SoftLayer Bare Metal compute cx2d $5.158/m
[root@aplikasia2 ~]# curl -sL yabs.sh | bash # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # # Yet-Another-Bench-Script # # v2024-06-09 # # https://github.com/masonr/yet-another-bench-script # # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # Tue Nov 5 01:51:07 UTC 2024 Basic System Information: --------------------------------- Uptime : 0 days, 8 hours, 22 minutes Processor : Intel(R) Xeon(R) Platinum 8260 CPU @ 2.40GHz CPU cores : 96 @ 3900.000 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ✔ Enabled RAM : 187.0 GiB Swap : 0.0 KiB Disk : 894.2 GiB Distro : Red Hat Enterprise Linux 8.10 (Ootpa) Kernel : 4.18.0-553.16.1.el8_10.x86_64 VM Type : NONE IPv4/IPv6 : ✔ Online / ❌ Offline IPv4 Network Information: --------------------------------- ISP : SoftLayer ASN : AS36351 SoftLayer Technologies Inc. Host : SoftLayer Technologies, Inc Location : Frankfurt am Main, Hesse (HE) Country : Germany fio Disk Speed Tests (Mixed R/W 50/50) (Partition /dev/sda3): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 106.53 MB/s (26.6k) | 265.60 MB/s (4.1k) Write | 106.81 MB/s (26.7k) | 267.00 MB/s (4.1k) Total | 213.34 MB/s (53.3k) | 532.60 MB/s (8.3k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 261.57 MB/s (510) | 266.20 MB/s (259) Write | 275.47 MB/s (538) | 283.93 MB/s (277) Total | 537.04 MB/s (1.0k) | 550.14 MB/s (536) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | Ping ----- | ----- | ---- | ---- | ---- Clouvider | London, UK (10G) | 8.76 Gbits/sec | 8.08 Gbits/sec | 12.2 ms Eranium | Amsterdam, NL (100G) | 16.1 Gbits/sec | 15.1 Gbits/sec | 6.91 ms Uztelecom | Tashkent, UZ (10G) | 2.29 Gbits/sec | 1.06 Gbits/sec | 92.6 ms Leaseweb | Singapore, SG (10G) | 781 Mbits/sec | 422 Mbits/sec | 210 ms Clouvider | Los Angeles, CA, US (10G) | 1.09 Gbits/sec | 626 Mbits/sec | 143 ms Leaseweb | NYC, NY, US (10G) | 2.20 Gbits/sec | 1.14 Gbits/sec | 82.8 ms Edgoo | Sao Paulo, BR (1G) | 848 Mbits/sec | 430 Mbits/sec | 205 ms Geekbench 6 Benchmark Test: --------------------------------- Test | Value | Single Core | 1494 Multi Core | 13968 Full Test | https://browser.geekbench.com/v6/cpu/8660415 YABS completed in 10 min 33 sec
TrackWith - Free Privacy Focused Analytics
AWS EC for 5/mo
# ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # # Yet-Another-Bench-Script # # v2024-06-09 # # https://github.com/masonr/yet-another-bench-script # # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # Tue Nov 5 03:16:32 UTC 2024 Basic System Information: --------------------------------- Uptime : 19 days, 8 hours, 26 minutes Processor : Intel(R) Xeon(R) Platinum 8259CL CPU @ 2.50GHz CPU cores : 2 @ 2499.998 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ❌ Disabled RAM : 447.8 MiB Swap : 0.0 KiB Disk : 19.6 GiB Distro : Debian GNU/Linux 12 (bookworm) Kernel : 6.1.0-26-cloud-amd64 VM Type : AMAZON IPv4/IPv6 : ✔ Online / ✔ Online IPv6 Network Information: --------------------------------- ISP : Amazon.com, Inc. ASN : AS16509 Amazon.com, Inc. Host : AWS EC2 (eu-central-1) Location : Frankfurt am Main, Hesse (HE) Country : Germany fio Disk Speed Tests (Mixed R/W 50/50) (Partition /dev/nvme0n1p1): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 6.19 MB/s (1.5k) | 66.04 MB/s (1.0k) Write | 6.19 MB/s (1.5k) | 66.40 MB/s (1.0k) Total | 12.38 MB/s (3.0k) | 132.44 MB/s (2.0k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 63.36 MB/s (123) | 62.83 MB/s (61) Write | 66.62 MB/s (130) | 67.45 MB/s (65) Total | 129.98 MB/s (253) | 130.28 MB/s (126) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | Ping ----- | ----- | ---- | ---- | ---- Clouvider | London, UK (10G) | 4.06 Gbits/sec | 2.33 Gbits/sec | 17.0 ms Eranium | Amsterdam, NL (100G) | 3.47 Gbits/sec | 4.40 Gbits/sec | 7.70 ms Uztelecom | Tashkent, UZ (10G) | 1.86 Gbits/sec | 543 Mbits/sec | 87.1 ms Leaseweb | Singapore, SG (10G) | 596 Mbits/sec | 426 Mbits/sec | 170 ms Clouvider | Los Angeles, CA, US (10G) | 876 Mbits/sec | 665 Mbits/sec | 143 ms Leaseweb | NYC, NY, US (10G) | 1.60 Gbits/sec | 741 Mbits/sec | 89.5 ms Edgoo | Sao Paulo, BR (1G) | 732 Mbits/sec | 450 Mbits/sec | 203 ms iperf3 Network Speed Tests (IPv6): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | Ping ----- | ----- | ---- | ---- | ---- Clouvider | London, UK (10G) | 2.43 Gbits/sec | 2.04 Gbits/sec | 17.0 ms Eranium | Amsterdam, NL (100G) | 4.30 Gbits/sec | 4.33 Gbits/sec | 7.61 ms Uztelecom | Tashkent, UZ (10G) | 1.56 Gbits/sec | 681 Mbits/sec | 87.1 ms Leaseweb | Singapore, SG (10G) | 909 Mbits/sec | 589 Mbits/sec | 169 ms Clouvider | Los Angeles, CA, US (10G) | 929 Mbits/sec | 504 Mbits/sec | 143 ms Leaseweb | NYC, NY, US (10G) | 1.42 Gbits/sec | 886 Mbits/sec | -- Edgoo | Sao Paulo, BR (1G) | 781 Mbits/sec | 446 Mbits/sec | 203 ms Geekbench test failed and low memory was detected. Add at least 1GB of SWAP or use GB4 instead (higher compatibility with low memory systems). YABS completed in 8 min 42 sec
KS-LE-B
# ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # # Yet-Another-Bench-Script # # v2024-06-09 # # https://github.com/masonr/yet-another-bench-script # # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # Tue Nov 5 13:53:59 UTC 2024 Basic System Information: --------------------------------- Uptime : 0 days, 0 hours, 3 minutes Processor : Intel(R) Xeon(R) CPU E3-1245 v6 @ 3.70GHz CPU cores : 8 @ 800.000 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ✔ Enabled RAM : 31.0 GiB Swap : 1024.0 MiB Disk : 410.9 GiB Distro : Debian GNU/Linux 12 (bookworm) Kernel : 6.1.0-26-amd64 VM Type : NONE IPv4/IPv6 : ✔ Online / ✔ Online IPv6 Network Information: --------------------------------- ISP : OVH SAS ASN : AS16276 OVH SAS Host : OVH GmbH Location : Saarbrücken, Saarland (SL) Country : Germany fio Disk Speed Tests (Mixed R/W 50/50) (Partition /dev/md3): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 397.79 MB/s (99.4k) | 470.24 MB/s (7.3k) Write | 398.84 MB/s (99.7k) | 472.71 MB/s (7.3k) Total | 796.63 MB/s (199.1k) | 942.96 MB/s (14.7k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 449.57 MB/s (878) | 467.10 MB/s (456) Write | 473.46 MB/s (924) | 498.21 MB/s (486) Total | 923.04 MB/s (1.8k) | 965.31 MB/s (942) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | Ping ----- | ----- | ---- | ---- | ---- Clouvider | London, UK (10G) | 295 Mbits/sec | 935 Mbits/sec | 17.4 ms Eranium | Amsterdam, NL (100G) | 297 Mbits/sec | 939 Mbits/sec | 9.03 ms Uztelecom | Tashkent, UZ (10G) | 275 Mbits/sec | 884 Mbits/sec | 98.9 ms Leaseweb | Singapore, SG (10G) | 241 Mbits/sec | 661 Mbits/sec | 210 ms Clouvider | Los Angeles, CA, US (10G) | 251 Mbits/sec | 799 Mbits/sec | 152 ms Leaseweb | NYC, NY, US (10G) | 268 Mbits/sec | 782 Mbits/sec | 84.9 ms Edgoo | Sao Paulo, BR (1G) | 249 Mbits/sec | 799 Mbits/sec | 194 ms iperf3 Network Speed Tests (IPv6): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | Ping ----- | ----- | ---- | ---- | ---- Clouvider | London, UK (10G) | 290 Mbits/sec | 923 Mbits/sec | 17.4 ms Eranium | Amsterdam, NL (100G) | 292 Mbits/sec | 926 Mbits/sec | 9.02 ms Uztelecom | Tashkent, UZ (10G) | 259 Mbits/sec | 765 Mbits/sec | 98.9 ms Leaseweb | Singapore, SG (10G) | 242 Mbits/sec | 710 Mbits/sec | 211 ms Clouvider | Los Angeles, CA, US (10G) | 204 Mbits/sec | 816 Mbits/sec | 152 ms Leaseweb | NYC, NY, US (10G) | 263 Mbits/sec | 792 Mbits/sec | 85.2 ms Edgoo | Sao Paulo, BR (1G) | 249 Mbits/sec | 766 Mbits/sec | 194 ms Running GB6 benchmark test... *cue elevator music* Geekbench 6 Benchmark Test: --------------------------------- Test | Value | Single Core | 1529 Multi Core | 5231 Full Test | https://browser.geekbench.com/v6/cpu/8668659 YABS completed in 12 min 37 sec
Free NAT KVM | Free NAT LXC | Bobr ITS WEDNESDAY MY DUDES
SoftLayer bx2a-8x32 balanced $319/m
# ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # # Yet-Another-Bench-Script # # v2024-06-09 # # https://github.com/masonr/yet-another-bench-script # # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # Thu Nov 7 02:55:30 UTC 2024 Basic System Information: --------------------------------- Uptime : 0 days, 3 hours, 14 minutes Processor : AMD EPYC-Rome Processor CPU cores : 8 @ 2445.406 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ✔ Enabled RAM : 31.4 GiB Swap : 0.0 KiB Disk : 193.7 GiB Distro : Ubuntu 24.04.1 LTS Kernel : 6.8.0-1011-ibm VM Type : KVM IPv4/IPv6 : ✔ Online / ❌ Offline IPv4 Network Information: --------------------------------- ISP : SoftLayer Technologies Inc. ASN : AS36351 SoftLayer Technologies Inc. Host : EDF NET05g Location : New York, New York (NY) Country : United States fio Disk Speed Tests (Mixed R/W 50/50) (Partition /dev/vda1): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 6.20 MB/s (1.5k) | 24.52 MB/s (383) Write | 6.19 MB/s (1.5k) | 25.03 MB/s (391) Total | 12.39 MB/s (3.0k) | 49.55 MB/s (774) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 23.64 MB/s (46) | 23.08 MB/s (22) Write | 24.93 MB/s (48) | 25.67 MB/s (25) Total | 48.58 MB/s (94) | 48.76 MB/s (47) Geekbench 6 Benchmark Test: --------------------------------- Test | Value | Single Core | 1604 Multi Core | 5588 Full Test | https://browser.geekbench.com/v6/cpu/8693485 YABS completed in 8 min 55 sec
Can't set IOPS higher than 3000 from console 😬
ServerFactory / Heartbeat IT free BGP VPS before it cancels tomorrow.
# ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # # Yet-Another-Bench-Script # # v2024-06-09 # # https://github.com/masonr/yet-another-bench-script # # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # Sun Nov 10 05:27:37 PM CET 2024 Basic System Information: --------------------------------- Uptime : 82 days, 9 hours, 53 minutes Processor : AMD EPYC 7452 32-Core Processor CPU cores : 1 @ 2349.998 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ✔ Enabled RAM : 1.9 GiB Swap : 0.0 KiB Disk : 49.1 GiB Distro : Debian GNU/Linux 12 (bookworm) Kernel : 6.1.0-22-amd64 VM Type : KVM IPv4/IPv6 : ✔ Online / ✔ Online IPv6 Network Information: --------------------------------- ISP : x ASN : xx Host : xxx Location : Eygelshoven, Limburg (LI) Country : Netherlands fio Disk Speed Tests (Mixed R/W 50/50) (Partition /dev/sda2): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 180.86 MB/s (45.2k) | 1.99 GB/s (31.1k) Write | 181.33 MB/s (45.3k) | 2.00 GB/s (31.3k) Total | 362.20 MB/s (90.5k) | 3.99 GB/s (62.4k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 7.40 GB/s (14.4k) | 6.20 GB/s (6.0k) Write | 7.79 GB/s (15.2k) | 6.61 GB/s (6.4k) Total | 15.19 GB/s (29.6k) | 12.82 GB/s (12.5k) Geekbench 5 Benchmark Test: --------------------------------- Test | Value | Single Core | 949 Multi Core | 940 Full Test | https://browser.geekbench.com/v5/cpu/23045727 YABS completed in 2 min 48 sec
The Ultimate Speedtest Script | Get Instant Alerts on new LES/LET deals | Cheap VPS Deals | VirMach Flash Sales Notifier FREE KVM VPS - FreeVPS.org | FREE LXC VPS - MicroLXC
KS-LE-B with a double memory.
# ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # # Yet-Another-Bench-Script # # v2024-06-09 # # https://github.com/masonr/yet-another-bench-script # # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # Tue Nov 12 12:01:46 UTC 2024 Basic System Information: --------------------------------- Uptime : 0 days, 0 hours, 3 minutes Processor : Intel(R) Xeon(R) CPU E3-1270 v6 @ 3.80GHz CPU cores : 8 @ 800.000 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ✔ Enabled RAM : 62.5 GiB Swap : 1024.0 MiB Disk : 410.9 GiB Distro : Debian GNU/Linux 12 (bookworm) Kernel : 6.1.0-26-amd64 VM Type : NONE IPv4/IPv6 : ✔ Online / ✔ Online IPv6 Network Information: --------------------------------- ISP : OVH SAS ASN : AS16276 OVH SAS Host : OVH Location : Gravelines, Hauts-de-France (HDF) Country : France fio Disk Speed Tests (Mixed R/W 50/50) (Partition /dev/md3): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 400.99 MB/s (100.2k) | 456.79 MB/s (7.1k) Write | 402.05 MB/s (100.5k) | 459.19 MB/s (7.1k) Total | 803.04 MB/s (200.7k) | 915.98 MB/s (14.3k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 445.46 MB/s (870) | 453.02 MB/s (442) Write | 469.12 MB/s (916) | 483.20 MB/s (471) Total | 914.58 MB/s (1.7k) | 936.22 MB/s (913) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | Ping ----- | ----- | ---- | ---- | ---- Clouvider | London, UK (10G) | 297 Mbits/sec | 940 Mbits/sec | 3.86 ms Eranium | Amsterdam, NL (100G) | 297 Mbits/sec | 940 Mbits/sec | 9.19 ms Uztelecom | Tashkent, UZ (10G) | 270 Mbits/sec | 889 Mbits/sec | 106 ms Leaseweb | Singapore, SG (10G) | 239 Mbits/sec | 610 Mbits/sec | 155 ms Clouvider | Los Angeles, CA, US (10G) | 264 Mbits/sec | 857 Mbits/sec | 137 ms Leaseweb | NYC, NY, US (10G) | 273 Mbits/sec | 835 Mbits/sec | 76.1 ms Edgoo | Sao Paulo, BR (1G) | 240 Mbits/sec | 784 Mbits/sec | 189 ms iperf3 Network Speed Tests (IPv6): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | Ping ----- | ----- | ---- | ---- | ---- Clouvider | London, UK (10G) | 293 Mbits/sec | busy | 3.80 ms Eranium | Amsterdam, NL (100G) | 292 Mbits/sec | 926 Mbits/sec | 9.17 ms Uztelecom | Tashkent, UZ (10G) | 249 Mbits/sec | 865 Mbits/sec | 106 ms Leaseweb | Singapore, SG (10G) | busy | busy | 155 ms Clouvider | Los Angeles, CA, US (10G) | 249 Mbits/sec | 817 Mbits/sec | 137 ms Leaseweb | NYC, NY, US (10G) | 254 Mbits/sec | 630 Mbits/sec | 75.9 ms Edgoo | Sao Paulo, BR (1G) | 246 Mbits/sec | 806 Mbits/sec | 189 ms Geekbench 6 Benchmark Test: --------------------------------- Test | Value | Single Core | 1565 Multi Core | 5321 Full Test | https://browser.geekbench.com/v6/cpu/8796796 YABS completed in 12 min 30 sec
@Chunkserve 4 vCore E5-2690v4 / 8 GB / 90 GB SSD Custom Plan
--------------------------------------------------------------------------- Basic System Info --------------------------------------------------------------------------- CPU Model : Intel(R) Xeon(R) CPU E5-2690 v4 @ 2.60GHz CPU Cores : 4 @ 2596.990 MHz CPU Cache : 16384 KB AES-NI : ✔ Enabled VM-x/AMD-V : ✔ Enabled Total Disk : 88.5 GB (2.2 GB Used) Total RAM : 7.8 GB (78.1 MB Used) System uptime : 0 days, 0 hour 29 min Load average : 0.11, 0.71, 0.71 OS : Debian GNU/Linux 11 Arch : x86_64 (64 Bit) Kernel : 5.10.0-23-amd64 Virtualization : KVM TCP Control : cubic --------------------------------------------------------------------------- Basic Network Info --------------------------------------------------------------------------- Primary Network : IPv4 IPv6 Access : ✔ Online IPv4 Access : ✔ Online ISP : Wojciech Czapkowicz ASN : AS214481 Wojciech Czapkowicz Host : Wojciech Czapkowicz Location : Warsaw, Mazovia-14, Poland Location (IPv4) : Amsterdam, North Holland, NL --------------------------------------------------------------------------- fio Disk Speed Tests (Mixed R/W 50/50) (Partition /dev/sda1): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 37.25 MB/s (9.3k) | 583.77 MB/s (9.1k) Write | 37.34 MB/s (9.3k) | 586.84 MB/s (9.1k) Total | 74.60 MB/s (18.6k) | 1.17 GB/s (18.2k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 1.21 GB/s (2.3k) | 1.15 GB/s (1.1k) Write | 1.27 GB/s (2.4k) | 1.23 GB/s (1.2k) Total | 2.49 GB/s (4.8k) | 2.38 GB/s (2.3k) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | Ping ----- | ----- | ---- | ---- | ---- Clouvider | London, UK (10G) | 1.98 Gbits/sec | 837 Mbits/sec | 6.78 ms Eranium | Amsterdam, NL (100G) | 2.01 Gbits/sec | 1.53 Gbits/sec | 0.521 ms Uztelecom | Tashkent, UZ (10G) | 315 Mbits/sec | 221 Mbits/sec | 89.4 ms Leaseweb | Singapore, SG (10G) | 272 Mbits/sec | 405 Mbits/sec | 156 ms Clouvider | Los Angeles, CA, US (10G) | 219 Mbits/sec | 72.6 Mbits/sec | 133 ms Leaseweb | NYC, NY, US (10G) | 355 Mbits/sec | 340 Mbits/sec | 75.1 ms Edgoo | Sao Paulo, BR (1G) | 441 Mbits/sec | 194 Mbits/sec | 196 ms iperf3 Network Speed Tests (IPv6): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | Ping ----- | ----- | ---- | ---- | ---- Clouvider | London, UK (10G) | 1.98 Gbits/sec | 765 Mbits/sec | 6.12 ms Eranium | Amsterdam, NL (100G) | 2.01 Gbits/sec | 1.48 Gbits/sec | 0.468 ms Uztelecom | Tashkent, UZ (10G) | 632 Mbits/sec | 180 Mbits/sec | 89.4 ms Leaseweb | Singapore, SG (10G) | 436 Mbits/sec | 365 Mbits/sec | 156 ms Clouvider | Los Angeles, CA, US (10G) | 258 Mbits/sec | 80.3 Mbits/sec | 133 ms Leaseweb | NYC, NY, US (10G) | 473 Mbits/sec | 500 Mbits/sec | 74.8 ms Edgoo | Sao Paulo, BR (1G) | 262 Mbits/sec | 120 Mbits/sec | 196 ms Geekbench 5 Benchmark Test: --------------------------------- Test | Value | Single Core | 806 Multi Core | 2976 Full Test | https://browser.geekbench.com/v5/cpu/23056182 Geekbench 6 Benchmark Test: --------------------------------- Test | Value | Single Core | 1021 Multi Core | 3258 Full Test | https://browser.geekbench.com/v6/cpu/8798280 ------------------------------------------------------------------------- Speedtest.net --------------------------------------------------------------------------- Location Latency Loss DL Speed UP Speed Server Dallas, US 115.91 ms 0.0% 478.45 Mbps 295.63 Mbps i3D.net - Dallas, TX Houston, TX 117.16 ms 0.0% 446.14 Mbps 189.72 Mbps Ezee Fiber - Houston, TX Chicago, IL 91.26 ms 0.0% 395.53 Mbps 322.33 Mbps Enzu.com - Chicago, IL Miami, US 105.77 ms N/A 467.94 Mbps 240.38 Mbps Dish Wireless - Miami, FL New York, NY 76.34 ms 0.0% 498.93 Mbps 320.79 Mbps Surfshark Ltd - New York, NY Miami, FL 106.20 ms 0.0% 447.20 Mbps 372.14 Mbps ReliableSite Hosting - Miami, FL Spokane, WA 152.05 ms 0.0% 459.34 Mbps 272.68 Mbps Crunchbits - Spokane, WA Seattle, WA 140.37 ms 0.0% 495.81 Mbps 158.44 Mbps Misaka Network, Inc. - Seattle, WA Los Angeles, US 134.23 ms 0.0% 388.35 Mbps 184.32 Mbps ReliableSite Hosting - Los Angeles, CA