@beagle said: @servarica_hani Any chance to order just 1 slice on Unified Slim Plan?
It seems the minimum order is at least 2 slices.
the issue is that i felt 250mbps with 1 slice is a bit too much and whmcs does not give us that level of control to disable option based on another option
Will check with the team and see what we can do
Thank you. I don't need unlimited bw @ 250mbps. I would rather have 4TB @ 10Gbps.
If I get a Unified FAT server now and want to add a SAN later, the prices for the new block will stay the same as at the moment of the purchase or they are subject to change?
SAN is guaranteed availability and price any time in the future
as it is not tied to the physical server and we always plan to have more than we need
fixed i did it fast and forgot the options
Thank you. Why the annual price is not 11 x monthly like other plans?
Any chance you can do something on a 3 month?
Free Hosting at YetiNode | MicroNode | Cryptid Security | URL Shortener | LaunchVPS | ExtraVM | Host-C | In the Node, or Out of the Loop?
for small plans that does not have monthly price it is not calculated the the same as other plans
sometimes they are lower or higher than 11 months
I'm not sure if I should I get a server with 1tb nvme and 2tb SAN. It's very tempting.
Should I?
Why?
Why not?
When?
I don't know what to do 😭
Do it!
Take my money!
Another question.
My order was marked as fraud
I'm not sure if I should try again.
if the address is good and not from VPN open a ticket or wait the team will review it anyway
I will wait 😀
I better opened a ticket. #601803 just in case.
