VirMach * 2024 * RYZEN * NVMe ** VPS Black Friday * Flash Deals ** Check inside for offers!
11718202223115
  • @beanman109 said:
    @VirMach said: Beta test coupon expired.
    There was a fucking coupon?
    Oh yeah! Go back a few pages and look for the Frank Z returns coupon....
  • Where is @FrankZ BTW?
    No
    edited November 2024
    Here's some coupon codes. They're all the same length as each other (this is probably the biggest clue.) There's a simple cipher used for encoding it so you have to decode it first but of course there's no clues on which cipher was applied, it's simple enough to where you'd be able to find it on some encoder/decoder. Most the codes don't work, but about 5% of them are real codes with 30-50% recurring discount (limit 1 each.) Actually I'm going to throw in one single 80% off recurring in there as well but that one expires on the 28th (tonight.) I don't know how difficult or easy this will be or if it's worth it, have fun. Actually, just in case it's too difficult, I've provided the same codes except with a different cipher you can compare against, that's the second paragraph. Oh and of course the codes will only work on one of the three flash specials (each.) They expire on the 30th.
    I figured everyone's going to figure out a way to programmatically do this anyway so I might as well make it harder than just a long list of coupons to try. If anyone asks for a coupon code refer them to this post.
    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
  • edited November 2024
    Is there a salt for decoding if it is not base64
    It's too difficult, boss. Even base64 and Rot13 don't work.
    @newlan said: Is there a salt for decoding if it is not base64
    Very very very basic cipher. Think the type a human could do on a piece of paper (if it wasn't this long.) You'll likely have to pick a few different ones to try, pick a few coupon lengths to chop it up, and test your luck. The coupons are spread out kind of evenly so you could focus on one chunk of it instead of the whole thing.
    Then once you're done, depending on the coupon lengths, it'd come out something like YgJy3yT4URU7
  • I'm too old for this. I want to sleep
    Thanked by (2)VirMach ariq01
  • And there's a code? That's a little difficult
  • @Virmach has been on the RedBull ? :open_mouth: :anguished:
    wtf is this i ain buying crypto
    Thanked by (4)criver VirMach sh97 ariq01
    Yes, I took the next hard step, splitting and trying. The last time I worked so hard was when I was studying calculus in college.
    Thanked by (2)criver localhost
    @VirMach is there a way to remove credit card on file for security purposes
    Your card isn't stored with us, the token for your card is stored with us, then API used with card processor. Contact us to remove it after you no longer have active services with us (or no recent payment with it on a service that's ongoing as a result of that payment.) We removed the ability to remove cards mostly as an antifraud measure.
    Otherwise people can add and remove a ton of cards, or move cards around multiple accounts without us being able to more easily catch that.
    If you've been a customer for a long time, don't have anything weird going on (as in you have a single card, not a bunch of declined payments or other issues like multiple accounts) we can generally make a policy exception and remove it. Keep in mind your card is still stored with the card processor, and they do not remove it as far as I know because that's not how card processing works, they need to keep it on file for things like refunds. Once again we don't store the card. There's no way for someone to get your card number even if our website is fully compromised. And if your account were to be hacked, we would obviously refund any payments the hacker made if you contact us and let us know. You can also disable auto payments. If there's other specific concerns let me know.
    I haven't figured out what to do with this one yet. I suppose it can just be a red herring for now.
    Thanked by (2)BHS FrankZ