San Jose, CA 134.78 ms 0.0% 411.02 Mbps 208.92 Mbps Misaka Network, Inc. - San Jose, CA London, UK 6.21 ms 0.0% 1442.75 Mbps 1927.14 Mbps VeloxServ Communications - London Amsterdam, NL 0.90 ms 0.0% 1361.40 Mbps 2028.49 Mbps 31173 Services AB - Amsterdam Paris, FR 36.96 ms N/A 1509.68 Mbps 629.38 Mbps Axione - Paris Frankfurt, DE 7.35 ms 0.0% 635.19 Mbps 1893.64 Mbps Clouvider Ltd - Frankfurt am Main Warsaw, PL 22.04 ms 0.0% 1442.91 Mbps 866.80 Mbps Play - Warszawa Kyiv, UA 34.79 ms 0.0% 618.56 Mbps 897.15 Mbps O3 - Kyiv Bucharest, RO 35.74 ms 0.0% 588.34 Mbps 547.56 Mbps Vodafone Romania Fixed – Bucharest - Bucharest Bangalore, IN 147.66 ms 0.0% 1.42 Mbps 251.15 Mbps Bharti Airtel Ltd - Bangalore Chennai, IN 271.42 ms N/A 1.98 Mbps 90.32 Mbps Jio - Chennai Mumbai, IN 117.39 ms 0.0% 534.25 Mbps 291.56 Mbps i3D.net - Mumbai Mumbai, MH 136.40 ms N/A 531.50 Mbps 255.07 Mbps Jio - Rajkot Delhi, IN 142.22 ms 0.0% 489.03 Mbps 250.94 Mbps Tata Play Fiber - New Delhi Jeddah, SA 68.07 ms 0.0% 1379.97 Mbps 441.74 Mbps Saudi Telecom Company Dubai, AE 124.93 ms 0.0% 1389.62 Mbps 325.28 Mbps du - Dubai Hong Kong 283.63 ms N/A 558.34 Mbps 55.15 Mbps Misaka Network, Inc. - Hong Kong Sydney 326.48 ms 0.0% 428.89 Mbps 160.59 Mbps Telstra - Sydney Perth 275.03 ms 0.0% 472.94 Mbps 151.91 Mbps Aussie Broadband - Perth --------------------------------------------------------------------------- Avg DL Speed : 689.76 Mbps Avg UL Speed : 507.74 Mbps --------------------------------------------------------------------------- Speedtest by Ookla Server: RETN - London ISP: Wojciech Czapkowicz Idle Latency: 5.76 ms (jitter: 0.27ms, low: 5.65ms, high: 6.22ms) Download: 1492.87 Mbps (data used: 1.3 GB) 8.13 ms (jitter: 3.38ms, low: 5.70ms, high: 217.48ms) Upload: 1919.16 Mbps (data used: 1.3 GB) 5.76 ms (jitter: 0.37ms, low: 5.54ms, high: 8.90ms) Packet Loss: 0.0% Result URL: https://www.speedtest.net/result/c/fa5dd667-7806-4409-a1f0-caeb265d3ca1
1 vCPU / 1GB RAM / 10 GB SSD NVMe / 50Mbit/s France (Paris) $0.99/m
# ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # # Yet-Another-Bench-Script # # v2024-06-09 # # https://github.com/masonr/yet-another-bench-script # # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # Wed Nov 13 12:38:28 UTC 2024 Basic System Information: --------------------------------- Uptime : 1 days, 5 hours, 29 minutes Processor : Intel Core Processor (Broadwell, IBRS) CPU cores : 1 @ 2199.998 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ✔ Enabled RAM : 961.6 MiB Swap : 0.0 KiB Disk : 9.3 GiB Distro : Ubuntu 24.04 LTS Kernel : 6.8.0-41-generic VM Type : KVM IPv4/IPv6 : ✔ Online / ❌ Offline IPv4 Network Information: --------------------------------- ISP : CGI GLOBAL LIMITED ASN : AS56971 CGI GLOBAL LIMITED Host : CGI GLOBAL LIMITED Location : Paris, Île-de-France (IDF) Country : France fio Disk Speed Tests (Mixed R/W 50/50) (Partition /dev/vda1): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 40.02 MB/s (10.0k) | 656.92 MB/s (10.2k) Write | 40.12 MB/s (10.0k) | 660.38 MB/s (10.3k) Total | 80.14 MB/s (20.0k) | 1.31 GB/s (20.5k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 934.52 MB/s (1.8k) | 1.21 GB/s (1.1k) Write | 984.18 MB/s (1.9k) | 1.29 GB/s (1.2k) Total | 1.91 GB/s (3.7k) | 2.51 GB/s (2.4k) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | Ping ----- | ----- | ---- | ---- | ---- Clouvider | London, UK (10G) | 53.1 Mbits/sec | 52.9 Mbits/sec | 13.5 ms Eranium | Amsterdam, NL (100G) | 52.6 Mbits/sec | 52.8 Mbits/sec | 16.0 ms Uztelecom | Tashkent, UZ (10G) | 48.0 Mbits/sec | 50.4 Mbits/sec | 198 ms Leaseweb | Singapore, SG (10G) | 48.5 Mbits/sec | 50.4 Mbits/sec | 173 ms Clouvider | Los Angeles, CA, US (10G) | 49.7 Mbits/sec | 51.4 Mbits/sec | 138 ms Leaseweb | NYC, NY, US (10G) | 51.3 Mbits/sec | 52.1 Mbits/sec | 78.6 ms Edgoo | Sao Paulo, BR (1G) | 45.8 Mbits/sec | 50.3 Mbits/sec | 202 ms Geekbench test failed and low memory was detected. Add at least 1GB of SWAP or use GB4 instead (higher compatibility with low memory systems).
@host_c $7/year:
# ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # # Yet-Another-Bench-Script # # v2024-06-09 # # https://github.com/masonr/yet-another-bench-script # # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # Wed Nov 13 15:19:16 UTC 2024 Basic System Information: --------------------------------- Uptime : 0 days, 0 hours, 0 minutes Processor : Intel(R) Xeon(R) CPU E5-2687W v4 @ 3.00GHz CPU cores : 1 @ 2999.996 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ✔ Enabled RAM : 977.3 MiB Swap : 0.0 KiB Disk : 9.8 GiB Distro : Debian GNU/Linux 12 (bookworm) Kernel : 6.1.0-18-cloud-amd64 VM Type : KVM IPv4/IPv6 : ✔ Online / ✔ Online IPv6 Network Information: --------------------------------- ISP : Andrei Tiberiu Holt ASN : AS211462 Andrei Tiberiu Holt Host : Andrei Tiberiu Holt Location : Oradea, Bihor County (BH) Country : Romania fio Disk Speed Tests (Mixed R/W 50/50) (Partition /dev/sda1 (NVMe) ): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 63.02 MB/s (15.7k) | 367.72 MB/s (5.7k) Write | 63.13 MB/s (15.7k) | 369.66 MB/s (5.7k) Total | 126.15 MB/s (31.5k) | 737.39 MB/s (11.5k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 658.56 MB/s (1.2k) | 902.83 MB/s (881) Write | 693.56 MB/s (1.3k) | 962.96 MB/s (940) Total | 1.35 GB/s (2.6k) | 1.86 GB/s (1.8k) fio Disk Speed Tests (Mixed R/W 50/50) (Partition /dev/sdb (HDD, 1 TB)): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 21.47 MB/s (5.3k) | 107.09 MB/s (1.6k) Write | 21.49 MB/s (5.3k) | 107.65 MB/s (1.6k) Total | 42.97 MB/s (10.7k) | 214.75 MB/s (3.3k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 117.40 MB/s (229) | 117.78 MB/s (115) Write | 123.64 MB/s (241) | 125.63 MB/s (122) Total | 241.05 MB/s (470) | 243.41 MB/s (237) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | Ping ----- | ----- | ---- | ---- | ---- Clouvider | London, UK (10G) | 51.7 Mbits/sec | 49.5 Mbits/sec | 44.0 ms Leaseweb | Singapore, SG (10G) | 47.9 Mbits/sec | 47.6 Mbits/sec | 191 ms Leaseweb | NYC, NY, US (10G) | 50.3 Mbits/sec | 48.9 Mbits/sec | 96.1 ms iperf3 Network Speed Tests (IPv6): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | Ping ----- | ----- | ---- | ---- | ---- Clouvider | London, UK (10G) | 51.2 Mbits/sec | 49.0 Mbits/sec | 208 ms Leaseweb | Singapore, SG (10G) | 46.2 Mbits/sec | 46.2 Mbits/sec | 344 ms Leaseweb | NYC, NY, US (10G) | 49.6 Mbits/sec | 48.0 Mbits/sec | 132 ms Geekbench 4 Benchmark Test: --------------------------------- Test | Value | Single Core | 2729 Multi Core | 2584 Full Test | https://browser.geekbench.com/v4/cpu/18259799
cpu_logger | Recommended providers: Layer7, dataforest (Avoro/PHP-Friends), @host_c
KS-LE-B 2x450G NVMe 2x4T HDD
Drive Type Power On Hours SMART Test Errors Wearout nvme0n1 NVMe 50,381 0 2.00% nvme1n1 NVMe 50,381 0 2.00% sda HDD 50,434 0 sdb HDD 50,434 0
# ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # # Yet-Another-Bench-Script # # v2024-06-09 # # https://github.com/masonr/yet-another-bench-script # # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # Sat Nov 16 15:34:59 PST 2024 Basic System Information: --------------------------------- Uptime : 0 days, 1 hours, 42 minutes Processor : Intel(R) Xeon(R) CPU E3-1270 v6 @ 3.80GHz CPU cores : 8 @ 1498.379 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ✔ Enabled RAM : 31.0 GiB Swap : 8.0 GiB Disk : 7.6 TiB Distro : Debian GNU/Linux 12 (bookworm) Kernel : 6.1.0-27-amd64 VM Type : NONE IPv4/IPv6 : ✔ Online / ✔ Online IPv6 Network Information: --------------------------------- ISP : OVH SAS ASN : AS16276 OVH SAS Host : OVH Location : Gravelines, Hauts-de-France (HDF) Country : France fio Disk Speed Tests (Mixed R/W 50/50) (Partition /dev/md3): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 386.48 MB/s (96.6k) | 444.55 MB/s (6.9k) Write | 387.50 MB/s (96.8k) | 446.89 MB/s (6.9k) Total | 773.99 MB/s (193.4k) | 891.45 MB/s (13.9k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 453.36 MB/s (885) | 458.65 MB/s (447) Write | 477.45 MB/s (932) | 489.20 MB/s (477) Total | 930.82 MB/s (1.8k) | 947.86 MB/s (924) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | Ping ----- | ----- | ---- | ---- | ---- Clouvider | London, UK (10G) | 297 Mbits/sec | 941 Mbits/sec | 3.84 ms Eranium | Amsterdam, NL (100G) | 297 Mbits/sec | 937 Mbits/sec | 9.21 ms Uztelecom | Tashkent, UZ (10G) | 238 Mbits/sec | 883 Mbits/sec | 101 ms Leaseweb | Singapore, SG (10G) | busy | busy | 208 ms Clouvider | Los Angeles, CA, US (10G) | 257 Mbits/sec | 815 Mbits/sec | 139 ms Leaseweb | NYC, NY, US (10G) | 259 Mbits/sec | 823 Mbits/sec | 76.4 ms Edgoo | Sao Paulo, BR (1G) | 255 Mbits/sec | 806 Mbits/sec | 186 ms iperf3 Network Speed Tests (IPv6): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | Ping ----- | ----- | ---- | ---- | ---- Clouvider | London, UK (10G) | 293 Mbits/sec | 927 Mbits/sec | 3.85 ms Eranium | Amsterdam, NL (100G) | 292 Mbits/sec | 926 Mbits/sec | 9.18 ms Uztelecom | Tashkent, UZ (10G) | 271 Mbits/sec | 826 Mbits/sec | 101 ms Leaseweb | Singapore, SG (10G) | 243 Mbits/sec | busy | 208 ms Clouvider | Los Angeles, CA, US (10G) | 256 Mbits/sec | 843 Mbits/sec | 139 ms Leaseweb | NYC, NY, US (10G) | 279 Mbits/sec | 779 Mbits/sec | 76.4 ms Edgoo | Sao Paulo, BR (1G) | 247 Mbits/sec | 810 Mbits/sec | 186 ms Geekbench 6 Benchmark Test: --------------------------------- Test | Value | Single Core | 1543 Multi Core | 5290 Full Test | https://browser.geekbench.com/v6/cpu/8864131 YABS completed in 12 min 15 sec
HDD
