VirMach * 2024 * RYZEN * NVMe ** VPS Black Friday * Flash Deals ** Check inside for offers!
15556586061116
  • edited December 2024
    @VirMach said: qlorm calwe aiyvf tdcqm ofvqf ieiqm ydoek phmbx poquf cgwgy fbibm lvgps cbpqa ooshf vimrk awpti qwfmn oddyk xaywg gunjo niwdm sqaem mhgaq isnwz xqabu xuxmg sbmqt uapyf tfrpu yzlqv mffkd zqyvg eksnb tvyih bglzv pjyvt zdmjo kletq rgnal wgmdl axwfd gcyfp lucye vfsjz
    is this a piece of text?
  • We need @FAT32, he's the intelligent one.
    Also @Wonder_Woman
  • @VirMach said:
    Alright, this one is going to be hard but it has 50 x 50% off recurring coupons inside it, so I recommend you guys create some type of community task force and crack it together since there should be plenty of codes for everyone once it's cracked. You'll see that one of you might not be in the position to figure it out, but maybe three or five might ring a bell or two
    You only have about eight ten hours to solve this, as all coupons will expire midnight PST on Cyber Monday. If it's solved, coupons can be extended to work later into the sale. There is no consolation prize, so waste your time at your own risk.
    Instructions:
    Coupon Cipher Block:
    QXUOKBTGGBHQHVOLVPYQCIBUWIGFDKOQKMNJFRQQSQVJALWOQPDGFKWIQLYDOLEZMAQOZRFCDQYFGDLCOLBPQHSDJNQHABGDWFOQUCNSCNOFQTKEJUZQTJHRYQVJJUUZQEFPVTNBMCYHSKOQQZELUFALJPQCOFCKFQMEEEUFCIEQSGJNQNSEAGKIZYQJYZLBYNQYZEOLIAJOGMQXQHCJXIGDQESDHNNFMYQOIMIPGQPTBMIFYQFUCNXGZNQHFXHSCQAZGWRICBNRXIQYQBLCLNCFQXZCIUFKNSRQRZGJYTYQBIPXCMQBLYOYLGQAZEODAXPDGQGLAOQNATGSQJZDAWNIDQLDSTLZBFZLQAFCTXCLQPAMCIIQMXMBLQTFEOHUALOUGQXZ
    How can we test if we get it? ;)
  • @adly said: How can we test if we get it? ;)
    Place an order?
    The cipher block seems only 49 coupons long though, so it could be that your voucher went missing :p
    Thanked by (1)vyas
  • FrankZFrankZ ModeratorOG
    Instructions:
    oh my !
    [ I want to be on @Wonder_Woman 's team ]
    good luck team i am off.. 2 am here
    chatgpt didnt have a clue about this (actually used all free tries i think )
    Instructions:
    qlorm calwe aiyvf tdcqm ofvqf ieiqm ydoek phmbx poquf cgwgy fbibm lvgps cbpqa ooshf vimrk awpti qwfmn oddyk xaywg gunjo >niwdm sqaem mhgaq isnwz xqabu xuxmg sbmqt uapyf tfrpu yzlqv mffkd zqyvg eksnb tvyih bglzv pjyvt zdmjo kletq rgnal wgmdl >axwfd gcyfp lucye vfsjz
    vimrk -> this may be virmach
    ok dropping some tools here :
    https://www.cachesleuth.com/multidecoder/
    https://texttools.org/
    https://toolsaday.com/text-tools/split-text
    https://www.dcode.fr/cipher-identifier (i dont thing it works...)
    https://www.thewordfinder.com/caesar-cipher-solver/ (try bruteforce nice)
  • @VirMach said: qlorm calwe aiyvf tdcqm ofvqf ieiqm ydoek phmbx poquf cgwgy fbibm lvgps cbpqa ooshf vimrk awpti qwfmn oddyk xaywg gunjo niwdm sqaem mhgaq isnwz xqabu xuxmg sbmqt uapyf tfrpu yzlqv mffkd zqyvg eksnb tvyih bglzv pjyvt zdmjo kletq rgnal wgmdl axwfd gcyfp lucye vfsjz
    I've read some comments on Instagram that look like this.
