HOST-C, Chat, Updates, Stuff
1235717
    @host_c said:
    I did not. :3
    Thank you for the question, as this way, my answer is more precise.
    So, any of you on the BF thread got a service? please either open a ticket or reply here if the IPV6 routing does not work correctly.
    Mine don't work but, it might be because I don't have any? :tongue:
    Thanked by (2)user123 host_c
    What's your excuse for that? :P
    Thanked by (1)host_c
    I have other needs ATM and we have a backdoor deal brewing
    Thanked by (1)Mumbly
  • edited December 2024
    I don't think I've come across that euphemism before. Bravo!
    Thanked by (2)host_c wankel
    @AuroraZero
    Here?
    everyone went to sleep?
    Wrong thread =)
    Thanked by (2)slownedstark admax
    I am everywhere and no where, I am the beginning and the end
    And now you have become death, destroyer of worlds.
    Thanked by (2)host_c nullnothere
  • Once you try a host-c storage deal, you know. No drama, BS, even runs windows fine, and no one mining shitcoin or running a train on the hypervisor... to the point of people stalking the ASN waiting for new deals.
    I feel bad taking one of the three but couldn't resist another machine... At least I have another storage machine + UptimeKuma instance (original purpose)
    Thanks @host_c for a very uneventful hosting experience - my favorite kind.
  • @SocksAreComfortable said:
    Honestly, when I got it I did not realize how good of a deal it was, but the longer I have it, the more likely I am to keep it now :P If a 4TB was cheaper I might swap down to that
    Same here... it's unlikely that any future 4TB deal might be cheaper than the 5TB special (~USD61/yr, with extra 2GB add-on).
    So I'll have to live with 1TB of /dev/sdb remaining unpartitioned and of no use (boo-hoo-hoo). :p
    will always do some crazy stuff, but yes, at that price / TB, only if someone finds cociu's drives and sends them to us.
    we have some NETAPP shelves around, so even 4 TB disks will do. =)
    @Kris said:
    This has sort of been my go to since... forever, just swap: ext2 -> 3 -> 4 -> xfs.
    Oh I meant to ask -- why xfs over ext4? My filesystem knowledge is not great, tbh.
    Xfs is a more modern film system, for todays work loads
    In the teste we did, and we tested all, it was a clear winner
    Especially handling large files, resiliency on hard reset, paralel read and write performance, IO handling, and low impact on cpu and ram.
    Since I am already in bed I will just quote this
    Best Use Cases:
    1. Large File Storage: XFS excels in environments where large files are common, such as video editing and large database applications.
    2. High-performance Applications: It is optimized for high-performance computing and I/O-intensive tasks, making it suitable for enterprise applications.
    3. Scalability: XFS can handle massive amounts of data and is designed to scale efficiently, which is beneficial for large storage systems.
    4. File Systems with High Throughput: If your application requires high throughput and low latency, XFS is a strong candidate.
    5. Multi-threaded Environments: XFS handles concurrent access well, making it ideal for multi-threaded applications and workloads.
    Advantages:
    • Excellent performance with large files and high I/O operations.
    • Dynamic allocation of inodes, which allows for more efficient space management.
    • Supports online resizing, enabling administrators to expand the file system without downtime.
    Best Use Cases:
    Advantages:
    Noted. Will go reformat my 5tb drive :tongue:
    Thanked by (2)host_c FrankZ
    @host_c You are supposed to be in bed mister!!!
    @SocksAreComfortable said: Oh I meant to ask -- why xfs over ext4? My filesystem knowledge is not great, tbh.
    Mostly parallel I/O over ext4 so large files, etc. will transfer faster. In some situations ext4 can serve smaller files faster. In most cases with large files and nowadays xfs has the upperhand. Also should something go wrong, xfs has a degree of built-in online self-healing, where as with ext4 in the same situation, you'll need a boot CD or fsck.
    EDIT: Just realized @host_c already gave a much better complete answer than I did, whoops.
    I already got it reformatted! Even updated my /etc/fstab (which helped me learn that changing filesystem would change the UUID...guessing it's whenever it reformats).
    NAME    FSTYPE  FSVER LABEL  UUID                                 FSAVAIL FSUSE% MOUNTPOINTS
    sda
    └─sda1  xfs                  5d3651c8-3c48-40a6-a429-2c1af829ff25    4.8T     1% /storage
    sdb
    ├─sdb1  ext4    1.0          84a58396-4a46-48f9-a4e6-1a0b1dfd14c4     17G     9% /
    ├─sdb14
    └─sdb15 vfat    FAT16        7B7C-64F9                             112.1M     9% /boot/efi
    sr0     iso9660       cidata 2024-11-15-02-54-12-00
    Thanked by (2)Kris host_c
    There's no one-size-fit-all solution when it comes to filesystems -- different user have different needs, different FSes have different pros/cons; one should always give some thought, rather than going for the purported "best" or "most popular". (FYI: vanilla BTRFS also works great for /sdb :bleep_bloop: )
    @Kris said: xfs has a degree of built-in online self-healing, where as with ext4 in the same situation, you'll need a boot CD or fsck.
    I Will underline this, THX @Kris , should have started with this.
    Thanked by (1)Kris
    Let's take a guess at what crazy deal host-c will offer today. :p ipv6 only / 2TB/4TB deals?
    Hmmmmm might , ah, sorry, for sure =)
    Just keep an eye on the BF thread
    it is alive!!!
    https://ping.pe/188.119.191.1
    I hate LOVE BGP!
    Thanked by (1)ariq01
  • CHICKENS?!
    @Jab said: CHICKENS?!
    soon,
    need to do the usual stuff, filters, vlans, you know, the boring stufff.
    Thanked by (1)bbass
  • @host_c said:
    soon,
    I started F5, finally I don't have to stay up late
  • Host-C has the best chicken!
    @NullSir said: I started F5, finally I don't have to stay up late
    If you take down the forum, @AuroraZero will kick your ass =) =)
  • @host_c is the new deal on BF mega thread or this thread?
    Mega thread ,
    Until that is closed, we will only post there the dealzzzz
  • It seems like today it won't have to stay up late to get host-c's "chicken" ?