fio Disk Speed Tests (Mixed R/W 50/50) (Partition /dev/md4): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 1.89 MB/s (472) | 27.30 MB/s (426) Write | 1.91 MB/s (478) | 27.70 MB/s (432) Total | 3.80 MB/s (950) | 55.01 MB/s (858) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 87.81 MB/s (171) | 92.72 MB/s (90) Write | 92.48 MB/s (180) | 98.90 MB/s (96) Total | 180.29 MB/s (351) | 191.62 MB/s (186)
@jcolideles said: KS-LE-B 2x450G NVMe 2x4T HDD
Wow congrats ! Never cancel this without transferring it Have fun
Layer7 Networks 2023BF flash sale on OGF LXC / 2vCPU / 4GB RAM / 40GB NVMe / 20TB BW / Paris, FR / 14 EUR annually
# ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # # Yet-Another-Bench-Script # # v2024-06-09 # # https://github.com/masonr/yet-another-bench-script # # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # Mon Nov 18 13:20:44 JST 2024 Basic System Information: --------------------------------- Uptime : 141 days, 15 hours, 41 minutes Processor : Intel(R) Xeon(R) Gold 6230 CPU @ 2.10GHz CPU cores : 2 @ 2432.874 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ✔ Enabled RAM : 4.0 GiB Swap : 512.0 MiB Disk : Distro : Debian GNU/Linux 12 (bookworm) Kernel : 6.8.8-2-pve VM Type : LXC IPv4/IPv6 : ✔ Online / ✔ Online IPv6 Network Information: --------------------------------- ISP : FBW NETWORKS SAS ASN : AS49434 FBW NETWORKS SAS Host : Layer7 Networks GmbH Location : Paris, Île-de-France (IDF) Country : France fio Disk Speed Tests (Mixed R/W 50/50) (Partition /dev/loop7): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 219.37 MB/s (54.8k) | 772.11 MB/s (12.0k) Write | 219.95 MB/s (54.9k) | 776.17 MB/s (12.1k) Total | 439.33 MB/s (109.8k) | 1.54 GB/s (24.1k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 404.61 MB/s (790) | 436.09 MB/s (425) Write | 426.10 MB/s (832) | 465.13 MB/s (454) Total | 830.71 MB/s (1.6k) | 901.22 MB/s (879) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | Ping ----- | ----- | ---- | ---- | ---- Clouvider | London, UK (10G) | busy | busy | 11.3 ms Eranium | Amsterdam, NL (100G) | 518 Mbits/sec | 490 Mbits/sec | 13.4 ms Uztelecom | Tashkent, UZ (10G) | 191 Mbits/sec | 427 Mbits/sec | 88.7 ms Leaseweb | Singapore, SG (10G) | 96.3 Mbits/sec | 413 Mbits/sec | 165 ms Clouvider | Los Angeles, CA, US (10G) | 146 Mbits/sec | 195 Mbits/sec | 136 ms Leaseweb | NYC, NY, US (10G) | 289 Mbits/sec | 473 Mbits/sec | 76.5 ms Edgoo | Sao Paulo, BR (1G) | 148 Mbits/sec | 416 Mbits/sec | 201 ms iperf3 Network Speed Tests (IPv6): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | Ping ----- | ----- | ---- | ---- | ---- Clouvider | London, UK (10G) | busy | 479 Mbits/sec | 11.3 ms Eranium | Amsterdam, NL (100G) | 518 Mbits/sec | 485 Mbits/sec | 13.4 ms Uztelecom | Tashkent, UZ (10G) | 271 Mbits/sec | 448 Mbits/sec | 88.7 ms Leaseweb | Singapore, SG (10G) | 203 Mbits/sec | 407 Mbits/sec | 165 ms Clouvider | Los Angeles, CA, US (10G) | 115 Mbits/sec | 437 Mbits/sec | 136 ms Leaseweb | NYC, NY, US (10G) | 296 Mbits/sec | 467 Mbits/sec | 76.6 ms Edgoo | Sao Paulo, BR (1G) | 176 Mbits/sec | 419 Mbits/sec | 201 ms Geekbench 6 Benchmark Test: --------------------------------- Test | Value | Single Core | 817 Multi Core | 1452 Full Test | https://browser.geekbench.com/v6/cpu/8911813 YABS completed in 17 min 37 sec
Virtono 2023BF flash sale on OGF KVM / 1 CPU / 2GB RAM / 23GB SSD / 1TB BW / Sydney, AU / 23 EUR annually
# ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # # Yet-Another-Bench-Script # # v2024-06-09 # # https://github.com/masonr/yet-another-bench-script # # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # Mon Nov 18 14:00:12 JST 2024 Basic System Information: --------------------------------- Uptime : 7 days, 13 hours, 23 minutes Processor : Intel(R) Xeon(R) Gold 5218 CPU @ 2.30GHz CPU cores : 1 @ 2300.000 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ✔ Enabled RAM : 1.9 GiB Swap : 2.0 GiB Disk : Distro : Debian GNU/Linux 12 (bookworm) Kernel : 6.1.0-27-amd64 VM Type : KVM IPv4/IPv6 : ✔ Online / ✔ Online IPv6 Network Information: --------------------------------- ISP : M247 Europe SRL ASN : AS9009 M247 Europe SRL Location : Sydney, New South Wales (NSW) Country : Australia fio Disk Speed Tests (Mixed R/W 50/50) (Partition /dev/vda1): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 100.33 MB/s (25.0k) | 362.88 MB/s (5.6k) Write | 100.59 MB/s (25.1k) | 364.79 MB/s (5.6k) Total | 200.93 MB/s (50.2k) | 727.67 MB/s (11.3k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 346.66 MB/s (677) | 341.90 MB/s (333) Write | 365.08 MB/s (713) | 364.67 MB/s (356) Total | 711.74 MB/s (1.3k) | 706.58 MB/s (689) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | Ping ----- | ----- | ---- | ---- | ---- Clouvider | London, UK (10G) | busy | 230 Mbits/sec | 383 ms Eranium | Amsterdam, NL (100G) | 260 Mbits/sec | 505 Mbits/sec | 259 ms Uztelecom | Tashkent, UZ (10G) | 266 Mbits/sec | busy | 274 ms Leaseweb | Singapore, SG (10G) | 520 Mbits/sec | 849 Mbits/sec | 448 ms Clouvider | Los Angeles, CA, US (10G) | 351 Mbits/sec | 150 Mbits/sec | 159 ms Leaseweb | NYC, NY, US (10G) | 305 Mbits/sec | 672 Mbits/sec | 407 ms Edgoo | Sao Paulo, BR (1G) | busy | 127 Mbits/sec | 378 ms iperf3 Network Speed Tests (IPv6): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | Ping ----- | ----- | ---- | ---- | ---- Clouvider | London, UK (10G) | 243 Mbits/sec | 217 Mbits/sec | 263 ms Eranium | Amsterdam, NL (100G) | 284 Mbits/sec | 522 Mbits/sec | 259 ms Uztelecom | Tashkent, UZ (10G) | 288 Mbits/sec | 283 Mbits/sec | 274 ms Leaseweb | Singapore, SG (10G) | 272 Mbits/sec | 496 Mbits/sec | 250 ms Clouvider | Los Angeles, CA, US (10G) | 405 Mbits/sec | 364 Mbits/sec | 159 ms Leaseweb | NYC, NY, US (10G) | busy | 408 Mbits/sec | 275 ms Edgoo | Sao Paulo, BR (1G) | busy | 198 Mbits/sec | 378 ms Geekbench 6 Benchmark Test: --------------------------------- Test | Value | Single Core | 974 Multi Core | 971 Full Test | https://browser.geekbench.com/v6/cpu/8912540 YABS completed in 22 min 15 sec
HostDare SSD1 https://lowendspirit.com/discussion/8550/hostdare-s-11-11-deals-are-here-don-t-miss-these-unbeatable-discounts KVM / 1 vCPU / 2GB RAM / 25GB NVMe / 2000GB BW @ 500Mbps / Los Angels, CA, US / 14 USD annually (RAM and BW are already doubled)
# ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # # Yet-Another-Bench-Script # # v2024-06-09 # # https://github.com/masonr/yet-another-bench-script # # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # Mon Nov 18 16:58:10 JST 2024 Basic System Information: --------------------------------- Uptime : 0 days, 0 hours, 0 minutes Processor : Intel Core Processor (Broadwell, IBRS) CPU cores : 1 @ 2593.992 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ✔ Enabled RAM : 1.9 GiB Swap : 1023.0 MiB Disk : Distro : Debian GNU/Linux 12 (bookworm) Kernel : 6.1.0-27-amd64 VM Type : KVM IPv4/IPv6 : ✔ Online / ✔ Online IPv6 Network Information: --------------------------------- ISP : QuadraNet Enterprises LLC ASN : AS8100 QuadraNet Enterprises LLC Host : QuadraNet Location : Los Angeles, California (CA) Country : United States fio Disk Speed Tests (Mixed R/W 50/50) (Partition /dev/vda1): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 196.23 MB/s (49.0k) | 1.31 GB/s (20.4k) Write | 196.75 MB/s (49.1k) | 1.31 GB/s (20.5k) Total | 392.98 MB/s (98.2k) | 2.62 GB/s (41.0k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 1.43 GB/s (2.8k) | 1.47 GB/s (1.4k) Write | 1.51 GB/s (2.9k) | 1.56 GB/s (1.5k) Total | 2.95 GB/s (5.7k) | 3.03 GB/s (2.9k) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | Ping ----- | ----- | ---- | ---- | ---- Clouvider | London, UK (10G) | 306 Mbits/sec | 149 Mbits/sec | 136 ms Eranium | Amsterdam, NL (100G) | 203 Mbits/sec | 349 Mbits/sec | 146 ms Uztelecom | Tashkent, UZ (10G) | 190 Mbits/sec | 119 Mbits/sec | 222 ms Leaseweb | Singapore, SG (10G) | 220 Mbits/sec | 260 Mbits/sec | 171 ms Clouvider | Los Angeles, CA, US (10G) | 471 Mbits/sec | 401 Mbits/sec | 77.3 ms Leaseweb | NYC, NY, US (10G) | 238 Mbits/sec | 219 Mbits/sec | 69.0 ms Edgoo | Sao Paulo, BR (1G) | 141 Mbits/sec | 93.8 Mbits/sec | 313 ms iperf3 Network Speed Tests (IPv6): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | Ping ----- | ----- | ---- | ---- | ---- Clouvider | London, UK (10G) | 207 Mbits/sec | busy | 130 ms Eranium | Amsterdam, NL (100G) | 176 Mbits/sec | 313 Mbits/sec | 146 ms Uztelecom | Tashkent, UZ (10G) | 131 Mbits/sec | 188 Mbits/sec | 223 ms Leaseweb | Singapore, SG (10G) | 241 Mbits/sec | 179 Mbits/sec | 171 ms Clouvider | Los Angeles, CA, US (10G) | 495 Mbits/sec | 407 Mbits/sec | 0.361 ms Leaseweb | NYC, NY, US (10G) | 256 Mbits/sec | busy | 68.9 ms Edgoo | Sao Paulo, BR (1G) | 239 Mbits/sec | 127 Mbits/sec | 170 ms Geekbench 6 Benchmark Test: --------------------------------- Test | Value | Single Core | 954 Multi Core | 978 Full Test | https://browser.geekbench.com/v6/cpu/8915713 YABS completed in 18 min 19 sec
Chunkserve KVM / 1 vCPU / 2GB RAM / 50GB NVMe / 5TB BW / Amsterdam, NL / 9.99 USD annually
# ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # # Yet-Another-Bench-Script # # v2024-06-09 # # https://github.com/masonr/yet-another-bench-script # # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # Mon Nov 18 18:06:12 JST 2024 Basic System Information: --------------------------------- Uptime : 6 days, 18 hours, 30 minutes Processor : Intel(R) Xeon(R) CPU E5-2690 v4 @ 2.60GHz CPU cores : 1 @ 2596.990 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ✔ Enabled RAM : 1.9 GiB Swap : 1024.0 MiB Disk : Distro : Debian GNU/Linux 12 (bookworm) Kernel : 6.1.0-27-amd64 VM Type : KVM IPv4/IPv6 : ✔ Online / ✔ Online IPv6 Network Information: --------------------------------- ISP : Wojciech Czapkowicz ASN : AS214481 Wojciech Czapkowicz Host : Wojciech Czapkowicz Location : Warsaw, Mazovia (14) Country : Poland fio Disk Speed Tests (Mixed R/W 50/50) (Partition /dev/vda1): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 282.14 MB/s (70.5k) | 2.46 GB/s (38.4k) Write | 282.89 MB/s (70.7k) | 2.47 GB/s (38.6k) Total | 565.04 MB/s (141.2k) | 4.93 GB/s (77.1k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 2.47 GB/s (4.8k) | 1.67 GB/s (1.6k) Write | 2.60 GB/s (5.0k) | 1.78 GB/s (1.7k) Total | 5.08 GB/s (9.9k) | 3.46 GB/s (3.3k) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | Ping ----- | ----- | ---- | ---- | ---- Clouvider | London, UK (10G) | 1.99 Gbits/sec | 1.06 Gbits/sec | 6.24 ms Eranium | Amsterdam, NL (100G) | 2.03 Gbits/sec | 1.59 Gbits/sec | 1.36 ms Uztelecom | Tashkent, UZ (10G) | 461 Mbits/sec | 265 Mbits/sec | 93.0 ms Leaseweb | Singapore, SG (10G) | 236 Mbits/sec | 381 Mbits/sec | 157 ms Clouvider | Los Angeles, CA, US (10G) | 259 Mbits/sec | 90.5 Mbits/sec | 133 ms Leaseweb | NYC, NY, US (10G) | 329 Mbits/sec | 741 Mbits/sec | 74.8 ms Edgoo | Sao Paulo, BR (1G) | 333 Mbits/sec | 250 Mbits/sec | 195 ms iperf3 Network Speed Tests (IPv6): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | Ping ----- | ----- | ---- | ---- | ---- Clouvider | London, UK (10G) | 2.00 Gbits/sec | 1.05 Gbits/sec | 6.28 ms Eranium | Amsterdam, NL (100G) | 2.02 Gbits/sec | 1.58 Gbits/sec | 0.842 ms Uztelecom | Tashkent, UZ (10G) | 536 Mbits/sec | 300 Mbits/sec | 92.9 ms Leaseweb | Singapore, SG (10G) | 369 Mbits/sec | 527 Mbits/sec | 157 ms Clouvider | Los Angeles, CA, US (10G) | 329 Mbits/sec | 99.8 Mbits/sec | 133 ms Leaseweb | NYC, NY, US (10G) | 503 Mbits/sec | 557 Mbits/sec | 74.9 ms Edgoo | Sao Paulo, BR (1G) | 346 Mbits/sec | 205 Mbits/sec | 195 ms Geekbench 6 Benchmark Test: --------------------------------- Test | Value | Single Core | 1010 Multi Core | 997 Full Test | https://browser.geekbench.com/v6/cpu/8916969 YABS completed in 17 min 47 sec
VirMach KVM / 2 vCPU / 2.5GB RAM / 50GB NVMe / 6TB BW / Tokyo, JP / 21.85 USD annually
# ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # # Yet-Another-Bench-Script # # v2024-06-09 # # https://github.com/masonr/yet-another-bench-script # # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # Wed Nov 20 00:39:31 JST 2024 Basic System Information: --------------------------------- Uptime : 5 days, 10 hours, 3 minutes Processor : AMD Ryzen 9 5900X 12-Core Processor CPU cores : 2 @ 3693.062 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ✔ Enabled RAM : 2.4 GiB Swap : 256.0 MiB Disk : Distro : Debian GNU/Linux 12 (bookworm) Kernel : 6.1.0-27-amd64 VM Type : KVM IPv4/IPv6 : ✔ Online / ❌ Offline IPv4 Network Information: --------------------------------- ISP : VIRMACH ASN : AS3258 xTom Japan Co., Ltd. Host : Virtual Machine Solutions LLC Location : Tokyo, Tokyo (13) Country : Japan fio Disk Speed Tests (Mixed R/W 50/50) (Partition /dev/vda1): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 275.54 MB/s (68.8k) | 1.68 GB/s (26.3k) Write | 276.26 MB/s (69.0k) | 1.69 GB/s (26.4k) Total | 551.80 MB/s (137.9k) | 3.37 GB/s (52.8k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 2.39 GB/s (4.6k) | 2.78 GB/s (2.7k) Write | 2.52 GB/s (4.9k) | 2.97 GB/s (2.9k) Total | 4.92 GB/s (9.6k) | 5.76 GB/s (5.6k) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | Ping ----- | ----- | ---- | ---- | ---- Clouvider | London, UK (10G) | 501 Mbits/sec | 288 Mbits/sec | 275 ms Eranium | Amsterdam, NL (100G) | 558 Mbits/sec | 518 Mbits/sec | 266 ms Uztelecom | Tashkent, UZ (10G) | busy | 125 Mbits/sec | 364 ms Leaseweb | Singapore, SG (10G) | 863 Mbits/sec | 561 Mbits/sec | 80.9 ms Clouvider | Los Angeles, CA, US (10G) | 858 Mbits/sec | 420 Mbits/sec | 104 ms Leaseweb | NYC, NY, US (10G) | 807 Mbits/sec | 405 Mbits/sec | 146 ms Edgoo | Sao Paulo, BR (1G) | 251 Mbits/sec | 177 Mbits/sec | 301 ms Geekbench 6 Benchmark Test: --------------------------------- Test | Value | Single Core | 1977 Multi Core | 3520 Full Test | https://browser.geekbench.com/v6/cpu/8946983 YABS completed in 10 min 42 sec
@SurferCloud said: SurferCloud Wed Aug 21 02:20:01 PDT 2024 Basic System Information: Uptime : 0 days, 2 hours, 29 minutes Processor : Intel Xeon Processor (Cascadelake) CPU cores : 4 @ 2992.968 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ❌ Disabled RAM : 7.6 GiB Swap : 0.0 KiB Disk : 120.0 GiB Distro : CentOS Linux 7 (Core) Kernel : 4.19.188-10.el7.ucloud.x86_64 VM Type : KVM IPv4/IPv6 : ✔ Online / ❌ Offline IPv4 Network Information: ISP : Scloud Pte Ltd ASN : AS142002 Scloud Pte Ltd Host : Scloud Pte Ltd Location : Los Angeles, California (CA) Country : United States fio Disk Speed Tests (Mixed R/W 50/50) (Partition /dev/vda1): Block Size 4k (IOPS) 64k (IOPS) Read 102.06 MB/s (25.5k) 214.24 MB/s (3.3k) Write 102.33 MB/s (25.5k) 215.36 MB/s (3.3k) Total 204.39 MB/s (51.0k) 429.61 MB/s (6.7k) Block Size 512k (IOPS) 1m (IOPS) ------ --- ---- ---- ---- Read 206.10 MB/s (402) 204.12 MB/s (199) Write 217.05 MB/s (423) 217.71 MB/s (212) Total 423.15 MB/s (825) 421.83 MB/s (411) iperf3 Network Speed Tests (IPv4): Provider Location (Link) Send Speed Recv Speed Ping Clouvider London, UK (10G) 30.9 Mbits/sec 50.4 Mbits/sec 137 ms Eranium Amsterdam, NL (100G) 31.1 Mbits/sec 49.5 Mbits/sec 142 ms Uztelecom Tashkent, UZ (10G) 29.9 Mbits/sec 48.4 Mbits/sec 235 ms Leaseweb Singapore, SG (10G) 30.2 Mbits/sec 49.5 Mbits/sec 186 ms Clouvider Los Angeles, CA, US (10G) 31.9 Mbits/sec 52.1 Mbits/sec 1.84 ms Leaseweb NYC, NY, US (10G) 32.1 Mbits/sec 50.5 Mbits/sec 62.5 ms Edgoo Sao Paulo, BR (1G) 30.0 Mbits/sec 50.1 Mbits/sec 169 ms
No GB?
