@AlwaysSkint said: Och it's nothing major. The new (untitled) column that displays Status, IP,Control Panel, VNC, spec. etc. My newly added NYC VM one just rotates the circular thingy (forgot its name) - the green status did pop up for a while.
Happened to me. FWIW, seemed to cut off at 10.
I fixed it by changing to 25 and reloading the page and they all came up without issue.
Nothing obvious in dev tools that's timing out or 403'd but just change 10-> 25 and you should be good for now.
Any tips on how to get ISO mounting working or is it just me? I have tried most of the ISOs on the list with different boot orders and power on/off permutations but nothing seems to work. Installing a system from a template work well though. I have also tried the same using lite and full control panels.
I had the same issue and it was the ISOs not being synced. Virmach fixed it for the node. Maybe it's the same with yours.
Could just be the node you're on needs a resync. Let me know the name.
@arirang said:
In Los angels Anyone who are able to mount and boot netboot.xyz? Booting is not working after mount but Reinstall via templates is working.
Which server?
RYZE.LAX-Z0029.VMS
That's right.
Clicking boot on the solusvm returns success but status still exists offline.
RYZE.LAX-Z0029.VMS
Confirmed. Ta.
the wall is painted with L.A. No Miami in sight.
offer #644 looks good
It likely varies depending on node..
On a NYC one: I couldn't get netboot.xyz to work but did manage to boot Centos 7, then Elevate to Alma 8.
Yeah considering it. 9m left on it though
Anyone please help with @VirMach website 14m locked,
Virmach Deals
644? Where do you see that?
middle one right now on flash page
if the general uptime had been good past year I would have snapped it up as a no brainier.
Another LA one ... time for zzz methinks.
now 646 is up someone messing w my discipline
welp. i got sent to another page to add a card just bc i clicked it out of curiosity and lost it in cart when I went back lmfao
NYCB043 whilst you're doing the other one.
English vocabulary, upgraded!
Are there any long-term discount codes?
Early coupons have always prevented me from purchasing the option.
What?
Tokyo prices down
MJJs incoming!!
Ah Tokyo almost enough I needed (1GB) for docker, etc.
Which server?
RYZE.LAX-Z0029.VMS
Atlanta Party
That's right.
RYZE.LAX-Z0029.VMS
who has the galls for #653?
quite good value
Resyncing. Try again in a couple hours.
Which code still available? I think I have a litttttle bit of time to decipher today
