VirMach * 2024 * RYZEN * NVMe ** VPS Black Friday * Flash Deals ** Check inside for offers!
18384868889118
    edited December 2024
    @amj said:
    @cybertech said:
    MJJS INCOMING
    MJJ work orders incoming....
    I CAN"T INSTALL DEBIAN 12 ON 256MB RAM !!!
    YOUR VPS SUCK !!! REFUND ME MY $2 !!!!
    In my experience with NATVPS.net 256MB NAT KVM, Debian works but requires swap to run apt.
    I agree that with some modifications it will run. I have a 222MB VirMach VM that runs fine.
    Debian has a how to reduce the memory footprint outline here for anyone that bought one of those tiny VMs
    My fav is
    Reduce the size of the initramfs
    create /etc/initramfs-tools/conf.d/compress with the content
    COMPRESS=xz
    reduce it further with
    sed -i s,MODULES=most,MODULES=dep,g /etc/initramfs-tools/initramfs.conf
    update-initramfs -u
  • FAT32FAT32 OGSenpai
    Ok so I bought that $1/YR VPS... now which OS should I install on this box with 3GB NVMe?
    Thanked by (3)tototo admax Wonder_Woman
    Alpine is the best all-around for these small RAM/disk boxes but as usual it depends for you usage etc
    Thanked by (1)FAT32
    For idle?
    DOS 3.1
  • @FAT32 said:
    For idle?
    perfect!
    Thanked by (1)FAT32
    Debian or Arch minimal using btrfs with zstd compression on
    /dev/vda1 / btrfs rw,relatime,compress-force=zstd:5,space_cache=v2,subvolid=5,subvol=/ 0 0
    deals are back to normal
    Thanked by (2)FAT32 ariq01
    @VirMach said: I'm going to be away for at least a bit and if I can fall asleep then a bit longer.
    Thanked by (3)tototo FAT32 Wonder_Woman
  • imokimok OG
    Oh I fell asleep again for one more hour. And it seems I skipped a lot of pages.
    What have happened for the last 8 hours?
    Thanked by (1)tridinebandim
    you missed a $999/yr deal.
    Thanked by (2)ariq01 imok
  • @imok said: What have happened for the last 8 hours?
    virbot going crazy again, $5 -> $4 -> $3 -> $2 -> even $1/year vps deal is available to purchase.
    Thanked by (1)imok
    $9.999/y is what I can afford. Even so it feels expensive.
  • edited December 2024
    @amj said:
    @cybertech said:
    MJJS INCOMING
    My fav is
    COMPRESS=xz
    update-initramfs -u
    Installed using the official Debian 12 without any modifications—extremely stable and absolutely fantastic.
    Thanked by (2)FrankZ theloafingone
  • Have you guys not bought anything or it's stuck at 15%? :-D
  • @Jab said: or it's stuck
    It's called Vir going to sleep (he did mention it).
    Thanked by (2)yoursunny FrankZ
    I read that message as it was bumped to 15% but still should progress if it catch up.
    SO
    HAVE YOU NOT BOUGHT ANYTHING?!
    @Jab said: HAVE YOU NOT BOUGHT ANYTHING?!
    Nope. Nearly a couple of times but has to be a REALLY good deal (+2G RAM & >=2IP) for me to bite, at this stage. ;)
  • Should the 0%-off apply to the vps.blackfriday plans?
    It tells me no items in my cart qualify "check the promotion terms". These terms were a bit complex ... :p
  • @VirMach said: Codes have to actually be used on a successful purchase for it to count
    So... is it applied afterwards?
  • @wankel said: Should the 0%-off apply to the vps.blackfriday plans?
    Only to middle plans, the VPS-BF-ORDER-2
    Thanked by (2)wankel ariq01
    It only works with 1 of the 3 deals ("randomly") at a time... currently it's set to work on the middle (256) deal
    Thanked by (1)wankel
    We have two rules: hostname and RTT.
    Based on these rules, we are disallowed from buying anything.
    Hostname limits: vps2 and vps7 are available, which needs to last until July.
    RTT limits:
    No servers within 30ms of existing servers.
    This basically excludes the entire North America.
    We have Eygelshoven and Tokyo from other providers too.
    We did buy offer 1024 in New York (YABS published) that is only 11ms from Toronto, but only because we are running out of RAM in Toronto.
    Thanked by (3)ariq01 wankel Wonder_Woman
    No hostname available. affbrr
  • This code can only be used once per client
    So much for my scheme of buying 20 small VMs to get a good coupon on a larger VM. ;)
    Thanked by (1)FAT32
    Wire me some money, I will buy 20 small VMs for you so you can buy one large.
    kthxbye
  • VVVVVVVVVVVVVVVVVVVIRRRRRMAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAACH
    Thanked by (3)admax ariq01 FAT32
    2nd time asking @VirMach : are the offers on https://vps.blackfriday/ RAID-10?
    🤡 "We can confirm that this is not an issue with any servers, network, or power equipment on our end." 🤡 "We have temporarily paused controls for this service as we are performing maintenance on the server." 🤡 "The servers are working, they are just not connected to the internet!" 🤡
    VIIIIIIIIIIIRBOT
    Thanked by (1)ariq01
  • Still need 5$/y one in Miami.... :(
    Well if you asked me, I would tell you no, but I understand you're asking VirMach so I'll stay out of it.