datalix's aff #1 fan
Datalix aff 2.45 € / mo, amazing server, 5TB bandwidth
root@ds0-de:~# curl -sL https://yabs.sh | bash # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # # Yet-Another-Bench-Script # # v2024-06-09 # # https://github.com/masonr/yet-another-bench-script # # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # Wed Nov 20 01:57:10 UTC 2024 Basic System Information: --------------------------------- Uptime : 0 days, 19 hours, 28 minutes Processor : AMD Ryzen 9 5950X 16-Core Processor CPU cores : 1 @ 3393.624 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ✔ Enabled RAM : 1.9 GiB Swap : 0.0 KiB Disk : 19.3 GiB Distro : Ubuntu 24.04.1 LTS Kernel : 6.8.0-31-generic VM Type : KVM IPv4/IPv6 : ✔ Online / ✔ Online IPv6 Network Information: --------------------------------- ISP : Florian Kolb ASN : AS58087 Florian Kolb Host : Datalix Location : Vaduz, Vaduz (11) Country : Liechtenstein fio Disk Speed Tests (Mixed R/W 50/50) (Partition /dev/sda1): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 128.97 MB/s (32.2k) | 261.09 MB/s (4.0k) Write | 129.31 MB/s (32.3k) | 262.47 MB/s (4.1k) Total | 258.28 MB/s (64.5k) | 523.56 MB/s (8.1k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 234.32 MB/s (457) | 247.56 MB/s (241) Write | 246.77 MB/s (481) | 264.05 MB/s (257) Total | 481.10 MB/s (938) | 511.62 MB/s (498) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | Ping ----- | ----- | ---- | ---- | ---- Clouvider | London, UK (10G) | 805 Mbits/sec | 777 Mbits/sec | 13.2 ms Eranium | Amsterdam, NL (100G) | 799 Mbits/sec | 777 Mbits/sec | 22.0 ms Uztelecom | Tashkent, UZ (10G) | 334 Mbits/sec | busy | 81.4 ms Leaseweb | Singapore, SG (10G) | 236 Mbits/sec | 691 Mbits/sec | 150 ms Clouvider | Los Angeles, CA, US (10G) | 294 Mbits/sec | 698 Mbits/sec | 145 ms Leaseweb | NYC, NY, US (10G) | 267 Mbits/sec | 663 Mbits/sec | 83.0 ms Edgoo | Sao Paulo, BR (1G) | 285 Mbits/sec | 676 Mbits/sec | 199 ms iperf3 Network Speed Tests (IPv6): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | Ping ----- | ----- | ---- | ---- | ---- Clouvider | London, UK (10G) | 814 Mbits/sec | busy | 11.6 ms Eranium | Amsterdam, NL (100G) | 794 Mbits/sec | 759 Mbits/sec | 22.0 ms Uztelecom | Tashkent, UZ (10G) | busy | busy | 75.1 ms Leaseweb | Singapore, SG (10G) | busy | busy | 150 ms Clouvider | Los Angeles, CA, US (10G) | busy | busy | 144 ms Leaseweb | NYC, NY, US (10G) | 284 Mbits/sec | 679 Mbits/sec | 83.0 ms Edgoo | Sao Paulo, BR (1G) | 288 Mbits/sec | 326 Mbits/sec | 199 ms Geekbench 6 Benchmark Test: --------------------------------- Test | Value | Single Core | 1215 Multi Core | 1210 Full Test | https://browser.geekbench.com/v6/cpu/8956032 YABS completed in 18 min 13 sec
Intel NUC i3 gen7
## ## ## ## ## ## ## ## ## ## ## # # Yet-Another-Bench-Script # # v2024-06-09 # # https://github.com/masonr/yet-another-bench-script # # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # Wed Nov 20 03:52:32 UTC 2024 Basic System Information: --------------------------------- Uptime : 0 days, 18 hours, 11 minutes Processor : Intel(R) Core(TM) i3-7100U CPU @ 2.40GHz CPU cores : 4 @ 1499.998 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ✔ Enabled RAM : 7.6 GiB Swap : 4.0 GiB Disk : 112.4 GiB Distro : Arch Linux Kernel : 6.6.61-0-lts VM Type : NONE IPv4/IPv6 : ✔ Online / ✔ Online fio Disk Speed Tests (Mixed R/W 50/50) (Partition /dev/sda3): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 74.64 MB/s (18.6k) | 75.79 MB/s (1.1k) Write | 74.84 MB/s (18.7k) | 76.19 MB/s (1.1k) Total | 149.48 MB/s (37.3k) | 151.98 MB/s (2.3k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 90.35 MB/s (176) | 96.08 MB/s (93) Write | 95.15 MB/s (185) | 102.48 MB/s (100) Total | 185.50 MB/s (361) | 198.56 MB/s (193) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | Ping ----- | ----- | ---- | ---- | ---- Clouvider | London, UK (10G) | 172 Mbits/sec | 85.9 Mbits/sec | 206 ms Eranium | Amsterdam, NL (100G) | busy | 290 Mbits/sec | 277 ms Uztelecom | Tashkent, UZ (10G) | 140 Mbits/sec | 31.6 Mbits/sec | 214 ms Leaseweb | Singapore, SG (10G) | 345 Mbits/sec | 281 Mbits/sec | 36.1 ms Clouvider | Los Angeles, CA, US (10G) | 289 Mbits/sec | 71.5 Mbits/sec | 223 ms Leaseweb | NYC, NY, US (10G) | 268 Mbits/sec | 265 Mbits/sec | 306 ms Edgoo | Sao Paulo, BR (1G) | busy | 41.2 Mbits/sec | 360 ms iperf3 Network Speed Tests (IPv6): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | Ping ----- | ----- | ---- | ---- | ---- Clouvider | London, UK (10G) | 297 Mbits/sec | 77.8 Mbits/sec | 193 ms Eranium | Amsterdam, NL (100G) | 279 Mbits/sec | 249 Mbits/sec | 279 ms Uztelecom | Tashkent, UZ (10G) | 295 Mbits/sec | 46.6 Mbits/sec | 214 ms Leaseweb | Singapore, SG (10G) | 339 Mbits/sec | 337 Mbits/sec | 35.4 ms Clouvider | Los Angeles, CA, US (10G) | 290 Mbits/sec | 29.7 Mbits/sec | 208 ms Leaseweb | NYC, NY, US (10G) | 258 Mbits/sec | 21.7 Mbits/sec | 294 ms Edgoo | Sao Paulo, BR (1G) | busy | 49.7 Mbits/sec | 360 ms Geekbench 6 Benchmark Test: --------------------------------- Test | Value | Single Core | 889 Multi Core | 1844 Full Test | https://browser.geekbench.com/v6/cpu/8957832 YABS completed in 21 min 43 sec
solidseovps NL
# ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # # Yet-Another-Bench-Script # # v2024-06-09 # # https://github.com/masonr/yet-another-bench-script # # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # Fri 22 Nov 2024 03:06:04 AM EST Basic System Information: --------------------------------- Uptime : 0 days, 0 hours, 5 minutes Processor : Intel(R) Xeon(R) CPU E5-2680 v4 @ 2.40GHz CPU cores : 2 @ 2394.652 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ❌ Disabled RAM : 976.2 MiB Swap : 1023.0 MiB Disk : 18.8 GiB Distro : Debian GNU/Linux 11 (bullseye) Kernel : 5.10.0-8-amd64 VM Type : KVM IPv4/IPv6 : ✔ Online / ❌ Offline IPv4 Network Information: --------------------------------- ISP : Solid Systems LLC ASN : AS399275 Solid Systems LLC Host : Solid Systems LLC Location : Amsterdam, North Holland (NH) Country : Netherlands fio Disk Speed Tests (Mixed R/W 50/50) (Partition /dev/vda1): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 108.08 MB/s (27.0k) | 619.93 MB/s (9.6k) Write | 108.36 MB/s (27.0k) | 623.19 MB/s (9.7k) Total | 216.44 MB/s (54.1k) | 1.24 GB/s (19.4k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 671.11 MB/s (1.3k) | 677.87 MB/s (661) Write | 706.77 MB/s (1.3k) | 723.02 MB/s (706) Total | 1.37 GB/s (2.6k) | 1.40 GB/s (1.3k) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | Ping ----- | ----- | ---- | ---- | ---- Clouvider | London, UK (10G) | 7.97 Gbits/sec | 7.99 Gbits/sec | 8.61 ms Eranium | Amsterdam, NL (100G) | 9.21 Gbits/sec | 8.30 Gbits/sec | 0.948 ms Uztelecom | Tashkent, UZ (10G) | 2.12 Gbits/sec | 1.86 Gbits/sec | 85.6 ms Leaseweb | Singapore, SG (10G) | 1.13 Gbits/sec | 1.11 Gbits/sec | 156 ms Clouvider | Los Angeles, CA, US (10G) | 967 Mbits/sec | 1.21 Gbits/sec | 146 ms Leaseweb | NYC, NY, US (10G) | 1.66 Gbits/sec | 1.22 Gbits/sec | 75.0 ms Edgoo | Sao Paulo, BR (1G) | 1.02 Gbits/sec | 799 Mbits/sec | 206 ms Geekbench 6 Benchmark Test: --------------------------------- Test | Value | Single Core | 768 Multi Core | 1029 Full Test | https://browser.geekbench.com/v6/cpu/9003276 YABS completed in 15 min 54 sec
0.50$/y Virmache
# ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # # Yet-Another-Bench-Script # # v2024-06-09 # # https://github.com/masonr/yet-another-bench-script # # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # Fri 22 Nov 2024 10:57:52 AM EST Basic System Information: --------------------------------- Uptime : 0 days, 0 hours, 2 minutes Processor : AMD Ryzen 9 3900X 12-Core Processor CPU cores : 2 @ 3799.996 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ✔ Enabled RAM : 1.8 GiB Swap : 512.0 MiB Disk : 229.3 GiB Distro : Debian GNU/Linux 11 (bullseye) Kernel : 5.10.0-8-amd64 VM Type : KVM IPv4/IPv6 : ✔ Online / ❌ Offline IPv4 Network Information: --------------------------------- ISP : RoyaleHosting BV ASN : AS212477 RoyaleHosting BV Host : Virtual Machine Solutions LLC Location : Secaucus, New Jersey (NJ) Country : United States fio Disk Speed Tests (Mixed R/W 50/50) (Partition /dev/vda1): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 301.00 MB/s (75.2k) | 188.28 MB/s (2.9k) Write | 301.79 MB/s (75.4k) | 189.27 MB/s (2.9k) Total | 602.80 MB/s (150.7k) | 377.55 MB/s (5.8k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 278.54 MB/s (544) | 282.27 MB/s (275) Write | 293.34 MB/s (572) | 301.07 MB/s (294) Total | 571.89 MB/s (1.1k) | 583.35 MB/s (569) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | Ping ----- | ----- | ---- | ---- | ---- Clouvider | London, UK (10G) | 889 Mbits/sec | 217 Mbits/sec | 67.7 ms Eranium | Amsterdam, NL (100G) | 892 Mbits/sec | 823 Mbits/sec | 72.5 ms Uztelecom | Tashkent, UZ (10G) | busy | 137 Mbits/sec | 223 ms Leaseweb | Singapore, SG (10G) | busy | 153 Mbits/sec | 233 ms Clouvider | Los Angeles, CA, US (10G) | 850 Mbits/sec | 295 Mbits/sec | 61.0 ms Leaseweb | NYC, NY, US (10G) | 935 Mbits/sec | busy | 1.49 ms Edgoo | Sao Paulo, BR (1G) | 837 Mbits/sec | 212 Mbits/sec | 124 ms Geekbench 6 Benchmark Test: --------------------------------- Test | Value | Single Core | 1464 Multi Core | 2609 Full Test | https://browser.geekbench.com/v6/cpu/9010519 YABS completed in 11 min 22 sec
took the gamble last month, working fine so far. $7/yr
# ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # # Yet-Another-Bench-Script # # v2024-06-09 # # https://github.com/masonr/yet-another-bench-script # # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # Sat Nov 23 08:26:36 UTC 2024 Basic System Information: --------------------------------- Uptime : 2 days, 23 hours, 51 minutes Processor : Intel(R) Xeon(R) CPU E5-2680 v4 @ 2.40GHz CPU cores : 1 @ 2399.996 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ✔ Enabled RAM : 1.9 GiB Swap : 0.0 KiB Disk : 38.7 GiB Distro : Ubuntu 22.04.5 LTS Kernel : 5.15.0-125-generic VM Type : KVM IPv4/IPv6 : ✔ Online / ❌ Offline IPv4 Network Information: --------------------------------- ISP : DC Host INC ASN : AS208287 DC Host INC Host : DC Host INC Location : Istanbul, Istanbul (34) Country : Türkiye fio Disk Speed Tests (Mixed R/W 50/50) (Partition /dev/vda1): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 110.10 MB/s (27.5k) | 1.09 GB/s (17.1k) Write | 110.39 MB/s (27.5k) | 1.10 GB/s (17.2k) Total | 220.50 MB/s (55.1k) | 2.19 GB/s (34.3k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 2.88 GB/s (5.6k) | 3.30 GB/s (3.2k) Write | 3.03 GB/s (5.9k) | 3.52 GB/s (3.4k) Total | 5.91 GB/s (11.5k) | 6.83 GB/s (6.6k) Geekbench 5 Benchmark Test: --------------------------------- Test | Value | Single Core | 486 Multi Core | 474 Full Test | https://browser.geekbench.com/v5/cpu/23088658 YABS completed in 4 min 45 sec
Alphavps Nuremberg 15.99eur
# ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # # Yet-Another-Bench-Script # # v2024-06-09 # # https://github.com/masonr/yet-another-bench-script # # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # Mon Nov 25 07:55:22 AM EST 2024 Basic System Information: --------------------------------- Uptime : 0 days, 0 hours, 13 minutes Processor : Intel(R) Xeon(R) CPU E5-2680 v4 @ 2.40GHz CPU cores : 2 @ 2397.222 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ✔ Enabled RAM : 1.9 GiB Swap : 1024.0 MiB Disk : 13.7 GiB Distro : Debian GNU/Linux 12 (bookworm) Kernel : 6.1.0-28-amd64 VM Type : KVM IPv4/IPv6 : ✔ Online / ✔ Online IPv6 Network Information: --------------------------------- ISP : DA International Group Ltd. ASN : AS203380 DA International Group Ltd. Host : AlphaVPS LLC Location : Nuremberg, Bavaria (BY) Country : Germany fio Disk Speed Tests (Mixed R/W 50/50) (Partition /dev/vda2): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 120.49 MB/s (30.1k) | 333.11 MB/s (5.2k) Write | 120.81 MB/s (30.2k) | 334.87 MB/s (5.2k) Total | 241.31 MB/s (60.3k) | 667.98 MB/s (10.4k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 719.83 MB/s (1.4k) | 1.01 GB/s (994) Write | 758.07 MB/s (1.4k) | 1.08 GB/s (1.0k) Total | 1.47 GB/s (2.8k) | 2.10 GB/s (2.0k) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | Ping ----- | ----- | ---- | ---- | ---- Clouvider | London, UK (10G) | 7.92 Gbits/sec | 4.58 Gbits/sec | 14.3 ms Eranium | Amsterdam, NL (100G) | 9.04 Gbits/sec | 6.44 Gbits/sec | 14.8 ms Uztelecom | Tashkent, UZ (10G) | 2.17 Gbits/sec | 1.62 Gbits/sec | 96.5 ms Leaseweb | Singapore, SG (10G) | 662 Mbits/sec | 810 Mbits/sec | 210 ms Clouvider | Los Angeles, CA, US (10G) | 1.07 Gbits/sec | 1.18 Gbits/sec | 144 ms Leaseweb | NYC, NY, US (10G) | busy | 2.20 Gbits/sec | 84.2 ms Edgoo | Sao Paulo, BR (1G) | 698 Mbits/sec | 819 Mbits/sec | 207 ms iperf3 Network Speed Tests (IPv6): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | Ping ----- | ----- | ---- | ---- | ---- Clouvider | London, UK (10G) | 8.01 Gbits/sec | 5.21 Gbits/sec | 14.2 ms Eranium | Amsterdam, NL (100G) | 8.52 Gbits/sec | 5.80 Gbits/sec | 14.6 ms Uztelecom | Tashkent, UZ (10G) | 1.64 Gbits/sec | 1.43 Gbits/sec | 96.9 ms Leaseweb | Singapore, SG (10G) | 640 Mbits/sec | 808 Mbits/sec | 210 ms Clouvider | Los Angeles, CA, US (10G) | 1.07 Gbits/sec | 209 Mbits/sec | 144 ms Leaseweb | NYC, NY, US (10G) | 1.94 Gbits/sec | 2.12 Gbits/sec | 84.4 ms Edgoo | Sao Paulo, BR (1G) | 677 Mbits/sec | 827 Mbits/sec | 207 ms Geekbench 6 Benchmark Test: --------------------------------- Test | Value | Single Core | 941 Multi Core | 1609 Full Test | https://browser.geekbench.com/v6/cpu/9063350 YABS completed in 16 min 52 sec
racknerd seattle free giveaway 1 year
# ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # # Yet-Another-Bench-Script # # v2024-06-09 # # https://github.com/masonr/yet-another-bench-script # # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # Wed Nov 27 07:56:38 AM UTC 2024 Basic System Information: --------------------------------- Uptime : 0 days, 0 hours, 11 minutes Processor : Intel(R) Xeon(R) CPU E5-2680 v2 @ 2.80GHz CPU cores : 1 @ 2799.962 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ❌ Disabled RAM : 961.6 MiB Swap : 1024.0 MiB Disk : 18.6 GiB Distro : Ubuntu 24.04.1 LTS Kernel : 6.8.0-49-generic VM Type : KVM IPv4/IPv6 : ✔ Online / ❌ Offline IPv4 Network Information: --------------------------------- ISP : HostPapa ASN : AS36352 HostPapa Host : RackNerd LLC Location : Seattle, Washington (WA) Country : United States fio Disk Speed Tests (Mixed R/W 50/50) (Partition /dev/vda2): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 58.49 MB/s (14.6k) | 878.47 MB/s (13.7k) Write | 58.60 MB/s (14.6k) | 883.09 MB/s (13.7k) Total | 117.10 MB/s (29.2k) | 1.76 GB/s (27.5k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 1.31 GB/s (2.5k) | 1.26 GB/s (1.2k) Write | 1.38 GB/s (2.7k) | 1.34 GB/s (1.3k) Total | 2.69 GB/s (5.2k) | 2.61 GB/s (2.5k) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | Ping ----- | ----- | ---- | ---- | ---- Clouvider | London, UK (10G) | busy | 398 Mbits/sec | 132 ms Eranium | Amsterdam, NL (100G) | 585 Mbits/sec | 629 Mbits/sec | 145 ms Uztelecom | Tashkent, UZ (10G) | 337 Mbits/sec | 242 Mbits/sec | 235 ms Leaseweb | Singapore, SG (10G) | 386 Mbits/sec | 550 Mbits/sec | 233 ms Clouvider | Los Angeles, CA, US (10G) | 859 Mbits/sec | 709 Mbits/sec | 30.9 ms Leaseweb | NYC, NY, US (10G) | 826 Mbits/sec | 669 Mbits/sec | 65.9 ms Edgoo | Sao Paulo, BR (1G) | 500 Mbits/sec | 174 Mbits/sec | 176 ms Geekbench 6 Benchmark Test: --------------------------------- Test | Value | Single Core | 388 Multi Core | 316 Full Test | https://browser.geekbench.com/v6/cpu/9096395
Virmach LAX 4.98/yr after one time 25% coupon
# ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # # Yet-Another-Bench-Script # # v2024-06-09 # # https://github.com/masonr/yet-another-bench-script # # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # Wed 27 Nov 2024 06:41:52 AM EST Basic System Information: --------------------------------- Uptime : 0 days, 0 hours, 11 minutes Processor : AMD Ryzen 9 3900X 12-Core Processor CPU cores : 1 @ 3799.998 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ✔ Enabled RAM : 464.5 MiB Swap : 512.0 MiB Disk : 14.2 GiB Distro : Debian GNU/Linux 11 (bullseye) Kernel : 6.11.10-amd64 VM Type : KVM IPv4/IPv6 : ✔ Online / ❌ Offline IPv4 Network Information: --------------------------------- ISP : Virtual Machine Solutions LLC ASN : AS8100 QuadraNet Enterprises LLC Host : Virtual Machine Solutions LLC Location : Crugers, New York (NY) Country : United States fio Disk Speed Tests (Mixed R/W 50/50) (Partition /dev/vda1): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 105.31 MB/s (26.3k) | 36.94 MB/s (577) Write | 105.59 MB/s (26.3k) | 37.23 MB/s (581) Total | 210.90 MB/s (52.7k) | 74.17 MB/s (1.1k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 41.73 MB/s (81) | 166.87 MB/s (162) Write | 43.88 MB/s (85) | 177.99 MB/s (173) Total | 85.61 MB/s (166) | 344.86 MB/s (335) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | Ping ----- | ----- | ---- | ---- | ---- Clouvider | London, UK (10G) | 827 Mbits/sec | 321 Mbits/sec | 137 ms Eranium | Amsterdam, NL (100G) | 830 Mbits/sec | 726 Mbits/sec | 144 ms Uztelecom | Tashkent, UZ (10G) | 489 Mbits/sec | 197 Mbits/sec | 248 ms Leaseweb | Singapore, SG (10G) | 675 Mbits/sec | 558 Mbits/sec | 182 ms Clouvider | Los Angeles, CA, US (10G) | 930 Mbits/sec | 933 Mbits/sec | 0.975 ms Leaseweb | NYC, NY, US (10G) | 883 Mbits/sec | 645 Mbits/sec | 64.9 ms Edgoo | Sao Paulo, BR (1G) | 755 Mbits/sec | 200 Mbits/sec | 161 ms Geekbench 4 Benchmark Test: --------------------------------- Test | Value | Single Core | 5140 Multi Core | 4998 Full Test | https://browser.geekbench.com/v4/cpu/18307724 YABS completed in 4 min 43 sec
@cybertech said: Virmach LAX 4.98/yr after one time 25% coupon
> # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # > # Yet-Another-Bench-Script # > # v2024-06-09 # > # https://github.com/masonr/yet-another-bench-script # > # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # > > Wed 27 Nov 2024 06:41:52 AM EST > > Basic System Information: > --------------------------------- > Uptime : 0 days, 0 hours, 11 minutes > Processor : AMD Ryzen 9 3900X 12-Core Processor > CPU cores : 1 @ 3799.998 MHz > AES-NI : ✔ Enabled > VM-x/AMD-V : ✔ Enabled > RAM : 464.5 MiB > Swap : 512.0 MiB > Disk : 14.2 GiB > Distro : Debian GNU/Linux 11 (bullseye) > Kernel : 6.11.10-amd64 > VM Type : KVM > IPv4/IPv6 : ✔ Online / ❌ Offline > > IPv4 Network Information: > --------------------------------- > ISP : Virtual Machine Solutions LLC > ASN : AS8100 QuadraNet Enterprises LLC > Host : Virtual Machine Solutions LLC > Location : Crugers, New York (NY) > Country : United States > > fio Disk Speed Tests (Mixed R/W 50/50) (Partition /dev/vda1): > --------------------------------- > Block Size | 4k (IOPS) | 64k (IOPS) > ------ | --- ---- | ---- ---- > Read | 105.31 MB/s (26.3k) | 36.94 MB/s (577) > Write | 105.59 MB/s (26.3k) | 37.23 MB/s (581) > Total | 210.90 MB/s (52.7k) | 74.17 MB/s (1.1k) > | | > Block Size | 512k (IOPS) | 1m (IOPS) > ------ | --- ---- | ---- ---- > Read | 41.73 MB/s (81) | 166.87 MB/s (162) > Write | 43.88 MB/s (85) | 177.99 MB/s (173) > Total | 85.61 MB/s (166) | 344.86 MB/s (335) > > iperf3 Network Speed Tests (IPv4): > --------------------------------- > Provider | Location (Link) | Send Speed | Recv Speed | Ping > ----- | ----- | ---- | ---- | ---- > Clouvider | London, UK (10G) | 827 Mbits/sec | 321 Mbits/sec | 137 ms > Eranium | Amsterdam, NL (100G) | 830 Mbits/sec | 726 Mbits/sec | 144 ms > Uztelecom | Tashkent, UZ (10G) | 489 Mbits/sec | 197 Mbits/sec | 248 ms > Leaseweb | Singapore, SG (10G) | 675 Mbits/sec | 558 Mbits/sec | 182 ms > Clouvider | Los Angeles, CA, US (10G) | 930 Mbits/sec | 933 Mbits/sec | 0.975 ms > Leaseweb | NYC, NY, US (10G) | 883 Mbits/sec | 645 Mbits/sec | 64.9 ms > Edgoo | Sao Paulo, BR (1G) | 755 Mbits/sec | 200 Mbits/sec | 161 ms > > Geekbench 4 Benchmark Test: > --------------------------------- > Test | Value > | > Single Core | 5140 > Multi Core | 4998 > Full Test | https://browser.geekbench.com/v4/cpu/18307724 > > YABS completed in 4 min 43 sec >