  • 4RGvM1QNUsts4LICOKR4sy2k7D7/MH3BZXQMVAl1IGPb9WPTn+LJb8HBgKAxCC5pwoRUzIQYLBzurZbQOBCseoxICP99CSTZLed3e/5jQR6by/18BU9Xd9I/uef1YG1fwWvr5JBOctYq+esYcIMiObFZr+OYWjP8Fe6XL3dAmmTxDuuaWck0AyKFFtdNB3LQNzxDstWaY033M8vXxMuYgKvaN7944orZIBfNjyi9u/I8e41QbG306fxODTDrP8kly98yjwrCfiVa7WZOSCTJocLmdLRCXj6ItuHSe1UNHXfATcGB90QI9095MNfx+M24UhYG5K7eXdBMZUulNpWsQrS4Da7BIYBszt9DvK/wdOsLgKdwr3g0Sk+2nfzivQ44NIemBe3T8cV25nUWX/z1eI7shdunjITDtv+QPbqD/zMoXAOLbo248VgLULaqaEwufpZiUzIyGXmdjWmY2h9cgStwHoVIm+yvF4jyKdD7QVe5v3/TJgCA942CeZ/hngVBlQlrsvncc9xSMD2U12a1tlqZMpf1APvfEPBMHyg/J5iYhdy+MYmQ2uRw/7igCPiWkvn/2/QTfwuA1JFrzBUilqXPCnQU0keUn0IIKhQI65oXd/u9IIEJvJcO0gC+exjgEQj6BYWE7HY/llo9NBZl56hDlDHW2qUcVCsqnEsmgLACC/AWat6lm/5AqqhdFrkSyI3P83FqwG3yz0B24MfVC6BmqdpLV8S0eL5Ts8/ElomogShWeoR3Y3rTenU9P1Cu1Ul69+I2yaTmm9P5hwG7fcFzFy4rjq6+QogIZdA6jAKwU0vaxSWFv6CUoyuXPCELpWFbLoeqwMnucXlXORFbFvstGmNGRgN41pYpG4VmEe8LE8ZVPILJxEEXCL9NfueHbDesKv68IbMkEeXCtAKNW5JPiL7IJvkRQYy/grlQXSpXtYsbtpq7xi89AfFONbjjgn18R6i3OmaaU+ELBaQDoMgXSOabJaMgllBl3E11pHTf9c9eojMABtQbAlfWWf4BgJCxJEA0RlAGobTLHZlUuCENN5jOGCSuRalTDsXl06kgZmHlslmhQCBVl61lmFxU1QAlZGvaW1gNTJAr6BXk4rjCAnxagZwGkBCghc2eKkEqS2BebYwGyeWUzoqQLA46M6Ntdl1UZpri21p+B/upcQUhsLXtbSbdIQ1vC3DV4orOr5CNOdqjseO2vT3bpXUahBjDhKD6tUV9PoUbOPSmgwmdj1xeC2RKRBbkeWeeIPW0VkyGjjhl2iAFnXFvoyk4MvUjjST/YD4cHvekbnXa5/La9i9bCeqXbt5S9T/VQlUpvocUIx3qpTJuxSmTF6XZHTG7PsXGUffmsRgUeRRikN4As6GJw/eFYpw7SfO50v/5oJ4aCPtQTslJqll6w3QLzqN0fadIY6bqx8jHdQoMwlrDcmXrNHwaL2H62yRJ013KPZtEb4GUg0bE0BnT3EpS++FrdBZREHykuMhpqFAnvuk7U5aD5bfgD9eoaHGIuZnEo7wUBPQ45BSg16uFapNPKzWVurDda1badpQMbDmOSTAlf2jzxCAjouDrMOhy1n0tVPV7li2OUOx2Hz/MnaNn
    I use full 0 cipher and got this
    If anyone finds any of the other coupons let me know how you found it. I feel like the cipher ones may have been too difficult.
  • Guessing a riddle, right?
    One of them is an anagram from someone's username who posted on this thread for 60% off recurring. Capital letter on the beginning of any word(s) and if it's more than one word, no space. As I find other anagrams I may add more for varying discounts.
    ok cool, sounds fair. will not change anything.
    (except the cryptic discount codes)
  • Discount codes are your credit card number
    Thanked by (3)VirMach vyas yoursunny
  • SAVEMON30N65MP35HDCP1DAY20SFXLR.. my problem is that it's 1:40AM and my flash sale is about to expire, good night
    Thanked by (1)VirMach
  • Grab OFFER #507 for an incredible deal!
    Regularly $74.67, flash sale price only $82.14! B)
    MOARRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRR
    OFFER #507
    Regularly $74.67, flash sale price $89.60
    Seems like the @virmach 's program is obsessed with raising prices .
    Edit: Great that Virmach has removed the original price!
    Thanked by (1)localhost
  • **The promotion code entered has already been used
    ** As soon as it was refreshed it was used up, looks like people are enthusiastic
    OFFER #507
    i got this for $4.98, can offer to push for $30
    #                     v2024-06-09                    #
    Thu 28 Nov 2024 09:24:00 PM EST
    Uptime     : 1 days, 14 hours, 53 minutes
    Processor  : AMD Ryzen 9 3900X 12-Core Processor
    CPU cores  : 1 @ 3799.998 MHz
    RAM        : 464.5 MiB
    Swap       : 512.0 MiB
    Disk       : 14.2 GiB
    Kernel     : 6.11.10-amd64
    ISP        : Virtual Machine Solutions LLC
    ASN        : AS8100 QuadraNet Enterprises LLC
    Host       : Virtual Machine Solutions LLC
    Country    : United States
    Read       | 154.08 MB/s  (38.5k) | 119.01 MB/s   (1.8k)
    Write      | 154.49 MB/s  (38.6k) | 119.63 MB/s   (1.8k)
    Total      | 308.58 MB/s  (77.1k) | 238.65 MB/s   (3.7k)
    Read       | 560.00 MB/s   (1.0k) | 682.43 MB/s    (666)
    Write      | 589.75 MB/s   (1.1k) | 727.88 MB/s    (710)
    Total      | 1.14 GB/s     (2.2k) | 1.41 GB/s     (1.3k)
    Geekbench 4 Benchmark Test:
    Single Core     | 5130
    Multi Core      | 4987
    Full Test       | https://browser.geekbench.com/v4/cpu/18312999
    YABS completed in 3 min 36 sec
  • Why are flash sale prices higher than regular prices? :o
    Prices fluctuate based on demand. If you think an offer is good, it's better to buy it sooner. If you think it's bad, you can wait and price will drop if it's not in demand. The crossed out price doesn't mean it's being discounted from a normal price, it means that was the original price of the flash sale. The current price can be lower or higher.
    I'm making some modifications to make any increases less drastic as that was not the intention for it to increase so fast multiple times in a row.
  • FrankZFrankZ ModeratorOG
    I was sleeping. Back now.
    Taking requests for any specific deals.
    The flash sale system relies on a third party monitoring system to pull up to date node data, and it looks like their system's gone down, superb timing. I'm attempting to code out a workaround, but it likely won't be very good, so that means manual deals are back. I'll be adding in a mixed variance of previous popular deals as well as some requests.
    Thanked by (2)criver FrankZ
