@VirMach said:
Alright, this one is going to be hard but it has 50 x 50% off recurring coupons inside it, so I recommend you guys create some type of community task force and crack it together since there should be plenty of codes for everyone once it's cracked. You'll see that one of you might not be in the positionto figure it out, but maybe three or five might ringa bell or two
You only have about eight ten hours to solve this, as all coupons will expire midnight PST on Cyber Monday. If it's solved, coupons can be extended to work later into the sale. There is no consolation prize, so waste your time at your own risk.
I can confirm this is not a bug. Different servers with different quantities, but similar enough ratio of everything left over. And both happened to randomize to the same location on initial pick. Pretty amazing they ended up right next to eachother. They're also the only offers to ever be $8.18
@VirMach - I just want to mention that your customer support service has been really really good. I don't ticket that often, but when I do the support is fast, helpful, and responsive. You have the best AI ticket system I've ever seen.
I had a bad experience because I made a payment on Friday 29/11, the debit card was charged but there was no invoice ID and no VPS account, I have created a ticket #912601, hopefully @VirMach can create an account manually or deposit into my account (if possible).
https://codepen.io/ZevanRosser/pen/dyxLRZq
is this a piece of text?
We need @FAT32, he's the intelligent one.
Also @Wonder_Woman
How can we test if we get it?
Place an order?
The cipher block seems only 49 coupons long though, so it could be that your voucher went missing
oh my !
[ I want to be on @Wonder_Woman 's team ]
good luck team i am off.. 2 am here
chatgpt didnt have a clue about this (actually used all free tries i think )
vimrk -> this may be virmach
ok dropping some tools here :
https://www.cachesleuth.com/multidecoder/
https://texttools.org/
https://toolsaday.com/text-tools/split-text
https://www.dcode.fr/cipher-identifier (i dont thing it works...)
https://www.thewordfinder.com/caesar-cipher-solver/ (try bruteforce nice)
I've read some comments on Instagram that look like this.
Maybe one of the codes is there elsewhere to help point you guys in the right direction, or maybe VirMach can't count.
Okay I went through and solved it just to make sure I didn't make any errors, and it's solvable.
O boy. More cryptic stuff and skimming through all the back pages
@VirMach
Great
Just felt like ordering one server and boom.
The login page is on loop essentially saying I am banned for 15 minutes and is refreshing every second.
I have been summoned - I think
50 Q in "Coupon Cipher Block"
It may correspond to 50 coupons
CRYPTOOOOOOOOOOOO
It's loading on loop to make sure you get banned for longer than 15 minutes. Uhhh, what order of operations caused this issue?
Remember the plan ID so I can generate it manually in this case if you don't make it in time.
There's no way you got enough sleep
That's the problem - I have rough idea on how the last few could have been solved due to patterns but somehow I keep failed to code something useful
Great. Can you post the code?
Nah, Japan node is no longer needed after I emigrated.
Yet forcefully kick your loyal old victims out, can't believe you did that.
I am very happy with $10 per year
and $20 per year
All I hope is you don't run away with my eHentai stash on the Tokyo storage
Em.. maybe I could grab better spec this year
Ontario Dildo Inspector
Well I simply clicked order now from the vps.blackfriday page and it looks like I got rate limited.
Don't even remember which one I wanted to get....
Will try again in sometime
Could it be a playfair cypher? https://www.boxentriq.com/code-breaking/playfair-cipher
The key I'm guessing is related to the italicised words in the original message:
The first something, at the thirty fifth position, something ring a two (interesting they're all spelled out)
Could be forum post related? Or something hidden on the vps.blackfriday website?
Dammit, still stuck at work. At least I'm WFH, but not able to spend as much time on the cipher. Tried a couple basic rots. hmm
The italicized words are:
see one position to three five ring a two
You're missing the "to", not sure if that's important yet.
Could be a sequence of shifts, like
That being said, all I've got is gibberish so far
Ditto, but I also don't know if there's significance in how the italicized words are broken up:
see / one / position to / three / five / ring a / two
