HOST-C, Chat, Updates, Stuff
13468920
  • Chicken? I want chicken.
    Thanked by (1)admax
    Chicken and rice with a hole?
    @host_c said:
    @NullSir said: I started F5, finally I don't have to stay up late
    If you take down the forum, @AuroraZero will kick your ass =) =)
    Damned right I will don't make send out the phone spiders!!
    Weird hole right? I'm going to tell them to not make holes to my food.
    Thanked by (1)wankel
    I think the hole is to put sauce in?
    Never. We don't do that.
    Fellas,
    We will halt all sales for the next 24 hours due to the fact that the 3 newly published /48 ( that get divided into /64 for you ) are only partially visible on global BGP
    Plus we have an issue with the old 2A0D:8140::/48 that our ISP accidentally removed from the filters rather then adding the new ones. - this is a more pressing issue =)
    We will be back tomorrow, but first we need to fix our stuff :3 <3
    @host_c fix my stuffs!!!!!!!!!!!!!!!!!
    Thanked by (1)host_c
  • edited December 2024
    We support providers that treat IPv6 as an essential service rather than secondary to IPv4.
    It is honorable to halt sales when IPv6 isn't working.
    Self rdns change would be cool.
    I will quote @imok
    I'm worried now. These deals are unsustainable right?
    How much time is @host_c going to survive?
    Don't leave too early please.
    Rest assured that the "Marketing Department" has enough funds to sustain these crazy deals.
    If you read the beginning of of this thread, I have stated that we have other measures of income also.
    With that said, we will make some more =) , on IPV6 only as that does lower the expense on this.
    We tried to implement NAT64, but it did not go as expected , so we dropped it and focus on more important stuff.
    We managed to fix the IPV6 problems ( almost all ) since last night so sales will resume shortly.
    We need a little time-off by the way, so see you shortly.
    HOST-C
  • FAT32FAT32 OGSenpai
    @host_c said:
    I will quote imok
    HOST-C
    LETS GO FAT32 SPECIAL DEAL
  • @host_c said: Plus we have an issue with the old 2A0D:8140::/48 that our ISP accidentally removed from the filters rather then adding the new ones. - this is a more pressing issue
    What's the current status of this more pressing issue? :P
    @host_c said:
    I will quote @imok
    HOST-C
    So, will the crazy IPV6 storage VPS deal make a comeback? :p
    @gritty said: So, will the crazy IPV6 storage VPS deal make a comeback? :p
    yes
    @Mumbly said: What's the current status of this more pressing issue? :P
    if you do not have connectivity by now, open a ticket, this goes for any of you reading this.
    Thanked by (3)lukast__ gritty o202
    yes
    I have multiple vps ipv6
    ping ipv6.google.com
    PING ipv6.google.com(sof02s48-in-x0e.1e100.net (2a00:1450:4017:811::200e)) 56 data bytes
    Do I need to open a work order as well?
    @NullSir said:
    yes
    What is the output of ip a?
    LTstats resource monitoring system | Recommended providers: Layer7, dataforest (Avoro/PHP-Friends), @host_c
    @NullSir said:
    yes
    please do,1 ticket, and we will take it from there.
    Thanked by (1)gritty
    yes
    Tonight? or Now? ;)
    @lukast__ said:
    @NullSir said:
    yes
    ticket
    open a ticket so we can fix these, this is not the place.
    @host_c said: open a ticket so we can fix these, this is not the place.
    Thank you for those that already did :3
    we will issue an official statement via e-mail once we sort all out.
    Thanked by (3)lukast__ gritty NullSir
  • While this is a bit off-topic, I have a question to those who know more about IPv6 than I do. I could reach the server from outside (via ssh and ICMP ping) over IPv6, however from inside the VPS I couldn't reach any IPv6.
    The output from ip a was the following:
    2: eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc fq_codel state UP group default qlen 1000
        link/ether XX:XX:XX:XX:XX:XX brd ff:ff:ff:ff:ff:ff
        inet XXX.XXX.XXX.XXX/24 brd XXX.XXX.XXX.XXX.255 scope global eth0 // allocated IPv4
        inet6 2a0d:XXXX:XXXX:XXXX::XX/64 scope global                     // allocated IPv6
        inet6 fe80::XXXX:XXXX:XXXX:XXXX/64 scope link                     // link-local address
        inet6 2a0d:XXXX:0:4b:XXXX:XXXX:XXXX:XXXX/64 scope global dynamic mngtmpaddr noprefixroute
           valid_lft XXXXXXXsec preferred_lft XXXXXXsec
        inet6 2a0d:XXXX:0:125:XXXX:XXXX:XXXX:XXXX/64 scope global dynamic mngtmpaddr noprefixroute
    I have no idea where the last two addresses (on some of my VPSes from @host_c there were even more) come from, I have set net.ipv6.conf.all.autoconf, net.ipv6.conf.all.accept_ra and net.ipv6.conf.all.use_tempaddr all to 0 and DHCP was disabled.
    When I deleted the two addresses with ip a del ADDRESS dev eth0, IPv6 worked from inside the VPS, but after a few seconds those addresses reappeared.
    But after some time (I think around 11 PM GMT+1), the addresses weren't added anymore and IPv6 works since then.
    (This is no criticism in any way, I'm just interested in how that happened.)
    Now my question is: where did these addresses come from and could I have disabled that?
    If this is too off-topic, mods can maybe move this post to the cest pit.
    The RA announcement were Meade wrongly by us. In attempt to preserve old configuration and the new one for /64 allocation
    Check your e-mail, we already announced that we will modify all services to /64 from /127
    Thanked by (2)lukast__ yoursunny
  • Since you push IPv6 automagically through Router Advertisements for most(?) customers, why not just simply provide the "new IPv6 settings" in the Control Panel (under "Assigned IPs"), for the few customers clever enough to manage IPv6 manually?
    When will the IPv6 network update be implemented?
    these will be available there.
    but we have to update ~500+ services, I doubt 50 will set the up manually.
    It has already started. It will take some time .....
    Thanked by (2)lukast__ zizi
    As a pain i the but this is for most of you, we wished tu finalize these ASAP, so we can all enjoy quiet holidays and other “stuff” :3
    Keep up to good work man I for one appreciate it
    Thanked by (2)host_c wankel
  • @lukast__ said: While this is a bit off-topic, I have a question to those who know more about IPv6 than I do. I could reach the server from outside (via ssh and ICMP ping) over IPv6, however from inside the VPS I couldn't reach any IPv6.
    Is this fixed? I've been there as well. They resolved it by manually whitelisting my subnet.
