@Mumbly said: @Hyp0901 said: I am new to this forum here @Otus9051 is that you?
Maybe ๐ค
@Hyp0901 said: @yoursunny said: We'll be your guinea pig as long as the VPS has routed /64 and you accept squats as payment. Will try to figure out how to get routed ipv6.
A technically competent upstream provider can assign an /48 or larger to you with no problems.
How heavy do U squat first? I do not accept anything below 3 plates (in Singapore we count it by 20kg plates on each side)
In USA we use 5lb plates. We can do 3 plates with no problems.
vps9
@yoursunny said: In USA we use 5lb plates. We can do 3 plates with no problems.
you don't need the gym for that
Hello! Fellow Singaporean here, in college as well. Hardly comment but just wanna welcome you here. Looking forward to seeing your posts ๐๐ป
Maybe ๐ค
vps9
hostname is available. affbrryou don't need the gym for that
