India, yea you exceeded 50% cpu usage on a shared system for a few hours.
omg sorry for that.
actually the cpu usage is quite strange as i don't use the india vm yet, for anything.
i have temporary shut it down to prevent anything worse
You can check the logs, from the first email you should be able to figure it out.
Sometimes I have seen apt-get hanging, while doing some background tasks, hammering a full cpu core.
However can't tell you what process that was, since not storing or processing that information.
Oradea Maitenence
Due to some infrastructure changes, Oradea will be offline on Saturday the 21 of September.
This will start at around 08:00 AM Bucharest Time and will take 4-6 hours.
ITS WEDNESDAY MY DUDES
Usually I log in to each VM to see their container ID.
https://microlxc.net/
Oradea Maitenence
8ffb-fabc-14cb-6f6a
datalix's aff #1 fan
2831-4a7d-30e6-01af
Mumbai is currently down, forgot to make it public visible on the status page, fixed.
fbaa-32e0-a92d-e4f7
4727-141c-9a73-6b62
6303-f03c-b698-ac91
There is a bug with the bot, will look into it today.
92a1-5edd-c1f2-2162
The regrex is broken as usual.
For some reason my debug tool doesn't want to work, so have to figure out that first.
Fixed.
17e9-2e5f-e9e7-3a5a
Since its CB and we still got a decent amount of memory free on some Nodes.
JP, NL and FI have 50% off memory usage.
So if you get a 128MB LXC container, only 64MB will be deducted, as long as you keep it.
Runs either until the memory threshold is hit or CM ends.
Anything for nanokvm?
No.
There is about 3GB memory left per Node for the promo.
Restocked Mumbai.
