@sh97 said: It got deployed on a SEA node, but ping tests suggest it's in LA.
I think the offer was for NYC Metro (not complaining, but guess I got affected by the bug you mentioned)
Yeah I'm going to have to go through most of these and verify them manually/move and probably fix specifications.
FRANKZ coupon code expired early as I need the system to calm down a little right now and probably not add to the workload. No replacement coupon at this time.
looks like I am late,was used coupon but waste few minutes to login,then the coupon gone😭
@tototo said:
Was Offer #143 (2C/1.4G/55G/5.7T/NYC) the last one in stock among Offers #141-143? I think I clicked the middle link, which was the only one not marked as OoS, but I’m starting to lose confidence.
I feel like this was a while ago, I have no idea. I don't think it was a stock issue though, timing maybe?
To provide some context, at that time, the links on the left and right were marked as "Out of Stock," so I clicked "Add to Cart" on the middle link. I thought I added Offer #142 (Los Angeles) to my cart, but the email and the information about the VPS I received indicate Offer #143 (NYC Metro). This makes me wonder whether my memory is incorrect or if the BF page and cart weren’t properly synced. So I asked.
Even if it was some kind of bug, I’m fine with it since I only paid $0.17.
Yours will likely need to be recreated. Confirm with me when convenient to do that.
It's an issue with the new clustering system. It clusters but then disregards the clusters at some point. So you ended up getting an adjacent offer.
@tototo said: To provide some context, at that time, the links on the left and right were marked as "Out of Stock," so I clicked "Add to Cart" on the middle link. I thought I added Offer #142 (Los Angeles) to my cart, but the email and the information about the VPS I received indicate Offer #143 (NYC Metro). This makes me wonder whether my memory is incorrect or if the BF page and cart weren’t properly synced. So I asked.
Most likely the bug I described above. Going through them now, some will have to be recreated.
Got it. Feel free to discard or regenerate as needed!
Background: Black Friday approaching, logging my account to check bills.
Unexpectation: Found account closed.
Appeal: Respect the decision, and just want to ask what would you deal with the affiliate earning associated? though I can't view affiliates.php pages at the moment.
This is another bug. It's not a major bug, it's a bug with price reduction handling. It makes sure it gets the important part done correctly which is actually updating the price on the service that you order, but pays less attention to updating the displayed price. This isn't a big deal as long as prices are dropping, but if prices are going up it can be problematic.
Are you experiencing that bug now? OFFER #148 $63.81 on BF page VPS-BF-ORDER-1 $70.19 USD Annually on Cart
Same delay for pricing update on frontend, this time it actually went up in price due to high quantity of orders.
Located what's causing the delay. Making an "improvement" (we'll see if it's an improvement or makes it worse I guess.)
Did it make it worse?
Stop the suspense!
It definitely improved the delay. I don't know whether or not it actually properly does anything else anymore though. It keeps increasing the sale duration for plan #158 right now. It's a feature, not a bug. Because uhh... it's good to have a plan never end.
New slashing sound plays if price changes and it's lower than the previous price (if you have sounds on.) This includes both if the deal changes to a cheaper deal or if it's an existing deal that has the price drop but may later be changed to only be on same plan price drop.
Price changes seem to update much more quickly now, so we can consider that bug squashed.
Provisionings have been going more smoothly as orders died down. I'm going to be working on some non-sales related things but will be focusing on adding more nodes to the pool and possibly reworking parts of the plan generation formula to fine-tune them as I noticed a couple cases of it being sub-optimal.
With that said, we might bring back a crazier coupon later if we need to test the provisioning again to see if it gets jumbled up, but as I mentioned my full attention is required elsewhere so let's tone it down a bit for the time being.
"1 IPv4 DEDICATED IPv4" does this alter in any way? Just asking.
I think I answered you much more thoroughly earlier but maybe I just imagined it. Customization idea has been totally nixed though because of creation issues (see my comment about it a page or two ago.)
If we enable the system to allow multiple IP addresses, it'll likely be after the beta test. I need to organize IP consolidations to try to minimize any swapping afterward.
@VirMach said: see my comment about it a page or two ago
Oops, I missed that one, in all the FrankZy frenzy. Ta.
@tenpera said: @VirMach, now it's #165, when will it go back to #1?
It's not an odometer you can roll back, it just goes up to infinity.
What happens when the dealz number reaches Number.MAX_SAFE_INTEGER?
JavaScript will lose precision, Tokyo will become Bangkok, FrankZ & Wonder_Woman will be sucked into eno1 & eno2 and get married.
Another delayed bus:
On time bus:
took a quick yabs - feel free to recreate now!
Looks like it is stuck in "pending" mode.
Update - looks like it has provisioned with the correct amounts
@VirMach
What is the new coupon?
@VirMach
@FrankZ is back !
Virmach Deals
Thanks @FrankZ now I have another VPS to idle.
@VirMach thanks for the additional FrankZ latefee
@VirMach, what's the current coupon? I missed all of them, dang!
VirMach is typing ....
Stop the suspense!
@VirMach, reveal the coupon please..
What can I say other than "I tried".
A timeout occurred Error code 524
Visit cloudflare.com for more information.
2024-11-22 20:11:40
Noooooo
Code: 25SFKLSFOW for 25% off one-time.
@FrankZ is back?!?!
Amsterdam onfire ... The disk is game changer with price
Damn that 125GB SSD in Amsterdam would be nice with -95% code!
No hostname available. affbrr