    @wankel said:
    Place an order?
    Maybe one of the codes is there elsewhere to help point you guys in the right direction, or maybe VirMach can't count.
    Okay I went through and solved it just to make sure I didn't make any errors, and it's solvable.
    O boy. More cryptic stuff and skimming through all the back pages
    Thanked by (1)imok
  • @VirMach
    Great
    Just felt like ordering one server and boom.
    The login page is on loop essentially saying I am banned for 15 minutes and is refreshing every second.
  • JabJab Senpai
    Spoiler
  • FAT32FAT32 OGSenpai
    I have been summoned - I think
  • 50 Q in "Coupon Cipher Block"
    It may correspond to 50 coupons
    CRYPTOOOOOOOOOOOO
    @localhost said:
    @VirMach
    Great
    It's loading on loop to make sure you get banned for longer than 15 minutes. Uhhh, what order of operations caused this issue?
    Remember the plan ID so I can generate it manually in this case if you don't make it in time.
    Thanked by (1)localhost
    There's no way you got enough sleep
    Thanked by (1)FAT32
    That's the problem - I have rough idea on how the last few could have been solved due to patterns but somehow I keep failed to code something useful
    Thanked by (1)Wonder_Woman
    Great. Can you post the code?
    @Jab said:
    Spoiler
    I can confirm this is not a bug. Different servers with different quantities, but similar enough ratio of everything left over. And both happened to randomize to the same location on initial pick. Pretty amazing they ended up right next to eachother. They're also the only offers to ever be $8.18
    @VirMach said: Do we need to re-expand to Buffalo for you?
    Nah, Japan node is no longer needed after I emigrated.
    Yet forcefully kick your loyal old victims out, can't believe you did that.
    I am very happy with $10 per year
    ATLANTA
    2 Core
    4000 MB
    100 GB DIK
    4 TB bandwidth
    and $20 per year
    TOKYO
    1 Core
    1500 MB
    500 GB DIK
    6 TB bandwidth
    All I hope is you don't run away with my eHentai stash on the Tokyo storage
    Em.. maybe I could grab better spec this year
    Ontario Dildo Inspector
    Well I simply clicked order now from the vps.blackfriday page and it looks like I got rate limited.
    Don't even remember which one I wanted to get....
    Will try again in sometime
    @VirMach - I just want to mention that your customer support service has been really really good. I don't ticket that often, but when I do the support is fast, helpful, and responsive. You have the best AI ticket system I've ever seen.
  • I had a bad experience because I made a payment on Friday 29/11, the debit card was charged but there was no invoice ID and no VPS account, I have created a ticket #912601, hopefully @VirMach can create an account manually or deposit into my account (if possible).
  • Could it be a playfair cypher? https://www.boxentriq.com/code-breaking/playfair-cipher
    The key I'm guessing is related to the italicised words in the original message:
    see one position three five ring a two
    The first something, at the thirty fifth position, something ring a two (interesting they're all spelled out)
    Could be forum post related? Or something hidden on the vps.blackfriday website?
  • Dammit, still stuck at work. :( At least I'm WFH, but not able to spend as much time on the cipher. Tried a couple basic rots. hmm
    The italicized words are:
    see one position to three five ring a two
    You're missing the "to", not sure if that's important yet.
    Could be a sequence of shifts, like
    1. "see one position": This might mean to look at the first position.
    2. "to three": This could mean to move to the third position.
    3. "five ring": This might mean to move to the fifth position and then wrap around (ring) back to the start.
    4. "a two": This could mean to move to the second position.
    That being said, all I've got is gibberish so far :)
    Thanked by (2)feeed FrankZ
  • Thanked by (2)localhost nightcat
    Ditto, but I also don't know if there's significance in how the italicized words are broken up:
    see / one / position to / three / five / ring a / two
