget -qO- nws.sh | bash
Region Speedtest : wget -qO- nws.sh | bash -s -- -r <region>
Basic System Info
CPU Model : AMD Ryzen 9 7950X 16-Core Processor
CPU Cores : 1 @ 4500.016 MHz
CPU Cache : 1024 KB
AES-NI : ✔ Enabled
Total Disk : 9.9 GB (4.4 GB Used)
Total RAM : 422.6 MB (132.6 MB Used)
Total Swap : 1024.0 MB (58.9 MB Used)
System uptime : 0 days, 0 hour 26 min
Load average : 0.07, 0.16, 0.27
OS : Debian GNU/Linux 12
Arch : x86_64 (64 Bit)
Virtualization : KVM
TCP Control : cubic
Basic Network Info
Primary Network : IPv4
IPv6 Access : ❌ Offline
IPv4 Access : ✔ Online
Host : Layer
Location Latency Loss DL Speed UP Speed Server
ISP: Layer Marketing Services
Nearest 2.09 ms 0.0% 7298.83 Mbps 2709.61 Mbps Contabo - Singapore
Kochi, IN 45.06 ms 0.0% 4008.28 Mbps 1489.66 Mbps Asianet Broadband - Cochin
Bangalore, IN 37.78 ms 0.0% 2449.50 Mbps 990.00 Mbps Bharti Airtel Ltd - Bangalore
Chennai, IN 33.49 ms N/A 3349.89 Mbps 1713.26 Mbps Jio - Chennai
Mumbai, IN 177.88 ms 0.0% 1885.40 Mbps 370.15 Mbps i3D.net - Mumbai
Delhi, IN 78.72 ms 0.0% 2389.45 Mbps 594.96 Mbps Tata Play Fiber - New Delhi
Seattle, US 190.81 ms N/A 1983.77 Mbps 396.18 Mbps Comcast - Seattle, WA
Los Angeles, US 188.86 ms 0.0% 2033.26 Mbps 386.41 Mbps ReliableSite Hosting - Los Angeles, CA
Dallas, US 321.14 ms 0.0% 1073.75 Mbps 223.12 Mbps i3D.net - Dallas, TX
Miami, US 324.60 ms N/A 1131.09 Mbps 209.32 Mbps Dish Wireless - Miami, FL
New York, US 221.90 ms 0.0% 1665.03 Mbps 282.26 Mbps GSL Networks - New York, NY
Toronto, CA FAILED
Mexico City, MX 235.69 ms N/A 1672.27 Mbps 325.66 Mbps INFINITUM - Ciudad de México
London, UK 165.89 ms 0.0% 2162.66 Mbps 437.87 Mbps VeloxServ Communications - London
Amsterdam, NL 158.73 ms 0.0% 2419.32 Mbps 407.90 Mbps 31173 Services AB - Amsterdam
Paris, FR 237.29 ms N/A 1643.18 Mbps 190.17 Mbps Axione - Paris
Frankfurt, DE 248.28 ms 0.0% 988.51 Mbps 303.97 Mbps Clouvider Ltd - Frankfurt am Main
Warsaw, PL 198.37 ms 0.0% 1990.33 Mbps 433.72 Mbps Play - Warszawa
Bucharest, RO 174.57 ms 0.0% 1870.17 Mbps 416.50 Mbps Vodafone Romania Fixed – Bucharest - Bucharest
Moscow, RU 193.18 ms 0.3% 1597.79 Mbps 96.67 Mbps RETN - Moscow
Jeddah, SA 97.93 ms 0.0% 3971.53 Mbps 532.33 Mbps Saudi Telecom Company
Dubai, AE 84.23 ms 0.0% 3113.65 Mbps 635.15 Mbps du - Dubai
Fujairah, AE 75.19 ms 0.0% 2140.19 Mbps 455.99 Mbps e& UAE - Fujairah
Istanbul, TR 196.99 ms 0.0% 1888.04 Mbps 346.57 Mbps Turkcell - Istanbul
Tehran, IR 314.29 ms 0.0% 819.98 Mbps 227.64 Mbps Asiatech - Tehran
Tokyo, JP 73.08 ms N/A 4443.39 Mbps 583.07 Mbps GSL Networks - Tokyo
Wu Xi, CU-CN FAILED
Nanjing, CT-CN 491.38 ms N/A 5.30 Mbps 1.45 Mbps China Telecom JiangSu 5G - Nanjing
Hong Kong, CN 45.21 ms N/A 6866.45 Mbps 1646.05 Mbps STC - Hong Kong
Singapore, SG 1.13 ms 0.0% 8086.59 Mbps 7276.99 Mbps i3D.net - Singapore
Jakarta, ID FAILED - IP has been rate limited. Try again after 1 hour.
Avg DL Speed : 2676.70 Mbps
Avg UL Speed : 845.81 Mbps
Total DL Data : 98.71 GB
Total UL Data : 26.79 GB
Total Data : 125.49 GB
Duration : 18 min 42 sec
System Time : 12/11/2024 - 17:24:23 +08
Total Script Runs : 87710
Result : https://result.nws.sh/r/1731402417_I8Z1T9_GLOBAL.txt
Thanked by (1)sh97
Interested in getting this. Check DM.
Transferred it to @loay, quick and easy
Flagged post to get it closed.
