ipv6 on mrvm sg node
Does anyone here have an old mrvm ovz in SG? If so, is ipv6 working for you?
Mine stopped working a while ago. In case I did something that I forgot about, I just reinstalled it from templates (tried both latest ubuntu and debian) and it's still not working. It has ipv6 address assigned/matches what's in the panel, route, etc (no ipt/nft).
Other than addresses, the ipv6 network configs are the same (defaults as installed) as my gullo ovz box (fresh installs all around with no changes) that is working fine. But the mrvm one won't contact out (ping/tr, etc) and can't ping/etc it. @SGraf said ipv6 sg network is working, so I'm asking here if there's something special that needs to be done to get ipv6 working for the mrvm ovz vps.
Thanks!
Sounds like the nat firewall rule on the host node might be the culprit