Run a geekbench 6 now 😅
not enough ram
@host_c 5 TB VPS after live migration (without downtime or reboot) to Intel Xeon Gold 6148, very consistent performance and basically no steal:
# ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # # Yet-Another-Bench-Script # # v2024-06-09 # # https://github.com/masonr/yet-another-bench-script # # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # Wed Nov 27 12:16:34 UTC 2024 Basic System Information: --------------------------------- Uptime : 0 days, 20 hours, 17 minutes Processor : Intel(R) Xeon(R) Gold 6148 CPU @ 2.40GHz CPU cores : 2 @ 2199.996 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ✔ Enabled RAM : 1.9 GiB Swap : 0.0 KiB Disk : 4.9 TiB Distro : Debian GNU/Linux 12 (bookworm) Kernel : 6.1.0-28-cloud-amd64 VM Type : KVM IPv4/IPv6 : ✔ Online / ✔ Online IPv6 Network Information: --------------------------------- ISP : Andrei Tiberiu Holt ASN : AS211462 Andrei Tiberiu Holt Host : Andrei Tiberiu Holt Location : Oradea, Bihor County (BH) Country : Romania fio Disk Speed Tests (Mixed R/W 50/50) (Partition /dev/sdb1 (NVMe)): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 176.87 MB/s (44.2k) | 860.05 MB/s (13.4k) Write | 177.34 MB/s (44.3k) | 864.57 MB/s (13.5k) Total | 354.21 MB/s (88.5k) | 1.72 GB/s (26.9k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 851.55 MB/s (1.6k) | 924.63 MB/s (902) Write | 896.80 MB/s (1.7k) | 986.21 MB/s (963) Total | 1.74 GB/s (3.4k) | 1.91 GB/s (1.8k) fio Disk Speed Tests (Mixed R/W 50/50) (Partition /dev/sda (HDD)): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 15.22 MB/s (3.8k) | 136.10 MB/s (2.1k) Write | 15.24 MB/s (3.8k) | 136.82 MB/s (2.1k) Total | 30.46 MB/s (7.6k) | 272.92 MB/s (4.2k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 132.13 MB/s (258) | 122.68 MB/s (119) Write | 139.15 MB/s (271) | 130.85 MB/s (127) Total | 271.28 MB/s (529) | 253.53 MB/s (246) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | Ping ----- | ----- | ---- | ---- | ---- Clouvider | London, UK (10G) | busy | 988 Mbits/sec | 35.0 ms Leaseweb | Singapore, SG (10G) | 233 Mbits/sec | 727 Mbits/sec | 242 ms Leaseweb | NYC, NY, US (10G) | 370 Mbits/sec | 940 Mbits/sec | 98.0 ms iperf3 Network Speed Tests (IPv6): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | Ping ----- | ----- | ---- | ---- | ---- Clouvider | London, UK (10G) | 650 Mbits/sec | 976 Mbits/sec | 35.0 ms Leaseweb | Singapore, SG (10G) | 231 Mbits/sec | 726 Mbits/sec | 242 ms Leaseweb | NYC, NY, US (10G) | 345 Mbits/sec | 926 Mbits/sec | 98.0 ms Geekbench 4 Benchmark Test: --------------------------------- Test | Value | Single Core | 2898 Multi Core | 5341 Full Test | https://browser.geekbench.com/v4/cpu/18307825 Geekbench 6 Benchmark Test: --------------------------------- Test | Value | Single Core | 775 Multi Core | 1374 Full Test | https://browser.geekbench.com/v6/cpu/9099664 YABS completed in 18 min 27 sec
ultravps storage AMS test done on HDD partition BHVE virtualization
# ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # # Yet-Another-Bench-Script # # v2024-06-09 # # https://github.com/masonr/yet-another-bench-script # # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # Fri Nov 29 02:23:00 AM UTC 2024 Basic System Information: --------------------------------- Uptime : 0 days, 0 hours, 9 minutes Processor : Intel(R) Xeon(R) CPU E5-2697 v3 @ 2.60GHz CPU cores : 1 @ 2599.974 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ❌ Disabled RAM : 960.1 MiB Swap : 0.0 KiB Disk : 1.4 TiB Distro : Debian GNU/Linux 12 (bookworm) Kernel : 6.1.0-28-amd64 VM Type : BHYVE IPv4/IPv6 : ✔ Online / ✔ Online IPv6 Network Information: --------------------------------- ISP : BNK ASN : AS29141 Bradler \u0026 Krantz GmbH \u0026 Co. KG Host : Bradler \u0026 Krantz GmbH \u0026 Co. KG Location : Bochum, North Rhine-Westphalia (NW) Country : Germany fio Disk Speed Tests (Mixed R/W 50/50) (Partition /dev/vdb): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 53.01 MB/s (13.2k) | 637.11 MB/s (9.9k) Write | 53.08 MB/s (13.2k) | 640.46 MB/s (10.0k) Total | 106.10 MB/s (26.5k) | 1.27 GB/s (19.9k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 2.88 GB/s (5.6k) | 7.74 GB/s (7.5k) Write | 3.03 GB/s (5.9k) | 8.26 GB/s (8.0k) Total | 5.91 GB/s (11.5k) | 16.00 GB/s (15.6k) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | Ping ----- | ----- | ---- | ---- | ---- Clouvider | London, UK (10G) | 2.76 Gbits/sec | 4.32 Gbits/sec | 6.91 ms Eranium | Amsterdam, NL (100G) | 7.95 Gbits/sec | 5.51 Gbits/sec | 6.40 ms Uztelecom | Tashkent, UZ (10G) | 2.32 Gbits/sec | 1.76 Gbits/sec | 87.6 ms Leaseweb | Singapore, SG (10G) | 1.22 Gbits/sec | 1.12 Gbits/sec | 156 ms Clouvider | Los Angeles, CA, US (10G) | 1.04 Gbits/sec | 1.07 Gbits/sec | 151 ms Leaseweb | NYC, NY, US (10G) | 2.10 Gbits/sec | 1.42 Gbits/sec | 76.1 ms Edgoo | Sao Paulo, BR (1G) | 929 Mbits/sec | 398 Mbits/sec | 183 ms iperf3 Network Speed Tests (IPv6): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | Ping ----- | ----- | ---- | ---- | ---- Clouvider | London, UK (10G) | 900 Mbits/sec | 4.15 Gbits/sec | 8.97 ms Eranium | Amsterdam, NL (100G) | 900 Mbits/sec | 6.53 Gbits/sec | 6.41 ms Uztelecom | Tashkent, UZ (10G) | 247 Mbits/sec | 1.23 Gbits/sec | 87.5 ms Leaseweb | Singapore, SG (10G) | 308 Mbits/sec | 1.12 Gbits/sec | 156 ms Clouvider | Los Angeles, CA, US (10G) | 301 Mbits/sec | 971 Mbits/sec | 151 ms Leaseweb | NYC, NY, US (10G) | 342 Mbits/sec | 2.46 Gbits/sec | 76.2 ms Edgoo | Sao Paulo, BR (1G) | 1.02 Gbits/sec | 603 Mbits/sec | 183 ms Geekbench 4 Benchmark Test: --------------------------------- Test | Value | Single Core | 3304 Multi Core | 3087 Full Test | https://browser.geekbench.com/v4/cpu/18313014 YABS completed in 9 min 32 sec
# root @ netcup-rs1000-us in ~ [5:53:36] C:130 $ curl -sL yabs.sh | bash # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # # Yet-Another-Bench-Script # # v2024-06-09 # # https://github.com/masonr/yet-another-bench-script # # ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## ## # Fri Nov 29 05:53:39 AM UTC 2024 Basic System Information: --------------------------------- Uptime : 0 days, 14 hours, 20 minutes Processor : AMD EPYC 9634 84-Core Processor CPU cores : 4 @ 2246.624 MHz AES-NI : ✔ Enabled VM-x/AMD-V : ❌ Disabled RAM : 7.7 GiB Swap : 0.0 KiB Disk : 503.8 GiB Distro : Debian GNU/Linux 12 (bookworm) Kernel : 6.1.0-28-cloud-amd64 VM Type : KVM IPv4/IPv6 : ✔ Online / ✔ Online IPv6 Network Information: --------------------------------- ISP : netcup GmbH ASN : AS214996 netcup GmbH Host : Netcup KVM MNZ Location : Vienna, Vienna (9) Country : Austria fio Disk Speed Tests (Mixed R/W 50/50) (Partition /dev/vda3): --------------------------------- Block Size | 4k (IOPS) | 64k (IOPS) ------ | --- ---- | ---- ---- Read | 211.27 MB/s (52.8k) | 423.15 MB/s (6.6k) Write | 211.83 MB/s (52.9k) | 425.38 MB/s (6.6k) Total | 423.11 MB/s (105.7k) | 848.53 MB/s (13.2k) | | Block Size | 512k (IOPS) | 1m (IOPS) ------ | --- ---- | ---- ---- Read | 437.82 MB/s (855) | 570.58 MB/s (557) Write | 461.08 MB/s (900) | 608.58 MB/s (594) Total | 898.90 MB/s (1.7k) | 1.17 GB/s (1.1k) iperf3 Network Speed Tests (IPv4): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | Ping ----- | ----- | ---- | ---- | ---- Clouvider | London, UK (10G) | busy | busy | 77.0 ms Eranium | Amsterdam, NL (100G) | 2.50 Gbits/sec | 2.19 Gbits/sec | 90.4 ms Uztelecom | Tashkent, UZ (10G) | busy | busy | 168 ms Leaseweb | Singapore, SG (10G) | 2.01 Gbits/sec | 1.58 Gbits/sec | 230 ms Clouvider | Los Angeles, CA, US (10G) | 2.61 Gbits/sec | 1.49 Gbits/sec | 58.2 ms Leaseweb | NYC, NY, US (10G) | 2.68 Gbits/sec | 2.37 Gbits/sec | 8.29 ms Edgoo | Sao Paulo, BR (1G) | 2.28 Gbits/sec | 1.16 Gbits/sec | 132 ms iperf3 Network Speed Tests (IPv6): --------------------------------- Provider | Location (Link) | Send Speed | Recv Speed | Ping ----- | ----- | ---- | ---- | ---- Clouvider | London, UK (10G) | busy | 929 Mbits/sec | 76.9 ms Eranium | Amsterdam, NL (100G) | 2.49 Gbits/sec | 2.17 Gbits/sec | 90.4 ms Uztelecom | Tashkent, UZ (10G) | 1.96 Gbits/sec | 537 Mbits/sec | 168 ms Leaseweb | Singapore, SG (10G) | 2.07 Gbits/sec | 1.41 Gbits/sec | 230 ms Clouvider | Los Angeles, CA, US (10G) | 2.61 Gbits/sec | 1.62 Gbits/sec | 58.1 ms Leaseweb | NYC, NY, US (10G) | 2.71 Gbits/sec | 2.34 Gbits/sec | 8.29 ms Edgoo | Sao Paulo, BR (1G) | 2.33 Gbits/sec | 1.11 Gbits/sec | 132 ms Geekbench 6 Benchmark Test: --------------------------------- Test | Value | Single Core | 1947 Multi Core | 6298 Full Test | https://browser.geekbench.com/v6/cpu/9131931 YABS completed in 12 min 25 sec
SoftLayer Bare Metal compute cx2d $5.158/m
TrackWith - Free Privacy Focused Analytics
AWS EC for 5/mo
KS-LE-B
ITS WEDNESDAY MY DUDES
SoftLayer bx2a-8x32 balanced $319/m
Can't set IOPS higher than 3000 from console 😬
ServerFactory / Heartbeat IT free BGP VPS before it cancels tomorrow.
KS-LE-B with a double memory.
@Chunkserve
4 vCore E5-2690v4 / 8 GB / 90 GB SSD
Custom Plan
France (Paris)
$0.99/m
@host_c $7/year:
KS-LE-B
2x450G NVMe
2x4T HDD
HDD
Wow congrats !
Have fun
Chunkserve
VirMach
No GB?
Intel NUC i3 gen7
solidseovps
NL
0.50$/y Virmache
$7/yr
Alphavps
Nuremberg
15.99eur
racknerd
seattle
Virmach
LAX
not enough ram
ultravps
storage
AMS
BHVE virtualization
