NameCrane Black Friday - CraneMail Email Hosting + Cloud Storage Launch with Lifetime Deal
124678
  • @NameCrane said:
    For those that have been asking:
    dacybermonday2024
    20% off recurring on any DirectAdmin shared/reseller/crate plan for annual & biennial billing only. This is on top of the discounts those annual/biennial plans already come with.
    https://namecrane.com/crates-semi-dedicated-hosting
    https://namecrane.com/store/budget-reseller-hosting
    https://namecrane.com/store/da-shared-hosting
    Enjoy
    Any 3 years da-shared-hosting? I want a long term plan.
  • NameCraneNameCrane Hosting Provider
    @hyperton said:
    How long will this offer be available? Partically CraneMail BF 100G - $10 / year, $20 / 3 years? Will be up tomorrow?
    Yep, the annual/triennial CraneMail deal will be up for a bit.
    Sure. Added triennial billing to DA Shared & Resellers.
    🏗 NameCrane - Shared, Reseller, Semi-Dedicated Hosting / cPanel + DirectAdmin / Ryzen + NVMe + 10Gbps / Free Blesta!
    🇺🇸🇬🇧🇱🇺🇸🇬 Now in Singapore 👉 Shared Hosting from $8/yr 🏆 $2/mo Reseller Hosting
    Flash sale offer in the megathread for anyone looking for a small DirectAdmin plan in Singapore or Luxembourg. ~50% off.
    https://lowendspirit.com/discussion/comment/194396/#Comment_194396
  • vyasvyas OGSenpai
    @NameCrane
    Order marked as fraud, thanks anyways
    Best wishes with sales
    @vyas said:
    @NameCrane
    Honestly no idea why that hit.. I whitelisted/approved, if you want to attempt a re-order.
    Thanked by (1)vyas
  • Loving this, it's awesome
  • the huge addition of the eM Client license is awesome, I been looking for a client to replace Thunderbird due to its handling (or not so much of) of inline images, not displaying them and showing them as attachments only, and eM Client seems to handle perfectly,
    it is a Business license that works out like 40% more expensive than the lifetime payment just for one year. as much as I hate having to purchase subscription based software over lifetime, it was one of the reasons I never looked at the originally, but this offer was a huge bonus!
    Hmm, 3 licenses per domain. Wonder how many domains these plans include 🤔
    Don't mind me.. I've been awake for 40+ hrs.
  • FYI for those using imapsync and these accounts https://imapsync.lamiral.info/FAQ.d/FAQ.SmarterMail.txt
    Thanked by (1)Snacho
  • @bdl said: imapsync
    I used it without any of these options and the sync went perfect for all folders
  • bdlbdl OG
    edited December 2024
    mine wouldn't sync completely from non-smartermail/cranemail to smartermail/cranemail but those switches made it work fine
  • @NameCrane is disk usage calculated as compressed or uncompressed? I have 1.5GB worth of mail after migrating from purelymail, it seems they were reporting that incorrectly, even looking at my backups. but the usage on the services page only reports 0.44GB while SmarterMail reports 1.5GB
    @dgc1980 said: essed or uncompressed? I have 1.5GB worth of mail after migrating from purelymail, it seems they were reporting that incorrectly, even looking at my backups. but the usage on the services page only reports 0.44GB while SmarterMail reports 1.5GB
    I would assume it's reporting uncompressed. Do you have some files uploaded?
    Francisco
    PurelyMail compresses I think, I remember seeing it in their pricing calculator thing. I believe SmarterMail shows uncompressed.
    One thing to note though is that it periodically indexes and calculates storage, so if you just moved a bunch it may take a little bit to do another run and calculate usage.
  • @NameCrane said: PurelyMail compresses I think, I remember seeing it in their pricing calculator thing. I believe SmarterMail shows uncompressed.
    I will rephrase it, I may it may of got lost :)
    • Purelymail reported 3.5GB uncompressed(2.4GB compressed) something wrong here maybe because of flat files it is increased due to block size
    • my mail backup is 1.5GB so is SmarterMail
    • namecrane services is listing as 0.44GB (I am guessing compressed?)
    @Francisco said: Do you have some files uploaded
    no files uploaded yet, just been playing with mail first, but I am loving it so far :)
  • The namecrane interface is now showing the correct information :)
    Awesome. This will probably speed up the process in future if you need to - Domain Settings -> Accounts, then you can select one and recalculate disk size. I haven't checked docs but I figure the storage tally runs on a ~24hr cron.
  • @NameCrane said: Domain Settings -> Accounts
    oh, SmarterMail was showing the correct information, it was the main product page that didnt.
  • Does the em client expire if the namecrane service expires?
  • @fan said: Does the em client expire if the namecrane service expires?
    they seems to get issued as 12 month subscription codes, I am guessing they will automatically renew if you plan renews or is lifetime.
  • @dgc1980 said: lifetime
    Already stacked two mxroute plans, now hesitating one more lifetime.
  • @NameCrane said:
    You can manually add domain aliases to the account, so you could create an alias for sub.domain.com (without using up 1 of the 15 primary domains), and then configure a catchall alias for that subdomain towards one of the mailboxes.
    Ok, i have created a domain alias for sub.domain.com
    How do i add a catchall alias for sub.domain.com only?
  • edited December 2024
    @ragtop4 said: domain alias
    a domain alias mirrors the settings for the base domain, so the base domain will need to have catch all enabled
    Domain Settings > Accounts > Aliases (at the top right)
    Thanked by (2)NameCrane ragtop4
  • Thanks for the tip. It looks like i need to add the subdomain as a primary domain since i don't want to enable catchall on the base domain.
    This is pulled once a day ish. I'll see if I can increase the pull times.
    Francisco
    We made a few tweaks this evening to improve outbound delivery times (reduce sending delays). So testing messages to gmail seems to have gone from ~15-20 seconds for delivery, to about 9-10 seconds now.
    Got a ticket open with SM to see if we can improve that further.
  • How do I change the postmaster? I don't want to add an extra account.
    login as postmaster, go to domain settings then accounts
    click on the postmaster account and choose rename like the above picture, I have not tried it, but you should be able to rename the postmaster account like this.
  • for your information (and without wanting to stress the drive here) a few interesting facts:
    https://lowendtalk.com/discussion/comment/4154445/#Comment_4154445
