VirMach * 2024 * RYZEN * NVMe ** VPS Black Friday * Flash Deals ** Check inside for offers!
18485878990108
  • I thought everything was raid10
  • FrankZFrankZ Moderator
    Storage servers are RAID 10, but I don't think the Specials are. I have been know to dispel misinformation at times. If this is the case I expect VirMach will provide a correction.
    Thanked by (1)localhost
  • skorousskorous OGSenpai
    Do I remember that they were at one point but it was actually making things more unstable so it changed? Seen to remember the ASRock motherboards being an issue....
    Thanked by (2)FrankZ yoursunny
    This is the way I remember it as well.
  • edited December 7
    OFFER #1359 RAM 1536MB CPU 1 Core 30GB SSD (NVMe) 2048GB BANDWIDTH IPs 1 IPv4 Atlanta 8.85
  • edited December 7
    @VirMach said:
    Okay let's try something new. It's going to be an evolving coupon. Existing customers only, so keep in mind it might not work on your account because WHMCS isn't great at deciding who's an existing customer.
    Every 30 minutes or so I'll check the usage and as more people use it, I'll increase the discount. It's a social experiment.
    By using it, you know someone else is going to get a better discount than you. Limit 50 quantity, caps out at 50% recurring. Starts at 0% recurring. Every use adds 1% (it's not live updated.) I'll warn you guys though, I don't think we'll actually reach 50% because I think everyone's finally sober and had more than their filling. Oh and to make it extra annoying, it rotates which of the three it works on every time I update it and final twist, it's only one time use :) Unless when I update it, WHMCS breaks it and lets you use it again.
    Coupon code: 0PERCENTOFF
    Sorry, but the coupon no longer works?
    I wanted to use it for offer #1362, but unfortunately it said that no items quality for the discount yet. :O
    edited December 7
    ^ Code works fine; it's your interpretation that's at fault. You need to read more of the thread.
    edited December 7
    There were a few servers that were RAID10. We decided against it pretty early on, and it was a good call. Almost all those servers with RAID10 had some type of catastrophic issue and probably ended up with more downtime, and eventually pulled out.
    I have a lot of personal opinions on NVMe SSDs now and probably know way too much about them. If we could go back and start over with how that technology progressed, I think we should. I don't like this NVMe timeline. The main problem with it is that for RAID10, the cards didn't really exist at the time and several years on, the cards that do exist with it that you can trust are outrageously expensive and bottleneck the NVMe SSDs pretty quickly. Then to actually make it useful with hotswapping, you get into really expensive chassis designs as well. So you're talking probably 2x the price per server to do it in the correct way, and that's today. Wasn't even possible back then. Like a $1400 controller for $800 worth of drives and another $800 for the chassis, then another $400 for the hot swappable form factor for the drives.
    We also tried out soft RAID1, I'd rate that 2/5.
  • edited December 7
    I don't quite understand where it goes and where it doesn't...
    I definitely like how that looks for the offer card but outside of that, my eyes refuse to read anything in your screenshots to assist you.
  • edited December 7
    I can transfer you this one if you can live with 2vCores .
    6GB RAM - 300GB - 2cores - 4 IPV4 - Amsterdam NL - $45.00 USD Annually
    I believe the coupon may apply to one of the 3 offers but this may change over time. (It was the offer in the middle few hours ago)
    And change those colors. You'll end up blind.
    And so will we.
  • @VirMach what is the latest update on the IPv6 situation (for AMS and NYC, if it matters)? It would be good to know if this is in the pipeline, or something to not expect anytime soon.
    edited December 7
    Redacted
  • I kinda wish I could combine my VMs I got.
  • edited December 7
    Wasn't the code discount percentage supposed to go up as people used it? Unless it was reset after hitting 50 already or some timer sort of set up. Can refer to black and green screenshots up for example
    It's at 8% currently, you guys didn't hit the 15% while I was sleeping.
    Thanked by (1)ariq01
    Thanked by (1)imok
    thats because i was sleeping too damn
    huh, I guess the first use was 15% or maybe it didn't start tracking until you woke up :)
  • FAT32FAT32 OGSenpai
    edited December 8
    We promise we will hit 99 usage during your next sleep, can we get 99% in advance? :joy:
  • edited December 8
    Big big Sorry and me culpa! Moreover, unfortunately the image sharing service reduced the size of the image. :(
    I'd rather not share any more pictures then. :)
    I wanted to purchase the AMS Offer #1362 using the 0PERCENTOFF coupon (wrote 15 %), but unfortunately it didn't validate (said that no items quality for the discount yet).
    In the next round, it gave 8 % for AMS Offer #1365, but not for TOK Offer #1366. I didn't fully understand that. But that should just be my problem.
    edited December 8
    @schneitommy said: I wanted to purchase the AMS Offer #1362 using the 0PERCENTOFF coupon (wrote 15 %), but unfortunately it didn't validate (said that no items quality for the discount yet).
    It rotates between which of the three plans its available on. And the system also needs to consider you as an existing customer.
    Ok, thx! Now I understand, it only works for one of the offers.
    And so will we.
    Thank you very much for your generous offer! But I don't want to cause you pain by losing it.
    Also, I want to use at least 3 vCores.
    Anyway, thank you very much again!
    And so will we.
    I ordered two big boxes like this one. And I need only one (If not 0)
    It seemed like a better deal than the one you were trying to get. That's why I offered.
    Good luck finding the right offer :)
    Thanked by (1)schneitommy
    1371 good price with 2 IPS!
    buy first and ask for $7 discount later to return one.
  • Virbot has good hardware spec.
    But I don't touch it ,keep safe.
    Good. Virbot doesn't like to be touched by anyone except by @FrankZ.
    we need to understand Virbot's love language. physical touch aint one of em
    Thanked by (3)FrankZ ariq01 ZA_capetown
  • One thing's for sure: virtbot has touched my wallet :s
    Thanked by (3)FrankZ ZA_capetown wankel
