VirMach * 2024 * RYZEN * NVMe ** VPS Black Friday * Flash Deals ** Check inside for offers!
13233353738118
  • @AlwaysSkint said: Och it's nothing major. The new (untitled) column that displays Status, IP,Control Panel, VNC, spec. etc. My newly added NYC VM one just rotates the circular thingy (forgot its name) - the green status did pop up for a while.
    Happened to me. FWIW, seemed to cut off at 10.
    I fixed it by changing to 25 and reloading the page and they all came up without issue.
    Nothing obvious in dev tools that's timing out or 403'd but just change 10-> 25 and you should be good for now.
    Thanked by (1)AlwaysSkint
  • @Kris said: but just change 10-> 25 and you should be good for now
    Confirmed. Ta. :+1:
    Thanked by (1)Kris
  • the wall is painted with L.A. No Miami in sight.
  • edited December 2024
    Any tips on how to get ISO mounting working or is it just me? I have tried most of the ISOs on the list with different boot orders and power on/off permutations but nothing seems to work. Installing a system from a template work well though. I have also tried the same using lite and full control panels.
  • imokimok OG
    I had the same issue and it was the ISOs not being synced. Virmach fixed it for the node. Maybe it's the same with yours.
    Thanked by (2)Crab FrankZ
    offer #644 looks good
    @Crab said: how to get ISO mounting working
    It likely varies depending on node..
    On a NYC one: I couldn't get netboot.xyz to work but did manage to boot Centos 7, then Elevate to Alma 8.
    Thanked by (1)Crab
    Yeah considering it. 9m left on it though
  • Anyone please help with @VirMach website 14m locked,
    644? Where do you see that?
    middle one right now on flash page
    if the general uptime had been good past year I would have snapped it up as a no brainier.
  • Another LA one ... time for zzz methinks. :sleeping:
    now 646 is up someone messing w my discipline
  • welp. i got sent to another page to add a card just bc i clicked it out of curiosity and lost it in cart when I went back lmfao
    Could just be the node you're on needs a resync. Let me know the name.
  • @VirMach said: Let me know the name.
    NYCB043 whilst you're doing the other one. ;)
    whilst
    English vocabulary, upgraded!
  • Are there any long-term discount codes?
    Early coupons have always prevented me from purchasing the option.
    What?
    Thanked by (1)imok
    Tokyo prices down
    MJJs incoming!!
    In Los angels Anyone who are able to mount and boot netboot.xyz? Booting is not working after mount but Reinstall via templates is working.
  • Ah Tokyo almost enough I needed (1GB) for docker, etc.
    Which server?
    Thanked by (1)arirang
  • @VirMach said:
    Which server?
    RYZE.LAX-Z0029.VMS
  • Atlanta Party
  • @Crab said:
    RYZE.LAX-Z0029.VMS
    That's right.
    Clicking boot on the solusvm returns success but status still exists offline.
    RYZE.LAX-Z0029.VMS
    who has the galls for #653?
    quite good value
    @Crab said:
    RYZE.LAX-Z0029.VMS
    Resyncing. Try again in a couple hours.
    Thanked by (2)Crab arirang
  • FAT32FAT32 OGSenpai
    Which code still available? I think I have a litttttle bit of time to decipher today
