login as postmaster, go to domain settings then accounts
click on the postmaster account and choose rename like the above picture, I have not tried it, but you should be able to rename the postmaster account like this.
add new user, change new user to domain administrator
logout, login as new user
click on postmaster, then do rename like above
then logout, login as new username you renamed to,
delete temp account you made
just tested the above
maybe @Francisco can add a rename admin account in their panel like resetting the admin password
It'll only be for incoming and the webmail. Outgoing will stick to IPV4 for the time being.
@dgc1980 said: maybe @Francisco can add a rename admin account in their panel like resetting the admin password
Yep that's on the request list. We're working on a user management page inside of cranemail so users don't have to login to SM to do basic user actions (create, edit, delete of users). we can most likely add the option 'make user primary administrator' on the user add/edit account.
I've gone ahead and just listed larger lifetimes up to 1TB. Creating too much extra work for myself asking people to order multiple and ticket to combine
Getting juicy with those lifetime deals. If there ever comes a time where 5-10GB lifetime email will be offered, let me know Need smth where I can idle my throwaway email accounts from my xyz domain I use to sign up on giveaways/special offers/newsletters but still occasionally need access to (hence a normal throwaway won't do). So far parked on MyW lifetime, but a backup would be nice. Basically, maybe sending 5 emails per year. It's more about receiving to active trials/links, and recover accounts if needed.
No plans on doing smaller lifetimes - but I know you've been a big contributor here and on OGF especially regarding lifetimes/etc - so if you want one I'll give you a free 100GB lifetime like we gave to some of our beta testers.
Just shoot me a DM and confirm your account email with us and I'll assign it
Well, this sounds like one of the offers you don't turn down Thanks! I'll gladly accept and am happy that my contributions to the community have been appreciated. Always happy to help And yeah, lifetime deals is an addiciton of mine, I can't deny. I'll shoot you DM (I already have an account and service with you).
that is honorable!
Indeed. Quite happy with this outcome and yet another lifetime addiciton to deal with
Edit: PM sent
Merry Christmas
Let us know what you think/feel free to share some feedback on where we can improve it.
Edit: PM sent
Merry Christmas
Allow a user to define the admin login & password at domain create time, as well as the ability to change it after the fact w/o a support ticket
DNS info page now does status checks w/ feedback
Self-serve SpamExperts cut over from Shared to CraneMail w/o staff intervention
File Storage & OnlyOffice toggles have been added for domains, as well as merged into the blesta & WHMCS modules
Non resellers can now set a different domain for their SSL instead of forcing mail.domain.tld every time
During domain creation a modal is now presented that shows the admin login/password, removing the silly 'create domain, view the password on another page' flow we had.
Lots of work going on behind the scenes to improve the user experience and expose more features from the portal where it makes sense, or where we can do things like bulk-adds easier via the API.
And what's the point of your post.
https://microlxc.net/
Thanks! But I didn't find rename.
I appreciated it. I don't really monitor OGF so hadn't seen that thread.
BTW, is there any IPv6 support?
No, I'll be adding that soon
Francisco
Can find them listed here: https://namecrane.com/store/email-hosting-deals
🏗️ NameCrane - Shared, Reseller, Semi-Dedicated Hosting / cPanel + DirectAdmin / Ryzen + NVMe + 10Gbps / Free Blesta!
🇺🇸🇬🇧🇱🇺🇸🇬 Now in Singapore 👉 Shared Hosting from $8/yr 🏆 $2/mo Reseller Hosting
We just rolled out the 'domain users' part of cranemail portal. This allows you to:
We'll expand this page to support mass user importing/creating via a CSV.
Feedback is welcome
Francisco
that is honorable!
Edit: PM sent
Merry Christmas
Merry X-MAS to you, too Will do!
Congratz @Ympker
Wanted to drop a quick update on some of the changes and things Fran has built into the CraneMail portal in the last ~2 weeks.
surprise is with the bigget update... cranemail europe starting on 1st of january 2025!
If I got two lifetime plans with other services I am eligible to get an 100GB lifetime plan too? xd
Awesome work!
for free? like teh other dude?
