VirMach * 2024 * RYZEN * NVMe ** VPS Black Friday * Flash Deals ** Check inside for offers!
14041434546112
    @animeiscool said:
    @VirMach You ever play Runescape?
    My friend showed me the game in 3rd grade around 2003, I remember mining in Barbarian Village for a very long time, and then getting scammed for my black platelegs or something like that.
    Thanked by (1)Wonder_Woman
  • @VirMach It would be a great surprise if some usernames were randomly selected as discount codes!
    VPS Discounts and Reviews | Hosting Provider Directory & Check out the latest VPS offers and reviews to help you choose the best VPS service.
  • @VirMach I understand that you disallow removing credit cards by default for a reason, but would it be possible to remove mine from my account. When I plan to renew I will obviously re-add it, I just don't like having payment methods saved if I'm not actively considering purchasing something.
  • @VirMach said:
    @nullnothere said:
    @VirMach that was a class act by @Wonder_Woman and I think you should release a code in hono(u)r of the achievement exclusively for him/her.
    Of course for the rest of us clapping here, it'll be nice to have something - we are happy to clap more for you as well.
    Alright, here's a coupon code. It's hidden in between 8 other coupon codes, and it's using the SHA256 cipher (am I pronouncing that right?) Anyway it should be really easy.
    ba5759530af4c7c155113141da135bcff8f5609e1c81ae35b89680f330990180
    In case you weren't fooling, I tried all the permutations of the 9 codes I'm aware of from the cipher block concatenated and hashed, with and without spaces. No match B)
    Thanked by (1)nullnothere
    Brain wave - is what was posted the actual coupon code? He must be fooling and toying with us.
    Thanked by (1)VirMach
  • edited December 1
    @user123 said:
    @VirMach said:
    @user123 said:
    @Wonder_Woman great job! You definitely earned that (recurring) $40 discount. :)
    And, the more years you idle it, the higher the valuation of your hourly work rate!
    Question for @Wonder_Woman, @Kris, and anyone else who has a larger NVMe VPS: does your disk show up as the swap? I started running YABS and it said this:
    Less than 2GB of space available. Skipping disk test...
    Which then led me to notice:
    RAM : 7.5 GiB
    Swap : 796.3 GiB
    Disk : 3.6 GiB
    I'm used to seeing the disk show up as...the disk. Is there something different I need to do for this or is the config on mine wonky?
    Which OS? I think someone reported something similar earlier. Could be my fault.
    So...it came with AlmaLinux 8.9 (Midnight Oncilla) installed, but SolusVM lists the OS as "DISABLED - Windows Desktop (Server 2019) Evaluation Legacy". There was no option for me to pick an OS at time of purchase. I'm going to be heading to bed now, as I should have done a few hours ago. :)
    Edit: I'll probably set it to reinstall something else and then hit the hay.
    I got a similar one @ with Alma already installed and Solus showing Disabled windows - which I found a bit odd
    But I haven't tried to install anything yet, so no idea if there'll be issues.
    Thanked by (1)user123
    Doesn't appear to be
    @ZA_capetown said: I got a similar one @ with Alma already installed and Solus showing Disabled windows - which I found a bit odd
    They added a new feature where it defaults a blank template to the first operating system it finds. For these specials, we disable it to prevent any problems from it trying to install so many operating systems at once but I guess it doesn't matter anymore if it's going to install Almalinux anyway and then label it as some other disabled operating system that doesn't exist.
    It's like if they're going to do that I don't understand why they wouldn't at least do it properly instead of making it go no OS found, panic, pick the first OS, regardless of whether that one exists or not, oh no, that one doesn't exist either, let me leave the name there but then install another OS without telling anyone what I'm doing.
    Thanked by (3)ZA_capetown tototo user123
  • So many special and undocumented bugs features of Solus :p
  • @mucstudio said: I didn't use any discount codes as I purchased the product at full price, although I do wish I could find some discount codes.
    Sorry - think you misunderstood. I am not blaming you, it is @virmach messing around.
    Enjoy your VPS.
    The part that's interesting to me is how it handles swap. Someone mentioned in a ticket that it came with Almalinux and the SWAP/disk were flipped in some way, and that after they re-installed the same exact OS from the control panel (Almalinux) it fixed itself. So are they really also keeping the partition numbers from the first template it tries and fails and applying it to the second? Because that'd be a feature.
    Thanked by (2)ZA_capetown user123
    edited December 1
    Enjoy your VPS.
    I really did think you had a good chance at figuring out MATTS when I created it (my reply to you asking for clues, I think.)
    @VirMach said: Okay I'll give you some clues on the many coupons that already exist. One of them has to do with a very popular UI error that we discussed previously on this thread. Then there's a bunch of anagrams for people's name, I don't even think anyone's looking for those but they're so easy, you can can use a solving too or AI and start giving it people's names here that make posts. I went ahead and added another one. I was going to also give you a hint on the cipher but I don't even remember what was exactly used anymore. Oh here I'll just give you one of them which should make it infinitely easier to solve, with one caveat: the first character is missing.
    Thanked by (1)msatt
  • @VirMach said: I really did think you had a good chance at figuring out MATTS when I created it.
    I did, but someone else got it - cest la vie.
    It is solvable and it is easy. I feel like so much time was spent on it the last time around that you might think it's more sophisticated than it really is.
    Coupon code "NOGAMES" for 30% off recurring. May expire at any time. No quantity limit. I'm going to expire it in about an hour or two, unless I forget.
  • vyasvyas OGSenpai
    edited December 1
    . #694 with that coupon would have breached the $ 7 threshold. :-)
    Of course, other codes also enable that
    Oh snap, I figured it out! Now.. what to use it on
  • Took me 2 hours just to catch up with all the messages in this thread - This shows LES does work and I hope Virmach really profits from this.
    Next can we have a 'stability' coupon <3
    edited December 1
    @user123 said: The CHI plan was wild
    What?! I was sleeping. :'(
    Also, missed out on the other CHI, when trawling through nightly posts for a coupon :'( :'(
  • @Wonder_Woman said: Oh snap, I figured it out! Now.. what to use it on
    Be sure to leave a clue when appropriate.
  • Oh bugger I just bought another one I don't really need - but it was a bargain.
    That's been like my whole year
    Thanked by (3)FAT32 FrankZ nullnothere
  • @mucstudio said:
    oh,no,1200GB SSD (NVMe)
    Fuuuuuuuu where? Missed it again
  • Damn, had work today so couldn't join the festivities. Had fun reading @Wonder_Woman 's post about solving the cipher though. Now just have to find the one flash sale deal I can't resist...
  • Offer #707
    SKU: RYZEN SKU# V0E-XD
    2 cores
    1536MB RAM
    50GB NVMe Storage
    1 IPv4
    4608GB Bandwidth
    LOS ANGELES, CA
    $11.61 per YEAR -> $8.13 USD
    My Black Friday ends with this purchase!
  • @tototo said: My Black Friday ends with this purchase!
    So you think...
    Thanked by (3)Wonder_Woman tototo vyas
  • @tototo said:
    Offer #707
    2 cores
    1536MB RAM
    50GB NVMe Storage
    1 IPv4
    4608GB Bandwidth
    LOS ANGELES, CA
    Cyber Monday is coming
  • FAT32FAT32 OGSenpai
    I think I am getting a little bit old
  • @julensm said:
    @tototo said:
    Offer #707
    2 cores
    1536MB RAM
    50GB NVMe Storage
    1 IPv4
    4608GB Bandwidth
    LOS ANGELES, CA
    Okay... I added some funds...
    Thanked by (2)Wonder_Woman julensm
